[MOAB-dev] OCC CGM testing
    Paul Wilson
    wilsonp at engr.wisc.edu
    Tue Mar 25 10:49:19 CDT 2014
Hi again,
just looked at gnep and confirmed that make check is occurring.
Here is my config:  ../configure
--with-occ=/home/wilsonp/.local/OCC/6.6.0_patched
--prefix=/home/wilsonp/.local/cgm/13.1.1_occ660
Make check log: make_check_log
Errors are attached as: make_check_err
The errors are all in iTaps, so I included: test-suite.log
I'll also try to sit with Jane to look at these.
Paul
On 03/25/2014 10:40 AM, Paul Wilson wrote:
> Hi Iulian,
> [Adding CGM mailing list]
> Do you run 'make check' on buildbot?  I did a clean build of OCC6.6.0
> and CGM13.1.1 and it built successfully but failed on 'make check'.
> Paul
> On 03/25/2014 07:11 AM, Grindeanu, Iulian R. wrote:
>> hello,
>>   I built occ 6.6.0 on gnep.mcs, and cgm 13.1 configured with it
>> worked fine last night
>> http://gnep.mcs.anl.gov:8010/builders/cgm131-occ660
>> On mcs network, occ 660 is installed at:
>> /homes/fathom/3rdparty/occ/OpenCASCADE6.6.0/gccGnep
>> I will update instructions on
>> http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingOcc65
>> Jane, will all cgm branches work against occ 660?
>> (I am pretty sure master branch will work, I don't know about cgm12.2)
>> Iulian
>> ________________________________________
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
>> behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
>> Sent: Monday, March 24, 2014 10:48 AM
>> To: Paul Wilson; Patrick Shriwise; MOAB-dev at mcs.anl.gov
>> Subject: Re: [MOAB-dev] OCC CGM testing
>> Hi Paul,
>> occ 653 was built on gnep.mcs.anl.gov. It is not built every night,
>> as part of buildbot. gnep is at ubuntu 10.04, but I did built it on
>> my laptop successfully, too, which is 12.04
>> Maybe I don't understand the question.
>> What kind of instructions? Maybe they are not up-to-date. Or the
>> patch fails to be applied ?
>> Iulian
>> From: Paul Wilson [wilsonp at engr.wisc.edu]
>> Sent: Monday, March 24, 2014 10:05 AM
>> To: Grindeanu, Iulian R.; Patrick Shriwise; MOAB-dev at mcs.anl.gov
>> Hi Iulian,
>> I was unsuccessful in following the instructions for building OCC653
>> with the provided patch. (Note: the instructions didn't work perfectly
>> either, but that's a different issue).
>> Can you provide the script or automated instructions that are used to
>> build this on buildbot?
>> Paul
>> On 03/21/2014 10:09 AM, Grindeanu, Iulian R. wrote:
>>> http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
>>> any build that contains occ in its name is built with occ653
>>> We actually test on cgm13.1 too, on buildbot
>>> "trunk", "tr", "tru" means current cgm master repo (former trunk on
>>> svn)
>>> the others are with cgm branch cgm12.2
>>> Sent: Thursday, March 20, 2014 3:59 PM
>>> To: Patrick Shriwise; MOAB-dev at mcs.anl.gov
>>> occ 653 with cgm master, and occ 653 with cgm branch cgm12.2 (serial
>>> and parallel)
>>> we used to test with cgm13.1 branch, too, but it should be fine
>>> Iulian
>>> behalf of Patrick Shriwise [shriwise at wisc.edu]
>>> Sent: Thursday, March 20, 2014 1:52 PM
>>> To: MOAB-dev at mcs.anl.gov
>>> Subject: [MOAB-dev] OCC CGM testing
>>> Hi all,
>>> What version(s) of OCC and CGM are tested in the MOAB nightlies?
>>> Going to create a similar set of builds for testing on my local
>>> machine.
>>> Thanks!
>>> Patrick C. Shriwise
>>> Research Assistant
>>> University of Wisconsin - Madison
>>> Engineering Research Building - Rm. 428
>>> 1500 Engineering Drive
>>> Madison, WI 53706
>>> (608) 446-8173
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure
*** Error in `./test_edge_orient': double free or corruption (!prev): 0x00000000015937d0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x80996)[0x2b9fff6ed996]
/lib/x86_64-linux-gnu/libc.so.6(__cxa_finalize+0x9a)[0x2b9fff6a947a]
/usr/lib/x86_64-linux-gnu/libTKernel.so.6(+0x977a3)[0x2b9fffacc7a3]
======= Memory map: ========
00400000-008c4000 r-xp 00000000 00:19 29884882                           /home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps/test_edge_orient
00ac4000-00ac5000 r--p 004c4000 00:19 29884882                           /home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps/test_edge_orient
00ac5000-00ac8000 rw-p 004c5000 00:19 29884882                           /home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps/test_edge_orient
00ac8000-00ace000 rw-p 00000000 00:00 0
01426000-01796000 rw-p 00000000 00:00 0                                  [heap]
2b9ff9694000-2b9ff96b7000 r-xp 00000000 fc:01 4066492                    /lib/x86_64-linux-gnu/ld-2.17.so
2b9ff96b7000-2b9ff96bb000 rw-p 00000000 00:00 0
2b9ff96db000-2b9ff96f7000 rw-p 00000000 00:00 0
2b9ff98b6000-2b9ff98b7000 r--p 00022000 fc:01 4066492                    /lib/x86_64-linux-gnu/ld-2.17.so
2b9ff98b7000-2b9ff98b9000 rw-p 00023000 fc:01 4066492                    /lib/x86_64-linux-gnu/ld-2.17.so
2b9ff98b9000-2b9ff9b16000 r-xp 00000000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b9ff9b16000-2b9ff9d15000 ---p 0025d000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b9ff9d15000-2b9ff9d1b000 r--p 0025c000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b9ff9d1b000-2b9ff9d24000 rw-p 00262000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b9ff9d24000-2b9ff9d29000 rw-p 00000000 00:00 0
2b9ff9d29000-2b9ffa09c000 r-xp 00000000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b9ffa09c000-2b9ffa29c000 ---p 00373000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b9ffa29c000-2b9ffa2a9000 r--p 00373000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b9ffa2a9000-2b9ffa2ac000 rw-p 00380000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b9ffa2ac000-2b9ffa2b3000 rw-p 00000000 00:00 0
2b9ffa2b3000-2b9ffa4f3000 r-xp 00000000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b9ffa4f3000-2b9ffa6f3000 ---p 00240000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b9ffa6f3000-2b9ffa6fd000 r--p 00240000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b9ffa6fd000-2b9ffa6ff000 rw-p 0024a000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b9ffa6ff000-2b9ffa714000 rw-p 00000000 00:00 0
2b9ffa714000-2b9ffa7db000 r-xp 00000000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b9ffa7db000-2b9ffa9da000 ---p 000c7000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b9ffa9da000-2b9ffa9e0000 r--p 000c6000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b9ffa9e0000-2b9ffa9e1000 rw-p 000cc000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b9ffa9e1000-2b9ffa9e4000 rw-p 00000000 00:00 0
2b9ffa9e4000-2b9ffaa8f000 r-xp 00000000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b9ffaa8f000-2b9ffac8f000 ---p 000ab000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b9ffac8f000-2b9ffac93000 r--p 000ab000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b9ffac93000-2b9ffac95000 rw-p 000af000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b9ffac95000-2b9ffadb2000 r-xp 00000000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b9ffadb2000-2b9ffafb2000 ---p 0011d000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b9ffafb2000-2b9ffafb5000 r--p 0011d000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b9ffafb5000-2b9ffafb8000 rw-p 00120000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b9ffafb8000-2b9ffafb9000 rw-p 00000000 00:00 0
2b9ffafb9000-2b9ffb207000 r-xp 00000000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b9ffb207000-2b9ffb406000 ---p 0024e000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b9ffb406000-2b9ffb40b000 r--p 0024d000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b9ffb40b000-2b9ffb40f000 rw-p 00252000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b9ffb40f000-2b9ffb410000 rw-p 00000000 00:00 0
2b9ffb410000-2b9ffb524000 r-xp 00000000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b9ffb524000-2b9ffb723000 ---p 00114000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b9ffb723000-2b9ffb726000 r--p 00113000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b9ffb726000-2b9ffb728000 rw-p 00116000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b9ffb728000-2b9ffb729000 rw-p 00000000 00:00 0
2b9ffb729000-2b9ffba9f000 r-xp 00000000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b9ffba9f000-2b9ffbc9f000 ---p 00376000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b9ffbc9f000-2b9ffbca5000 r--p 00376000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b9ffbca5000-2b9ffbcae000 rw-p 0037c000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b9ffbcae000-2b9ffbcb0000 rw-p 00000000 00:00 0
2b9ffbcb0000-2b9ffbece000 r-xp 00000000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b9ffbece000-2b9ffc0cd000 ---p 0021e000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b9ffc0cd000-2b9ffc0d2000 r--p 0021d000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b9ffc0d2000-2b9ffc0d7000 rw-p 00222000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b9ffc0d7000-2b9ffc0d8000 rw-p 00000000 00:00 0
2b9ffc0d8000-2b9ffc2a4000 r-xp 00000000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b9ffc2a4000-2b9ffc4a4000 ---p 001cc000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b9ffc4a4000-2b9ffc4ab000 r--p 001cc000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b9ffc4ab000-2b9ffc4af000 rw-p 001d3000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b9ffc4af000-2b9ffc4b0000 rw-p 00000000 00:00 0
2b9ffc4b0000-2b9ffc502000 r-xp 00000000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b9ffc502000-2b9ffc702000 ---p 00052000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b9ffc702000-2b9ffc704000 r--p 00052000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b9ffc704000-2b9ffc705000 rw-p 00054000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b9ffc705000-2b9ffc79a000 r-xp 00000000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b9ffc79a000-2b9ffc99a000 ---p 00095000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b9ffc99a000-2b9ffc99d000 r--p 00095000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b9ffc99d000-2b9ffc99f000 rw-p 00098000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b9ffc99f000-2b9ffc9a0000 rw-p 00000000 00:00 0
2b9ffc9a0000-2b9ffcbae000 r-xp 00000000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b9ffcbae000-2b9ffcdae000 ---p 0020e000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b9ffcdae000-2b9ffcdb3000 r--p 0020e000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b9ffcdb3000-2b9ffcdb8000 rw-p 00213000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b9ffcdb8000-2b9ffcdba000 rw-p 00000000 00:00 0
2b9ffcdba000-2b9ffd1e9000 r-xp 00000000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b9ffd1e9000-2b9ffd3e9000 ---p 0042f000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b9ffd3e9000-2b9ffd3f2000 r--p 0042f000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b9ffd3f2000-2b9ffd3f9000 rw-p 00438000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b9ffd3f9000-2b9ffd3fd000 rw-p 00000000 00:00 0
2b9ffd3fd000-2b9ffd4c9000 r-xp 00000000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b9ffd4c9000-2b9ffd6c9000 ---p 000cc000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b9ffd6c9000-2b9ffd6ce000 r--p 000cc000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b9ffd6ce000-2b9ffd6d0000 rw-p 000d1000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b9ffd6d0000-2b9ffd6d2000 rw-p 00000000 00:00 0
2b9ffd6d2000-2b9ffda9e000 r-xp 00000000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b9ffda9e000-2b9ffdc9e000 ---p 003cc000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b9ffdc9e000-2b9ffdca4000 r--p 003cc000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b9ffdca4000-2b9ffdcea000 rw-p 003d2000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b9ffdcea000-2b9ffdd09000 rw-p 00000000 00:00 0
2b9ffdd09000-2b9ffde0a000 r-xp 00000000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b9ffde0a000-2b9ffe00a000 ---p 00101000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b9ffe00a000-2b9ffe00f000 r--p 00101000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b9ffe00f000-2b9ffe011000 rw-p 00106000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b9ffe011000-2b9ffe013000 rw-p 00000000 00:00 0
2b9ffe013000-2b9ffe077000 r-xp 00000000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b9ffe077000-2b9ffe277000 ---p 00064000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b9ffe277000-2b9ffe27a000 r--p 00064000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b9ffe27a000-2b9ffe27b000 rw-p 00067000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b9ffe27b000-2b9ffe27c000 rw-p 00000000 00:00 0
2b9ffe27c000-2b9ffe3d7000 r-xp 00000000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b9ffe3d7000-2b9ffe5d6000 ---p 0015b000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b9ffe5d6000-2b9ffe5da000 r--p 0015a000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b9ffe5da000-2b9ffe5dd000 rw-p 0015e000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b9ffe5dd000-2b9ffe5df000 rw-p 00000000 00:00 0
2b9ffe5df000-2b9ffe811000 r-xp 00000000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b9ffe811000-2b9ffea11000 ---p 00232000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b9ffea11000-2b9ffea1b000 r--p 00232000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b9ffea1b000-2b9ffea1f000 rw-p 0023c000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b9ffea1f000-2b9ffea2e000 rw-p 00000000 00:00 0
2b9ffea2e000-2b9ffea31000 r-xp 00000000 fc:01 4066504                    /lib/x86_64-linux-gnu/libdl-2.17.so
2b9ffea31000-2b9ffec30000 ---p 00003000 fc:01 4066504                    /lib/x86_64-linux-gnu/libdl-2.17.so
2b9ffec30000-2b9ffec31000 r--p 00002000 fc:01 4066504                    /lib/x86_64-linux-gnu/libdl-2.1*** Error in `./testgeom_occ': double free or corruption (!prev): 0x0000000001a927d0 ***
/lib/x86_64-linux-gnu/libc.so.6(+0x80996)[0x2b6bd7f1f996]
/lib/x86_64-linux-gnu/libc.so.6(__cxa_finalize+0x9a)[0x2b6bd7edb47a]
/usr/lib/x86_64-linux-gnu/libTKernel.so.6(+0x977a3)[0x2b6bd82fe7a3]
00400000-008cc000 r-xp 00000000 00:19 29884884                           /home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps/testgeom_occ
00acc000-00acd000 r--p 004cc000 00:19 29884884                           /home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps/testgeom_occ
00acd000-00ad0000 rw-p 004cd000 00:19 29884884                           /home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps/testgeom_occ
00ad0000-00ad6000 rw-p 00000000 00:00 0
01925000-01d53000 rw-p 00000000 00:00 0                                  [heap]
2b6bd1ec6000-2b6bd1ee9000 r-xp 00000000 fc:01 4066492                    /lib/x86_64-linux-gnu/ld-2.17.so
2b6bd1ee9000-2b6bd1eed000 rw-p 00000000 00:00 0
2b6bd1f0d000-2b6bd1f29000 rw-p 00000000 00:00 0
2b6bd20e8000-2b6bd20e9000 r--p 00022000 fc:01 4066492                    /lib/x86_64-linux-gnu/ld-2.17.so
2b6bd20e9000-2b6bd20eb000 rw-p 00023000 fc:01 4066492                    /lib/x86_64-linux-gnu/ld-2.17.so
2b6bd20eb000-2b6bd2348000 r-xp 00000000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b6bd2348000-2b6bd2547000 ---p 0025d000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b6bd2547000-2b6bd254d000 r--p 0025c000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b6bd254d000-2b6bd2556000 rw-p 00262000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b6bd2556000-2b6bd255b000 rw-p 00000000 00:00 0
2b6bd255b000-2b6bd28ce000 r-xp 00000000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b6bd28ce000-2b6bd2ace000 ---p 00373000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b6bd2ace000-2b6bd2adb000 r--p 00373000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b6bd2adb000-2b6bd2ade000 rw-p 00380000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b6bd2ade000-2b6bd2ae5000 rw-p 00000000 00:00 0
2b6bd2ae5000-2b6bd2d25000 r-xp 00000000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b6bd2d25000-2b6bd2f25000 ---p 00240000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b6bd2f25000-2b6bd2f2f000 r--p 00240000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b6bd2f2f000-2b6bd2f31000 rw-p 0024a000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b6bd2f31000-2b6bd2f46000 rw-p 00000000 00:00 0
2b6bd2f46000-2b6bd300d000 r-xp 00000000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b6bd300d000-2b6bd320c000 ---p 000c7000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b6bd320c000-2b6bd3212000 r--p 000c6000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b6bd3212000-2b6bd3213000 rw-p 000cc000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b6bd3213000-2b6bd3216000 rw-p 00000000 00:00 0
2b6bd3216000-2b6bd32c1000 r-xp 00000000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b6bd32c1000-2b6bd34c1000 ---p 000ab000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b6bd34c1000-2b6bd34c5000 r--p 000ab000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b6bd34c5000-2b6bd34c7000 rw-p 000af000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b6bd34c7000-2b6bd35e4000 r-xp 00000000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b6bd35e4000-2b6bd37e4000 ---p 0011d000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b6bd37e4000-2b6bd37e7000 r--p 0011d000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b6bd37e7000-2b6bd37ea000 rw-p 00120000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b6bd37ea000-2b6bd37eb000 rw-p 00000000 00:00 0
2b6bd37eb000-2b6bd3a39000 r-xp 00000000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b6bd3a39000-2b6bd3c38000 ---p 0024e000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b6bd3c38000-2b6bd3c3d000 r--p 0024d000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b6bd3c3d000-2b6bd3c41000 rw-p 00252000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b6bd3c41000-2b6bd3c42000 rw-p 00000000 00:00 0
2b6bd3c42000-2b6bd3d56000 r-xp 00000000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b6bd3d56000-2b6bd3f55000 ---p 00114000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b6bd3f55000-2b6bd3f58000 r--p 00113000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b6bd3f58000-2b6bd3f5a000 rw-p 00116000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b6bd3f5a000-2b6bd3f5b000 rw-p 00000000 00:00 0
2b6bd3f5b000-2b6bd42d1000 r-xp 00000000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b6bd42d1000-2b6bd44d1000 ---p 00376000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b6bd44d1000-2b6bd44d7000 r--p 00376000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b6bd44d7000-2b6bd44e0000 rw-p 0037c000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b6bd44e0000-2b6bd44e2000 rw-p 00000000 00:00 0
2b6bd44e2000-2b6bd4700000 r-xp 00000000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b6bd4700000-2b6bd48ff000 ---p 0021e000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b6bd48ff000-2b6bd4904000 r--p 0021d000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b6bd4904000-2b6bd4909000 rw-p 00222000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b6bd4909000-2b6bd490a000 rw-p 00000000 00:00 0
2b6bd490a000-2b6bd4ad6000 r-xp 00000000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b6bd4ad6000-2b6bd4cd6000 ---p 001cc000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b6bd4cd6000-2b6bd4cdd000 r--p 001cc000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b6bd4cdd000-2b6bd4ce1000 rw-p 001d3000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b6bd4ce1000-2b6bd4ce2000 rw-p 00000000 00:00 0
2b6bd4ce2000-2b6bd4d34000 r-xp 00000000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b6bd4d34000-2b6bd4f34000 ---p 00052000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b6bd4f34000-2b6bd4f36000 r--p 00052000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b6bd4f36000-2b6bd4f37000 rw-p 00054000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b6bd4f37000-2b6bd4fcc000 r-xp 00000000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b6bd4fcc000-2b6bd51cc000 ---p 00095000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b6bd51cc000-2b6bd51cf000 r--p 00095000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b6bd51cf000-2b6bd51d1000 rw-p 00098000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b6bd51d1000-2b6bd51d2000 rw-p 00000000 00:00 0
2b6bd51d2000-2b6bd53e0000 r-xp 00000000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b6bd53e0000-2b6bd55e0000 ---p 0020e000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b6bd55e0000-2b6bd55e5000 r--p 0020e000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b6bd55e5000-2b6bd55ea000 rw-p 00213000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b6bd55ea000-2b6bd55ec000 rw-p 00000000 00:00 0
2b6bd55ec000-2b6bd5a1b000 r-xp 00000000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b6bd5a1b000-2b6bd5c1b000 ---p 0042f000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b6bd5c1b000-2b6bd5c24000 r--p 0042f000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b6bd5c24000-2b6bd5c2b000 rw-p 00438000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b6bd5c2b000-2b6bd5c2f000 rw-p 00000000 00:00 0
2b6bd5c2f000-2b6bd5cfb000 r-xp 00000000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b6bd5cfb000-2b6bd5efb000 ---p 000cc000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b6bd5efb000-2b6bd5f00000 r--p 000cc000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b6bd5f00000-2b6bd5f02000 rw-p 000d1000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b6bd5f02000-2b6bd5f04000 rw-p 00000000 00:00 0
2b6bd5f04000-2b6bd62d0000 r-xp 00000000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b6bd62d0000-2b6bd64d0000 ---p 003cc000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b6bd64d0000-2b6bd64d6000 r--p 003cc000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b6bd64d6000-2b6bd651c000 rw-p 003d2000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b6bd651c000-2b6bd653b000 rw-p 00000000 00:00 0
2b6bd653b000-2b6bd663c000 r-xp 00000000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b6bd663c000-2b6bd683c000 ---p 00101000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b6bd683c000-2b6bd6841000 r--p 00101000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b6bd6841000-2b6bd6843000 rw-p 00106000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b6bd6843000-2b6bd6845000 rw-p 00000000 00:00 0
2b6bd6845000-2b6bd68a9000 r-xp 00000000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b6bd68a9000-2b6bd6aa9000 ---p 00064000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b6bd6aa9000-2b6bd6aac000 r--p 00064000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b6bd6aac000-2b6bd6aad000 rw-p 00067000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b6bd6aad000-2b6bd6aae000 rw-p 00000000 00:00 0
2b6bd6aae000-2b6bd6c09000 r-xp 00000000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b6bd6c09000-2b6bd6e08000 ---p 0015b000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b6bd6e08000-2b6bd6e0c000 r--p 0015a000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b6bd6e0c000-2b6bd6e0f000 rw-p 0015e000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b6bd6e0f000-2b6bd6e11000 rw-p 00000000 00:00 0
2b6bd6e11000-2b6bd7043000 r-xp 00000000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b6bd7043000-2b6bd7243000 ---p 00232000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b6bd7243000-2b6bd724d000 r--p 00232000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b6bd724d000-2b6bd7251000 rw-p 0023c000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b6bd7251000-2b6bd7260000 rw-p 00000000 00:00 0
2b6bd7260000-2b6bd7263000 r-xp 00000000 fc:01 4066504                    /lib/x86_64-linux-gnu/libdl-2.17.so*** Error in `./copy_attrib': double free or corruption (!prev): 0x0000000000c4b7d0 ***
/lib/x86_64-linux-gnu/libc.so.6(+0x80996)[0x2b7d33431996]
/lib/x86_64-linux-gnu/libc.so.6(__cxa_finalize+0x9a)[0x2b7d333ed47a]
/usr/lib/x86_64-linux-gnu/libTKernel.so.6(+0x977a3)[0x2b7d338107a3]
00400000-008c5000 r-xp 00000000 00:19 29884878                           /home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps/copy_attrib
00ac5000-00ac6000 r--p 004c5000 00:19 29884878                           /home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps/copy_attrib
00ac6000-00ac9000 rw-p 004c6000 00:19 29884878                           /home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps/copy_attrib
00ac9000-00acf000 rw-p 00000000 00:00 0
00ade000-00e06000 rw-p 00000000 00:00 0                                  [heap]
2b7d2d3d8000-2b7d2d3fb000 r-xp 00000000 fc:01 4066492                    /lib/x86_64-linux-gnu/ld-2.17.so
2b7d2d3fb000-2b7d2d3ff000 rw-p 00000000 00:00 0
2b7d2d41f000-2b7d2d43b000 rw-p 00000000 00:00 0
2b7d2d5fa000-2b7d2d5fb000 r--p 00022000 fc:01 4066492                    /lib/x86_64-linux-gnu/ld-2.17.so
2b7d2d5fb000-2b7d2d5fd000 rw-p 00023000 fc:01 4066492                    /lib/x86_64-linux-gnu/ld-2.17.so
2b7d2d5fd000-2b7d2d85a000 r-xp 00000000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b7d2d85a000-2b7d2da59000 ---p 0025d000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b7d2da59000-2b7d2da5f000 r--p 0025c000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b7d2da5f000-2b7d2da68000 rw-p 00262000 fc:01 24388113                   /usr/lib/x86_64-linux-gnu/libTKSTEP.so.6.0.0
2b7d2da68000-2b7d2da6d000 rw-p 00000000 00:00 0
2b7d2da6d000-2b7d2dde0000 r-xp 00000000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b7d2dde0000-2b7d2dfe0000 ---p 00373000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b7d2dfe0000-2b7d2dfed000 r--p 00373000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b7d2dfed000-2b7d2dff0000 rw-p 00380000 fc:01 24388108                   /usr/lib/x86_64-linux-gnu/libTKIGES.so.6.0.0
2b7d2dff0000-2b7d2dff7000 rw-p 00000000 00:00 0
2b7d2dff7000-2b7d2e237000 r-xp 00000000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b7d2e237000-2b7d2e437000 ---p 00240000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b7d2e437000-2b7d2e441000 r--p 00240000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b7d2e441000-2b7d2e443000 rw-p 0024a000 fc:01 24388122                   /usr/lib/x86_64-linux-gnu/libTKXSBase.so.6.0.0
2b7d2e443000-2b7d2e458000 rw-p 00000000 00:00 0
2b7d2e458000-2b7d2e51f000 r-xp 00000000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b7d2e51f000-2b7d2e71e000 ---p 000c7000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b7d2e71e000-2b7d2e724000 r--p 000c6000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b7d2e724000-2b7d2e725000 rw-p 000cc000 fc:01 24388940                   /usr/lib/x86_64-linux-gnu/libTKLCAF.so.6.0.0
2b7d2e725000-2b7d2e728000 rw-p 00000000 00:00 0
2b7d2e728000-2b7d2e7d3000 r-xp 00000000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b7d2e7d3000-2b7d2e9d3000 ---p 000ab000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b7d2e9d3000-2b7d2e9d7000 r--p 000ab000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b7d2e9d7000-2b7d2e9d9000 rw-p 000af000 fc:01 24389123                   /usr/lib/x86_64-linux-gnu/libTKCAF.so.6.0.0
2b7d2e9d9000-2b7d2eaf6000 r-xp 00000000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b7d2eaf6000-2b7d2ecf6000 ---p 0011d000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b7d2ecf6000-2b7d2ecf9000 r--p 0011d000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b7d2ecf9000-2b7d2ecfc000 rw-p 00120000 00:19 19680132                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKOffset.so.0.0.0
2b7d2ecfc000-2b7d2ecfd000 rw-p 00000000 00:00 0
2b7d2ecfd000-2b7d2ef4b000 r-xp 00000000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b7d2ef4b000-2b7d2f14a000 ---p 0024e000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b7d2f14a000-2b7d2f14f000 r--p 0024d000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b7d2f14f000-2b7d2f153000 rw-p 00252000 00:19 19680124                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFillet.so.0.0.0
2b7d2f153000-2b7d2f154000 rw-p 00000000 00:00 0
2b7d2f154000-2b7d2f268000 r-xp 00000000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b7d2f268000-2b7d2f467000 ---p 00114000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b7d2f467000-2b7d2f46a000 r--p 00113000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b7d2f46a000-2b7d2f46c000 rw-p 00116000 00:19 19680128                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKFeat.so.0.0.0
2b7d2f46c000-2b7d2f46d000 rw-p 00000000 00:00 0
2b7d2f46d000-2b7d2f7e3000 r-xp 00000000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b7d2f7e3000-2b7d2f9e3000 ---p 00376000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b7d2f9e3000-2b7d2f9e9000 r--p 00376000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b7d2f9e9000-2b7d2f9f2000 rw-p 0037c000 00:19 19680120                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBool.so.0.0.0
2b7d2f9f2000-2b7d2f9f4000 rw-p 00000000 00:00 0
2b7d2f9f4000-2b7d2fc12000 r-xp 00000000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b7d2fc12000-2b7d2fe11000 ---p 0021e000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b7d2fe11000-2b7d2fe16000 r--p 0021d000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b7d2fe16000-2b7d2fe1b000 rw-p 00222000 00:19 19680112                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKShHealing.so.0.0.0
2b7d2fe1b000-2b7d2fe1c000 rw-p 00000000 00:00 0
2b7d2fe1c000-2b7d2ffe8000 r-xp 00000000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b7d2ffe8000-2b7d301e8000 ---p 001cc000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b7d301e8000-2b7d301ef000 r--p 001cc000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b7d301ef000-2b7d301f3000 rw-p 001d3000 00:19 19680100                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBO.so.0.0.0
2b7d301f3000-2b7d301f4000 rw-p 00000000 00:00 0
2b7d301f4000-2b7d30246000 r-xp 00000000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b7d30246000-2b7d30446000 ---p 00052000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b7d30446000-2b7d30448000 r--p 00052000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b7d30448000-2b7d30449000 rw-p 00054000 00:19 19680096                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKPrim.so.0.0.0
2b7d30449000-2b7d304de000 r-xp 00000000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b7d304de000-2b7d306de000 ---p 00095000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b7d306de000-2b7d306e1000 r--p 00095000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b7d306e1000-2b7d306e3000 rw-p 00098000 00:19 19680108                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMesh.so.0.0.0
2b7d306e3000-2b7d306e4000 rw-p 00000000 00:00 0
2b7d306e4000-2b7d308f2000 r-xp 00000000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b7d308f2000-2b7d30af2000 ---p 0020e000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b7d30af2000-2b7d30af7000 r--p 0020e000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b7d30af7000-2b7d30afc000 rw-p 00213000 00:19 19680092                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKTopAlgo.so.0.0.0
2b7d30afc000-2b7d30afe000 rw-p 00000000 00:00 0
2b7d30afe000-2b7d30f2d000 r-xp 00000000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b7d30f2d000-2b7d3112d000 ---p 0042f000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b7d3112d000-2b7d31136000 r--p 0042f000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b7d31136000-2b7d3113d000 rw-p 00438000 00:19 19680088                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomAlgo.so.0.0.0
2b7d3113d000-2b7d31141000 rw-p 00000000 00:00 0
2b7d31141000-2b7d3120d000 r-xp 00000000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b7d3120d000-2b7d3140d000 ---p 000cc000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b7d3140d000-2b7d31412000 r--p 000cc000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b7d31412000-2b7d31414000 rw-p 000d1000 00:19 19680084                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKBRep.so.0.0.0
2b7d31414000-2b7d31416000 rw-p 00000000 00:00 0
2b7d31416000-2b7d317e2000 r-xp 00000000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b7d317e2000-2b7d319e2000 ---p 003cc000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b7d319e2000-2b7d319e8000 r--p 003cc000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b7d319e8000-2b7d31a2e000 rw-p 003d2000 00:19 19680080                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKGeomBase.so.0.0.0
2b7d31a2e000-2b7d31a4d000 rw-p 00000000 00:00 0
2b7d31a4d000-2b7d31b4e000 r-xp 00000000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b7d31b4e000-2b7d31d4e000 ---p 00101000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b7d31d4e000-2b7d31d53000 r--p 00101000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b7d31d53000-2b7d31d55000 rw-p 00106000 00:19 19680076                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG3d.so.0.0.0
2b7d31d55000-2b7d31d57000 rw-p 00000000 00:00 0
2b7d31d57000-2b7d31dbb000 r-xp 00000000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b7d31dbb000-2b7d31fbb000 ---p 00064000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b7d31fbb000-2b7d31fbe000 r--p 00064000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b7d31fbe000-2b7d31fbf000 rw-p 00067000 00:19 19680072                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKG2d.so.0.0.0
2b7d31fbf000-2b7d31fc0000 rw-p 00000000 00:00 0
2b7d31fc0000-2b7d3211b000 r-xp 00000000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b7d3211b000-2b7d3231a000 ---p 0015b000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b7d3231a000-2b7d3231e000 r--p 0015a000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b7d3231e000-2b7d32321000 rw-p 0015e000 00:19 19680064                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKMath.so.0.0.0
2b7d32321000-2b7d32323000 rw-p 00000000 00:00 0
2b7d32323000-2b7d32555000 r-xp 00000000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b7d32555000-2b7d32755000 ---p 00232000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b7d32755000-2b7d3275f000 r--p 00232000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b7d3275f000-2b7d32763000 rw-p 0023c000 00:19 19680060                   /home/wilsonp/.local/OCC/6.6.0_patched/lib/libTKernel.so.0.0.0
2b7d32763000-2b7d32772000 rw-p 00000000 00:00 0
2b7d32772000-2b7d32775000 r-xp 00000000 fc:01 4066504                    /lib/x86_64-linux-gnu/libdl-2.17.so
2b7d32775000-2b7d32974000 ---p 00003000 fc:01 4066504                    /lib/x86_64-linux-gnu/libdl-2.17.so
2b7d32974000-2b7d32975000 r--p 00002000 fc:01 4066504                    /lib/x86_64-linux-gnu/libdl-2.17.so
2b7d32975000-2b7d32976000 rw-p 00003000 fc:01 4066504                    /lib/x86_64-linux-gnu/libdl-2.17.so
2b7d32976000-2b7d3298d000 r-xp 00000000 fc:01 4066505                    /lib/x86_64-linux-gnu/libpthread-2.17.so
Making check in compat
make[1]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/compat'
Making check in util
make[1]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/util'
make[1]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/util'
Making check in geom
make[1]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom'
Making check in .
make[2]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom'
make[2]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom'
Making check in Cholla
make[2]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/facetbool'
make[2]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/facetbool'
make[2]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/facet'
make[2]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/virtual'
make[2]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/virtual'
Making check in OCC
make[2]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/OCC'
make[2]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom/OCC'
make[1]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/geom'
Making check in init
make[1]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/init'
make[1]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/init'
Making check in .
make[1]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC'
make[1]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC'
Making check in itaps
make[1]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make  check-recursive
make[2]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
Making check in .
make[3]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make  chaman test_edge_orient   testgeom_occ copy_attrib
make[4]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make[4]: `test_edge_orient' is up to date.
make[4]: `testgeom_occ' is up to date.
make[4]: `copy_attrib' is up to date.
make[4]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make  check-TESTS
make[5]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
../../test-driver: line 95: 24577 Aborted                 (core dumped) "$@" > $log_file 2>&1
FAIL: test_edge_orient
../../test-driver: line 95: 24584 Aborted                 (core dumped) "$@" > $log_file 2>&1
FAIL: testgeom_occ
../../test-driver: line 95: 24591 Aborted                 (core dumped) "$@" > $log_file 2>&1
FAIL: copy_attrib
make[6]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make  all-recursive
make[7]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
Making all in .
make[8]: Entering directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make[8]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make[7]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make[6]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
Testsuite summary for CGMA 13.1.1
# TOTAL: 3
# PASS:  0
# SKIP:  0
# XFAIL: 0
# FAIL:  3
# XPASS: 0
# ERROR: 0
See itaps/test-suite.log
make[5]: *** [test-suite.log] Error 1
make[5]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make[4]: *** [check-TESTS] Error 2
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make[1]: *** [check] Error 2
make[1]: Leaving directory `/home/wilsonp/UW/research/software/cgm/bld_13.1.1_OCC/itaps'
make: *** [check-recursive] Error 1
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140325/0c45039d/attachment-0002.bin>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140325/0c45039d/attachment-0003.bin>
