[MOAB-dev] OCC CGM testing
    Paul Wilson
    wilsonp at engr.wisc.edu
    Tue Mar 25 10:40:36 CDT 2014
Hi Iulian,
[Adding CGM mailing list]
Do you run 'make check' on buildbot?  I did a clean build of OCC6.6.0
and CGM13.1.1 and it built successfully but failed on 'make check'.
Paul
On 03/25/2014 07:11 AM, Grindeanu, Iulian R. wrote:
> hello,
>   I built occ 6.6.0 on gnep.mcs, and cgm 13.1 configured with it  worked fine last night
> http://gnep.mcs.anl.gov:8010/builders/cgm131-occ660
> On mcs network, occ 660 is installed at:
> /homes/fathom/3rdparty/occ/OpenCASCADE6.6.0/gccGnep
> I will update instructions on
> http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingOcc65
> Jane, will all cgm branches work against occ 660?
> (I am pretty sure master branch will work, I don't know about cgm12.2)
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
> Sent: Monday, March 24, 2014 10:48 AM
> To: Paul Wilson; Patrick Shriwise; MOAB-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] OCC CGM testing
> Hi Paul,
> occ 653 was built on gnep.mcs.anl.gov. It is not built every night, as part of buildbot. gnep is at ubuntu 10.04, but I did built it on my laptop successfully, too, which is 12.04
> Maybe I don't understand the question.
> What kind of instructions? Maybe they are not up-to-date. Or the patch fails to be applied ?
> Iulian
> From: Paul Wilson [wilsonp at engr.wisc.edu]
> Sent: Monday, March 24, 2014 10:05 AM
> To: Grindeanu, Iulian R.; Patrick Shriwise; MOAB-dev at mcs.anl.gov
> Hi Iulian,
> I was unsuccessful in following the instructions for building OCC653
> with the provided patch. (Note: the instructions didn't work perfectly
> either, but that's a different issue).
> Can you provide the script or automated instructions that are used to
> build this on buildbot?
> Paul
> On 03/21/2014 10:09 AM, Grindeanu, Iulian R. wrote:
>> http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
>> any build that contains occ in its name is built with occ653
>> We actually test on cgm13.1 too, on buildbot
>> "trunk", "tr", "tru" means current cgm master repo (former trunk on svn)
>> the others are with cgm branch cgm12.2
>> Sent: Thursday, March 20, 2014 3:59 PM
>> To: Patrick Shriwise; MOAB-dev at mcs.anl.gov
>> occ 653 with cgm master, and occ 653 with cgm branch cgm12.2 (serial and parallel)
>> we used to test with cgm13.1 branch, too, but it should be fine
>> Iulian
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Patrick Shriwise [shriwise at wisc.edu]
>> Sent: Thursday, March 20, 2014 1:52 PM
>> To: MOAB-dev at mcs.anl.gov
>> Subject: [MOAB-dev] OCC CGM testing
>> Hi all,
>> What version(s) of OCC and CGM are tested in the MOAB nightlies?
>> Going to create a similar set of builds for testing on my local machine.
>> Thanks!
>> Patrick C. Shriwise
>> Research Assistant
>> University of Wisconsin - Madison
>> Engineering Research Building - Rm. 428
>> 1500 Engineering Drive
>> Madison, WI 53706
>> (608) 446-8173
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140325/b930ffc3/attachment.bin>
