[MOAB-dev] Entity set format
    Tim Tautges (ANL)
    tautges at mcs.anl.gov
    Thu Jan  9 16:16:57 CST 2014
Remember though that that's file format, which we don't generally make any promises about in terms of stability.
I'm not sure what the source is of "vertex_filed" below, but that sounds like a tag name we've used to put data on
vertices; storage of that type isn't related to entity sets, it's tagged directly on vertices.  For a bit more detail on
how tag data is stored, see http://www.mcs.anl.gov/~fathom/moab-docs/html/contents.html#twofour.
- tim
On 01/09/2014 04:09 PM, Grindeanu, Iulian R. wrote:
> Hello,
> Did you see this?
> http://trac.mcs.anl.gov/projects/ITAPS/wiki/MOAB/h5m
> Iulian
> *From:* kanaev at ibrae.ac.ru [kanaev at ibrae.ac.ru]
> *Sent:* Thursday, January 09, 2014 4:05 PM
> *To:* Grindeanu, Iulian R.
> *Cc:* MOAB dev
> *Subject:* Entity set format
> Hello MOAB-dev!
> Where can i actually find more or less detailed info about "contents" and "list" tables? (e.g. how tag data
> "vertex_field" for all nodes is stored there)
> Anton
