[MOAB-dev] commit/MOAB: danwu: Minor changes to SET_ERR macros.
commits-noreply at bitbucket.org
Tue Feb 18 16:33:12 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/2e34a553893c/
Changeset: 2e34a553893c
Branch: error_handling_enhancement
User: danwu
Date: 2014-02-18 23:32:57
Summary: Minor changes to SET_ERR macros.
Affected #: 3 files
diff --git a/examples/TestErrorHandling.cpp b/examples/TestErrorHandling.cpp
index f7f3cc9..0ea0fa4 100644
--- a/examples/TestErrorHandling.cpp
+++ b/examples/TestErrorHandling.cpp
@@ -26,13 +26,13 @@ ErrorInfo FunctionC(int n)
else if (2 == n) {
// Simulate MB_FILE_WRITE_ERROR
- SET_ERR1(MB_FILE_WRITE_ERROR, "FunctionC() created a contrived error MB_FILE_WRITE_ERROR");
+ SET_ERR(MB_FILE_WRITE_ERROR, "FunctionC() created a contrived error MB_FILE_WRITE_ERROR");
else if (3 == n) {
// Simulate MB_NOT_IMPLEMENTED
ErrorInfo err_info(MB_NOT_IMPLEMENTED);
err_info << "n = " << n << ", FunctionC() created a contrived error MB_NOT_IMPLEMENTED (this message is built with C++ streaming)";
- SET_ERR(err_info);
+ SET_ERR1(err_info);
return ERROR_INFO_SUCCESS;
diff --git a/examples/TestErrorHandlingPar.cpp b/examples/TestErrorHandlingPar.cpp
index 99f9c9f..5245349 100644
--- a/examples/TestErrorHandlingPar.cpp
+++ b/examples/TestErrorHandlingPar.cpp
@@ -20,7 +20,7 @@ ErrorInfo FunctionC(int rank)
ErrorInfo err_info(MB_FILE_WRITE_ERROR);
err_info << "FunctionC() created a contrived error MB_FILE_WRITE_ERROR in processor " << rank;
diff --git a/src/moab/ErrorHandler.hpp b/src/moab/ErrorHandler.hpp
index f387f29..99f6daa 100644
--- a/src/moab/ErrorHandler.hpp
+++ b/src/moab/ErrorHandler.hpp
@@ -118,11 +118,16 @@ ErrorCode MBError(int line, const char* func, const char* file, const char* dir,
#endif
#ifdef USE_ERROR_INFO_CLASS
-#define SET_ERR(err_info) \
+#define SET_ERR(err_code, err_msg) \
+ return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, ErrorInfo(err_code, err_msg), MB_ERROR_TYPE_NEW)
+#define SET_ERR1(err_info) \
return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_info, MB_ERROR_TYPE_NEW)
-#define SET_ERR1(err_code, err_msg) \
- return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, ErrorInfo(err_code, err_msg), MB_ERROR_TYPE_NEW)
+#define SET_ERR_STR(err_code, err_msg_str) \
+ ErrorInfo err_info; \
+ err_info << err_msg_str; \
+ return MBError(__LINE__, __func__, __FILENAME__, __SDIR__, err_info, MB_ERROR_TYPE_NEW)
#define CHK_ERR(err_info) \
do { \
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
