[MOAB-dev] DAGMC HDF5 Issues
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Thu Mar 27 12:14:53 CDT 2014
I think I fixed those, you should git pull and try.
(I modified dagmc/Makefile.am )
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Andrew Davis [davisa at engr.wisc.edu]
Sent: Thursday, March 27, 2014 11:50 AM
To: moab-dev at mcs.anl.gov
Subject: [MOAB-dev] DAGMC HDF5 Issues
    Ive added the lines
         dagmc/dagmc_rayfire_test \
         dagmc/dagmc_simple_test \
         dagmc/dagmc_pointinvol_test
    (I also tried without the starting dagmc/)
    to if HDF5_FILE in Makefile.am in /test/
    I also added the h5m file we require MeshFiles/unittest/Makefile.am
    I then build build without hdf5, and the test still run.
    Could you please clarify that these are the correct locations for these
    files
    Thanks
    Andy
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140327/34c248c3/attachment.html>
