[MOAB-dev] OCC CGM testing
    Jiangtao Hu
    jiangtao_ma at yahoo.com
    Tue Mar 25 10:25:40 CDT 2014
Paul said he's unsuccessful building 12.2.0 with occ6.5.3, I double checked that this release we don't have occ6.5.3 patch, which means they may not compatible. It seems that 12.2.1 should be compatible with occ6.5.3.
Based on this, I would say 12.2 won't be compatible with occ6.6.0, but always welcome any try-outs for it if time permits.
I also removed all other patches except occ_patches6.6.0 from tag 13.1.0 and 13.1.1, indicating this is the official occ engine that we support, I'll do similar thing for 12.2 today, in which occ6.5.3 or 6.5.2 will be officially supported.
Jane
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called according to his purpose, all things are working together for good." (Romans 8:28)
On Tuesday, March 25, 2014 7:11 AM, "Grindeanu, Iulian R." <iulian at mcs.anl.gov> wrote:
hello,
I built occ 6.6.0 on gnep.mcs, and cgm 13.1 configured with it  worked fine last night
http://gnep.mcs.anl.gov:8010/builders/cgm131-occ660
On mcs network, occ 660 is installed at:
/homes/fathom/3rdparty/occ/OpenCASCADE6.6.0/gccGnep
I will update instructions on
http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingOcc65
Jane, will all cgm branches work against occ 660?
(I am pretty sure master branch will work, I don't know about cgm12.2)
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
Sent: Monday, March 24, 2014 10:48 AM
To: Paul Wilson; Patrick Shriwise; MOAB-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] OCC CGM testing
Hi Paul,
occ 653 was built on gnep.mcs.anl.gov. It is not built every night, as part of buildbot. gnep is at ubuntu 10.04, but I did built it on my laptop successfully, too, which is 12.04
Maybe I don't understand the question.
What kind of instructions? Maybe they are not up-to-date. Or the patch fails to be applied ?
Iulian
Sent: Monday, March 24, 2014 10:05 AM
To: Grindeanu, Iulian R.; Patrick Shriwise; MOAB-dev at mcs.anl.gov
Hi Iulian,
I was unsuccessful in following the instructions for building OCC653
with the provided patch. (Note: the instructions didn't work perfectly
either, but that's a different issue).
Can you provide the script or automated instructions that are used to
build this on buildbot?
Paul
On 03/21/2014 10:09 AM, Grindeanu, Iulian R. wrote:
> http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
> any build that contains occ in its name is built with occ653
> We actually test on cgm13.1 too, on buildbot
> "trunk", "tr", "tru" means current cgm master repo (former trunk on svn)
> the others are with cgm branch cgm12.2
> Sent: Thursday, March 20, 2014 3:59 PM
> To: Patrick Shriwise; MOAB-dev at mcs.anl.gov
> occ 653 with cgm master, and occ 653 with cgm branch cgm12.2 (serial and parallel)
> we used to test with cgm13.1 branch, too, but it should be fine
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Patrick Shriwise [shriwise at wisc.edu]
> Sent: Thursday, March 20, 2014 1:52 PM
> To: MOAB-dev at mcs.anl.gov
> Subject: [MOAB-dev] OCC CGM testing
> Hi all,
> What version(s) of OCC and CGM are tested in the MOAB nightlies?
> Going to create a similar set of builds for testing on my local machine.
> Thanks!
> Patrick C. Shriwise
> Research Assistant
> University of Wisconsin - Madison
> Engineering Research Building - Rm. 428
> 1500 Engineering Drive
> Madison, WI 53706
> (608) 446-8173
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140325/a6580ac6/attachment-0001.html>
