[MOAB-dev] commit/MOAB: iulian07: concavity fixes for parallel	transport
    commits-noreply at bitbucket.org
    Fri Jan 10 14:26:20 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/eb4b9ff5b775/
Changeset:   eb4b9ff5b775
Branch:      master
User:        iulian07
Date:        2014-01-10 19:30:43
Summary:     concavity fixes for parallel transport
the decomposed polygons just need to know their
arrival poly;
either as a correlation red poly, or the global id.
Global id is used for remote red cells
Affected #:  1 file
diff --git a/tools/mbcslam/CslamUtils.cpp b/tools/mbcslam/CslamUtils.cpp
index c5417c1..43668a6 100644
--- a/tools/mbcslam/CslamUtils.cpp
+++ b/tools/mbcslam/CslamUtils.cpp
@@ -926,6 +926,14 @@ ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
            MB_TAG_DENSE, &dumH);
   if(rval==MB_TAG_NOT_FOUND)
     corrTag = 0;
+  Tag gidTag;
+  rval = mb->tag_get_handle("GLOBAL_ID", 1, MB_TYPE_INTEGER,
+        gidTag, MB_TAG_DENSE);
+  if(rval!=MB_SUCCESS)
+    return rval;
   std::vector<double> coords;
   coords.resize(3*MAXEDGES); // at most 10 vertices per polygon
   // we should create a queue with new polygons that need processing for reflex angles
@@ -959,6 +967,10 @@ ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
       if (MB_SUCCESS != rval)
         return rval;
+    int gid=0;
+    rval = mb->tag_get_data(gidTag, &eh, 1, &gid);
+    if (MB_SUCCESS != rval)
+      return rval;
     coords.resize(3 * num_nodes);
     if (num_nodes < 4)
       continue; // if already triangles, don't bother
@@ -1021,6 +1033,9 @@ ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
             return rval;
+        rval = mb->tag_set_data(gidTag, &newElement, 1, &gid);
+          return rval;
         if (num_nodes == 4)
           // create another triangle
@@ -1046,6 +1061,9 @@ ErrorCode enforce_convexity(Interface * mb, EntityHandle lset, int my_rank)
             return rval;
+           return rval;
         mb->remove_entities(lset, &eh, 1);
         brokenPolys++;
         /*std::cout<<"remove: " ;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
