[MOAB-dev] commit/MOAB: iulian07: transport example in imeshp and fortran
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue Dec 31 16:37:30 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/1791bb594f3f/
Changeset:   1791bb594f3f
Branch:      master
User:        iulian07
Date:        2013-12-31 23:33:07
Summary:     transport example in imeshp and fortran
first, add a DP tag to a partitioned mesh using create_dp
then, use intx_imesh or advection to interface with mbcslam intersection
wrap_intx contains the callable c imesh function
fortran example might need cleanup, with respect to passing the
imeshp arguments
Affected #:  4 files
diff --git a/tools/mbcslam/advection.F90 b/tools/mbcslam/advection.F90
new file mode 100644
index 0000000..fb102ba
--- /dev/null
+++ b/tools/mbcslam/advection.F90
@@ -0,0 +1,122 @@
+! advection: do a one time step transport, using c binding module
+!            example of how to do it in parallel in fortran
+! This program shows how to load in parallel in moab from Fortran90, and how
+!   to call the transport wrapper. It is a fortran equivalent of intx_imesh
+!   driver
+! Usage: advection
+#define CHECK(a)   if (ierr .ne. 0) print *, a
+program advection
+  use ISO_C_BINDING
+  implicit none
+#include "mpif.h"
+#ifdef USE_MPI
+#  include "iMeshP_f.h"
+#else
+#  include "iMesh_f.h"
+#endif
+! extern void update_tracer( iMesh_Instance instance,  iBase_EntitySetHandle * opEulerSet, int * ierr);
+  INTERFACE
+   SUBROUTINE update_tracer ( instance , opEulerSet, ierr) bind(C)
+     use ISO_C_BINDING
+     implicit none
+     iMesh_Instance, INTENT(IN) , VALUE :: instance
+     iBase_EntityHandle, INTENT(OUT) :: opEulerSet
+     integer(c_int) , INTENT (OUT) :: ierr
+   END SUBROUTINE update_tracer
+  END INTERFACE
+  ! declarations
+  ! imesh is the instance handle
+  iMesh_Instance imesh
+  ! ents, verts will be arrays storing vertex/entity handles
+  iBase_EntityHandle, pointer :: ents, verts
+  iBase_EntitySetHandle root_set
+  iBase_EntitySetHandle opEulerSet
+  CHARACTER (LEN=200) options
+  CHARACTER (LEN=200) filename
+  CHARACTER (LEN=200) optionswrite
+  CHARACTER (LEN=200) outname
+  TYPE(C_PTR) :: vertsPtr, entsPtr
+  integer rank, sz, ierr
+  integer lenopt, lenname
+#ifdef USE_MPI
+  ! local variables for parallel runs
+  iMeshP_PartitionHandle imeshp
+  IBASE_HANDLE_T mpi_comm_c
+#endif
+  ! init the parallel partition
+  call MPI_INIT(ierr)
+  CHECK("fail to initialize MPI")
+  call MPI_COMM_SIZE(MPI_COMM_WORLD, sz, ierr)
+  CHECK("fail to get MPI size")
+  call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr)
+  CHECK("fail to get MPI rank")
+  ! now load the mesh; this also initializes parallel sharing
+  imesh = 0
+  imeshp = 0
+  call iMesh_newMesh("MOAB", imesh, ierr)
+  CHECK("fail to initialize imesh")
+  call iMesh_getRootSet(%VAL(imesh), root_set, ierr)
+  CHECK("fail to get root set")
+  call iMeshP_getCommunicator(%VAL(imesh), MPI_COMM_WORLD, mpi_comm_c, ierr)
+  call iMeshP_createPartitionAll(%VAL(imesh), %VAL(mpi_comm_c), imeshp, ierr)
+  CHECK("fail to create parallel partition ")
+  options = " moab:PARALLEL=READ_PART moab:PARTITION=PARALLEL_PARTITION" // &
+            " moab:PARALLEL_RESOLVE_SHARED_ENTS moab:PARTITION_DISTRIBUTE "
+!            " moab:PARALLEL=READ_PART moab:PARTITION=PARALLEL_PARTITION " &
+!              " moab:PARALLEL_RESOLVE_SHARED_ENTS moab:PARTITION_DISTRIBUTE ", & ! options
+  if (0 .eq. rank) then
+    print *, "load in parallel file HN16DP.h5m"
+  endif
+  lenname = 11;
+  lenopt = 123
+  filename = "HN16DP.h5m"
+  call iMeshP_loadAll(%VAL(imesh), &
+              %VAL(imeshp), &
+              %VAL(root_set), &
+              filename, & ! filename
+              options, & !options
+              ierr, &
+              %VAL(lenname), & ! strlen(filename),
+              %VAL(lenopt) )  !119) !strlen(options));
+  CHECK("fail to load mesh in parallel ")
+  call update_tracer(imesh, opEulerSet, ierr)
+  CHECK("fail to update tracer ")
+  outname = "outF.h5m";
+  optionswrite = " moab:PARALLEL=WRITE_PART " ;
+  lenname = 8
+  lenopt = 27
+  call iMeshP_saveAll( %VAL(imesh), &
+              %VAL(imeshp), &
+               %VAL(opEulerSet), &
+               outname, &
+               optionswrite, &
+               ierr, &
+  CHECK(" can't save ")
+  if (0==rank) then
+    print *, "Done"
+  endif
+  call MPI_FINALIZE(ierr)
+  stop
+end program advection
diff --git a/tools/mbcslam/create_dp.cpp b/tools/mbcslam/create_dp.cpp
index 0000000..bd2459b
--- /dev/null
+++ b/tools/mbcslam/create_dp.cpp
@@ -0,0 +1,273 @@
+ * create_dp.cpp
+ *  Created on: Dec 12, 2013
+ *  just to add a "DP" tag to an already partitioned mesh, based on some formula
+ *  it is launched in serial
+#include "moab/Core.hpp"
+#include "moab/Interface.hpp"
+#include <iostream>
+#include <math.h>
+#include <TestUtil.hpp>
+#include "CslamUtils.hpp"
+#include <assert.h>
+using namespace moab;
+double radius = 1.;// in m:  6371220.
+int field_type = 1;
+ErrorCode add_field_value(Interface & mb)
+  ErrorCode rval = MB_SUCCESS;
+  Tag tagTracer = 0;
+  std::string tag_name("Tracer");
+  rval = mb.tag_get_handle(tag_name.c_str(), 1, MB_TYPE_DOUBLE, tagTracer, MB_TAG_DENSE | MB_TAG_CREAT);
+  CHECK_ERR(rval);
+  // tagElem is the average computed at each element, from nodal values
+  Tag tagElem = 0;
+  std::string tag_name2("TracerAverage");
+  rval = mb.tag_get_handle(tag_name2.c_str(), 1, MB_TYPE_DOUBLE, tagElem, MB_TAG_DENSE | MB_TAG_CREAT);
+  CHECK_ERR(rval);
+  Tag tagArea = 0;
+  std::string tag_name4("Area");
+  rval = mb.tag_get_handle(tag_name4.c_str(), 1, MB_TYPE_DOUBLE, tagArea, MB_TAG_DENSE | MB_TAG_CREAT);
+  CHECK_ERR(rval);
+   * get all plys first, then vertices, then move them on the surface of the sphere
+   *  radius is 1., most of the time
+  Range polygons;
+  rval = mb.get_entities_by_dimension(0, 2, polygons);
+  if (MB_SUCCESS != rval)
+    return rval;
+  Range connecVerts;
+  rval = mb.get_connectivity(polygons, connecVerts);
+    return rval;
+  void *data; // pointer to the LOC in memory, for each vertex
+  int count;
+  rval = mb.tag_iterate(tagTracer, connecVerts.begin(), connecVerts.end(), count, data);
+  CHECK_ERR(rval);
+  // here we are checking contiguity
+  assert(count == (int) connecVerts.size());
+  double * ptr_DP=(double*)data;
+  // lambda is for longitude, theta for latitude
+   // param will be: (la1, te1), (la2, te2), b, c; hmax=1, r=1/2
+  // nondivergent flow, page 5, case 1, (la1, te1) = (M_PI, M_PI/3)
+  //                                    (la2, te2) = (M_PI, -M_PI/3)
+  //                 la1,    te1    la2    te2     b     c  hmax  r
+  if (field_type==1) // quasi smooth
+    double params[] = { M_PI, M_PI/3, M_PI, -M_PI/3, 0.1, 0.9, 1., 0.5};
+    for (Range::iterator vit=connecVerts.begin();vit!=connecVerts.end(); vit++ )
+      EntityHandle oldV=*vit;
+      CartVect posi;
+      rval = mb.get_coords(&oldV, 1, &(posi[0]) );
+      CHECK_ERR(rval);
+      SphereCoords sphCoord = cart_to_spherical(posi);
+      ptr_DP[0]=quasi_smooth_field(sphCoord.lon, sphCoord.lat, params);;
+      ptr_DP++; // increment to the next node
+  else if (2 == field_type) // smooth
+    CartVect p1, p2;
+    SphereCoords spr;
+    spr.R = 1;
+    spr.lat = M_PI/3;
+    spr.lon= M_PI;
+    p1 = spherical_to_cart(spr);
+    spr.lat = -M_PI/3;
+    p2 = spherical_to_cart(spr);
+    //                  x1,    y1,     z1,    x2,   y2,    z2,   h_max, b0
+    double params[] = { p1[0], p1[1], p1[2], p2[0], p2[1], p2[2], 1,    5.};
+      CartVect posi;
+      CHECK_ERR(rval);
+      ptr_DP[0]=smooth_field(sphCoord.lon, sphCoord.lat, params);;
+  else if (3 == field_type) // slotted
+    //                   la1, te1,   la2, te2,       b,   c,   r
+    double params[] = { M_PI, M_PI/3, M_PI, -M_PI/3, 0.1, 0.9, 0.5};// no h_max
+      CartVect posi;
+      CHECK_ERR(rval);
+      ptr_DP[0]=slotted_cylinder_field(sphCoord.lon, sphCoord.lat, params);;
+  // add average value for quad/polygon (average corners)
+  // do some averages
+  Range::iterator iter = polygons.begin();
+  double local_mass = 0.; // this is total mass on one proc
+  while (iter != polygons.end())
+    rval = mb.tag_iterate(tagElem, iter, polygons.end(), count, data);
+    CHECK_ERR(rval);
+    double * ptr=(double*)data;
+    rval = mb.tag_iterate(tagArea, iter, polygons.end(), count, data);
+    CHECK_ERR(rval);
+    double * ptrArea=(double*)data;
+    for (int i=0; i<count; i++, iter++, ptr++, ptrArea++)
+      const moab::EntityHandle * conn = NULL;
+      int num_nodes = 0;
+      rval = mb.get_connectivity(*iter, conn, num_nodes);
+      CHECK_ERR(rval);
+      if (num_nodes==0)
+        return MB_FAILURE;
+      std::vector<double> nodeVals(num_nodes);
+      double average=0.;
+      rval = mb.tag_get_data(tagTracer, conn, num_nodes, &nodeVals[0] );
+      CHECK_ERR(rval);
+      for (int j=0; j<num_nodes; j++)
+        average+=nodeVals[j];
+      average/=num_nodes;
+      *ptr = average;
+      // now get area
+      std::vector<double> coords;
+      coords.resize(3*num_nodes);
+      rval = mb.get_coords(conn, num_nodes, &coords[0]);
+      CHECK_ERR(rval);
+      *ptrArea =  area_spherical_polygon_lHuiller (&coords[0], num_nodes, radius);
+      // we should have used some
+      // total mass:
+      local_mass += *ptrArea * average;
+  // now we can delete the tags? not yet
+  return MB_SUCCESS;
+int main(int argc, char **argv)
+  if (argc < 3)
+    std::cout << " usage: create_dp <input><output> -t <time>  -dt <delta_t> -h \n";
+    return 1;
+  double dt=0.1;
+  double t=0.1; // corresponding to diffusion first step
+  int index = 2;
+  char * input_mesh1 = argv[1];
+  char * output = argv[2];
+  while (index < argc)
+    if (!strcmp(argv[index], "-t")) // this is for radius to project
+      t = atof(argv[++index]);
+    if (!strcmp(argv[index], "-dt")) // delete partition sets
+      dt = atof(argv[++index]);
+    if (!strcmp(argv[index], "-h"))
+      return 1;
+    index++;
+  Core moab;
+  Interface & mb = moab;
+  ErrorCode rval;
+  rval = mb.load_mesh(input_mesh1);
+  std::cout  << " -t " << t <<  " -dt " << dt << " input: " << input_mesh1 <<
+      "  output: " << output << "\n";
+  Range verts;
+  rval = mb.get_entities_by_dimension(0, 0, verts);
+    return 1;
+  double *x_ptr, *y_ptr, *z_ptr;
+  int count;
+  rval = mb.coords_iterate(verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count);
+      return 1;
+  assert(count == (int) verts.size()); // should end up with just one contiguous chunk of vertices
+  Tag tagh = 0;
+  std::string tag_name("DP");
+  rval = mb.tag_get_handle(tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT);
+  CHECK_ERR(rval);
+  int count_tag;
+  rval = mb.tag_iterate(tagh, verts.begin(), verts.end(), count_tag, data);
+  CHECK_ERR(rval);
+  assert(count_tag == (int) verts.size());
+  for (int v = 0; v < count; v++) {
+     //EntityHandle v = verts[v];
+     CartVect pos( x_ptr[v], y_ptr[v] , z_ptr[v]);
+     CartVect newPos;
+     departure_point_case1(pos, t, dt, newPos);
+     ptr_DP[0]=newPos[0];
+     ptr_DP[1]=newPos[1];
+     ptr_DP[2]=newPos[2];
+     ptr_DP+=3; // increment to the next vertex
+  rval = add_field_value(mb);
+  mb.write_file(output);
+  return 0;
diff --git a/tools/mbcslam/intx_imesh.cpp b/tools/mbcslam/intx_imesh.cpp
index 0000000..0c49ac4
--- /dev/null
+++ b/tools/mbcslam/intx_imesh.cpp
@@ -0,0 +1,92 @@
+ *  This program updates a manufactured tracer field from time T0 to time T1, in parallel.
+ *  Input: arrival mesh, already distributed on processors, and a departure position for
+ *  each vertex, saved in a tag DP
+#include <stdio.h>
+#include <string.h>
+#include "moab_mpi.h"
+#include "iMeshP.h"
+#define IMESH_ASSERT(ierr) if (ierr!=0) printf("imesh assert\n");
+#define IMESH_NULL 0
+#ifdef __cplusplus
+extern "C" {
+#endif
+ void update_tracer( iMesh_Instance instance,  iBase_EntitySetHandle * opEulerSet, int * ierr);
+#ifdef __cplusplus
+} // extern "C"
+#endif
+int main(int argc, char* argv[]){
+  MPI_Init(&argc, &argv);
+  iMesh_Instance imesh;
+  iMeshP_PartitionHandle partn;
+  int ierr, num_sets;
+  iBase_EntitySetHandle root;
+  imesh = IMESH_NULL;
+  iMesh_newMesh(0, &imesh, &ierr, 0);
+  IMESH_ASSERT(ierr);
+  iMesh_getRootSet( imesh, &root, &ierr );
+  iMeshP_createPartitionAll(imesh, MPI_COMM_WORLD, &partn, &ierr);
+  int rank, size;
+  MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  MPI_Comm_size(MPI_COMM_WORLD, &size);
+  const char options[] = " moab:PARALLEL=READ_PART "
+                         " moab:PARTITION=PARALLEL_PARTITION "
+                         " moab:PARALLEL_RESOLVE_SHARED_ENTS "
+                         " moab:PARTITION_DISTRIBUTE ";
+  const char * filename = "HN16DP.h5m"; // the file should have the dp tag already
+  if (0==rank)
+    printf("load in parallel the file: %s \n", filename);
+  iMeshP_loadAll(imesh,
+              partn,
+              root,
+              filename,
+              options,
+              &ierr,
+              strlen(filename),
+              strlen(options));
+  iMesh_getNumEntSets(imesh,
+                      IMESH_NULL,
+                      1,
+                      &num_sets,
+                      &ierr);
+  printf("There's %d entity sets here on process rank %d \n", num_sets, rank);
+  iBase_EntitySetHandle euler_set;
+  update_tracer( imesh, &euler_set, &ierr);
+  // write everything
+  const char * out_name = "out.h5m";
+  const char optionswrite[] = " moab:PARALLEL=WRITE_PART " ;
+  iMeshP_saveAll( imesh, partn, euler_set,
+                     out_name,
+                     optionswrite,
+                     &ierr,
+                     strlen(out_name),
+                     strlen(optionswrite));
+  if (0==rank)
+    printf("Done\n");
+  MPI_Finalize(); //probably the 4th time this is called.. no big deal
diff --git a/tools/mbcslam/wrap_intx.cpp b/tools/mbcslam/wrap_intx.cpp
index 0000000..fa6bc20
--- /dev/null
+++ b/tools/mbcslam/wrap_intx.cpp
@@ -0,0 +1,104 @@
+ * wrap_intx.cpp
+ *  Will implement the intersection method that will be callable from fortran too
+ *  will be added to the library mbcslam.a
+ *  Created on: Dec 14, 2013
+ *      Author: iulian
+#include "iMesh.h"
+#include "MBiMesh.hpp"
+#include "moab/Range.hpp"
+#include "Intx2MeshOnSphere.hpp"
+double gtol = 1.e-9;
+bool debug = true;
+#ifdef __cplusplus
+extern "C" {
+#endif
+void update_tracer( iMesh_Instance instance, iBase_EntitySetHandle * opEulerSet, int * ierr)
+  Range ents;
+  moab::Interface * mb =MOABI;
+  *ierr =1;
+  ErrorCode rval = mb->get_entities_by_dimension(0, 2, ents);// root 0
+  ERRORV(rval,  "can't get all 2d entities from root");
+  EntityHandle euler_set;
+  //EntityHandle lagr_set;
+  rval = mb->create_meshset(MESHSET_SET, euler_set);
+  ERRORV(rval , "can't create arrival mesh set");
+  *opEulerSet = (iBase_EntitySetHandle)euler_set;
+  rval = mb->add_entities(euler_set, ents);
+  ERRORV(rval , "can't add ents to arrival set");
+  Intx2MeshOnSphere worker(mb);
+  worker.SetRadius(radius);
+  worker.SetErrorTolerance(gtol);
+  EntityHandle covering_lagr_set;
+  rval = mb->create_meshset(MESHSET_SET, covering_lagr_set);
+  ERRORV(rval , "can't create covering set ");
+  // we need to update the correlation tag and remote tuples
+  rval = worker.create_departure_mesh_2nd_alg(euler_set, covering_lagr_set);
+  ERRORV(rval , "can't populate covering set ");
+  if (debug)
+    rval = mb->write_file("lagr.h5m", 0, 0, &covering_lagr_set, 1  );
+    ERRORV(rval , "can't write covering set ");
+  EntityHandle outputSet;
+  rval = mb->create_meshset(MESHSET_SET, outputSet);
+  ERRORV(rval , "can't create output set ");
+  rval = worker.intersect_meshes(covering_lagr_set, euler_set, outputSet);
+  ERRORV(rval , "can't intersect ");
+  if (debug)
+    rval = mb->write_file("output.vtk", 0, 0, &outputSet, 1  );
+  Tag tagElem = 0;
+  rval = mb->tag_get_handle(tag_name2.c_str(), 1, MB_TYPE_DOUBLE, tagElem, MB_TAG_DENSE | MB_TAG_CREAT);
+  ERRORV(rval , "can't get tracer tag ");
+  // area of the euler element is fixed, store it; it is used to recompute the averages at each
+  // time step
+  Tag tagArea = 0;
+  rval = mb->tag_get_handle(tag_name4.c_str(), 1, MB_TYPE_DOUBLE, tagArea, MB_TAG_DENSE | MB_TAG_CREAT);
+  ERRORV(rval , "can't get area tag");
+  rval = worker.update_tracer_data(outputSet, tagElem, tagArea);
+  ERRORV(rval , "can't update tracer ");
+  // everything can be deleted now from intx data; polygons, etc.
+  *ierr = 0;
+  return;
+#ifdef __cplusplus
+} // extern "C"
+#endif
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
