[MOAB-dev] commit/MOAB: tautges: Adding IBM bgq compile options.
    commits-noreply at bitbucket.org
    Fri Jan 10 14:34:11 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b012aa0a2064/
Changeset:   b012aa0a2064
Branch:      master
User:        tautges
Date:        2014-01-10 21:34:04
Summary:     Adding IBM bgq compile options.
Affected #:  1 file
diff --git a/config/compiler.m4 b/config/compiler.m4
index ce83a5f..4787100 100644
--- a/config/compiler.m4
+++ b/config/compiler.m4
@@ -548,6 +548,8 @@ case "$cc_compiler:$host_cpu" in
       bgq)
         FATHOM_CC_32BIT=-q32
         FATHOM_CC_64BIT=-q64
+	FATHOM_CC_SPECIAL=-qarch=qp
+	FATHOM_CXX_SPECIAL="-qarch=qp -qpic=large -qmaxmem=-1"
         AR="ar"
         NM="nm -B"
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
