[MOAB-dev] commit/MOAB: danwu: Applied error handling code to parallel read for testing. If a file does not exist, or it is not recognized by MOAB, error messages and stack traces will be printed out (examples/TestErrorHandlingPar.cpp is updated to demonstrate this feature).
    commits-noreply at bitbucket.org
    Tue Feb 18 17:04:04 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/e9651b84b830/
Changeset:   e9651b84b830
Branch:      error_handling_enhancement
User:        danwu
Date:        2014-02-19 00:03:41
Summary:     Applied error handling code to parallel read for testing. If a file does not exist, or it is not recognized by MOAB, error messages and stack traces will be printed out (examples/TestErrorHandlingPar.cpp is updated to demonstrate this feature).
Affected #:  3 files
diff --git a/examples/TestErrorHandlingPar.cpp b/examples/TestErrorHandlingPar.cpp
index 5245349..eed938c 100644
--- a/examples/TestErrorHandlingPar.cpp
+++ b/examples/TestErrorHandlingPar.cpp
@@ -2,10 +2,10 @@
  * Description: Demonstrates enhanced error handling of parallel MOAB.\n
  * This example tests MOAB's trace back error handler in parallel.\n
- * <b>To run</b>: mpiexec -np 4 ./TestErrorHandlingPar \n
+ * <b>To run</b>: mpiexec -np <n> ./TestErrorHandlingPar \n
-#include "moab/Core.hpp" // Note, moab::Core is not used in this example
+#include "moab/Core.hpp"
 #ifdef USE_MPI
 #include "moab_mpi.h"
@@ -13,6 +13,7 @@
 using namespace moab;
+// Functions that create and handle a contrived error
 // Call hierarchy: A calls B, and B calls C
 #ifdef USE_ERROR_INFO_CLASS
 ErrorInfo FunctionC(int rank)
@@ -68,14 +69,74 @@ ErrorCode FunctionA(int rank)
   return MB_SUCCESS;
+#endif
+#ifdef USE_ERROR_INFO_CLASS
 // In this test case, MB_FILE_WRITE_ERROR is returned by FunctionC in each processor
-ErrorCode TestErrorHandlingPar(int rank)
+ErrorInfo TestErrorHandlingPar_1()
+  int rank = 0;
+#ifdef USE_MPI
+  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+#endif
+  ErrorInfo err_info = FunctionA(rank);CHK_ERR(err_info);
+  return ERROR_INFO_SUCCESS;
+#else
+// In this test case, MB_FILE_WRITE_ERROR is returned by FunctionC in each processor
+ErrorCode TestErrorHandlingPar_1()
+  int rank = 0;
+#ifdef USE_MPI
+#endif
   ErrorCode err_code = FunctionA(rank);CHK_ERR(err_code);
   return MB_SUCCESS;
+// In this test case, a real error MB_FILE_DOES_NOT_EXIST is returned by MOAB
+ErrorCode TestErrorHandlingPar_2()
+  Core moab;
+  Interface& mb = moab;
+  std::string opts;
+#ifdef USE_MPI
+  // Use parallel options
+  opts = std::string(";;PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL");
+#else
+  opts = std::string(";;");
+#endif
+  // Load a file that does not exist
+  ErrorCode rval = mb.load_file("no_such_file.nc", NULL, opts.c_str());CHK_ERR(rval);
+  return MB_SUCCESS;
+// In this test case, a real error MB_INDEX_OUT_OF_RANGE is returned by MOAB
+ErrorCode TestErrorHandlingPar_3()
+  Core moab;
+  std::string opts;
+#ifdef USE_MPI
+#else
+#endif
+  // Load a file that is not recognized by MOAB
+  ErrorCode rval = mb.load_file("TestErrorHandlingPar.cpp", NULL, opts.c_str());CHK_ERR(rval);
 #endif
 int main(int argc, char** argv)
@@ -86,11 +147,14 @@ int main(int argc, char** argv)
   MBErrorHandler_Init();
-  int rank = 0;
-#ifdef USE_MPI
-  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  TestErrorHandlingPar_1();
+#else
+  TestErrorHandlingPar_2();
+  TestErrorHandlingPar_3();
 #endif
-  TestErrorHandlingPar(rank);
   MBErrorHandler_Finalize();
diff --git a/src/Core.cpp b/src/Core.cpp
index 8012355..fed3285 100644
--- a/src/Core.cpp
+++ b/src/Core.cpp
@@ -479,10 +479,12 @@ ErrorCode Core::load_file( const char* file_name,
     else if (rval != MB_ENTITY_NOT_FOUND)
       return rval;
-    if (set_tag_name && num_set_tag_vals)
-      rval = ReadParallel(this,pcomm).load_file( file_name, file_set, opts, &sl );
-    else
-      rval = ReadParallel(this,pcomm).load_file( file_name, file_set, opts );
+    if (set_tag_name && num_set_tag_vals) {
+      rval = ReadParallel(this,pcomm).load_file( file_name, file_set, opts, &sl );CHK_ERR(rval);
+    else {
+      rval = ReadParallel(this,pcomm).load_file( file_name, file_set, opts );CHK_ERR(rval);
 #else
     mError->set_last_error( "PARALLEL option not valid, this instance"
                             " compiled for serial execution.\n" );
@@ -546,8 +548,10 @@ ErrorCode Core::serial_load_file( const char* file_name,
   status = stat(file_name, &stat_data);
 #endif
   if (status) {
     mError->set_last_error( "%s: %s", file_name, strerror(errno) );
-    //return MB_FILE_DOES_NOT_EXIST;
+    return MB_FILE_DOES_NOT_EXIST;
     SET_ERR_STR(MB_FILE_DOES_NOT_EXIST, file_name << ": " << strerror(errno));
 #if defined(WIN32) || defined(WIN64) || defined(MSC_VER)
diff --git a/src/parallel/ReadParallel.cpp b/src/parallel/ReadParallel.cpp
index fe4ed55..9d45a70 100644
--- a/src/parallel/ReadParallel.cpp
+++ b/src/parallel/ReadParallel.cpp
@@ -234,7 +234,7 @@ ErrorCode ReadParallel::load_file(const char **file_names,
                    subset_list, file_id_tag,
                    reader_rank, cputime,
                    resolve_dim, shared_dim,
-                   ghost_dim, bridge_dim, num_layers, addl_ents);
+                   ghost_dim, bridge_dim, num_layers, addl_ents);CHK_ERR(result);
   if (parallel_mode == POPT_BCAST_DELETE && !is_reader)
     opts.mark_all_seen();
@@ -519,17 +519,23 @@ ErrorCode ReadParallel::load_file(const char **file_names,
     if (MB_SUCCESS != tmp_result) {
       result = tmp_result;
       if (myPcomm->proc_config().proc_size() != 1) {
         std::ostringstream ostr;
         ostr << "Failed in step " << ParallelActionsNames[*vit] << std::endl;
         std::string tmp_str;
         if (MB_SUCCESS == mbImpl->get_last_error(tmp_str)) ostr << tmp_str << std::endl;
         RR(ostr.str());
+        if (MB_SUCCESS != result) {
+          SET_ERR_STR(result, "Failed in step " << ParallelActionsNames[*vit]);
       break;
     if (cputime) act_times[i] = MPI_Wtime();
+  CHK_ERR(result);
   if (use_id_tag) {
     ErrorCode tmp_result = mbImpl->tag_delete( id_tag );
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
