[MOAB-dev] DAGMC HDF5 Issues
    Andrew Davis
    davisa at engr.wisc.edu
    Thu Mar 27 12:23:21 CDT 2014
HI Iulian
Just tried them thanks works great. Is there a source of documentation
that would have described the process to adding those things? I tried
and failed miserably at this end.
Andy
On 03/27/2014 12:14 PM, Grindeanu, Iulian R. wrote:
> I think I fixed those, you should git pull and try.
> (I modified dagmc/Makefile.am )
> *From:* moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
> behalf of Andrew Davis [davisa at engr.wisc.edu]
> *Sent:* Thursday, March 27, 2014 11:50 AM
> *To:* moab-dev at mcs.anl.gov
> *Subject:* [MOAB-dev] DAGMC HDF5 Issues
>      Ive added the lines
>           dagmc/dagmc_rayfire_test \
>           dagmc/dagmc_simple_test \
>           dagmc/dagmc_pointinvol_test
>      (I also tried without the starting dagmc/)
>      to if HDF5_FILE in Makefile.am in/test/
>      I also added the h5m file we require MeshFiles/unittest/Makefile.am
>      I then build build without hdf5, and the test still run.
>      Could you please clarify that these are the correct locations for these
>      files
>      Thanks
>      Andy
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140327/4850203a/attachment.html>
