[MOAB-dev] moab-4.6.2
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Fri Jan  3 13:33:43 CST 2014
The cmake based build is incomplete and wont succeed in the
configuration yet. I have not updated my branch or merged the
outstanding changes fully to Fathom to enable this route. On cygwin,
if you can get MPI and HDF5 compiled cleanly, then hopefully the
autoconf based configure system should work well as is. We might have
to specify the right flags for MSVC but as Tim mentioned, not many
people have tried this recently and so any updates on what is broken
can help us fix things better.
Vijay
On Fri, Jan 3, 2014 at 1:11 PM, Tim Tautges (ANL) <tautges at mcs.anl.gov> wrote:
> Hi Hangbok,
>   We haven't supported MOAB on Windows up to this point, and I'm not aware
> of anybody who has built it on cygwin.  That said, there is cmake-based
> support, which may work on windows.  I suggest trying that first.  If you
> have problems with the cmake-based build, please email them to this list.
> I'd also be interested if you got that to succeed, as we haven't tried that
> ourselves.  Thanks.
> - tim
> On 12/30/2013 03:52 PM, Choi, Hangbok wrote:
>> Hi
>> I have downloaded moab-4.6.2 but it seems to be difficult to install it.
>> The biggest problem is that I am not familiar with this operating system.
>> Is this module work in Window system. I couldn't find a command equivalent
>> to "autoreconf".
>> Is it possible to use "cygwin" for this?
>> In the unix system the "autoreconf" and "./confiure" worked Based on
>> "Mesh-Oriented datABase (MOAB) Version 4.0
>> User's Guide" by T. J. Tautges et al.
>> In page 20 step 4. './confiyre -prefix=/home/...  " looks fine.
>> But I couldn't understand what to do with step b) and C) regarding hdf5
>> and netCDF. Should I go through all these steps. Do you have any examples of
>> commands actually used for the installation.
>> I would appreciate you can give me any guideline.
>> Sincerely
>> Hangbok Choi
>> General Atomics
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
