[MOAB-dev] commit/MOAB: danwu: Updated NC writer and its unit test. Parallel write should work now for HOMME.
commits-noreply at bitbucket.org
Thu Apr 24 15:48:01 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/9136633af5e1/
Changeset: 9136633af5e1
Branch: ncwriter
User: danwu
Date: 2014-04-24 22:47:43
Summary: Updated NC writer and its unit test. Parallel write should work now for HOMME.
Affected #: 3 files
diff --git a/src/io/NCWriteHOMME.cpp b/src/io/NCWriteHOMME.cpp
index 45ccff0..36ea5c7 100644
--- a/src/io/NCWriteHOMME.cpp
+++ b/src/io/NCWriteHOMME.cpp
@@ -6,6 +6,7 @@
#include "NCWriteHOMME.hpp"
#include "moab/WriteUtilIface.hpp"
+#include "MBTagConventions.hpp"
#define ERRORR(rval, str) \
if (MB_SUCCESS != rval) { _writeNC->mWriteIface->report_error("%s", str); return rval; }
@@ -51,13 +52,36 @@ ErrorCode NCWriteHOMME::collect_mesh_info()
ERRORR(rval, "Trouble getting local vertices in current file set.");
assert(!local_verts.empty());
- std::vector<int> gids(local_verts.size());
- rval = mbImpl->tag_get_data(mGlobalIdTag, local_verts, &gids[0]);
+#ifdef USE_MPI
+ bool& isParallel = _writeNC->isParallel;
+ if (isParallel) {
+ ParallelComm*& myPcomm = _writeNC->myPcomm;
+ int rank = myPcomm->proc_config().proc_rank();
+ int procs = myPcomm->proc_config().proc_size();
+ if (procs > 1) {
+ rval = myPcomm->filter_pstatus(local_verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &localVertsOwned);
+ ERRORR(rval, "Trouble getting owned vertices in set.");
+ // Assume that PARALLEL_RESOLVE_SHARED_ENTS option is set
+ // We should avoid writing in parallel with overlapped data
+ if (rank > 0)
+ assert("PARALLEL_RESOLVE_SHARED_ENTS option is set" && localVertsOwned.size() < local_verts.size());
+ else
+ localVertsOwned = local_verts;
+ else
+ localVertsOwned = local_verts; // Not running in parallel, but still with MPI
+#else
+#endif
+ std::vector<int> gids(localVertsOwned.size());
+ rval = mbImpl->tag_get_data(mGlobalIdTag, localVertsOwned, &gids[0]);
ERRORR(rval, "Trouble getting global IDs on local vertices.");
// Restore localGidVerts
- std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidVerts));
- nLocalVertices = localGidVerts.size();
+ std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidVertsOwned));
+ nLocalVerticesOwned = localGidVertsOwned.size();
return MB_SUCCESS;
@@ -100,8 +124,8 @@ ErrorCode NCWriteHOMME::collect_variable_data(std::vector<std::string>& var_name
// Vertices
// Start from the first localGidVerts
// Actually, this will be reset later for writing
- currentVarData.writeStarts[2] = localGidVerts[0] - 1;
- currentVarData.writeCounts[2] = nLocalVertices;
+ currentVarData.writeStarts[2] = localGidVertsOwned[0] - 1;
+ currentVarData.writeCounts[2] = nLocalVerticesOwned;
break;
default:
ERRORR(MB_FAILURE, "Unexpected entity location type for HOMME non-set variable.");
@@ -124,8 +148,6 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
std::set<std::string>& dummyVarNames = _writeNC->dummyVarNames;
std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
- ErrorCode rval;
// Start with coordinates
for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
setIt != usedCoordinates.end(); ++setIt) {
@@ -172,12 +194,9 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
int numTimeSteps = (int)variableData.varTags.size();
if (variableData.has_tsteps) {
// Get entities of this variable
- Range ents;
switch (variableData.entLoc) {
case WriteNC::ENTLOCVERT:
// Vertices
- rval = mbImpl->get_entities_by_dimension(_fileSet, 0, ents);
- ERRORR(rval, "Can't get entities for vertices.");
break;
default:
@@ -189,16 +208,16 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
// FIXME: Should use tstep_nums (from writing options) later
for (int j = 0; j < numTimeSteps; j++) {
// We will write one time step, and count will be one; start will be different
- // We will write values directly from tag_iterate, but we should also transpose for level
- // so that means deep copy for transpose
+ // Use tag_get_data instead of tag_iterate to get values, as localVertsOwned
+ // might not be contiguous. We should also transpose for level so that means
+ // deep copy for transpose
variableData.writeStarts[0] = j; // This is time, again
- int count;
- void* dataptr;
- rval = mbImpl->tag_iterate(variableData.varTags[j], ents.begin(), ents.end(), count, dataptr);
- assert(count == (int)ents.size());
+ std::vector<double> tag_data(nLocalVerticesOwned * variableData.numLev);
+ ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[j], localVertsOwned, &tag_data[0]);
+ ERRORR(rval, "Trouble getting tag data on owned vertices.");
#ifdef PNETCDF_FILE
- size_t nb_writes = localGidVerts.psize();
+ size_t nb_writes = localGidVertsOwned.psize();
std::vector<int> requests(nb_writes), statuss(nb_writes);
size_t idxReq = 0;
#endif
@@ -207,14 +226,14 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
int success = 0;
switch (variableData.varDataType) {
case NC_DOUBLE: {
- std::vector<double> tmpdoubledata(nLocalVertices * variableData.numLev);
+ std::vector<double> tmpdoubledata(nLocalVerticesOwned * variableData.numLev);
// Transpose (ncol, lev) back to (lev, ncol)
- jik_to_kji(nLocalVertices, 1, variableData.numLev, &tmpdoubledata[0], (double*)(dataptr));
+ jik_to_kji(nLocalVerticesOwned, 1, variableData.numLev, &tmpdoubledata[0], &tag_data[0]);
size_t indexInDoubleArray = 0;
size_t ic = 0;
- for (Range::pair_iterator pair_iter = localGidVerts.pair_begin();
- pair_iter != localGidVerts.pair_end(); ++pair_iter, ic++) {
+ for (Range::pair_iterator pair_iter = localGidVertsOwned.pair_begin();
+ pair_iter != localGidVertsOwned.pair_end(); ++pair_iter, ic++) {
EntityHandle starth = pair_iter->first;
EntityHandle endh = pair_iter->second;
variableData.writeStarts[2] = (NCDF_SIZE)(starth - 1);
@@ -236,7 +255,7 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
// next subrange
indexInDoubleArray += (endh - starth + 1) * variableData.numLev;
- assert(ic == localGidVerts.psize());
+ assert(ic == localGidVertsOwned.psize());
#ifdef PNETCDF_FILE
success = ncmpi_wait_all(_fileId, requests.size(), &requests[0], &statuss[0]);
ERRORS(success, "Failed on wait_all.");
diff --git a/src/io/NCWriteHelper.hpp b/src/io/NCWriteHelper.hpp
index 6678bb5..b05fe12 100644
--- a/src/io/NCWriteHelper.hpp
+++ b/src/io/NCWriteHelper.hpp
@@ -100,21 +100,24 @@ class UcdNCWriteHelper : public NCWriteHelper
public:
UcdNCWriteHelper(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
: NCWriteHelper(writeNC, fileId, opts, fileSet),
- nLocalCells(0), nLocalEdges(0), nLocalVertices(0),
+ nLocalCellsOwned(0), nLocalEdgesOwned(0), nLocalVerticesOwned(0),
cDim(-1), eDim(-1), vDim(-1) {}
virtual ~UcdNCWriteHelper() {}
protected:
- //! Dimensions of my local part of grid
- int nLocalCells;
- int nLocalEdges;
- int nLocalVertices;
+ //! Dimensions of my local owned part of grid
+ int nLocalCellsOwned;
+ int nLocalEdgesOwned;
+ int nLocalVerticesOwned;
//! Dimension numbers for nCells, nEdges and nVertices
int cDim, eDim, vDim;
- //! Local global ID for cells, edges and vertices
- Range localGidCells, localGidEdges, localGidVerts;
+ //! Local owned cells, edges and vertices
+ Range localCellsOwned, localEdgesOwned, localVertsOwned;
+ //! Local global ID for owned cells, edges and vertices
+ Range localGidCellsOwned, localGidEdgesOwned, localGidVertsOwned;
} // namespace moab
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index 827b102..8f87063 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -106,6 +106,7 @@ void test_eul_read_write_T()
rval = mb.write_file("test_par_eul_T.nc", 0, write_opts.c_str(), &set, 1);
else
rval = mb.write_file("test_eul_T.nc", 0, write_opts.c_str(), &set, 1);
+ CHECK_ERR(rval);
// Check non-set variable T on some quads
@@ -256,6 +257,7 @@ void test_fv_read_write_T()
rval = mb.write_file("test_par_fv_T.nc", 0, write_opts.c_str(), &set, 1);
else
rval = mb.write_file("test_fv_T.nc", 0, write_opts.c_str(), &set, 1);
+ CHECK_ERR(rval);
@@ -358,10 +360,6 @@ void test_homme_read_write_T()
return;
#endif
- // Only test serial case for the time being
- if (procs > 1)
- return;
Core moab;
Interface& mb = moab;
@@ -374,12 +372,21 @@ void test_homme_read_write_T()
// Load non-set variable T, set variable lat, set variable lon, and the mesh
read_opts += ";DEBUG_IO=0;VARIABLE=T,lat,lon";
+ if (procs > 1)
+ read_opts += ";PARALLEL_RESOLVE_SHARED_ENTS";
rval = mb.load_file(example_homme, &set, read_opts.c_str());
CHECK_ERR(rval);
// Write variables T, lat and lon
std::string write_opts = ";;VARIABLE=T,lat,lon;DEBUG_IO=0;";
- rval = mb.write_file("test_homme_T.nc", 0, write_opts.c_str(), &set, 1);
+#ifdef USE_MPI
+ // Use parallel options
+ write_opts += std::string(";PARALLEL=WRITE_PART");
+#endif
+ if (procs > 1)
+ rval = mb.write_file("test_par_homme_T.nc", 0, write_opts.c_str(), &set, 1);
+ else
+ rval = mb.write_file("test_homme_T.nc", 0, write_opts.c_str(), &set, 1);
CHECK_ERR(rval);
@@ -387,8 +394,10 @@ void test_homme_read_write_T()
// Also check set variables lat and lon
void test_homme_check_T()
+ int rank = 0;
int procs = 1;
#ifdef USE_MPI
+ MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm_size(MPI_COMM_WORLD, &procs);
#endif
@@ -398,10 +407,6 @@ void test_homme_check_T()
return;
#endif
- if (procs > 1)
- return;
Core moab;
@@ -416,9 +421,14 @@ void test_homme_check_T()
read_opts += ";VARIABLE=T,lat,lon";
read_opts += ";CONN=";
read_opts += example_homme_mapping;
- rval = mb.load_file("test_homme_T.nc", &set, read_opts.c_str());
+ if (procs > 1)
+ rval = mb.load_file("test_par_homme_T.nc", &set, read_opts.c_str());
+ else
+ rval = mb.load_file("test_homme_T.nc", &set, read_opts.c_str());
CHECK_ERR(rval);
+ double eps = 1e-10;
if (1 == procs) {
// Get tag lat
Tag lat_tag;
@@ -432,7 +442,6 @@ void test_homme_check_T()
CHECK_ERR(rval);
CHECK_EQUAL(3458, var_len);
double* lat_val = (double*)var_data;
- double eps = 1e-10;
CHECK_REAL_EQUAL(-35.2643896827547, lat_val[0], eps);
CHECK_REAL_EQUAL(23.8854752772335, lat_val[1728], eps);
CHECK_REAL_EQUAL(29.8493120043874, lat_val[1729], eps);
@@ -453,33 +462,49 @@ void test_homme_check_T()
CHECK_REAL_EQUAL(202.5, lon_val[1728], eps);
CHECK_REAL_EQUAL(194.359423525313, lon_val[1729], eps);
CHECK_REAL_EQUAL(135, lon_val[3457], eps);
- // Get tag T0
- Tag Ttag0;
- rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0);
- CHECK_ERR(rval);
+ // Get tag T0
+ Tag Ttag0;
+ rval = mb.tag_get_handle("T0", 26, MB_TYPE_DOUBLE, Ttag0);
+ CHECK_ERR(rval);
- // Get vertices
- Range verts;
- rval = mb.get_entities_by_type(0, MBVERTEX, verts);
- CHECK_ERR(rval);
- CHECK_EQUAL((size_t)3458, verts.size());
+ // Get vertices
+ Range verts;
+ rval = mb.get_entities_by_type(0, MBVERTEX, verts);
+ CHECK_ERR(rval);
- // Get all values of tag T0
- int count;
- void* Tbuf;
- rval = mb.tag_iterate(Ttag0, verts.begin(), verts.end(), count, Tbuf);
- CHECK_ERR(rval);
- CHECK_EQUAL((size_t)count, verts.size());
+ // Get all values of tag T0
+ int count;
+ void* Tbuf;
+ rval = mb.tag_iterate(Ttag0, verts.begin(), verts.end(), count, Tbuf);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)count, verts.size());
- // Check some values of tag T0 on first level
- eps = 0.0001;
- double* data = (double*) Tbuf;
+ double* data = (double*) Tbuf;
+ eps = 0.0001;
+ if (1 == procs) {
+ CHECK_EQUAL((size_t)3458, verts.size());
CHECK_REAL_EQUAL(233.1136, data[0 * 26], eps); // First vert
CHECK_REAL_EQUAL(236.1505, data[1728 * 26], eps); // Median vert
CHECK_REAL_EQUAL(235.7722, data[1729 * 26], eps); // Median vert
CHECK_REAL_EQUAL(234.0416, data[3457 * 26], eps); // Last vert
+ else if (2 == procs) {
+ if (0 == rank) {
+ CHECK_EQUAL((size_t)1825, verts.size());
+ CHECK_REAL_EQUAL(233.1136, data[0 * 26], eps); // First vert
+ CHECK_REAL_EQUAL(237.1977, data[912 * 26], eps); // Median vert
+ CHECK_REAL_EQUAL(234.9711, data[1824 * 26], eps); // Last vert
+ else if (1 == rank) {
+ CHECK_REAL_EQUAL(231.0446, data[912 * 26], eps); // Median vert
+ CHECK_REAL_EQUAL(234.0416, data[1824 * 26], eps); // Last vert
void get_eul_read_options(std::string& opts)
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
