[MOAB-dev] commit/MOAB: danwu: Added two test cases to write_nc for MPAS. As the output file does not contain mesh information, variables will be checked without using NC reader.
commits-noreply at bitbucket.org
Fri Apr 25 13:44:55 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8139ed1b1957/
Changeset: 8139ed1b1957
Branch: ncwriter
User: danwu
Date: 2014-04-25 20:44:40
Summary: Added two test cases to write_nc for MPAS. As the output file does not contain mesh information, variables will be checked without using NC reader.
Affected #: 3 files
diff --git a/test/io/Makefile.am b/test/io/Makefile.am
index fffcbb4..6463d0a 100644
--- a/test/io/Makefile.am
+++ b/test/io/Makefile.am
@@ -91,5 +91,6 @@ MOSTLYCLEANFILES = dumped_acis.sat \
singlecyl_tmp.ccmg \
test_eul_T.nc \
test_fv_T.nc \
- test_homme_T.nc
+ test_homme_T.nc \
+ test_mpas_vars.nc
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index 8f87063..2d9bdae 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -9,11 +9,13 @@ static const char example_eul[] = STRINGIFY(MESHDIR) "/io/camEul26x48x96.t3.nc";
static const char example_fv[] = STRINGIFY(MESHDIR) "/io/fv26x46x72.t.3.nc";
static const char example_homme[] = STRINGIFY(MESHDIR) "/io/homme26x3458.t.3.nc";
static const char example_homme_mapping[] = STRINGIFY(MESHDIR) "/io/HommeMapping.nc";
+static const char example_mpas[] = STRINGIFY(MESHDIR) "/io/mpasx1.642.t.2.nc";
#else
static const char example_eul[] = "/io/camEul26x48x96.t3.nc";
static const char example_fv[] = "/io/fv26x46x72.t.3.nc";
static const char example_homme[] = "/io/homme26x3458.t.3.nc";
static const char example_homme_mapping[] = "/io/HommeMapping.nc";
+static const char example_mpas[] = "/io/mpasx1.642.t.2.nc";
#endif
#ifdef USE_MPI
@@ -21,6 +23,16 @@ static const char example_homme_mapping[] = "/io/HommeMapping.nc";
#include "moab/ParallelComm.hpp"
#endif
+#ifdef PNETCDF_FILE
+#include "pnetcdf.h"
+#define NCFUNC(func) ncmpi_ ## func
+#define NCDF_SIZE MPI_Offset
+#else
+#include "netcdf.h"
+#define NCFUNC(func) nc_ ## func
+#define NCDF_SIZE size_t
+#endif
// CAM-EUL
void test_eul_read_write_T();
void test_eul_check_T();
@@ -33,9 +45,14 @@ void test_fv_check_T();
void test_homme_read_write_T();
void test_homme_check_T();
+// MPAS
+void test_mpas_read_write_vars();
+void test_mpas_check_vars();
void get_eul_read_options(std::string& opts);
void get_fv_read_options(std::string& opts);
void get_homme_read_options(std::string& opts);
+void get_mpas_read_options(std::string& opts);
int main(int argc, char* argv[])
@@ -55,6 +72,8 @@ int main(int argc, char* argv[])
result += RUN_TEST(test_fv_check_T);
result += RUN_TEST(test_homme_read_write_T);
result += RUN_TEST(test_homme_check_T);
+ //result += RUN_TEST(test_mpas_read_write_vars);
+ //result += RUN_TEST(test_mpas_check_vars);
#ifdef USE_MPI
fail = MPI_Finalize();
@@ -507,6 +526,115 @@ void test_homme_check_T()
+ int procs = 1;
+#ifdef USE_MPI
+ MPI_Comm_size(MPI_COMM_WORLD, &procs);
+#endif
+// We will not test NC writer in parallel without pnetcdf support
+#ifndef PNETCDF_FILE
+ if (procs > 1)
+ return;
+#endif
+ Core moab;
+ Interface& mb = moab;
+ std::string read_opts;
+ get_mpas_read_options(read_opts);
+ EntityHandle set;
+ ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
+ CHECK_ERR(rval);
+ // Load non-set variable u, non-set variable ke, non-set variable vorticity, and the mesh
+ read_opts += ";DEBUG_IO=0;VARIABLE=u,ke,vorticity";
+ if (procs > 1)
+ read_opts += ";PARALLEL_RESOLVE_SHARED_ENTS";
+ rval = mb.load_file(example_mpas, &set, read_opts.c_str());
+ CHECK_ERR(rval);
+ // Write variables u, ke and vorticity (no mesh information)
+ std::string write_opts = ";;VARIABLE=u,ke,vorticity;DEBUG_IO=0;";
+#ifdef USE_MPI
+ // Use parallel options
+ write_opts += std::string(";PARALLEL=WRITE_PART");
+#endif
+ if (procs > 1)
+ rval = mb.write_file("test_par_mpas_vars.nc", 0, write_opts.c_str(), &set, 1);
+ else
+ rval = mb.write_file("test_mpas_vars.nc", 0, write_opts.c_str(), &set, 1);
+ CHECK_ERR(rval);
+// Check variables without using NC reader (the output file does not contain mesh information)
+// For the time being, we only check cell variable ke
+ int rank = 0;
+ int procs = 1;
+#ifdef USE_MPI
+ MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+#endif
+ if (procs > 1)
+ return;
+#endif
+ if (0 == rank) {
+ int ncid, varid;
+ int success;
+ const double eps = 1e-10;
+ std::string filename;
+ if (procs > 1)
+ filename = "test_mpas_vars.nc";
+ else
+ filename = "test_par_mpas_vars.nc";
+ success = NCFUNC(open)(MPI_COMM_SELF, filename.c_str(), NC_NOWRITE, MPI_INFO_NULL, &ncid);
+#else
+ success = NCFUNC(open)(filename.c_str(), NC_NOWRITE, &ncid);
+#endif
+ CHECK_EQUAL(0, success);
+ success = NCFUNC(inq_varid)(ncid, "ke", &varid);
+ // Enter independent I/O mode
+ success = NCFUNC(begin_indep_data)(ncid);
+#endif
+ NCDF_SIZE start[] = {0, 0, 0};
+ NCDF_SIZE count[] = {1, 642, 1};
+ double vals[642];
+ success = NCFUNC(get_vara_double)(ncid, varid, start, count, vals);
+ // End independent I/O mode
+ success = NCFUNC(end_indep_data)(ncid);
+#endif
+ CHECK_REAL_EQUAL(15.001, vals[0], eps);
+ CHECK_REAL_EQUAL(15.012, vals[11], eps);
+ CHECK_REAL_EQUAL(16.013, vals[12], eps);
+ CHECK_REAL_EQUAL(16.642, vals[641], eps);
+ success = NCFUNC(close)(ncid);
#ifdef USE_MPI
@@ -536,3 +664,17 @@ void get_homme_read_options(std::string& opts)
opts = ";;";
#endif
+#ifdef USE_MPI
+#ifdef HAVE_ZOLTAN
+ opts = ";;PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN";
+#else
+ opts = ";;PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL";
+#endif
+#else
+ opts = ";;";
+#endif
diff --git a/test/parallel/Makefile.am b/test/parallel/Makefile.am
index 59c39c3..8a11dd1 100644
--- a/test/parallel/Makefile.am
+++ b/test/parallel/Makefile.am
@@ -123,4 +123,5 @@ MOSTLYCLEANFILES = mhdf_ll.h5m tmp0.h5m tmp1.h5m tmp2.h5m tmp3.h5m \
test_mpas_rcbzoltan_no_mixed_elements.h5m \
test_par_eul_T.nc \
test_par_fv_T.nc \
- test_par_homme_T.nc
+ test_par_homme_T.nc \
+ test_par_mpas_vars.nc
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
