[MOAB-dev] DAGMC HDF5 Issues
    Paul Wilson
    wilsonp at engr.wisc.edu
    Thu Mar 27 12:48:52 CDT 2014
Hi Andy,
I think I learned that we need to run more tests before we push:
  * make check
  * make dist
  * make distcheck
The last of these is important (and nominally a superset of the first 2)
and makes sure that tests pass from a tarball, not just from the repo.
Paul
On 03/27/2014 12:23 PM, Andrew Davis wrote:
> HI Iulian
> Just tried them thanks works great. Is there a source of documentation
> that would have described the process to adding those things? I tried
> and failed miserably at this end.
> Andy
> On 03/27/2014 12:14 PM, Grindeanu, Iulian R. wrote:
>> I think I fixed those, you should git pull and try.
>> (I modified dagmc/Makefile.am )
>> *From:* moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov]
>> on behalf of Andrew Davis [davisa at engr.wisc.edu]
>> *Sent:* Thursday, March 27, 2014 11:50 AM
>> *To:* moab-dev at mcs.anl.gov
>> *Subject:* [MOAB-dev] DAGMC HDF5 Issues
>>      Ive added the lines
>>           dagmc/dagmc_rayfire_test \
>>           dagmc/dagmc_simple_test \
>>           dagmc/dagmc_pointinvol_test
>>      (I also tried without the starting dagmc/)
>>      to if HDF5_FILE in Makefile.am in/test/
>>      I also added the h5m file we require MeshFiles/unittest/Makefile.am
>>      I then build build without hdf5, and the test still run.
>>      Could you please clarify that these are the correct locations for these
>>      files
>>      Thanks
>>      Andy
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140327/b4dd995c/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140327/b4dd995c/attachment.bin>
