[MOAB-dev] DAGMC HDF5 Issues
    Andrew Davis
    davisa at engr.wisc.edu
    Thu Mar 27 11:50:42 CDT 2014
     Ive added the lines
          dagmc/dagmc_rayfire_test \
          dagmc/dagmc_simple_test \
          dagmc/dagmc_pointinvol_test
     (I also tried without the starting dagmc/)
     to if HDF5_FILE in Makefile.am in/test/
     I also added the h5m file we require MeshFiles/unittest/Makefile.am
     I then build build without hdf5, and the test still run.
     Could you please clarify that these are the correct locations for these
     files
     Thanks
     Andy
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140327/18d2aff4/attachment.html>
