[MOAB-dev] Fwd: [cgma-dev] Adapting Meshkit to Stretched Grid
    Jane Hu
    janejhu at gmail.com
    Tue Jan 14 13:28:26 CST 2014
Forwarding to moab and meshkit dev for better assistance on this.
Jane
---------- Forwarded message ----------
Date: Tue, Jan 14, 2014 at 1:02 PM
Subject: [cgma-dev] Adapting Meshkit to Stretched Grid
To: cgma-dev at mcs.anl.gov
Hello,
I am a researcher at George Washington University, aiming to use MeshKit to
to find volume fractions for a fluid-structure interaction problem, which I
will solve using an in-house immersed boundary CFD code. The surface
geometry that I plan to use is in .stl format, so my understanding is that
I do not need to configure the MeshKit with the "iGeom" option. I am able
to configure the MeshKit with iMesh successfully, following all steps on
the "How do I build MeshKit for EBMesh" page, except the final step for
running the test executable, for I have not included the iGeom software in
the configuration which I assume the test requires.
My question now is as follows: the 3D cartesian fluid grid that I will use
on my fluid simulation is stretched in the vertical and streamwise
directions (finer grid near the wall, for example). My understanding is
that this should not be a problematic change to implement into the volume
fraction solver, but I am unsure of how to approach the alterations. As
always, any assistance and insight that you can provide is greatly
appreciated.
Sincerely,
Alexander Vizard
avizard at gwmail.gwu.edu
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140114/7232d25c/attachment.html>
