[MOAB-dev] commit/MOAB: iulian07: enhance crystal router example
commits-noreply at bitbucket.org
Wed Feb 19 11:15:51 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/8aa5ee497b10/
Changeset: 8aa5ee497b10
Branch: master
User: iulian07
Date: 2014-02-19 18:09:19
Summary: enhance crystal router example
add some options for the routing;
use ProgOptions class to parse input parameters
print timing information, and print tuples sent/received for one proc
only if requested
input the number of tuples sent from one task to a designated task
input the number of tasks each task will communicate with
the example could be used as a stress test and to measure communication
performance
the communication load is not balanced, some tasks receive/send more than
others; this is intentional, and part of the stress test
some receiving buffers will have to reallocate memory.
The reals sent are not verified, only the long data is checked for
what we expect to receive.
Affected #: 1 file
diff --git a/examples/CrystalRouterExample.cpp b/examples/CrystalRouterExample.cpp
index 200f012..83a1e7c 100644
--- a/examples/CrystalRouterExample.cpp
+++ b/examples/CrystalRouterExample.cpp
@@ -18,12 +18,14 @@
* the example needs to be launched in parallel.
* Every proc will build a list of tuples, that will be send to a few procs;
+ * In general, we will send to num_comms tasks, and about num_tuples to each task
+ * We vary num_comms and num_tuples for processor
- * every proc will send 1 tuple, to proc rank + 1 and rank + rank*(size-1)+2 , with value
- * 10000 * send + 100* rank
+ * we will send long ints of the form
+ * 100000 * send + 1000* rank +j, where j is the index of tuple
- * at the receive, we verify we received
- * 10000 * rank + 100 * from
+ * after routing, we verify we received
+ * 100000 * rank + 1000 * from
* For some reportrank we also print the tuples.
@@ -35,13 +37,20 @@
/** @example CrystalRouterExample.cpp \n
* \brief generalized gather scatter using tuples \n
- * <b>To run</b>: mpiexec -np <n> CrystalRouterExample [reportrank] \n
+ * <b>To run</b>: mpiexec -np <n> CrystalRouterExample -r [reportrank] -t [num_tuples] -n [num_comms] \n
#include "moab/ProcConfig.hpp"
#include "moab/TupleList.hpp"
+#include "moab/ProgOptions.hpp"
+#include <time.h>
#include <iostream>
+#include <sstream>
+const char BRIEF_DESC[] =
+ "Example of gather scatter with tuple lists \n";
+std::ostringstream LONG_DESC;
using namespace moab;
using namespace std;
@@ -50,56 +59,94 @@ int main(int argc, char **argv)
MPI_Init(&argc, &argv);
- int reportrank = 1;
- if (argc>1)
- reportrank = atoi(argv[1]);
ProcConfig pc(MPI_COMM_WORLD);
int size = pc.proc_size();
int rank = pc.proc_rank();
- if (reportrank==rank)
+ // start copy
+ LONG_DESC << "This program does a gather scatter with a list of tuples. \n"
+ " It tries to see how much communication costs in terms of time and memory. \n"
+ << "It starts with creating a list of tuples to be sent from each processor, \n to a list of other processors.\n" <<
+ "The number of tuples and how many tasks to communicate to are controlled by input parameters.\n" <<
+ "After communication, we verify locally if we received what we expected. \n";
+ ProgOptions opts(LONG_DESC.str(), BRIEF_DESC);
+ // how many procs communicate to current proc, on average (we will vary that too)
+ int num_comms = 2;
+ opts.addOpt<int>("num_comms,n",
+ "each task will send to about num_comms other tasks some tuples (default 2)", &num_comms);
+ int num_tuples = 4;
+ opts.addOpt<int>("num_tuples,t",
+ "each task will send to some task about num_tuples tuples (default 4)", &num_tuples);
+ int reportrank = size+1;
+ opts.addOpt<int>("reporting_rank,r",
+ "this rank will report the tuples sent and the tuples received; it could be higher than num_procs, then no reporting"
+ ,&reportrank);
+ opts.parseCommandLine(argc, argv);
+ if (rank==reportrank || (reportrank>=size && rank == 0))
- std::cout << " there are " << size << " procs in example\n";
+ std::cout << " There are " << size << " tasks in example.\n";
+ std::cout<< " We will send groups of " << num_tuples << " from each task towards " <<
+ num_comms << " other tasks.\n";
- // send some data from proc i to i+n/2, also to i +n/2+1 modulo n, wher en is num procs
+ // send some data from proc i to i+n/2, also to i +n/2+1 modulo n, where n is num procs
gs_data::crystal_data *cd = pc.crystal_router();
- TupleList tl;
+ long total_n_tuples = num_comms*num_tuples;
- // at most 100 to send
+ // vary the number of tasks to send to, and the number of tuples to send
+ if (rank<size/2)
+ num_comms--;
+ else
+ num_comms++;
+ if (rank<size/3)
+ num_tuples*=2;
+ else if (rank>size-size/3)
+ num_tuples/=2;
+ TupleList tl;
+ // at most num_tuples* num_comms to send
// we do a preallocate with this; some tuples on some processors might need more memory, to be able
- // to grow locally; 100 is a very large number for this example, considering that each task sends only
- // 2 tuples. Some tasks might receive more tuples though, and in the process, some might grow more than
+ // to grow locally; Some tasks might receive more tuples though, and in the process, some might grow more than
// others. By doing these logP sends/receives, we do not grow local memory too much.
- tl.initialize(1, 1, 0, 1, 100);
+ tl.initialize(1, 1, 0, 1, num_tuples*num_comms);
tl.enableWriteAccess();
- // form 2 tuples, send to rank+1 and rank+2 (mod size)
+ // form num_tuples*num_comms tuples, send to various ranks
unsigned int n = tl.get_n();
- int sendTo = rank+1;
- sendTo = sendTo%size;
- long intToSend = 100*rank + 10000*sendTo;
- tl.vi_wr[n]= sendTo;
- tl.vl_wr[n]= intToSend;
- tl.vr_wr[n]= 100.*rank;
- tl.inc_n();
- n = tl.get_n();
- sendTo = rank+(rank+1)*rank+2;// just some number relatively different from rank
- intToSend = 100*rank + 10000*sendTo;
- tl.vr_wr[n]= 1000.*rank;
- tl.inc_n();
+ for (int i=0; i<num_comms; i++)
+ int sendTo = rank+i*size/2+1;// spread out the send to, for a stress-like test
+ sendTo = sendTo%size;//
+ long intToSend = 1000*rank + 100000*sendTo;
+ for (int j=0; j<num_tuples; j++)
+ n = tl.get_n();
+ tl.vi_wr[n]= sendTo;
+ tl.vl_wr[n]= intToSend+j;
+ tl.vr_wr[n]= 10000.*rank+j;
+ tl.inc_n();
+ if (rank==reportrank)
std::cout << "rank " << rank << "\n";
tl.print(" before sending");
- // all communication happens here:
+ clock_t tt = clock();
+ // all communication happens here; no mpi calls for the user
ErrorCode rval = cd->gs_transfer(1,tl,0);
if (MB_SUCCESS!= rval)
@@ -107,23 +154,34 @@ int main(int argc, char **argv)
std::cout << "error in tuple transfer\n";
+ double secs=0;
+ secs = (clock() - tt) / (double) CLOCKS_PER_SEC;
tl.print(" after transfer");
// check that all tuples received have the form 10000* rank + 100*from
unsigned int received = tl.get_n();
- for (int i=0; i<received; i++)
+ for (int i=0; i<(int)received; i++)
int from = tl.vi_rd[i];
long valrec = tl.vl_rd[i];
- int remainder = valrec -10000*rank -100*from;
- if (remainder != 0 )
+ int remainder = valrec -100000*rank -1000*from;
+ if (remainder < 0 || remainder >= num_tuples*4)
std::cout << " error: tuple " << i << " received at proc rank " << rank << " from proc " << from << " has value " <<
valrec << " remainder " << remainder << "\n";
+ std::cout << "communication of about "<< total_n_tuples << " tuples/per proc took "
+ << secs << " seconds" << std::endl;
+ tt = clock();
MPI_Finalize();
return 0;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
