[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Mon Jan 6 13:51:14 CST 2014
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/1491a201d7f2/
Changeset:   1491a201d7f2
Branch:      None
User:        iulian07
Date:        2014-01-06 19:12:08
Summary:     robustness issues with intersection
appeared at diffusion example at time step 5;
2 very close vertices, on departure and arrival meshes
were left outside everything:
intersection of edges is very strict (interval [0, 1]
in a normalized segment)
and interior points in a convex poly is also too strict
(comparing areas with 0.)
this fix relaxes the interior issues in convex polygon
by introducing an epsilon square (epsilon_area) which
is set at the same time with distance epsilon (epsilon_1)
so area check is now area < -epsilon_area
still need to think about interior segment normalization
Affected #:  7 files
diff --git a/tools/mbcslam/CslamUtils.cpp b/tools/mbcslam/CslamUtils.cpp
index 6cca02d..e806d61 100644
--- a/tools/mbcslam/CslamUtils.cpp
+++ b/tools/mbcslam/CslamUtils.cpp
@@ -30,7 +30,7 @@ double area2D(double *a, double *b, double *c)
   // (b-a)x(c-a) / 2
   return ((b[0] - a[0]) * (c[1] - a[1]) - (b[1] - a[1]) * (c[0] - a[0])) / 2;
-int borderPointsOfXinY2(double * X, int nX, double * Y, int nY, double * P, int side[MAXEDGES])
+int borderPointsOfXinY2(double * X, int nX, double * Y, int nY, double * P, int side[MAXEDGES], double epsilon_area)
   // 2 triangles, 3 corners, is the corner of X in Y?
   // Y must have a positive area
@@ -54,7 +54,7 @@ int borderPointsOfXinY2(double * X, int nX, double * Y, int nY, double * P, int
       double area2 = (B[0] - A[0]) * (C[1] - A[1])
           - (C[0] - A[0]) * (B[1] - A[1]);
-      if (area2 < 0.)
+      if (area2 < -epsilon_area)
         inside = 0;
         break;
diff --git a/tools/mbcslam/CslamUtils.hpp b/tools/mbcslam/CslamUtils.hpp
index 05775df..66f4e99 100644
--- a/tools/mbcslam/CslamUtils.hpp
+++ b/tools/mbcslam/CslamUtils.hpp
@@ -21,7 +21,7 @@ namespace moab
 double dist2(double * a, double * b);
 double area2D(double *a, double *b, double *c);
-int borderPointsOfXinY2(double * X, int nX, double * Y, int nY, double * P, int side[MAXEDGES]);
+int borderPointsOfXinY2(double * X, int nX, double * Y, int nY, double * P, int side[MAXEDGES], double epsilon_area);
 int SortAndRemoveDoubles2(double * P, int & nP, double epsilon);
 // the marks will show what edges of blue intersect the red
diff --git a/tools/mbcslam/Intx2Mesh.cpp b/tools/mbcslam/Intx2Mesh.cpp
index c1da3fd..625a442 100644
--- a/tools/mbcslam/Intx2Mesh.cpp
+++ b/tools/mbcslam/Intx2Mesh.cpp
@@ -18,7 +18,7 @@
 namespace moab {
-Intx2Mesh::Intx2Mesh(Interface * mbimpl):mb(mbimpl), parcomm(NULL), myTree(NULL), remote_cells(NULL)
+Intx2Mesh::Intx2Mesh(Interface * mbimpl): mb(mbimpl), parcomm(NULL), remote_cells(NULL)
   dbg_1=0;
   box_error=0;
diff --git a/tools/mbcslam/Intx2Mesh.hpp b/tools/mbcslam/Intx2Mesh.hpp
index 2daa052..d54b0b5 100644
--- a/tools/mbcslam/Intx2Mesh.hpp
+++ b/tools/mbcslam/Intx2Mesh.hpp
@@ -34,7 +34,6 @@ namespace moab {
 // forward declarations
 class ParallelComm;
-class AdaptiveKDTree;
 class TupleList;
 class Intx2Mesh
@@ -68,7 +67,7 @@ public:
   ErrorCode GetOrderedNeighbors(EntityHandle set, EntityHandle quad,
       EntityHandle neighbors[MAXEDGES]);
-  void SetErrorTolerance(double eps) { epsilon_1=eps;}
+  void SetErrorTolerance(double eps) { epsilon_1=eps; epsilon_area = eps*eps/2;}
   //void SetEntityType (EntityType tp) { type=tp;}
@@ -97,7 +96,8 @@ public:
   ErrorCode correct_intersection_points_positions();
-  void enable_debug() {dbg_1=1;};
+  void enable_debug()  {dbg_1 = 1;}
+  void disable_debug() {dbg_1 = 0;}
 protected: // so it can be accessed in derived classes, InPlane and OnSphere
   Interface * mb;
@@ -139,10 +139,10 @@ protected: // so it can be accessed in derived classes, InPlane and OnSphere
   std::vector<std::vector<EntityHandle> *> extraNodesVec;
   double epsilon_1;
+  double epsilon_area;
   ParallelComm * parcomm;
-  AdaptiveKDTree *myTree;
   std::vector<double> allBoxes;
   double box_error;
   /* \brief Local root of the kdtree */
diff --git a/tools/mbcslam/Intx2MeshInPlane.cpp b/tools/mbcslam/Intx2MeshInPlane.cpp
index 9fb2a94..2ddea3a 100644
--- a/tools/mbcslam/Intx2MeshInPlane.cpp
+++ b/tools/mbcslam/Intx2MeshInPlane.cpp
@@ -106,7 +106,7 @@ int Intx2MeshInPlane::computeIntersectionBetweenRedAndBlue(EntityHandle red, Ent
   int side[MAXEDGES] = { 0 };// this refers to what side? blue or red?
-  int extraPoints = borderPointsOfXinY2(blueCoords2D, nsBlue, redCoords2D, nsRed, &(P[2 * nP]), side);
+  int extraPoints = borderPointsOfXinY2(blueCoords2D, nsBlue, redCoords2D, nsRed, &(P[2 * nP]), side, epsilon_area);
   if (extraPoints >= 1)
     for (int k = 0; k < nsBlue; k++)
@@ -133,7 +133,7 @@ int Intx2MeshInPlane::computeIntersectionBetweenRedAndBlue(EntityHandle red, Ent
   nP += extraPoints;
-  extraPoints = borderPointsOfXinY2(redCoords2D, nsRed, blueCoords2D, nsBlue, &(P[2 * nP]), side);
+  extraPoints = borderPointsOfXinY2(redCoords2D, nsRed, blueCoords2D, nsBlue, &(P[2 * nP]), side, epsilon_area);
     for (int k = 0; k < nsRed; k++)
diff --git a/tools/mbcslam/Intx2MeshOnSphere.cpp b/tools/mbcslam/Intx2MeshOnSphere.cpp
index a1d786b..ef4d219 100644
--- a/tools/mbcslam/Intx2MeshOnSphere.cpp
+++ b/tools/mbcslam/Intx2MeshOnSphere.cpp
@@ -124,7 +124,7 @@ int Intx2MeshOnSphere::computeIntersectionBetweenRedAndBlue(EntityHandle red, En
     return 1; // some unforeseen error
@@ -144,7 +144,7 @@ int Intx2MeshOnSphere::computeIntersectionBetweenRedAndBlue(EntityHandle red, En
   nP += extraPoints;
@@ -370,10 +370,11 @@ int Intx2MeshOnSphere::findNodes(EntityHandle red, int nsRed, EntityHandle blue,
       std::stringstream fff;
       fff << "file0" <<  count<< ".vtk";
-          mb->write_mesh(fff.str().c_str(), &outSet, 1);
+         mb->write_mesh(fff.str().c_str(), &outSet, 1);
+  disable_debug();
   delete[] foundIds;
   foundIds = NULL;
   return 0;
diff --git a/tools/mbcslam/intx_on_sphere_test.cpp b/tools/mbcslam/intx_on_sphere_test.cpp
index 350a39b..360aa28 100644
--- a/tools/mbcslam/intx_on_sphere_test.cpp
+++ b/tools/mbcslam/intx_on_sphere_test.cpp
@@ -69,10 +69,12 @@ int main(int argc, char* argv[])
     return 1;
   Intx2MeshOnSphere  worker(mb);
-  double radius= 6. * sqrt(3.) / 2; // input
-  worker.SetErrorTolerance(radius*1.e-8);
+  worker.SetErrorTolerance(R*1.e-8);
   //worker.SetEntityType(moab::MBQUAD);
-  worker.SetRadius(radius);
+  worker.SetRadius(R);
+  //worker.enable_debug();
   rval = worker.intersect_meshes(sf1, sf2, outputSet);
   //compute total area with 2 methods
@@ -81,11 +83,15 @@ int main(int argc, char* argv[])
   rval = mb->write_mesh(newFile, &outputSet, 1);
   if (MB_SUCCESS != rval)
     return 1;
-  double area_method1 = area_on_sphere_lHuiller(mb, outputSet, radius);
-  double area_method2 = area_on_sphere(mb, outputSet, radius);
+  double initial_area = area_on_sphere_lHuiller(mb, sf1, R);
+  double area_method1 = area_on_sphere_lHuiller(mb, outputSet, R);
+  double area_method2 = area_on_sphere(mb, outputSet, R);
+  std::cout << "initial area: " << initial_area << "\n";
   std::cout<< " area with l'Huiller: " << area_method1 << " with Girard: " << area_method2<< "\n";
-  std::cout << " relative difference: " << fabs(area_method1-area_method2)/area_method1 << "\n";
+  std::cout << " relative difference areas " << fabs(area_method1-area_method2)/area_method1 << "\n";
+  std::cout << " relative error " << fabs(area_method1-initial_area)/area_method1 << "\n";
   return 0;
https://bitbucket.org/fathomteam/moab/commits/ec2239392ca2/
Changeset:   ec2239392ca2
Branch:      master
User:        iulian07
Date:        2014-01-06 20:44:27
Summary:     modify imesh example
create the euler mesh before calling the wrapper
so the wrapper takes as input the euler mesh set
that contains the arrival mesh; departure point
is defined as DP tag
A tracer field is also a tag (TracerAverage), a value for
each cell
After calling the wrapper from C (intx_imesh) or from Fortran
(advection), the tracer is updated and saved to a new file)
All this works in parallel too
with
mpiexec -np 2 intx_imesh
or
mpiexec -np 2 advection
(need to prepare the input file using create_dp )
Affected #:  3 files
diff --git a/tools/mbcslam/advection.F90 b/tools/mbcslam/advection.F90
index fb102ba..ad92f88 100644
--- a/tools/mbcslam/advection.F90
+++ b/tools/mbcslam/advection.F90
@@ -26,7 +26,7 @@ program advection
      use ISO_C_BINDING
      implicit none
      iMesh_Instance, INTENT(IN) , VALUE :: instance
-     iBase_EntityHandle, INTENT(OUT) :: opEulerSet
+     iBase_EntityHandle, INTENT(IN), VALUE :: opEulerSet
      integer(c_int) , INTENT (OUT) :: ierr
    END SUBROUTINE update_tracer
   END INTERFACE
@@ -35,18 +35,22 @@ program advection
   ! imesh is the instance handle
   iMesh_Instance imesh
-  ! ents, verts will be arrays storing vertex/entity handles
-  iBase_EntityHandle, pointer :: ents, verts
+  ! cells will be storing 2d cells
+  TYPE(C_PTR) cells_ptr
+  iBase_EntityHandle, pointer :: cells(:)
+  INTEGER ents_alloc,  ents_size
   iBase_EntitySetHandle root_set
   iBase_EntitySetHandle opEulerSet
   CHARACTER (LEN=200) options
   CHARACTER (LEN=200) filename
   CHARACTER (LEN=200) optionswrite
   CHARACTER (LEN=200) outname
-  TYPE(C_PTR) :: vertsPtr, entsPtr
+  ! TYPE(C_PTR) :: vertsPtr, entsPtr
   integer rank, sz, ierr
   integer lenopt, lenname
+  integer isList
 #ifdef USE_MPI
   ! local variables for parallel runs
@@ -95,6 +99,24 @@ program advection
               %VAL(lenopt) )  !119) !strlen(options));
   CHECK("fail to load mesh in parallel ")
+  isList = 0
+  call iMesh_createEntSet(%VAL(imesh), %VAL(isList), opEulerSet, ierr)
+  CHECK("fail to create euler set ")
+  ents_alloc = 0
+  ents_size = 0
+  call iMesh_getEntities(%VAL(imesh),%VAL(root_set), &
+   %VAL(iBase_FACE), &
+   %VAL(iMesh_ALL_TOPOLOGIES), cells_ptr, &
+      ents_alloc, ents_size, ierr);
+  CHECK("fail to get 2d entities ")
+  call c_f_pointer(cells_ptr, cells, [ents_size])
+  call iMesh_addEntArrToSet(%VAL(imesh), cells, %VAL(ents_size), &
+      %VAL(opEulerSet), ierr)
   call update_tracer(imesh, opEulerSet, ierr)
   CHECK("fail to update tracer ")
diff --git a/tools/mbcslam/intx_imesh.cpp b/tools/mbcslam/intx_imesh.cpp
index 0c49ac4..cb7b494 100644
--- a/tools/mbcslam/intx_imesh.cpp
+++ b/tools/mbcslam/intx_imesh.cpp
@@ -16,7 +16,7 @@
 #ifdef __cplusplus
 extern "C" {
 #endif
- void update_tracer( iMesh_Instance instance,  iBase_EntitySetHandle * opEulerSet, int * ierr);
+ void update_tracer( iMesh_Instance instance,  iBase_EntitySetHandle eulerSet, int * ierr);
 #ifdef __cplusplus
 } // extern "C"
@@ -71,7 +71,23 @@ int main(int argc, char* argv[]){
   printf("There's %d entity sets here on process rank %d \n", num_sets, rank);
   iBase_EntitySetHandle euler_set;
-  update_tracer( imesh, &euler_set, &ierr);
+  iMesh_createEntSet(imesh, 0, &euler_set, &ierr);
+  IMESH_ASSERT(ierr);
+  iBase_EntityHandle *cells = NULL;
+  int ents_alloc = 0;
+  int ents_size = 0;
+  iMesh_getEntities(imesh, root, iBase_FACE, iMesh_ALL_TOPOLOGIES, &cells,
+      &ents_alloc, &ents_size, &ierr);
+  iMesh_addEntArrToSet(imesh, cells, ents_size, euler_set, &ierr);
+  update_tracer( imesh, euler_set, &ierr);
   IMESH_ASSERT(ierr);
   // write everything
diff --git a/tools/mbcslam/wrap_intx.cpp b/tools/mbcslam/wrap_intx.cpp
index e38c897..b973acf 100644
--- a/tools/mbcslam/wrap_intx.cpp
+++ b/tools/mbcslam/wrap_intx.cpp
@@ -23,25 +23,14 @@ bool debug = false;
 extern "C" {
 #endif
-void update_tracer( iMesh_Instance instance, iBase_EntitySetHandle * opEulerSet, int * ierr)
+void update_tracer( iMesh_Instance instance, iBase_EntitySetHandle imesh_euler_set, int * ierr)
   Range ents;
   moab::Interface * mb =MOABI;
   *ierr =1;
-  ErrorCode rval = mb->get_entities_by_dimension(0, 2, ents);// root 0
-  ERRORV(rval,  "can't get all 2d entities from root");
-  EntityHandle euler_set;
-  //EntityHandle lagr_set;
-  rval = mb->create_meshset(MESHSET_SET, euler_set);
-  ERRORV(rval , "can't create arrival mesh set");
-  *opEulerSet = (iBase_EntitySetHandle)euler_set;
-  rval = mb->add_entities(euler_set, ents);
-  ERRORV(rval , "can't add ents to arrival set");
+  EntityHandle euler_set = (EntityHandle) imesh_euler_set;
@@ -49,7 +38,8 @@ void update_tracer( iMesh_Instance instance, iBase_EntitySetHandle * opEulerSet,
   worker.SetErrorTolerance(gtol);
   EntityHandle covering_lagr_set;
-  rval = mb->create_meshset(MESHSET_SET, covering_lagr_set);
+  ErrorCode rval = mb->create_meshset(MESHSET_SET, covering_lagr_set);
   ERRORV(rval , "can't create covering set ");
   // we need to update the correlation tag and remote tuples
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
