[MOAB-dev] commit/MOAB: 4 new changesets
commits-noreply at bitbucket.org
Wed Nov 27 19:28:42 CST 2013
4 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/9b03dd4476f3/
Changeset: 9b03dd4476f3
Branch: None
User: tautges
Date: 2013-11-28 02:25:15
Summary: Revert "LloydSmoother: proper handling of communicator."
This reverts commit c1b51c7ed3eeb44a13dfc81f7ecd667b20bf88a2.
Affected #: 5 files
diff --git a/src/LloydSmoother.cpp b/src/LloydSmoother.cpp
index d60b615..09546b5 100644
--- a/src/LloydSmoother.cpp
+++ b/src/LloydSmoother.cpp
@@ -7,7 +7,6 @@
#ifdef USE_MPI
#include "moab/ParallelComm.hpp"
-#include "MBParallelConventions.h"
#endif
#include <iostream>
@@ -162,7 +161,7 @@ ErrorCode LloydSmoother::perform_smooth()
#ifdef USE_MPI
// 2c. exchange tags on owned verts
if (myPcomm->size() > 1) {
- rval = myPcomm->exchange_tags(centroid, shared_owned_verts); RR("Failed to exchange tags.");
+ rval = pcomm->exchange_tags(centroid, shared_owned_verts); RR("Failed to exchange tags.");
#endif
@@ -172,7 +171,7 @@ ErrorCode LloydSmoother::perform_smooth()
// global reduce for maximum delta, then report it
MPI_Reduce(&resid, &global_max, 1, MPI_DOUBLE, MPI_MAX, 0, myPcomm->comm());
- if (!myPcomm->rank())
+ if (!pcomm->rank())
#endif
std::cout << "Max residual = " << global_max << std::endl;
diff --git a/test/perf/point_location/elem_eval_time.cpp b/test/perf/point_location/elem_eval_time.cpp
index ef86762..186bd81 100644
--- a/test/perf/point_location/elem_eval_time.cpp
+++ b/test/perf/point_location/elem_eval_time.cpp
@@ -158,7 +158,7 @@ ErrorCode time_reverse_eval(Interface *mbi, int method, Range &elems,
bool ins;
for (rit = elems.begin(), i = 0; rit != elems.end(); rit++, i++) {
eeval.set_ent_handle(*rit);
- rval = eeval.reverse_eval(coords[i].array(), 1.0e-10, 1.0e-6, params[i].array(), &ins);
+ rval = eeval.reverse_eval(coords[i].array(), 1.0e-6, params[i].array(), &ins);
assert(ins);
#ifndef NDEBUG
if (MB_SUCCESS != rval) return rval;
diff --git a/test/perf/point_location/point_location.cpp b/test/perf/point_location/point_location.cpp
index 4f5ddcc..df4132e 100644
--- a/test/perf/point_location/point_location.cpp
+++ b/test/perf/point_location/point_location.cpp
@@ -290,7 +290,7 @@ void do_kdtree_test( Interface& mb, int tree_depth, int elem_per_leaf,
int len;
for (long i = 0; i < num_test; ++i) {
const size_t idx = (size_t)i % points.size();
- rval = tool.point_search( points[idx].array(), leaf, 1.0e-10, 1.0e-6, NULL, &root ); CHK(rval);
+ rval = tool.point_search( points[idx].array(), leaf, 0.0, NULL, &root ); CHK(rval);
hexes.clear();
rval = mb.get_entities_by_handle( leaf, hexes ); CHK(rval);
for (j = hexes.begin(); j != hexes.end(); ++j) {
diff --git a/test/perf/point_location/sploc_searching_perf.cpp b/test/perf/point_location/sploc_searching_perf.cpp
index 158504d..bf09a8e 100644
--- a/test/perf/point_location/sploc_searching_perf.cpp
+++ b/test/perf/point_location/sploc_searching_perf.cpp
@@ -160,7 +160,7 @@ ErrorCode test_locator(SpatialLocator &sl, int npoints, double rtol, double &cpu
CpuTimer ct;
// call spatial locator to locate points
- rval = sl.locate_points(test_pts[0].array(), npoints, &ents[0], test_res[0].array(), &is_in[0], rtol, 0.0);
+ rval = sl.locate_points(test_pts[0].array(), npoints, &ents[0], test_res[0].array(), rtol, 0.0, &is_in[0]);
cpu_time = ct.time_elapsed();
diff --git a/test/perf/point_location/tree_searching_perf.cpp b/test/perf/point_location/tree_searching_perf.cpp
index 9e35d9b..6d1badb 100644
--- a/test/perf/point_location/tree_searching_perf.cpp
+++ b/test/perf/point_location/tree_searching_perf.cpp
@@ -32,10 +32,9 @@ int main(int argc, char **argv)
#endif
int npoints = 100, dim = 3;
- int dints = 1, dleafs = 1, ddeps = 1, csints = 0;
+ int dints = 1, dleafs = 1, ddeps = 1;
- ProgOptions po;
- po.addOpt<int>( "candidateplaneset,c", "Candidate plane set (0=SUBDIVISION,1=SUBDIV_SNAP,2=VERTEX_MEDIAN,3=VERTEX_SAMPLE", &csints);
+ ProgOptions po("tree_searching_perf options" );
po.addOpt<int>( "ints,i", "Number of doublings of intervals on each side of scd mesh", &dints);
po.addOpt<int>( "leaf,l", "Number of doublings of maximum number of elements per leaf", &dleafs);
po.addOpt<int>( "max_depth,m", "Number of 5-intervals on maximum depth of tree", &ddeps);
@@ -79,7 +78,7 @@ int main(int argc, char **argv)
for (std::vector<int>::iterator leafs_it = leafs.begin(); leafs_it != leafs.end(); leafs_it++) {
// iteration: tree type
- for (int tree_tp = 1; tree_tp < 2; tree_tp++) {
+ for (int tree_tp = 0; tree_tp < 2; tree_tp++) {
// create tree
Tree *tree;
if (0 == tree_tp)
@@ -89,11 +88,6 @@ int main(int argc, char **argv)
std::ostringstream opts;
opts << "MAX_DEPTH=" << *dep_it << ";MAX_PER_LEAF=" << *leafs_it;
- if (csints) {
- if (opts.str().length() > 0)
- opts << ";";
- opts << "PLANE_SET=" << csints;
FileOptions fo(opts.str().c_str());
rval = tree->parse_options(fo);
SpatialLocator sl(&mb, elems, tree);
@@ -151,7 +145,7 @@ ErrorCode test_locator(SpatialLocator &sl, int npoints, double &cpu_time, double
CpuTimer ct;
- rval = sl.locate_points(test_pts[0].array(), npoints, &ents[0], test_res[0].array(), &is_in[0]);
+ rval = sl.locate_points(test_pts[0].array(), npoints, &ents[0], test_res[0].array(), 0.0, 0.0, &is_in[0]);
https://bitbucket.org/fathomteam/moab/commits/1637bd66eac9/
Changeset: 1637bd66eac9
Branch: None
User: tautges
Date: 2013-11-28 02:27:59
Summary: Revert "General debugging and small feature additions."
This reverts commit 97620d2ef9c1ef3f71284ba0ab57be5ad0b18ca2.
Affected #: 31 files
diff --git a/examples/DeformMeshRemap.cpp b/examples/DeformMeshRemap.cpp
index 7614934..500d969 100644
--- a/examples/DeformMeshRemap.cpp
+++ b/examples/DeformMeshRemap.cpp
@@ -14,8 +14,6 @@
#include "moab/Range.hpp"
#include "moab/LloydSmoother.hpp"
#include "moab/ProgOptions.hpp"
-#include "moab/BoundBox.hpp"
-#include "moab/SpatialLocator.hpp"
#include "MBTagConventions.hpp"
#include "DataCoupler.hpp"
@@ -32,7 +30,7 @@ using namespace std;
ErrorCode read_file(string &fname, EntityHandle &seth,
Range &solids, Range &solid_elems, Range &fluids, Range &fluid_elems);
-void deform_func(const BoundBox &bbox, double *xold, double *xnew);
+void deform_func(double *xold, double *xnew);
ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, Tag &xnew);
ErrorCode smooth_master(int dim, Tag xnew, EntityHandle &master, Range &fluids);
ErrorCode write_to_coords(Range &elems, Tag tagh);
@@ -195,30 +193,9 @@ ErrorCode DeformMeshRemap::execute()
rval = read_file(SLAVE, slaveFileName, slaveSet);
- Range src_elems = solidElems[MASTER];
- src_elems.merge(fluidElems[MASTER]);
- // locate slave vertices in master, orig coords; do this with a data coupler, so you can
- // later interpolate
- Range tgt_verts, tmp_range = solidElems[SLAVE];
- tmp_range.merge(fluidElems[SLAVE]);
- rval = mbImpl->get_adjacencies(tmp_range, 0, false, tgt_verts, Interface::UNION);
- RR("Failed to get target verts.");
- // initialize data coupler on source elements
- DataCoupler dc_master(mbImpl, NULL, src_elems, 0);
- // locate slave vertices, caching results in dc
- rval = dc_master.locate_points(tgt_verts); RR("Point location of tgt verts failed.");
- int num_located = dc_master.spatial_locator()->local_num_located();
- if (num_located != (int)tgt_verts.size()) {
- rval = MB_FAILURE;
- std::cout << "Only " << num_located << " out of " << tgt_verts.size() << " target points successfully located." << std::endl;
- return rval;
// deform the master's solid mesh, put results in a new tag
rval = deform_master(fluidElems[MASTER], solidElems[MASTER], "xnew"); RR("");
+ if (debug) write_and_save(solidElems[MASTER], masterSet, xNew, "deformed.vtk");
{ // to isolate the lloyd smoother & delete when done
@@ -230,6 +207,22 @@ ErrorCode DeformMeshRemap::execute()
// map new locations to slave
+ // locate slave vertices in master, orig coords; do this with a data coupler, so you can
+ // later interpolate
+ Range src_elems = solidElems[MASTER];
+ src_elems.merge(fluidElems[MASTER]);
+ // initialize data coupler on source elements
+ DataCoupler dc_master(mbImpl, NULL, src_elems, 0);
+ Range tgt_verts, tmp_range = solidElems[SLAVE];
+ tmp_range.merge(fluidElems[SLAVE]);
+ rval = mbImpl->get_adjacencies(tmp_range, 0, false, tgt_verts, Interface::UNION);
+ RR("Failed to get target verts.");
+ // locate slave vertices, caching results in dc
+ rval = dc_master.locate_points(tgt_verts, 0.0, 1e-10); RR("Point location of tgt verts failed.");
// interpolate xNew to slave points
rval = dc_master.interpolate((int)DataCoupler::VOLUME, "xnew"); RR("Failed to interpolate target solution.");
@@ -324,10 +317,9 @@ ErrorCode DeformMeshRemap::write_to_coords(Range &elems, Tag tagh)
return MB_SUCCESS;
-/* Deformation function based on max delx and dely at top of rod
- const double RODWIDTH = 0.2, RODHEIGHT = 0.5;
+ const double RODWIDTH = 0.2, RODHEIGHT = 0.5;
// function: origin is at middle base of rod, and is .5 high
// top of rod is (0,.55) on left and (.2,.6) on right
double delx = 0.5*RODWIDTH;
@@ -335,13 +327,6 @@ void deform_func(const BoundBox &bbox, double *xold, double *xnew)
double xfrac = (xold[0] + .5*RODWIDTH)/RODWIDTH, yfrac = xold[1]/RODHEIGHT;
xnew[0] = xold[0] + yfrac * delx;
xnew[1] = xold[1] + yfrac * (1.0 + xfrac) * 0.05;
-/* Deformation function based on fraction of bounding box dimension in each direction */
- double frac = 0.01; // taken from approximate relative deformation from LLNL Diablo of XX09 assys
- CartVect *xo = reinterpret_cast<CartVect*>(xold), *xn = reinterpret_cast<CartVect*>(xnew);
- CartVect disp = frac * (*xo - bbox.bMin);
- *xn = *xo + disp;
ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems, const char *tag_name)
@@ -361,10 +346,6 @@ ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems,
RR("Failed to get vertex coords.");
rval = mbImpl->tag_set_data(xNew, verts, &coords[0]);
RR("Failed to set xnew tag on fluid verts.");
- // get the bounding box of the solid mesh
- BoundBox bbox;
- bbox.update(*mbImpl, solid_elems);
// get all the vertices and coords in the solid
verts.clear();
@@ -375,7 +356,7 @@ ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems,
unsigned int num_verts = verts.size();
for (unsigned int i = 0; i < num_verts; i++)
- deform_func(bbox, &coords[3*i], &coords[3*i]);
+ deform_func(&coords[3*i], &coords[3*i]);
// set the new tag to those coords
diff --git a/src/AdaptiveKDTree.cpp b/src/AdaptiveKDTree.cpp
index 1324c30..f66acbc 100644
--- a/src/AdaptiveKDTree.cpp
+++ b/src/AdaptiveKDTree.cpp
@@ -1303,8 +1303,7 @@ namespace moab {
ErrorCode AdaptiveKDTree::point_search(const double *point,
EntityHandle& leaf_out,
- const double iter_tol,
- const double inside_tol,
+ double tol,
bool *multiple_leaves,
EntityHandle *start_node,
CartVect *params)
@@ -1323,7 +1322,7 @@ namespace moab {
treeStats.nodesVisited++;
ErrorCode rval = get_bounding_box(box, &node);
- if (!box.contains_point(point, iter_tol)) return MB_SUCCESS;
+ if (!box.contains_point(point, tol)) return MB_SUCCESS;
rval = moab()->get_child_meshsets( node, children );
@@ -1347,7 +1346,7 @@ namespace moab {
treeStats.leavesVisited++;
if (myEval && params) {
- rval = myEval->find_containing_entity(node, point, iter_tol, inside_tol,
+ rval = myEval->find_containing_entity(node, point, tol,
leaf_out, params->array(), &treeStats.leafObjectTests);
@@ -1359,8 +1358,7 @@ namespace moab {
AdaptiveKDTreeIter& leaf_it,
- const double /*inside_tol*/,
+ double tol,
EntityHandle *start_node)
@@ -1374,7 +1372,7 @@ namespace moab {
leaf_it.mBox[1] = boundBox.bMax;
// test that point is inside tree
- if (!boundBox.contains_point(point, iter_tol)) {
+ if (!boundBox.contains_point(point, tol)) {
return MB_ENTITY_NOT_FOUND;
@@ -1425,8 +1423,7 @@ namespace moab {
ErrorCode AdaptiveKDTree::distance_search(const double from_point[3],
const double distance,
std::vector<EntityHandle>& result_list,
+ double tol,
std::vector<double> *result_dists,
std::vector<CartVect> *result_params,
EntityHandle *tree_root)
@@ -1448,7 +1445,7 @@ namespace moab {
// (zero if inside box)
BoundBox box;
rval = get_bounding_box(box);
- if (MB_SUCCESS == rval && !box.contains_point(from_point, iter_tol)) {
+ if (MB_SUCCESS == rval && !box.contains_point(from_point, tol)) {
return MB_SUCCESS;
@@ -1487,7 +1484,7 @@ namespace moab {
if (myEval && result_params) {
EntityHandle ent;
CartVect params;
- rval = myEval->find_containing_entity(node.handle, from_point, iter_tol, inside_tol,
+ rval = myEval->find_containing_entity(node.handle, from_point, tol,
ent, params.array(), &treeStats.leafObjectTests);
else if (ent) {
@@ -1805,7 +1802,7 @@ namespace moab {
// the same distance from the input point as the current closest
// point is.
CartVect diff = closest_pt - from;
- rval = distance_search(from_coords, sqrt(diff%diff), leaves, 1.0e-10, 1.0e-6, NULL, NULL, &tree_root);
+ rval = distance_search(from_coords, sqrt(diff%diff), leaves, 0.0, NULL, NULL, &tree_root);
// Check any close leaves to see if they contain triangles that
@@ -1837,7 +1834,7 @@ namespace moab {
// get leaves of tree that intersect sphere
assert(tree_root);
- rval = distance_search(center, radius, leaves, 1.0e-10, 1.0e-6, NULL, NULL, &tree_root);
+ rval = distance_search(center, radius, leaves, 0.0, NULL, NULL, &tree_root);
// search each leaf for triangles intersecting sphere
diff --git a/src/BVHTree.cpp b/src/BVHTree.cpp
index b65eae4..8903070 100644
--- a/src/BVHTree.cpp
+++ b/src/BVHTree.cpp
@@ -435,8 +435,7 @@ namespace moab
ErrorCode BVHTree::find_point(const std::vector<double> &point,
const unsigned int &index,
+ const double tol,
std::pair<EntityHandle, CartVect> &result)
if (index == 0) treeStats.numTraversals++;
@@ -454,7 +453,7 @@ namespace moab
for(Range::iterator i = entities.begin(); i != entities.end(); i++) {
treeStats.leafObjectTests++;
myEval->set_ent_handle(*i);
- myEval->reverse_eval(&point[0], iter_tol, inside_tol, params.array(), &is_inside);
+ myEval->reverse_eval(&point[0], tol, params.array(), &is_inside);
if (is_inside) {
result.first = *i;
result.second = params;
@@ -470,11 +469,11 @@ namespace moab
rval = mbImpl->get_child_meshsets(startSetHandle+index, children);
if (MB_SUCCESS != rval || children.size() != 2) return rval;
- if((node.Lmax+iter_tol) < (node.Rmin-iter_tol)){
- if(point[node.dim] <= (node.Lmax + iter_tol))
- return find_point(point, children[0]-startSetHandle, iter_tol, inside_tol, result);
- else if(point[ node.dim] >= (node.Rmin - iter_tol))
- return find_point(point, children[1]-startSetHandle, iter_tol, inside_tol, result);
+ if((node.Lmax+tol) < (node.Rmin-tol)){
+ if(point[node.dim] <= (node.Lmax + tol))
+ return find_point(point, children[0]-startSetHandle, tol, result);
+ else if(point[ node.dim] >= (node.Rmin - tol))
+ return find_point(point, children[1]-startSetHandle, tol, result);
result = std::make_pair(0, CartVect(&point[0])); //point lies in empty space.
return MB_SUCCESS;
@@ -483,11 +482,11 @@ namespace moab
//left of Rmin, you must be on the left
//we can't be sure about the boundaries since the boxes overlap
//this was a typo in the paper which caused pain.
- if(point[node.dim] < (node.Rmin - iter_tol))
+ if(point[node.dim] < (node.Rmin - tol))
//if you are on the right Lmax, you must be on the right
- else if(point[ node.dim] > (node.Lmax+iter_tol))
+ else if(point[ node.dim] > (node.Lmax+tol))
/* pg5 of paper
* However, instead of always traversing either subtree
@@ -502,22 +501,22 @@ namespace moab
//branch predicted..
//bool dir = (point[ node.dim] - node.Rmin) <=
// (node.Lmax - point[ node.dim]);
- find_point(point, children[0]-startSetHandle, iter_tol, inside_tol, result);
+ find_point(point, children[0]-startSetHandle, tol, result);
if(result.first == 0){
return MB_SUCCESS;
- EntityHandle BVHTree::bruteforce_find(const double *point, const double iter_tol, const double inside_tol) {
+ EntityHandle BVHTree::bruteforce_find(const double *point, const double tol) {
CartVect params;
for(unsigned int i = 0; i < myTree.size(); i++) {
- if(myTree[i].dim != 3 || !myTree[i].box.contains_point(point, iter_tol)) continue;
+ if(myTree[i].dim != 3 || !myTree[i].box.contains_point(point, tol)) continue;
if (myEval) {
EntityHandle entity = 0;
- ErrorCode rval = myEval->find_containing_entity(startSetHandle+i, point, iter_tol, inside_tol,
+ ErrorCode rval = myEval->find_containing_entity(startSetHandle+i, point, tol,
entity, params.array(), &treeStats.leafObjectTests);
if (entity) return entity;
else if (MB_SUCCESS != rval) return 0;
@@ -543,8 +542,7 @@ namespace moab
ErrorCode BVHTree::point_search(const double *point,
+ double tol,
CartVect *params)
@@ -574,7 +572,7 @@ namespace moab
// test box of this node
ErrorCode rval = get_bounding_box(box, &this_set);
- if (!box.contains_point(point, iter_tol)) continue;
+ if (!box.contains_point(point, tol)) continue;
// else if not a leaf, test children & put on list
else if (myTree[ind].dim != 3) {
@@ -583,7 +581,7 @@ namespace moab
continue;
else if (myTree[ind].dim == 3 && myEval && params) {
- rval = myEval->find_containing_entity(startSetHandle+ind, point, iter_tol, inside_tol,
+ rval = myEval->find_containing_entity(startSetHandle+ind, point, tol,
if (leaf_out || MB_SUCCESS != rval) return rval;
@@ -601,8 +599,7 @@ namespace moab
ErrorCode BVHTree::distance_search(const double from_point[3],
+ double params_tol,
@@ -656,7 +653,7 @@ namespace moab
EntityHandle ent;
CartVect params;
- rval = myEval->find_containing_entity(startSetHandle+ind, from_point, iter_tol, inside_tol,
+ rval = myEval->find_containing_entity(startSetHandle+ind, from_point, params_tol,
else if (ent) {
diff --git a/src/LocalDiscretization/ElemEvaluator.cpp b/src/LocalDiscretization/ElemEvaluator.cpp
index 4ca3943..4446281 100644
--- a/src/LocalDiscretization/ElemEvaluator.cpp
+++ b/src/LocalDiscretization/ElemEvaluator.cpp
@@ -6,7 +6,6 @@
// need to include eval set types here to support get_eval_set; alternative would be to have some
// type of registration, but we'd still need static registration for the built-in types
-#include "moab/LinearTri.hpp"
#include "moab/LinearQuad.hpp"
#include "moab/LinearTet.hpp"
#include "moab/LinearHex.hpp"
@@ -17,12 +16,12 @@
namespace moab {
ErrorCode EvalSet::evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
const double *posn, const double *verts, const int nverts,
- const int ndim, const double iter_tol, const double inside_tol,
- double *work, double *params, bool *inside) {
+ const int ndim, const double tol, double *work,
+ double *params, bool *inside) {
// TODO: should differentiate between epsilons used for
// Newton Raphson iteration, and epsilons used for curved boundary geometry errors
// right now, fix the tolerance used for NR
- const double error_tol_sqr = iter_tol*iter_tol;
+ const double error_tol_sqr = tol*tol;
CartVect *cvparams = reinterpret_cast<CartVect*>(params);
const CartVect *cvposn = reinterpret_cast<const CartVect*>(posn);
@@ -39,26 +38,23 @@ namespace moab {
// residual is diff between old and new pos; need to minimize that
CartVect res = new_pos - *cvposn;
Matrix3 J;
- bool dum, *tmp_inside = (inside ? inside : &dum);
int iters=0;
// while |res| larger than tol
while (res % res > error_tol_sqr) {
if(++iters>10) {
- // if we haven't converged but we're outside, that's defined as success
- *tmp_inside = (*inside_f)(params, ndim, inside_tol);
- if (!(*tmp_inside)) return MB_SUCCESS;
- else return MB_FAILURE;
+ if (inside) {
+ // if we haven't converged but we're outside, that's defined as success
+ *inside = (*inside_f)(params, ndim, tol);
+ if (!(*inside)) return MB_SUCCESS;
+ return MB_FAILURE;
// get jacobian at current params
rval = (*jacob)(cvparams->array(), verts, nverts, ndim, work, J[0]);
double det = J.determinant();
- if (det < std::numeric_limits<double>::epsilon()) {
+ assert(det > std::numeric_limits<double>::epsilon());
// new params tries to eliminate residual
*cvparams -= J.inverse(1.0/det) * res;
@@ -72,7 +68,7 @@ namespace moab {
if (inside)
- *inside = (*inside_f)(params, ndim, inside_tol);
return MB_SUCCESS;
}// Map::evaluate_reverse()
@@ -93,7 +89,6 @@ namespace moab {
case MBEDGE:
break;
case MBTRI:
- if (LinearTri::compatible(tp, num_vertices, eval_set)) return MB_SUCCESS;
break;
case MBQUAD:
if (LinearQuad::compatible(tp, num_vertices, eval_set)) return MB_SUCCESS;
@@ -114,9 +109,9 @@ namespace moab {
return MB_NOT_IMPLEMENTED;
- ErrorCode ElemEvaluator::find_containing_entity(Range &entities, const double *point, const double iter_tol,
- const double inside_tol, EntityHandle &containing_ent,
- double *params, unsigned int *num_evals)
+ ErrorCode ElemEvaluator::find_containing_entity(Range &entities, const double *point, double tol,
+ EntityHandle &containing_ent, double *params,
+ unsigned int *num_evals)
bool is_inside;
ErrorCode rval = MB_SUCCESS;
@@ -125,7 +120,7 @@ namespace moab {
for(i = entities.begin(); i != entities.end(); i++) {
nevals++;
set_ent_handle(*i);
- rval = reverse_eval(point, iter_tol, inside_tol, params, &is_inside);
+ rval = reverse_eval(point, tol, params, &is_inside);
if (is_inside) break;
diff --git a/src/LocalDiscretization/LinearHex.cpp b/src/LocalDiscretization/LinearHex.cpp
index 5e730af..14de2d9 100644
--- a/src/LocalDiscretization/LinearHex.cpp
+++ b/src/LocalDiscretization/LinearHex.cpp
@@ -96,12 +96,10 @@ namespace moab
ErrorCode LinearHex::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
const double *posn, const double *verts, const int nverts, const int ndim,
- const double iter_tol, const double inside_tol, double *work,
- double *params, bool *is_inside)
+ const double tol, double *work, double *params, bool *is_inside)
assert(posn && verts);
- return EvalSet::evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol, work,
- params, is_inside);
+ return EvalSet::evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, tol, work, params, is_inside);
bool LinearHex::insideFcn(const double *params, const int ndim, const double tol)
diff --git a/src/LocalDiscretization/LinearQuad.cpp b/src/LocalDiscretization/LinearQuad.cpp
index 63c9959..93237f9 100644
--- a/src/LocalDiscretization/LinearQuad.cpp
+++ b/src/LocalDiscretization/LinearQuad.cpp
@@ -75,11 +75,9 @@ namespace moab
ErrorCode LinearQuad::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
bool LinearQuad::insideFcn(const double *params, const int ndim, const double tol)
diff --git a/src/LocalDiscretization/LinearTet.cpp b/src/LocalDiscretization/LinearTet.cpp
index 4965cfc..705dbee 100644
--- a/src/LocalDiscretization/LinearTet.cpp
+++ b/src/LocalDiscretization/LinearTet.cpp
@@ -74,29 +74,27 @@ namespace moab
ErrorCode LinearTet::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
- return evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol,
- work, params, is_inside);
+ return evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, tol, work, params, is_inside);
bool LinearTet::insideFcn(const double *params, const int , const double tol)
return (params[0] >= -1.0-tol && params[1] >= -1.0-tol && params[2] >= -1.0-tol &&
- params[0] + params[1] + params[2] <= 1.0+tol);
+ params[0] + params[1] + params[2] <= -1.0+tol);
ErrorCode LinearTet::evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
@@ -140,7 +138,7 @@ namespace moab
if (inside)
return MB_SUCCESS;
diff --git a/src/LocalDiscretization/LinearTri.cpp b/src/LocalDiscretization/LinearTri.cpp
deleted file mode 100644
index 8fe9d23..0000000
--- a/src/LocalDiscretization/LinearTri.cpp
+++ /dev/null
@@ -1,145 +0,0 @@
-#include "moab/Forward.hpp"
-#include <algorithm>
-namespace moab
- const double LinearTri::corner[3][2] = { {0,0},
- {1,0},
- {0,1}};
- ErrorCode LinearTri::initFcn(const double *verts, const int /*nverts*/, double *&work) {
- // allocate work array as:
- // work[0..8] = T
- // work[9..17] = Tinv
- // work[18] = detT
- // work[19] = detTinv
- assert(!work && verts);
- work = new double[20];
- Matrix3 *T = reinterpret_cast<Matrix3*>(work),
- *Tinv = reinterpret_cast<Matrix3*>(work+9);
- double *detT = work+18, *detTinv = work+19;
- *T = Matrix3(verts[1*3+0]-verts[0*3+0],verts[2*3+0]-verts[0*3+0],0.0,
- verts[1*3+1]-verts[0*3+1],verts[2*3+1]-verts[0*3+1],0.0,
- verts[1*3+2]-verts[0*3+2],verts[2*3+2]-verts[0*3+2],1.0);
- *T *= 0.5;
- (*T)(2,2) = 1.0;
- *Tinv = T->inverse();
- *detT = T->determinant();
- *detTinv = (0.0 == *detT ? HUGE : 1.0 / *detT);
- return MB_SUCCESS;
- ErrorCode LinearTri::evalFcn(const double *params, const double *field, const int /*ndim*/, const int num_tuples,
- double */*work*/, double *result) {
- assert(params && field && num_tuples > 0);
- // convert to [0,1]
- double p1 = 0.5 * (1.0 + params[0]),
- p2 = 0.5 * (1.0 + params[1]),
- p0 = 1.0 - p1 - p2;
- for (int j = 0; j < num_tuples; j++)
- result[j] = p0 * field[0*num_tuples+j] + p1 * field[1*num_tuples+j] + p2 * field[2*num_tuples+j];
- ErrorCode LinearTri::integrateFcn(const double *field, const double */*verts*/, const int /*nverts*/, const int /*ndim*/, const int num_tuples,
- double *work, double *result)
- assert(field && num_tuples > 0);
- double tmp = work[18];
- for (int i = 0; i < num_tuples; i++)
- result[i] = tmp * (field[num_tuples+i] + field[2*num_tuples+i]);
- ErrorCode LinearTri::jacobianFcn(const double *, const double *, const int, const int ,
- // jacobian is cached in work array
- assert(work);
- std::copy(work, work+9, result);
- ErrorCode LinearTri::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
- const double *posn, const double *verts, const int nverts, const int ndim,
- assert(posn && verts);
- return evaluate_reverse(eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol, work,
- bool LinearTri::insideFcn(const double *params, const int , const double tol)
- return (params[0] >= -1.0-tol && params[1] >= -1.0-tol &&
- params[0] + params[1] <= 1.0+tol);
- ErrorCode LinearTri::evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
- // TODO: should differentiate between epsilons used for
- // Newton Raphson iteration, and epsilons used for curved boundary geometry errors
- // right now, fix the tolerance used for NR
- CartVect *cvparams = reinterpret_cast<CartVect*>(params);
- const CartVect *cvposn = reinterpret_cast<const CartVect*>(posn);
- // find best initial guess to improve convergence
- CartVect tmp_params[] = {CartVect(-1,-1,-1), CartVect(1,-1,-1), CartVect(-1,1,-1)};
- double resl = HUGE;
- CartVect new_pos, tmp_pos;
- ErrorCode rval;
- for (unsigned int i = 0; i < 3; i++) {
- rval = (*eval)(tmp_params[i].array(), verts, ndim, 3, work, tmp_pos.array());
- if (MB_SUCCESS != rval) return rval;
- double tmp_resl = (tmp_pos-*cvposn).length_squared();
- if (tmp_resl < resl) {
- *cvparams = tmp_params[i];
- new_pos = tmp_pos;
- resl = tmp_resl;
- // residual is diff between old and new pos; need to minimize that
- CartVect res = new_pos - *cvposn;
- Matrix3 J;
- rval = (*jacob)(cvparams->array(), verts, nverts, ndim, work, J[0]);
- double det = J.determinant();
- assert(det > std::numeric_limits<double>::epsilon());
- Matrix3 Ji = J.inverse(1.0/det);
- int iters=0;
- // while |res| larger than tol
- while (res % res > error_tol_sqr) {
- if(++iters>25)
- return MB_FAILURE;
- // new params tries to eliminate residual
- *cvparams -= Ji * res;
- // get the new forward-evaluated position, and its difference from the target pt
- rval = (*eval)(params, verts, ndim, 3, work, new_pos.array());
- res = new_pos - *cvposn;
- if (inside)
- }// Map::evaluate_reverse()
-} // namespace moab
diff --git a/src/LocalDiscretization/Makefile.am b/src/LocalDiscretization/Makefile.am
index cb34071..7309aef 100644
--- a/src/LocalDiscretization/Makefile.am
+++ b/src/LocalDiscretization/Makefile.am
@@ -17,7 +17,6 @@ MOAB_LOCALDISCR_SRCS = \
LinearHex.cpp \
LinearQuad.cpp \
LinearTet.cpp \
- LinearTri.cpp \
QuadraticHex.cpp
MOAB_LOCALDISCR_HDRS = \
@@ -25,7 +24,6 @@ MOAB_LOCALDISCR_HDRS = \
moab/LinearHex.hpp \
moab/LinearQuad.hpp \
moab/LinearTet.hpp \
- moab/LinearTri.hpp \
moab/QuadraticHex.hpp
# The list of source files, and any header files that do not need to be installed
diff --git a/src/LocalDiscretization/QuadraticHex.cpp b/src/LocalDiscretization/QuadraticHex.cpp
index 5c621f6..ca4758b 100644
--- a/src/LocalDiscretization/QuadraticHex.cpp
+++ b/src/LocalDiscretization/QuadraticHex.cpp
@@ -107,12 +107,10 @@ namespace moab
ErrorCode QuadraticHex::reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
bool QuadraticHex::insideFcn(const double *params, const int ndim, const double tol)
diff --git a/src/LocalDiscretization/SpectralHex.cpp b/src/LocalDiscretization/SpectralHex.cpp
index 31f5391..0e40eba 100644
--- a/src/LocalDiscretization/SpectralHex.cpp
+++ b/src/LocalDiscretization/SpectralHex.cpp
@@ -73,8 +73,7 @@ CartVect SpectralHex::evaluate( const CartVect& params ) const
return result;
// replicate the functionality of hex_findpt
- bool SpectralHex::evaluate_reverse(CartVect const & xyz, CartVect ¶ms, double iter_tol, const double inside_tol,
- const CartVect &init) const
+bool SpectralHex::evaluate_reverse(CartVect const & xyz, CartVect ¶ms, double tol, const CartVect &init) const
params = init;
@@ -93,7 +92,7 @@ CartVect SpectralHex::evaluate( const CartVect& params ) const
//copy parametric coords back
params = r;
- return is_inside(params, inside_tol);
+ return is_inside(params, tol);
Matrix3 SpectralHex::jacobian(const CartVect& params) const
diff --git a/src/LocalDiscretization/SpectralQuad.cpp b/src/LocalDiscretization/SpectralQuad.cpp
index 5c11d13..cbd1251 100644
--- a/src/LocalDiscretization/SpectralQuad.cpp
+++ b/src/LocalDiscretization/SpectralQuad.cpp
@@ -95,8 +95,7 @@ CartVect SpectralQuad::evalFcn(const double *params, const double *field, const
bool SpectralQuad::reverseEvalFcn(const double *posn, const double *verts, const int nverts, const int ndim,
params = init;
@@ -115,7 +114,7 @@ bool SpectralQuad::reverseEvalFcn(const double *posn, const double *verts, const
params = r;
- return insideFcn(params, 2, inside_tol);
+ return insideFcn(params, 2, tol);
diff --git a/src/LocalDiscretization/moab/ElemEvaluator.hpp b/src/LocalDiscretization/moab/ElemEvaluator.hpp
index 29d1051..eac008d 100644
--- a/src/LocalDiscretization/moab/ElemEvaluator.hpp
+++ b/src/LocalDiscretization/moab/ElemEvaluator.hpp
@@ -25,8 +25,7 @@ namespace moab {
typedef ErrorCode (*ReverseEvalFcn)(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
- double *work, double *params, bool *is_inside);
+ const double tol, double *work, double *params, bool *is_inside);
class EvalSet
@@ -77,8 +76,8 @@ namespace moab {
/** \brief Common function to do reverse evaluation based on evaluation and jacobian functions */
static ErrorCode evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
- double *work, double *params, bool *inside);
+ const int ndim, const double tol, double *work, double *params,
+ bool *inside);
/** \brief Common function that returns true if params is in [-1,1]^ndims */
static bool inside_function(const double *params, const int ndims, const double tol);
@@ -134,14 +133,12 @@ namespace moab {
/** \brief Reverse-evaluate the cached entity at a given physical position
* \param posn Position at which to evaluate parameters
- * \param iter_tol Tolerance of reverse evaluation non-linear iteration, usually 10^-10 or so
- * \param inside_tol Tolerance of is_inside evaluation, usually 10^-6 or so
+ * \param tol Tolerance of reverse evaluation, usually 10^-6 or so
* \param params Result of evaluation
* \param is_inside If non-NULL, returns true of resulting parameters place the point inside the element
* (in most cases, within [-1]*(dim)
- ErrorCode reverse_eval(const double *posn, double iter_tol, double inside_tol, double *params,
- bool *is_inside = NULL) const;
+ ErrorCode reverse_eval(const double *posn, double tol, double *params, bool *is_inside = NULL) const;
/** \brief Evaluate the jacobian of the cached entity at a given parametric location
* \param params Parameters at which to evaluate jacobian
@@ -169,16 +166,14 @@ namespace moab {
* object is changed.
* \param entities Entities tested
* \param point Point tested, must have 3 dimensions, even for edge and face entities
- * \param iter_tol Tolerance for non-linear reverse evaluation
- * \param inside_tol Tolerance for is_inside test
+ * \param tol Tolerance for is_inside test
* \param containing_ent Entity containing the point, returned 0 if no entity
* \param params Parameters of point in containing entity, unchanged if no containing entity
* \param num_evals If non-NULL, incremented each time reverse_eval is called
* \return Returns non-success only if evaulation failed for some reason (point not in element is NOT a
* reason for failure)
- ErrorCode find_containing_entity(Range &entities, const double *point,
+ ErrorCode find_containing_entity(Range &entities, const double *point, double tol,
unsigned int *num_evals = NULL);
@@ -191,16 +186,14 @@ namespace moab {
* \param ent_set Entity set containing the entities to be tested
- ErrorCode find_containing_entity(EntityHandle ent_set, const double *point,
+ ErrorCode find_containing_entity(EntityHandle ent_set, const double *point, double tol,
@@ -225,12 +218,8 @@ namespace moab {
inline ErrorCode set_ent_handle(EntityHandle ent);
/** \brief Get entity handle for this ElemEval */
- inline EntityHandle get_ent_handle() const {return entHandle;}
+ inline EntityHandle get_ent_handle() const {return entHandle;};
- /* \brief Get vertex positions cached on this EE
- inline double *get_vert_pos() {return vertPos[0].array();}
/* \brief Get the vertex handles cached here */
inline const EntityHandle *get_vert_handles() const {return vertHandles;}
@@ -262,11 +251,6 @@ namespace moab {
/* \brief Set the dimension of entities having the tag */
inline ErrorCode set_tagged_ent_dim(int dim);
- /* \brief Get work space, sometimes this is useful for evaluating data you don't want to set as tags on entities
- * Can't be const because most of the functions (evaluate, integrate, etc.) take non-const work space *'s
- inline double *get_work_space() {return workSpace;}
/* \brief MOAB interface cached on this evaluator */
inline Interface *get_moab() {return mbImpl;}
@@ -450,13 +434,12 @@ namespace moab {
(-1 == num_tuples ? numTuples : num_tuples), workSpace, result);
- inline ErrorCode ElemEvaluator::reverse_eval(const double *posn, const double iter_tol, const double inside_tol,
- double *params, bool *ins) const
+ inline ErrorCode ElemEvaluator::reverse_eval(const double *posn, const double tol, double *params, bool *ins) const
assert(entHandle && MBMAXTYPE != entType);
return (*evalSets[entType].reverseEvalFcn)(evalSets[entType].evalFcn, evalSets[entType].jacobianFcn, evalSets[entType].insideFcn,
posn, vertPos[0].array(), numVerts,
- entDim, iter_tol, inside_tol, workSpace, params, ins);
+ entDim, tol, workSpace, params, ins);
/** \brief Evaluate the jacobian of the cached entity at a given parametric location */
@@ -481,8 +464,7 @@ namespace moab {
workSpace, result);
- inline ErrorCode ElemEvaluator::find_containing_entity(EntityHandle ent_set, const double *point,
+ inline ErrorCode ElemEvaluator::find_containing_entity(EntityHandle ent_set, const double *point, double tol,
@@ -490,7 +472,7 @@ namespace moab {
Range entities;
ErrorCode rval = mbImpl->get_entities_by_handle(ent_set, entities);
- else return find_containing_entity(entities, point, iter_tol, inside_tol, containing_ent, params, num_evals);
+ else return find_containing_entity(entities, point, tol, containing_ent, params, num_evals);
inline bool ElemEvaluator::inside(const double *params, const double tol) const
diff --git a/src/LocalDiscretization/moab/LinearHex.hpp b/src/LocalDiscretization/moab/LinearHex.hpp
index 03ed33f..e7ca3f4 100644
--- a/src/LocalDiscretization/moab/LinearHex.hpp
+++ b/src/LocalDiscretization/moab/LinearHex.hpp
@@ -17,8 +17,7 @@ public:
/** \brief Reverse-evaluation of parametric coordinates at physical space position */
static ErrorCode reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
- double *params, bool *is_inside);
/** \brief Evaluate the jacobian at a specified parametric position */
static ErrorCode jacobianFcn(const double *params, const double *verts, const int nverts, const int ndim,
diff --git a/src/LocalDiscretization/moab/LinearQuad.hpp b/src/LocalDiscretization/moab/LinearQuad.hpp
index 2eb3027..26882a1 100644
--- a/src/LocalDiscretization/moab/LinearQuad.hpp
+++ b/src/LocalDiscretization/moab/LinearQuad.hpp
diff --git a/src/LocalDiscretization/moab/LinearTet.hpp b/src/LocalDiscretization/moab/LinearTet.hpp
index f621b2f..464b1f6 100644
--- a/src/LocalDiscretization/moab/LinearTet.hpp
+++ b/src/LocalDiscretization/moab/LinearTet.hpp
@@ -36,7 +35,7 @@ public:
- const int ndim, const double iter_tol, const double inside_tol, double *work,
static EvalSet eval_set()
@@ -46,7 +45,7 @@ public:
static bool compatible(EntityType tp, int numv, EvalSet &eset)
- if (tp == MBTET && numv >= 4) {
+ if (tp == MBTET && numv == 4) {
eset = eval_set();
return true;
diff --git a/src/LocalDiscretization/moab/LinearTri.hpp b/src/LocalDiscretization/moab/LinearTri.hpp
index 93820a7..0000000
--- a/src/LocalDiscretization/moab/LinearTri.hpp
+++ /dev/null
@@ -1,63 +0,0 @@
-#ifndef LINEAR_TRI_HPP
-#define LINEAR_TRI_HPP
- /**\brief Shape function space for trilinear tetrahedron, obtained by a pushforward of the canonical linear (affine) functions. */
-#include "moab/ElemEvaluator.hpp"
-namespace moab
-class LinearTri
-public:
- /** \brief Forward-evaluation of field at parametric coordinates */
- static ErrorCode evalFcn(const double *params, const double *field, const int ndim, const int num_tuples,
- double *work, double *result);
- /** \brief Reverse-evaluation of parametric coordinates at physical space position */
- static ErrorCode reverseEvalFcn(EvalFcn eval, JacobianFcn jacob, InsideFcn ins,
- /** \brief Evaluate the jacobian at a specified parametric position */
- static ErrorCode jacobianFcn(const double *params, const double *verts, const int nverts, const int ndim,
- static ErrorCode integrateFcn(const double *field, const double *verts, const int nverts, const int ndim, const int num_tuples,
- /** \brief Initialize this EvalSet */
- static ErrorCode initFcn(const double *verts, const int nverts, double *&work);
- /** \brief Function that returns whether or not the parameters are inside the natural space of the element */
- static bool insideFcn(const double *params, const int ndim, const double tol);
- static ErrorCode evaluate_reverse(EvalFcn eval, JacobianFcn jacob, InsideFcn inside_f,
- double *params, bool *inside);
- static EvalSet eval_set()
- return EvalSet(evalFcn, reverseEvalFcn, jacobianFcn, integrateFcn, initFcn, insideFcn);
- static bool compatible(EntityType tp, int numv, EvalSet &eset)
- if (tp == MBTRI && numv >= 3) {
- eset = eval_set();
- return true;
- else return false;
-protected:
- static const double corner[3][2];
-};// class LinearTri
-#endif
diff --git a/src/LocalDiscretization/moab/QuadraticHex.hpp b/src/LocalDiscretization/moab/QuadraticHex.hpp
index 0e5cfb8..0801ad7 100644
--- a/src/LocalDiscretization/moab/QuadraticHex.hpp
+++ b/src/LocalDiscretization/moab/QuadraticHex.hpp
diff --git a/src/LocalDiscretization/moab/SpectralHex.hpp b/src/LocalDiscretization/moab/SpectralHex.hpp
index 648cc70..e6464c3 100644
--- a/src/LocalDiscretization/moab/SpectralHex.hpp
+++ b/src/LocalDiscretization/moab/SpectralHex.hpp
@@ -19,8 +19,7 @@ public:
diff --git a/src/LocalDiscretization/moab/SpectralQuad.hpp b/src/LocalDiscretization/moab/SpectralQuad.hpp
index a72f9b4..8716a43 100644
--- a/src/LocalDiscretization/moab/SpectralQuad.hpp
+++ b/src/LocalDiscretization/moab/SpectralQuad.hpp
diff --git a/src/MergeMesh.cpp b/src/MergeMesh.cpp
index 72c4f66..4cc8158 100644
--- a/src/MergeMesh.cpp
+++ b/src/MergeMesh.cpp
@@ -171,7 +171,7 @@ moab::ErrorCode MergeMesh::find_merged_to(moab::EntityHandle &tree_root,
// check close-by leaves too
leaves_out.clear();
result = tree.distance_search(from.array(), mergeTol,
- leaves_out, mergeTol, 1.0e-6, NULL, NULL, &tree_root);
+ leaves_out, 0.0, NULL, NULL, &tree_root);
leaf_range2.clear();
for (std::vector<moab::EntityHandle>::iterator vit = leaves_out.begin();
vit != leaves_out.end(); vit++) {
diff --git a/src/SpatialLocator.cpp b/src/SpatialLocator.cpp
index f765ab9..d3b521e 100644
--- a/src/SpatialLocator.cpp
+++ b/src/SpatialLocator.cpp
@@ -3,8 +3,6 @@
#include "moab/AdaptiveKDTree.hpp"
-bool debug = true;
namespace moab
@@ -35,47 +33,41 @@ namespace moab
#ifdef USE_MPI
ErrorCode SpatialLocator::par_locate_points(Range &/*vertices*/,
- const double /*rel_iter_tol*/, const double /*abs_iter_tol*/,
- const double /*inside_tol*/)
+ double /*rel_tol*/, double /*abs_tol*/)
return MB_UNSUPPORTED_OPERATION;
ErrorCode SpatialLocator::par_locate_points(const double */*pos*/, int /*num_points*/,
#endif
ErrorCode SpatialLocator::locate_points(Range &verts,
- const double rel_iter_tol, const double abs_iter_tol,
- const double inside_tol)
+ double rel_eps, double abs_eps)
assert(!verts.empty() && mbImpl->type_from_handle(*verts.rbegin()) == MBVERTEX);
std::vector<double> pos(3*verts.size());
ErrorCode rval = mbImpl->get_coords(verts, &pos[0]);
- rval = locate_points(&pos[0], verts.size(), rel_iter_tol, abs_iter_tol, inside_tol);
+ rval = locate_points(&pos[0], verts.size(), rel_eps, abs_eps);
return MB_SUCCESS;
ErrorCode SpatialLocator::locate_points(const double *pos, int num_points,
// initialize to tuple structure (p_ui, hs_ul, r[3]_d) (see header comments for locTable)
locTable.initialize(1, 0, 1, 3, num_points);
locTable.enableWriteAccess();
// pass storage directly into locate_points, since we know those arrays are contiguous
- ErrorCode rval = locate_points(pos, num_points, locTable.vul_wr, locTable.vr_wr, NULL, rel_iter_tol, abs_iter_tol,
- inside_tol);
+ ErrorCode rval = locate_points(pos, num_points, locTable.vul_wr, locTable.vr_wr, NULL, rel_eps, abs_eps);
std::fill(locTable.vi_wr, locTable.vi_wr+num_points, 0);
- locTable.set_n(num_points);
return MB_SUCCESS;
@@ -83,27 +75,25 @@ namespace moab
EntityHandle *ents, double *params, bool *is_inside,
- return locate_points(&pos[0], verts.size(), ents, params, is_inside, rel_iter_tol, abs_iter_tol, inside_tol);
+ return locate_points(&pos[0], verts.size(), ents, params, is_inside, rel_eps, abs_eps);
- double tmp_abs_iter_tol = abs_iter_tol;
- if (rel_iter_tol && !tmp_abs_iter_tol) {
+ if (rel_eps && !abs_eps) {
// relative epsilon given, translate to absolute epsilon using box dimensions
BoundBox box;
myTree->get_bounding_box(box);
- tmp_abs_iter_tol = rel_iter_tol * box.diagonal_length();
+ abs_eps = rel_eps * box.diagonal_length();
EntityHandle closest_leaf;
@@ -114,8 +104,8 @@ namespace moab
for (int i = 0; i < num_points; i++) {
int i3 = 3*i;
ents[i] = 0;
- if (tmp_abs_iter_tol) {
- rval = myTree->distance_search(pos+i3, tmp_abs_iter_tol, leaves, tmp_abs_iter_tol, inside_tol, &dists);
+ if (abs_eps) {
+ rval = myTree->distance_search(pos+i3, abs_eps, leaves, abs_eps, &dists);
if (!leaves.empty()) {
// get closest leaf
@@ -155,71 +145,22 @@ namespace moab
// loop over the range_leaf
bool tmp_inside;
- bool *is_ptr = (is_inside ? is_inside+i : &tmp_inside);
- *is_ptr = false;
- EntityHandle ent = 0;
for(Range::iterator rit = range_leaf.begin(); rit != range_leaf.end(); rit++)
+ bool *is_ptr = (is_inside ? is_inside+i : &tmp_inside);
rval = elemEval->set_ent_handle(*rit);
- rval = elemEval->reverse_eval(pos+i3, tmp_abs_iter_tol, inside_tol, params+i3, is_ptr);
+ rval = elemEval->reverse_eval(pos+i3, abs_eps, params+i3, is_ptr);
if (*is_ptr) {
- ent = *rit;
+ ents[i] = *rit;
break;
- if (debug && !ent) {
- std::cout << "Point " << i << " not found; point: ("
- << pos[i3] << "," << pos[i3+1] << "," << pos[i3+2] << ")" << std::endl;
- std::cout << "Source element candidates: " << std::endl;
- range_leaf.print(" ");
- for(Range::iterator rit = range_leaf.begin(); rit != range_leaf.end(); rit++)
- std::cout << "Candidate " << CN::EntityTypeName(mbImpl->type_from_handle(*rit)) << " " << mbImpl->id_from_handle(*rit) << ": ";
- rval = elemEval->set_ent_handle(*rit);
- std::cout << "Parameters: (" << params[i3] << "," << params[i3+1] << "," << params[i3+2] << ")"
- << " inside = " << *is_ptr << std::endl;
- ents[i] = ent;
return MB_SUCCESS;
- /* Count the number of located points in locTable
- * Return the number of entries in locTable that have non-zero entity handles, which
- * represents the number of points in targetEnts that were inside one element in sourceEnts
- int SpatialLocator::local_num_located()
- int num_located = locTable.get_n() - std::count(locTable.vul_rd, locTable.vul_rd+locTable.get_n(), 0);
- if (num_located != (int)locTable.get_n()) {
- unsigned long *nl = std::find(locTable.vul_rd, locTable.vul_rd+locTable.get_n(), 0);
- if (nl) {
- int idx = nl - locTable.vul_rd;
- if (idx) {}
- return num_located;
- /* Count the number of located points in parLocTable
- * Return the number of entries in parLocTable that have a non-negative index in on a remote
- * proc in parLocTable, which gives the number of points located in at least one element in a
- * remote proc's sourceEnts.
- int SpatialLocator::remote_num_located()
- int located = 0;
- for (unsigned int i = 0; i < parLocTable.get_n(); i++)
- if (parLocTable.vi_rd[2*i] != -1) located++;
- return located;
} // namespace moab
diff --git a/src/moab/AdaptiveKDTree.hpp b/src/moab/AdaptiveKDTree.hpp
index 54d48e5..4a5ce1b 100644
--- a/src/moab/AdaptiveKDTree.hpp
+++ b/src/moab/AdaptiveKDTree.hpp
@@ -68,8 +68,7 @@ namespace moab {
* containing the point in that case.
* \param point Point to be located in tree
* \param leaf_out Leaf containing point
- * \param iter_tol Tolerance for convergence of point search
- * \param inside_tol Tolerance for inside element calculation
+ * \param tol Tolerance below which a point is "in"
* \param multiple_leaves Some tree types can have multiple leaves containing a point;
* if non-NULL, this parameter is returned true if multiple leaves contain
* the input point
@@ -78,8 +77,7 @@ namespace moab {
virtual ErrorCode point_search(const double *point,
- const double iter_tol = 1.0e-10,
- const double inside_tol = 1.0e-6,
+ double tol = 0.0,
bool *multiple_leaves = NULL,
EntityHandle *start_node = NULL,
CartVect *params = NULL);
@@ -94,8 +92,7 @@ namespace moab {
* \param leaf_it Iterator to leaf containing point
* the input point
@@ -104,8 +101,7 @@ namespace moab {
+ double tol = 0.0,
EntityHandle *start_node = NULL);
@@ -118,8 +114,7 @@ namespace moab {
* \param distance Distance within which to query
* \param leaves_out Leaves within distance or containing point
* \param dists_out If non-NULL, will contain distsances to leaves
* \param params_out If non-NULL, will contain parameters of the point in the ents in leaves_out
* \param start_node Start from this tree node (non-NULL) instead of tree root (NULL)
@@ -127,8 +122,7 @@ namespace moab {
virtual ErrorCode distance_search(const double *point,
std::vector<EntityHandle>& leaves_out,
+ double tol = 0.0,
std::vector<double> *dists_out = NULL,
std::vector<CartVect> *params_out = NULL,
diff --git a/src/moab/BVHTree.hpp b/src/moab/BVHTree.hpp
index d435ebf..7f0c7ec 100644
--- a/src/moab/BVHTree.hpp
+++ b/src/moab/BVHTree.hpp
@@ -74,8 +74,7 @@ namespace moab {
* the input point
@@ -84,8 +83,7 @@ namespace moab {
+ double tol = 0.0,
@@ -99,8 +97,7 @@ namespace moab {
* \param from_point Point to be located in tree
* \param result_list Leaves within distance or containing point
* \param result_dists If non-NULL, will contain distsances to leaves
* \param result_params If non-NULL, will contain parameters of the point in the ents in leaves_out
* \param tree_root Start from this tree node (non-NULL) instead of tree root (NULL)
@@ -108,8 +105,7 @@ namespace moab {
virtual ErrorCode distance_search(const double from_point[3],
+ double tol = 0.0,
std::vector<double> *result_dists = NULL,
std::vector<CartVect> *result_params = NULL,
EntityHandle *tree_root = NULL);
@@ -246,13 +242,10 @@ namespace moab {
ErrorCode find_point(const std::vector<double> &point,
+ const double tol,
std::pair<EntityHandle, CartVect> &result);
- EntityHandle bruteforce_find(const double *point,
- const double inside_tol = 1.0e-6);
+ EntityHandle bruteforce_find(const double *point, const double tol);
int local_build_tree(std::vector<Node> &tree_nodes,
HandleDataVec::iterator begin,
diff --git a/src/moab/SpatialLocator.hpp b/src/moab/SpatialLocator.hpp
index bb639d0..780c086 100644
--- a/src/moab/SpatialLocator.hpp
+++ b/src/moab/SpatialLocator.hpp
@@ -62,44 +62,26 @@ namespace moab {
/* locate a set of vertices, Range variant */
ErrorCode locate_points(Range &vertices,
EntityHandle *ents, double *params, bool *is_inside = NULL,
- const double rel_iter_tol = 1.0e-10, const double abs_iter_tol = 1.0e-10,
+ double rel_tol = 0.0, double abs_tol = 0.0);
/* locate a set of points */
ErrorCode locate_points(const double *pos, int num_points,
/* locate a set of vertices or entity centroids, storing results on TupleList in this class
* Locate a set of vertices or entity centroids, storing the detailed results in member
* variable (TupleList) locTable (see comments on locTable for structure of that tuple).
ErrorCode locate_points(Range &ents,
/* locate a set of points, storing results on TupleList in this class
* Locate a set of points, storing the detailed results in member variable (TupleList) locTable
* (see comments on locTable for structure of that tuple).
- int local_num_located();
- int remote_num_located();
#ifdef USE_MPI
@@ -108,8 +90,7 @@ namespace moab {
* structure of those tuples).
ErrorCode par_locate_points(Range &vertices,
@@ -117,8 +98,7 @@ namespace moab {
ErrorCode par_locate_points(const double *pos, int num_points,
#endif
/* return the tree */
@@ -147,15 +127,14 @@ namespace moab {
const ElemEvaluator *elem_eval() const {return elemEval;}
/* set elemEval */
- void elem_eval(ElemEvaluator *eval) {elemEval = eval; if (myTree) myTree->set_eval(eval);}
+ void elem_eval(ElemEvaluator *eval) {elemEval = eval;}
private:
/* locate a point */
ErrorCode locate_point(const double *pos,
EntityHandle &ent, double *params, bool *is_inside = NULL,
/* MOAB instance */
Interface* mbImpl;
@@ -206,10 +185,9 @@ namespace moab {
inline ErrorCode SpatialLocator::locate_point(const double *pos,
EntityHandle &ent, double *params, bool *is_inside,
+ double rel_tol, double abs_tol)
- return locate_points(pos, 1, &ent, params, is_inside, rel_iter_tol, abs_iter_tol, inside_tol);
+ return locate_points(pos, 1, &ent, params, is_inside, rel_tol, abs_tol);
inline ErrorCode SpatialLocator::get_bounding_box(BoundBox &box)
diff --git a/src/moab/Tree.hpp b/src/moab/Tree.hpp
index 4d2694a..c2a117c 100644
--- a/src/moab/Tree.hpp
+++ b/src/moab/Tree.hpp
@@ -100,8 +100,7 @@ namespace moab {
* the input point
@@ -110,8 +109,7 @@ namespace moab {
+ double tol = 0.0,
CartVect *params = NULL) = 0;
@@ -125,8 +123,7 @@ namespace moab {
@@ -134,8 +131,7 @@ namespace moab {
+ double params_tol = 0.0,
EntityHandle *start_node = NULL) = 0;
diff --git a/test/elem_eval_test.cpp b/test/elem_eval_test.cpp
index 1e669c3..6f07d7a 100644
--- a/test/elem_eval_test.cpp
+++ b/test/elem_eval_test.cpp
@@ -7,7 +7,6 @@
#include "moab/Core.hpp"
#include "moab/ReadUtilIface.hpp"
@@ -23,7 +22,6 @@ std::string TestDir(".");
using namespace moab;
-void test_linear_tri();
void test_linear_quad();
void test_linear_hex();
void test_linear_tet();
@@ -80,11 +78,11 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
if (!test_integrate) return;
- // tag equal to coordinates should integrate to avg position, test that
+ // tag equal to coordinates should integrate to avg position, since volume is 1
Tag tag;
// make a temporary tag and set it on vertices to the vertex positions
rval = ee.get_moab()->tag_get_handle(NULL, 3, MB_TYPE_DOUBLE, tag, MB_TAG_DENSE | MB_TAG_CREAT); CHECK_ERR(rval);
- rval = ee.get_moab()->tag_set_data(tag, ee.get_vert_handles(), ee.get_num_verts(), ee.get_vert_pos()); CHECK_ERR(rval);
+ rval = ee.get_moab()->tag_set_data(tag, ee.get_vert_handles(), ee.get_num_verts(), hex_verts[0].array()); CHECK_ERR(rval);
// set that temporary tag on the evaluator so that's what gets integrated
rval = ee.set_tag_handle(tag, 0); CHECK_ERR(rval);
@@ -97,8 +95,8 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
EvalSet es;
EntityHandle eh = ee.get_ent_handle();
rval = EvalSet::get_eval_set(ee.get_moab(), eh, es); CHECK_ERR(rval);
- rval = (*es.integrateFcn)(&one[0], ee.get_vert_pos(), ee.get_num_verts(), ee.get_moab()->dimension_from_handle(eh),
- 1, ee.get_work_space(), &measure); CHECK_ERR(rval);
+ rval = (*es.integrateFcn)(&one[0], hex_verts[0].array(), ee.get_num_verts(), ee.get_moab()->dimension_from_handle(eh),
+ 1, NULL, &measure); CHECK_ERR(rval);
if (measure) integral /= measure;
// check against avg of entity's vertices' positions
@@ -138,7 +136,6 @@ int main()
int failures = 0;
-// failures += RUN_TEST(test_linear_tri); currently failing linear tri, bad formulation, working on it...
failures += RUN_TEST(test_linear_quad);
failures += RUN_TEST(test_linear_hex);
failures += RUN_TEST(test_quadratic_hex);
@@ -147,28 +144,6 @@ int main()
return failures;
- Core mb;
- Range verts;
- double tri_verts[] = {-1.0, -1.0, -1.0,
- 1.0, -1.0, -1.0,
- -1.0, 1.0, -1.0};
- ErrorCode rval = mb.create_vertices(tri_verts, 3, verts); CHECK_ERR(rval);
- EntityHandle tri;
- std::vector<EntityHandle> connect;
- std::copy(verts.begin(), verts.end(), std::back_inserter(connect));
- rval = mb.create_element(MBTRI, &connect[0], 3, tri); CHECK_ERR(rval);
- ElemEvaluator ee(&mb, tri, 0);
- ee.set_tag_handle(0, 0);
- ee.set_eval_set(MBTRI, LinearTri::eval_set());
- test_eval(ee, true);
Core mb;
diff --git a/tools/mbcoupler/Coupler.cpp b/tools/mbcoupler/Coupler.cpp
index 0a10d14..71231b8 100644
--- a/tools/mbcoupler/Coupler.cpp
+++ b/tools/mbcoupler/Coupler.cpp
@@ -614,7 +614,7 @@ ErrorCode Coupler::nat_param(double xyz[3],
if (epsilon) {
std::vector<double> dists;
std::vector<EntityHandle> leaves;
- result = myTree->distance_search(xyz, epsilon, leaves, 1.0e-10, 1.0e-6, &dists, NULL, &localRoot);
+ result = myTree->distance_search(xyz, epsilon, leaves, 0.0, &dists, NULL, &localRoot);
if (leaves.empty())
// not found returns success here, with empty list, just like case with no epsilon
return MB_SUCCESS;
@@ -631,7 +631,7 @@ ErrorCode Coupler::nat_param(double xyz[3],
else {
- result = myTree->point_search(xyz, treeiter, 1.0e-10, 1.0e-6, NULL, &localRoot);
+ result = myTree->point_search(xyz, treeiter, 0.0, NULL, &localRoot);
if(MB_ENTITY_NOT_FOUND==result) //point is outside of myTree's bounding box
return MB_SUCCESS;
else if (MB_SUCCESS != result) {
diff --git a/tools/mbcoupler/DataCoupler.cpp b/tools/mbcoupler/DataCoupler.cpp
index 421f45c..71f3497 100644
--- a/tools/mbcoupler/DataCoupler.cpp
+++ b/tools/mbcoupler/DataCoupler.cpp
@@ -40,8 +40,7 @@ DataCoupler::DataCoupler(Interface *impl,
for (; pit != source_ents.pair_end(); pit++) {
EntityType this_type = mbImpl->type_from_handle(pit->first);
if (last_type == this_type) continue;
- ErrorCode rval = myLocator->elem_eval()->set_eval_set(pit->first);
- if (MB_SUCCESS != rval) throw(rval);
+ myLocator->elem_eval()->set_eval_set(pit->first);
last_type = this_type;
@@ -62,19 +61,19 @@ DataCoupler::~DataCoupler()
ErrorCode DataCoupler::locate_points(Range &targ_ents,
+ double rel_eps,
+ double abs_eps)
targetEnts = targ_ents;
- return myLocator->locate_points(targ_ents, rel_iter_tol, abs_iter_tol, inside_tol);
+ return myLocator->locate_points(targ_ents, rel_eps, abs_eps);
ErrorCode DataCoupler::locate_points(double *xyz, int num_points,
+ double rel_eps,
+ double abs_eps)
- return myLocator->locate_points(xyz, num_points, rel_iter_tol, abs_iter_tol, inside_tol);
+ return myLocator->locate_points(xyz, num_points, rel_eps, abs_eps);
ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int method,
diff --git a/tools/mbcoupler/DataCoupler.hpp b/tools/mbcoupler/DataCoupler.hpp
index bfe2ba5..3ad1d74 100644
--- a/tools/mbcoupler/DataCoupler.hpp
+++ b/tools/mbcoupler/DataCoupler.hpp
@@ -65,9 +65,8 @@ public:
* This is a pass-through function to SpatialLocator::locate_points
* \param xyz Point locations (interleaved) being located
* \param num_points Number of points in xyz
- * \param rel_iter_tol Relative tolerance for non-linear iteration
- * \param abs_iter_tol Relative tolerance for non-linear iteration, usually 10^-10 or so
+ * \param rel_eps Relative tolerance for the non-linear iteration inside a given element
+ * \param abs_eps Absolute tolerance for the non-linear iteration inside a given element
* \param loc_results Tuple list containing the results; two types of results are possible,
* controlled by value of store_local parameter:
* store_local = true: each tuple T[j] consists of (p, i), p = proc with src element containing
@@ -77,15 +76,13 @@ public:
* \param store_local If true, stores the located points on SpatialLocator
ErrorCode locate_points(double *xyz, int num_points,
+ double rel_eps = 0.0, double abs_eps = 0.0);
/* \brief Locate points on the source mesh
* \param ents Target entities being located
@@ -95,8 +92,8 @@ public:
+ double abs_eps = 0.0);
/* \brief Interpolate data from the source mesh onto points
* All entities/points or, if tuple_list is input, only those points
diff --git a/tools/skin.cpp b/tools/skin.cpp
index 25caa43..761f7d2 100644
--- a/tools/skin.cpp
+++ b/tools/skin.cpp
@@ -525,7 +525,7 @@ ErrorCode merge_duplicate_vertices( Interface& moab, const double epsilon )
leaves.clear();;
- rval = tree.distance_search(coords, epsilon, leaves, epsilon, epsilon);
+ rval = tree.distance_search(coords, epsilon, leaves, epsilon);
Range near;
https://bitbucket.org/fathomteam/moab/commits/2f201e3cc437/
Changeset: 2f201e3cc437
Branch: None
User: tautges
Date: 2013-11-28 02:28:05
Summary: Revert "DeformMeshRemap: add some of the data interpolation calls, basically filling"
This reverts commit 50b351b1783034467478a44be883d056d7e84e4b.
Affected #: 12 files
index 500d969..fac83ae 100644
@@ -15,7 +15,6 @@
-#include "DataCoupler.hpp"
#include <iostream>
#include <set>
@@ -85,7 +84,7 @@ public:
private:
//! apply a known deformation to the solid elements, putting the results in the xNew tag; also
//! write current coordinates to the xNew tag for fluid elements
- ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, const char *tag_name = NULL);
+ ErrorCode deform_master(Range &fluid_elems, Range &solid_elems);
//! read a file and establish proper ranges
ErrorCode read_file(int m_or_s, string &fname, EntityHandle &seth);
@@ -194,46 +193,20 @@ ErrorCode DeformMeshRemap::execute()
- rval = deform_master(fluidElems[MASTER], solidElems[MASTER], "xnew"); RR("");
+ rval = deform_master(fluidElems[MASTER], solidElems[MASTER]); RR("");
- { // to isolate the lloyd smoother & delete when done
- // smooth the master mesh
- LloydSmoother ll(mbImpl, NULL, fluidElems[MASTER], xNew);
- rval = ll.perform_smooth();
- RR("Failed in lloyd smoothing.");
- cout << "Lloyd smoothing required " << ll.num_its() << " iterations." << endl;
- // map new locations to slave
+ // smooth the master mesh
+ LloydSmoother *ll = new LloydSmoother(mbImpl, NULL, fluidElems[MASTER], xNew);
+ rval = ll->perform_smooth();
+ RR("Failed in lloyd smoothing.");
+ cout << "Lloyd smoothing required " << ll->num_its() << " iterations." << endl;
+ if (debug) write_and_save(fluidElems[MASTER], masterSet, xNew, "smoothed.vtk");
- rval = dc_master.locate_points(tgt_verts, 0.0, 1e-10); RR("Point location of tgt verts failed.");
+ // map new locations to slave
- // interpolate xNew to slave points
- rval = dc_master.interpolate((int)DataCoupler::VOLUME, "xnew"); RR("Failed to interpolate target solution.");
- // transfer xNew to coords, for master and slave
- rval = write_to_coords(fluidElems[MASTER], xNew); RR("Failed writing tag to master fluid verts.");
- rval = write_to_coords(tgt_verts, xNew); RR("Failed writing tag to slave verts.");
- if (debug) {
- rval = mbImpl->write_file("smoothed_master.vtk", NULL, NULL, &masterSet, 1);
- rval = mbImpl->write_file("slave_interp.vtk", NULL, NULL, &slaveSet, 1);
+ delete ll;
return MB_SUCCESS;
@@ -329,12 +302,12 @@ void deform_func(double *xold, double *xnew)
-ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems, const char *tag_name)
+ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems)
// deform elements with an analytic function
// create the tag
- ErrorCode rval = mbImpl->tag_get_handle((tag_name ? tag_name : ""), 3, MB_TYPE_DOUBLE, xNew, MB_TAG_CREAT|MB_TAG_DENSE);
+ ErrorCode rval = mbImpl->tag_get_handle("", 3, MB_TYPE_DOUBLE, xNew, MB_TAG_CREAT|MB_TAG_DENSE);
RR("Failed to create xnew tag.");
// get all the vertices and coords in the fluid, set xnew to them
diff --git a/examples/makefile b/examples/makefile
index 773c443..87c0132 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -14,43 +14,43 @@ EXOIIEXAMPLES = TestExodusII
default: ${EXAMPLES}
-HelloMOAB : HelloMOAB.o ${MOAB_LIBDIR}/libMOAB.la
+HelloMOAB : HelloMOAB.o
${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
-GetEntities: GetEntities.o ${MOAB_LIBDIR}/libMOAB.la
+GetEntities: GetEntities.o
-SetsNTags: SetsNTags.o ${MOAB_LIBDIR}/libMOAB.la
+SetsNTags: SetsNTags.o
-LloydRelaxation: LloydRelaxation.o ${MOAB_LIBDIR}/libMOAB.la
+LloydRelaxation: LloydRelaxation.o
-StructuredMeshSimple : StructuredMeshSimple.o ${MOAB_LIBDIR}/libMOAB.la
+StructuredMeshSimple : StructuredMeshSimple.o
-DirectAccessWithHoles: DirectAccessWithHoles.o ${MOAB_LIBDIR}/libMOAB.la
+DirectAccessWithHoles: DirectAccessWithHoles.o
-DirectAccessNoHoles: DirectAccessNoHoles.o ${MOAB_LIBDIR}/libMOAB.la
+DirectAccessNoHoles: DirectAccessNoHoles.o
-DirectAccessNoHolesF90: DirectAccessNoHolesF90.o ${MOAB_LIBDIR}/libMOAB.la
+DirectAccessNoHolesF90: DirectAccessNoHolesF90.o
${MOAB_CXX} -o $@ $< ${IMESH_LIBS}
-ReduceExchangeTags : ReduceExchangeTags.o ${MOAB_LIBDIR}/libMOAB.la
+ReduceExchangeTags : ReduceExchangeTags.o
-HelloParMOAB: HelloParMOAB.o ${MOAB_LIBDIR}/libMOAB.la
+HelloParMOAB: HelloParMOAB.o
-TestExodusII: TestExodusII.o ${MOAB_LIBDIR}/libMOAB.la
+TestExodusII: TestExodusII.o
-point_in_elem_search: point_in_elem_search.o ${MOAB_LIBDIR}/libMOAB.la
+point_in_elem_search: point_in_elem_search.o
-DeformMeshRemap: DeformMeshRemap.o ${MOAB_LIBDIR}/libMOAB.la
- ${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK} -lmbcoupler ${MOAB_LIBS_LINK}
+DeformMeshRemap: DeformMeshRemap.o
+ ${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
clean:
rm -rf *.o ${EXAMPLES} ${PAREXAMPLES} ${EXOIIEXAMPLES}
index 4446281..b132da9 100644
@@ -30,9 +30,7 @@ namespace moab {
CartVect new_pos;
// evaluate that first guess to get a new position
- ErrorCode rval = (*eval)(cvparams->array(), verts, ndim,
- 3, // hardwire to num_tuples to 3 since the field is coords
- work, new_pos.array());
+ ErrorCode rval = (*eval)(cvparams->array(), verts, ndim, ndim, work, new_pos.array());
@@ -60,9 +58,7 @@ namespace moab {
+ rval = (*eval)(params, verts, ndim, ndim, work, new_pos.array());
index 93237f9..ddd4918 100644
@@ -16,23 +16,23 @@ namespace moab
const double LinearQuad::gauss[1][2] = { { 2.0, 0.0 } };
- ErrorCode LinearQuad::jacobianFcn(const double *params, const double *verts, const int /*nverts*/, const int /*ndim*/,
+ ErrorCode LinearQuad::jacobianFcn(const double *params, const double *verts, const int /*nverts*/, const int ndim,
double *, double *result)
Matrix3 *J = reinterpret_cast<Matrix3*>(result);
*J = Matrix3(0.0);
for (unsigned i = 0; i < 4; ++i) {
- const double xi_p = 1 + params[0]*corner[i][0];
+ const double params_p = 1 + params[0]*corner[i][0];
const double eta_p = 1 + params[1]*corner[i][1];
- const double dNi_dxi = corner[i][0] * eta_p;
- const double dNi_deta = corner[i][1] * xi_p;
- (*J)(0,0) += dNi_dxi * verts[i*3+0];
- (*J)(1,0) += dNi_dxi * verts[i*3+1];
- (*J)(0,1) += dNi_deta * verts[i*3+0];
- (*J)(1,1) += dNi_deta * verts[i*3+1];
+ const double dNi_dparams = corner[i][0] * eta_p;
+ const double dNi_deta = corner[i][1] * params_p;
+ (*J)(0,0) += dNi_dparams * verts[i*ndim+0];
+ (*J)(1,0) += dNi_dparams * verts[i*ndim+1];
+ (*J)(0,1) += dNi_deta * verts[i*ndim+0];
+ (*J)(1,1) += dNi_deta * verts[i*ndim+1];
- (*J) *= 0.25;
(*J)(2,2) = 1.0; /* to make sure the Jacobian determinant is non-zero */
+ (*J) *= 0.25;
return MB_SUCCESS;
}// LinearQuad::jacobian()
@@ -62,7 +62,7 @@ namespace moab
for(unsigned int j2 = 0; j2 < LinearQuad::gauss_count; ++j2) {
x[1] = LinearQuad::gauss[j2][1];
double w2 = LinearQuad::gauss[j2][0];
- rval = evalFcn(x.array(), field, ndim, num_tuples, NULL, tmp_result);
+ rval = evalFcn(x.array(),field, ndim, num_tuples, NULL, tmp_result);
rval = jacobianFcn(x.array(), verts, nverts, ndim, work, J[0]);
index eac008d..48d34ac 100644
@@ -119,9 +119,9 @@ namespace moab {
* \param impl MOAB instance
* \param ent Entity handle to cache on the evaluator
* \param tag Tag to cache on the evaluator
- * \param tagged_ent_dim Dimension of entities to be tagged to cache on the evaluator
+ * \param tag_dim Tag dimension to cache on the evaluator
- ElemEvaluator(Interface *impl, EntityHandle ent = 0, Tag tag = 0, int tagged_ent_dim = -1);
+ ElemEvaluator(Interface *impl, EntityHandle ent = 0, Tag tag = 0, int tag_dim = -1);
/** \brief Evaluate cached tag at a given parametric location within the cached entity
* If evaluating coordinates, call set_tag(0, 0), which indicates coords instead of a tag.
@@ -233,23 +233,23 @@ namespace moab {
* To designate that vertex coordinates are the desired tag, pass in a tag handle of 0
* and a tag dimension of 0.
* \param tag Tag handle to cache, or 0 to cache vertex positions
- * \param tagged_ent_dim Dimension of entities tagged with this tag
+ * \param tag_dim Dimension of entities tagged with this tag
- inline ErrorCode set_tag_handle(Tag tag, int tagged_ent_dim = -1);
+ inline ErrorCode set_tag_handle(Tag tag, int tag_dim = -1);
/* \brief Set the name of the tag to cache on this evaluator
* To designate that vertex coordinates are the desired tag, pass in "COORDS" as the name
- * \param tag_name Tag handle to cache, or 0 to cache vertex positions
+ * \param tag Tag handle to cache, or 0 to cache vertex positions
- inline ErrorCode set_tag(const char *tag_name, int tagged_ent_dim = -1);
+ inline ErrorCode set_tag(const char *tag_name, int ent_dim = -1);
/* \brief Get the dimension of the entities on which tag is set */
- inline int get_tagged_ent_dim() const {return taggedEntDim;};
+ inline int get_tag_dim() const {return tagDim;};
- inline ErrorCode set_tagged_ent_dim(int dim);
+ inline ErrorCode set_tag_dim(int dim);
@@ -287,7 +287,7 @@ namespace moab {
int numTuples;
/** \brief Dimension of entities from which to grab tag */
- int taggedEntDim;
+ int tagDim;
/** \brief Tag space */
std::vector<unsigned char> tagSpace;
@@ -300,13 +300,13 @@ namespace moab {
}; // class ElemEvaluator
- inline ElemEvaluator::ElemEvaluator(Interface *impl, EntityHandle ent, Tag tag, int tagged_ent_dim)
+ inline ElemEvaluator::ElemEvaluator(Interface *impl, EntityHandle ent, Tag tag, int tag_dim)
: mbImpl(impl), entHandle(0), entType(MBMAXTYPE), entDim(-1), numVerts(0),
vertHandles(NULL), tagHandle(0), tagCoords(false), numTuples(0),
- taggedEntDim(0), workSpace(NULL)
+ tagDim(0), workSpace(NULL)
if (ent) set_ent_handle(ent);
- if (tag) set_tag_handle(tag, tagged_ent_dim);
+ if (tag) set_tag_handle(tag, tag_dim);
inline ErrorCode ElemEvaluator::set_ent_handle(EntityHandle ent)
@@ -329,17 +329,18 @@ namespace moab {
rval = set_tag_handle(tagHandle);
if (evalSets[entType].initFcn) return (*evalSets[entType].initFcn)(vertPos[0].array(), numVerts, workSpace);
return MB_SUCCESS;
- inline ErrorCode ElemEvaluator::set_tag_handle(Tag tag, int tagged_ent_dim)
+ inline ErrorCode ElemEvaluator::set_tag_handle(Tag tag, int tag_dim)
- if (!tag && !tagged_ent_dim) {
+ if (!tag && !tag_dim) {
tagCoords = true;
numTuples = 3;
- taggedEntDim = 0;
+ tagDim = 0;
tagHandle = 0;
return rval;
@@ -354,14 +355,14 @@ namespace moab {
tagCoords = false;
- taggedEntDim = (-1 == tagged_ent_dim ? 0 : tagged_ent_dim);
+ tagDim = (-1 == tag_dim ? 0 : tag_dim);
if (entHandle) {
- if (0 == taggedEntDim) {
+ if (0 == tagDim) {
rval = mbImpl->tag_get_data(tagHandle, vertHandles, numVerts, &tagSpace[0]);
- else if (taggedEntDim == entDim) {
+ else if (tagDim == entDim) {
rval = mbImpl->tag_get_data(tagHandle, &entHandle, 1, &tagSpace[0]);
@@ -370,14 +371,14 @@ namespace moab {
return rval;
- inline ErrorCode ElemEvaluator::set_tag(const char *tag_name, int tagged_ent_dim)
+ inline ErrorCode ElemEvaluator::set_tag(const char *tag_name, int tag_dim)
if (!tag_name || strlen(tag_name) == 0) return MB_FAILURE;
Tag tag;
if (!strcmp(tag_name, "COORDS")) {
tagCoords = true;
- taggedEntDim = 0;
+ tagDim = 0;
numTuples = 3;
tagHandle = 0;
// can return here, because vertex coords already cached when entity handle set
@@ -398,15 +399,15 @@ namespace moab {
tagCoords = false;
- taggedEntDim = (-1 == tagged_ent_dim ? entDim : tagged_ent_dim);
+ tagDim = (-1 == tag_dim ? entDim : tag_dim);
if (entHandle) {
@@ -430,16 +431,16 @@ namespace moab {
return (*evalSets[entType].evalFcn)(params,
(tagCoords ? (const double*) vertPos[0].array(): (const double*)&tagSpace[0]),
- entDim,
- (-1 == num_tuples ? numTuples : num_tuples), workSpace, result);
+ entDim, (-1 == num_tuples ? numTuples : num_tuples),
+ workSpace, result);
- posn, vertPos[0].array(), numVerts,
- entDim, tol, workSpace, params, ins);
+ posn, vertPos[0].array(), numVerts, entDim, tol, workSpace,
+ params, ins);
@@ -455,7 +456,7 @@ namespace moab {
assert(entHandle && MBMAXTYPE != entType && (tagCoords || tagHandle));
if (!tagCoords) {
- if (0 == taggedEntDim) rval = mbImpl->tag_get_data(tagHandle, vertHandles, numVerts, (void*)&tagSpace[0]);
+ if (0 == tagDim) rval = mbImpl->tag_get_data(tagHandle, vertHandles, numVerts, (void*)&tagSpace[0]);
else rval = mbImpl->tag_get_data(tagHandle, &entHandle, 1, (void*)&tagSpace[0]);
index d3b521e..a543dc9 100644
@@ -31,62 +31,10 @@ namespace moab
return MB_SUCCESS;
-#ifdef USE_MPI
- ErrorCode SpatialLocator::par_locate_points(Range &/*vertices*/,
- double /*rel_tol*/, double /*abs_tol*/)
- return MB_UNSUPPORTED_OPERATION;
- ErrorCode SpatialLocator::par_locate_points(const double */*pos*/, int /*num_points*/,
-#endif
- ErrorCode SpatialLocator::locate_points(Range &verts,
- double rel_eps, double abs_eps)
- assert(!verts.empty() && mbImpl->type_from_handle(*verts.rbegin()) == MBVERTEX);
- std::vector<double> pos(3*verts.size());
- ErrorCode rval = mbImpl->get_coords(verts, &pos[0]);
- rval = locate_points(&pos[0], verts.size(), rel_eps, abs_eps);
- ErrorCode SpatialLocator::locate_points(const double *pos, int num_points,
- // initialize to tuple structure (p_ui, hs_ul, r[3]_d) (see header comments for locTable)
- locTable.initialize(1, 0, 1, 3, num_points);
- locTable.enableWriteAccess();
- // pass storage directly into locate_points, since we know those arrays are contiguous
- ErrorCode rval = locate_points(pos, num_points, locTable.vul_wr, locTable.vr_wr, NULL, rel_eps, abs_eps);
- std::fill(locTable.vi_wr, locTable.vi_wr+num_points, 0);
- EntityHandle *ents, double *params, bool *is_inside,
- return locate_points(&pos[0], verts.size(), ents, params, is_inside, rel_eps, abs_eps);
+ EntityHandle *ents, double *params,
+ double rel_eps, double abs_eps,
+ bool *is_inside)
index 780c086..a8f694f 100644
@@ -1,30 +1,6 @@
/**\file SpatialLocator.hpp
* \class moab::SpatialLocator
* \brief Tool to facilitate spatial location of a point in a mesh
- * SpatialLocator facilitates searching for points in or performing ray traces on collections of mesh entities
- * in 2D or 3D. This searching is facilitated by a tree-based decomposition of the mesh. Various types
- * of trees are implemented in MOAB and can be used by this tool, but by default it uses AdaptiveKDTree
- * (see child classes of Tree for which others are available). Parallel and serial searching are both
- * supported.
- * SpatialLocator can either cache the search results for points or pass back this information in arguments.
- * Cached information is kept in locTable, indexed in the same order as search points passed in. This information
- * consists of the entity handle containing the point and the parametric coordinates inside that element.
- * Information about the points searched, e.g. the entities from which those points are derived, can be stored
- * in the calling application if desired.
- * In parallel, there is a separation between the proc deciding which points to search for (the "target" proc),
- * and the proc locating the point in its local mesh (the "source" proc). On the source proc, location
- * information is cached in locTable, as in the serial case. By default, this location information (handle and
- * parametric coords) is not returned to the target proc, since it would be of no use there. Instead, the rank
- * of the source proc locating the point, and the index of that location info in the source proc's locTable, is
- * returned; this information is stored on the target proc in this class's parLocTable variable. Again,
- * information about the points searched should be stored in the calling application, if desired.
- * This class uses the ElemEvaluator class for specification and evaluation of basis functions (used for computing
- * parametric coords within an entity). See documentation and examples for that class for usage information.
#ifndef MOAB_SPATIALLOCATOR_HPP
@@ -33,7 +9,6 @@
#include "moab/Types.hpp"
#include "moab/Tree.hpp"
#include "moab/Range.hpp"
-#include "moab/TupleList.hpp"
#include <string>
#include <vector>
@@ -59,83 +34,23 @@ namespace moab {
/* get bounding box of this locator */
ErrorCode get_bounding_box(BoundBox &box);
- /* locate a set of vertices, Range variant */
- ErrorCode locate_points(Range &vertices,
- EntityHandle *ents, double *params, bool *is_inside = NULL,
- double rel_tol = 0.0, double abs_tol = 0.0);
- /* locate a set of vertices or entity centroids, storing results on TupleList in this class
- * Locate a set of vertices or entity centroids, storing the detailed results in member
- * variable (TupleList) locTable (see comments on locTable for structure of that tuple).
- ErrorCode locate_points(Range &ents,
+ double rel_tol = 0.0, double abs_tol = 0.0,
+ bool *is_inside = NULL);
- /* locate a set of points, storing results on TupleList in this class
- * Locate a set of points, storing the detailed results in member variable (TupleList) locTable
- * (see comments on locTable for structure of that tuple).
- ErrorCode locate_points(const double *pos, int num_points,
-#ifdef USE_MPI
- * variables (TupleList) locTable and parLocTable (see comments on locTable and parLocTable for
- * structure of those tuples).
- ErrorCode par_locate_points(Range &vertices,
- ErrorCode par_locate_points(const double *pos, int num_points,
-#endif
+ /* locate a point */
+ ErrorCode locate_point(const double *pos,
+ EntityHandle &ent, double *params,
Tree *get_tree() {return myTree;}
- /* get the locTable
- TupleList &loc_table() {return locTable;}
- const TupleList &loc_table() const {return locTable;}
- /* get the parLocTable
- TupleList &par_loc_table() {return parLocTable;}
- const TupleList &par_loc_table() const {return parLocTable;}
- /* get elemEval */
- ElemEvaluator *elem_eval() {return elemEval;}
- const ElemEvaluator *elem_eval() const {return elemEval;}
- /* set elemEval */
- void elem_eval(ElemEvaluator *eval) {elemEval = eval;}
private:
- /* locate a point */
- ErrorCode locate_point(const double *pos,
- EntityHandle &ent, double *params, bool *is_inside = NULL,
/* MOAB instance */
Interface* mbImpl;
@@ -153,29 +68,6 @@ namespace moab {
/* whether I created the tree or not (determines whether to delete it or not on destruction) */
bool iCreatedTree;
- /* \brief local locations table
- * This table stores detailed local location data results from locate_points, that is, location data
- * for points located on the local mesh. Data is stored
- * in a TupleList, where each tuple consists of (p_i, hs_ul, r[3]_d), where
- * p_i = (int) proc from which request for this point was made (0 if serial)
- * hs_ul = (unsigned long) source entity containing the point
- * r[3]_d = (double) parametric coordinates of the point in hs
- TupleList locTable;
- /* \brief parallel locations table
- * This table stores information about points located on a local or remote processor. For
- * points located on this processor's local mesh, detailed location data is stored in locTable.
- * For points located on remote processors, more communication is required to retrieve specific
- * location data (usually that information isn't useful on this processor).
- * The tuple structure of this TupleList is (p_i, ri_i), where:
- * p_i = (int) processor rank containing this point
- * ri_i = (int) index into locTable on remote proc containing this point's location information
- * The indexing of parLocTable corresponds to that of the points/entities passed in.
- TupleList parLocTable;
inline SpatialLocator::~SpatialLocator()
@@ -184,10 +76,11 @@ namespace moab {
- EntityHandle &ent, double *params, bool *is_inside,
- double rel_tol, double abs_tol)
+ double rel_tol, double abs_tol,
+ bool *is_inside)
- return locate_points(pos, 1, &ent, params, is_inside, rel_tol, abs_tol);
+ return locate_points(pos, 1, &ent, params, rel_tol, abs_tol, is_inside);
index 6f07d7a..a5907fd 100644
@@ -7,7 +7,6 @@
-#include "moab/LinearQuad.hpp"
#include "moab/QuadraticHex.hpp"
@@ -22,7 +21,6 @@ std::string TestDir(".");
-void test_linear_quad();
void test_quadratic_hex();
@@ -51,7 +49,6 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
bool is_inside;
Matrix3 jacob;
ErrorCode rval;
- int ent_dim = ee.get_moab()->dimension_from_handle(ee.get_ent_handle());
for (params[0] = -1; params[0] <= 1; params[0] += 0.2) {
for (params[1] = -1; params[1] <= 1; params[1] += 0.2) {
@@ -62,11 +59,9 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
rval = ee.eval(params.array(), posn.array()); CHECK_ERR(rval);
rval = ee.reverse_eval(posn.array(), EPS1, params2.array(), &is_inside); CHECK_ERR(rval);
- CHECK_REAL_EQUAL(0.0, params[0] - params2[0], 3*EPS1);
- if (ent_dim > 1)
- CHECK_REAL_EQUAL(0.0, params[1] - params2[1], 3*EPS1);
- if (ent_dim > 2)
- CHECK_REAL_EQUAL(0.0, params[2] - params2[2], 3*EPS1);
+ if ((params - params2).length() > 3*EPS1)
+ std::cerr << params << std::endl;
+ CHECK_REAL_EQUAL(0.0, (params - params2).length(), 3*EPS1);
// jacobian should be >= 0
rval = ee.jacobian(params.array(), jacob.array()); CHECK_ERR(rval);
@@ -86,21 +81,8 @@ void test_eval(ElemEvaluator &ee, bool test_integrate)
- CartVect integral, avg;
+ CartVect integral, avg(0.0);
rval = ee.integrate(integral.array()); CHECK_ERR(rval);
- // now integrate a const 1-valued function, using direct call to the integrate function
- std::vector<double> one(ee.get_num_verts(), 1.0);
- double measure;
- EvalSet es;
- EntityHandle eh = ee.get_ent_handle();
- rval = EvalSet::get_eval_set(ee.get_moab(), eh, es); CHECK_ERR(rval);
- rval = (*es.integrateFcn)(&one[0], hex_verts[0].array(), ee.get_num_verts(), ee.get_moab()->dimension_from_handle(eh),
- 1, NULL, &measure); CHECK_ERR(rval);
- if (measure) integral /= measure;
- // check against avg of entity's vertices' positions
- rval = ee.get_moab()->get_coords(&eh, 1, avg.array()); CHECK_ERR(rval);
CHECK_REAL_EQUAL(0.0, (avg - integral).length(), EPS1);
// delete the temporary tag
@@ -136,7 +118,6 @@ int main()
int failures = 0;
- failures += RUN_TEST(test_linear_quad);
failures += RUN_TEST(test_linear_tet);
@@ -144,23 +125,6 @@ int main()
return failures;
- Core mb;
- Range verts;
- ErrorCode rval = mb.create_vertices((double*)hex_verts, 4, verts); CHECK_ERR(rval);
- EntityHandle quad;
- rval = mb.create_element(MBQUAD, &connect[0], 4, quad); CHECK_ERR(rval);
- ElemEvaluator ee(&mb, quad, 0);
- ee.set_eval_set(MBQUAD, LinearQuad::eval_set());
Core mb;
diff --git a/test/spatial_locator_test.cpp b/test/spatial_locator_test.cpp
index 6ffa109..31bf08a 100644
--- a/test/spatial_locator_test.cpp
+++ b/test/spatial_locator_test.cpp
@@ -116,7 +116,7 @@ void test_locator(SpatialLocator *sl)
test_pt = box.bMin + CartVect(rx*box_del[0], ry*box_del[1], rz*box_del[2]);
// call spatial locator to locate points
- rval = sl->locate_points(test_pt.array(), 1, &ent, test_res.array(), &is_in); CHECK_ERR(rval);
+ rval = sl->locate_points(test_pt.array(), 1, &ent, test_res.array(), 0.0, 0.0, &is_in); CHECK_ERR(rval);
// verify that the point was found
CHECK_EQUAL(is_in, true);
index 71f3497..0000000
+++ /dev/null
@@ -1,225 +0,0 @@
-#include "moab/ParallelComm.hpp"
-#include "moab/Tree.hpp"
-#include "moab/SpatialLocator.hpp"
-#include "moab/Error.hpp"
-#include "iostream"
-#include <stdio.h>
-#include <sstream>
-#include "assert.h"
-namespace moab {
-bool debug = false;
-DataCoupler::DataCoupler(Interface *impl,
- ParallelComm *pc,
- Range &source_ents,
- int coupler_id,
- bool init_locator,
- int dim)
- : mbImpl(impl), myPcomm(pc), myId(coupler_id), myDim(dim)
- assert(NULL != mbImpl && (myPcomm || !source_ents.empty()));
- // now initialize the tree
- if (init_locator) {
- myLocator = new SpatialLocator(mbImpl, source_ents);
- myLocator->elem_eval(new ElemEvaluator(mbImpl));
- // initialize element evaluator with the default for the entity types in source_ents;
- // can be replaced later by application if desired
- if (!source_ents.empty()) {
- Range::pair_iterator pit = source_ents.pair_begin();
- EntityType last_type = MBMAXTYPE;
- for (; pit != source_ents.pair_end(); pit++) {
- EntityType this_type = mbImpl->type_from_handle(pit->first);
- if (last_type == this_type) continue;
- myLocator->elem_eval()->set_eval_set(pit->first);
- last_type = this_type;
- if (-1 == dim && !source_ents.empty())
- dim = mbImpl->dimension_from_handle(*source_ents.rbegin());
- ErrorCode rval = impl->query_interface(mError);
- /* destructor
-DataCoupler::~DataCoupler()
- delete myLocator;
-ErrorCode DataCoupler::locate_points(Range &targ_ents,
- double rel_eps,
- double abs_eps)
- targetEnts = targ_ents;
- return myLocator->locate_points(targ_ents, rel_eps, abs_eps);
-ErrorCode DataCoupler::locate_points(double *xyz, int num_points,
- double rel_eps,
- double abs_eps)
- return myLocator->locate_points(xyz, num_points, rel_eps, abs_eps);
-ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int method,
- const std::string &interp_tag,
- double *interp_vals,
- std::vector<int> *point_indices,
- bool normalize)
- // tag name input, translate to tag handle and pass down the chain
- // not inlined because of call to set_last_error, class Error isn't in public interface
- Tag tag;
- ErrorCode result = mbImpl->tag_get_handle(interp_tag.c_str(), tag);
- if (MB_SUCCESS != result) {
- std::ostringstream str;
- str << "Failed to get handle for interpolation tag \"" << interp_tag << "\"";
- mError->set_last_error(str.str());
- return result;
- return interpolate(method, tag, interp_vals, point_indices, normalize);
-ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int *methods,
- Tag *tags,
- int *points_per_method,
- int num_methods,
- bool /*normalize*/)
- // lowest-level interpolate function, does actual interpolation using calls to ElemEvaluator
- ErrorCode result = MB_SUCCESS;
- unsigned int pts_total = 0;
- for (int i = 0; i < num_methods; i++) pts_total += (points_per_method ? points_per_method[i] : targetEnts.size());
- unsigned int num_indices = (point_indices ? point_indices->size() : targetEnts.size());
- int max_tsize = -1;
- for (int i = 0; i < num_methods; i++) {
- int tmp_tsize;
- result = mbImpl->tag_get_length(tags[i], tmp_tsize);
- if (MB_SUCCESS != result) return MB_FAILURE;
- max_tsize = std::max(max_tsize, tmp_tsize);
- // if tl was passed in non-NULL, just have those points, otherwise have targetPts plus
- // locally mapped pts
- if (pts_total != num_indices)
- if (myPcomm) {
- // TL to send interpolation indices to target procs
- // Tuple structure: (pto_i, ridx_i, lidx_i, meth_i, tagidx_i, interp_val[max_tsize]_d)
- TupleList tinterp;
- tinterp.initialize(5, 0, 0, max_tsize, num_indices);
- int t = 0;
- tinterp.enableWriteAccess();
- int num_points = (points_per_method ? points_per_method[i] : targetEnts.size());
- for (int j = 0; j < num_points; j++) {
- int idx = (point_indices ? (*point_indices)[j] : j);
- // remote proc/idx from myLocator->parLocTable
- tinterp.vi_wr[5*t] = myLocator->par_loc_table().vi_rd[2*idx]; // proc
- tinterp.vi_wr[5*t+1] = myLocator->par_loc_table().vi_rd[2*idx+1]; // remote idx
- // local entity index, tag/method index from my data
- tinterp.vi_wr[5*t+2] = idx;
- tinterp.vi_wr[5*t+3] = methods[i];
- tinterp.vi_wr[5*t+4] = i;
- tinterp.inc_n();
- t++;
- // scatter/gather interpolation points
- myPcomm->proc_config().crystal_router()->gs_transfer(1, tinterp, 0);
- // perform interpolation on local source mesh; put results into
- // tinterp.vr_wr
- for (unsigned int i = 0; i < tinterp.get_n(); i++) {
- int lidx = tinterp.vi_rd[5*i+1];
-// /*Method*/ int method = (/*Method*/ int)tinterp.vi_rd[5*i+3];
- Tag tag = tags[tinterp.vi_rd[5*i+4]];
- myLocator->elem_eval()->set_tag_handle(tag);
- myLocator->elem_eval()->set_ent_handle(myLocator->loc_table().vul_rd[lidx]);
- result = myLocator->elem_eval()->eval(myLocator->loc_table().vr_rd+3*lidx, tinterp.vr_rd+i*max_tsize);
- if (MB_SUCCESS != result) return result;
- // scatter/gather interpolation data
- // copy the interpolated field as a unit
- std::copy(tinterp.vr_rd, tinterp.vr_rd+tinterp.get_n()*max_tsize, interp_vals);
- else {
- std::vector<double> tmp_vals;
- std::vector<EntityHandle> tmp_ents;
- double *tmp_dbl = interp_vals;
- // interpolated data is tsize long, which is either max size (if data passed back to caller in tinterp)
- // or tag size (if data will be set on entities, in which case it shouldn't have padding)
- int tsize = max_tsize, tsize_bytes = 0;
- if (!interp_vals) {
- tmp_vals.resize(num_points*max_tsize);
- tmp_dbl = &tmp_vals[0];
- tmp_ents.resize(num_points);
- result = mbImpl->tag_get_length(tags[i], tsize);
- result = mbImpl->tag_get_bytes(tags[i], tsize_bytes);
- int lidx;
- if (point_indices) {
- lidx = (*point_indices)[j];
- else {
- lidx = j;
- myLocator->elem_eval()->set_tag_handle(tags[i]);
- if (!interp_vals) tmp_ents[j] = targetEnts[lidx]; // could be performance-sensitive, thus the if test
- result = myLocator->elem_eval()->eval(myLocator->loc_table().vr_rd+3*lidx, tmp_dbl);
- tmp_dbl += tsize;
- } // for j
- // set tags on tmp_ents; data is already w/o padding, due to tsize setting above
- result = mbImpl->tag_set_data(tags[i], &tmp_ents[0], tmp_ents.size(), &tmp_vals[0]);
- } // for i
- } // if myPcomm
- // done
- return MB_SUCCESS;
-} // namespace_moab
deleted file mode 100644
index 3ad1d74..0000000
+++ /dev/null
@@ -1,255 +0,0 @@
- * \class moab::DataCoupler
- * \brief This class couples data between meshes.
- * The coupler interpolates solution data at a set of points. Data being interpolated resides on a "source"
- * mesh, in a tag or in vertex coords. Applications calling this coupler send in entities, and receive back
- * data interpolated at those points. Entities in the source mesh containing those points do not have to reside
- * on the same processor.
- * To use, an application should:
- * - instantiate this DataCoupler by calling the constructor collectively on all processors in the communicator
- * - call locate_points, which locates the points to be interpolated and (optionally) caches the results in
- * this class and SpatialLocator
- * - call interpolate, which does the interpolation
- * Multiple interpolations (of multiple tags, or element-average vs. true interpolation) can be done after
- * locating the points.
- * SpatialLocator is used for the spatial location portion of this work.
- * This class is a next-generation implementation of Coupler.
-#ifndef DATACOUPLER_HPP
-#define DATACOUPLER_HPP
-#include "moab/Range.hpp"
-#include "moab/Interface.hpp"
-#include <sstream>
-namespace moab {
-class ParallelComm;
-class SpatialLocator;
-class Error;
-class DataCoupler
-public:
- enum IntegType {VOLUME};
- /* constructor
- * Constructor, which also optionally initializes the coupler
- * \param pc ParallelComm object to be used with this coupler, representing the union
- * of processors containing source and target meshes
- * \param source_elems Elements in the source mesh
- * \param coupler_id Id of this coupler, should be the same over all procs
- * \param init_locator If true, initializes a spatial locator inside the constructor
- * \param dim Dimension of entities to be coupled; if -1, get from source_elems
- DataCoupler(Interface *impl,
- ParallelComm *pc,
- int coupler_id,
- bool init_locator = true,
- int dim = -1);
- /* destructor
- virtual ~DataCoupler();
- /* \brief Locate points on the source mesh
- * This is a pass-through function to SpatialLocator::locate_points
- * \param xyz Point locations (interleaved) being located
- * \param num_points Number of points in xyz
- * \param rel_eps Relative tolerance for the non-linear iteration inside a given element
- * \param abs_eps Absolute tolerance for the non-linear iteration inside a given element
- * \param loc_results Tuple list containing the results; two types of results are possible,
- * controlled by value of store_local parameter:
- * store_local = true: each tuple T[j] consists of (p, i), p = proc with src element containing
- * point j (or 0 if serial), i = index in stored list (in SpatialLocator) on src proc
- * store_local = false: each tuple T[j] consists of (p, ht, hs, pr[3]), where ht = target mesh entity
- * handle, hs = source mesh entity containing point (0 if not found), pr = parameters in hs
- * \param store_local If true, stores the located points on SpatialLocator
- ErrorCode locate_points(double *xyz, int num_points,
- double rel_eps = 0.0, double abs_eps = 0.0);
- * \param ents Target entities being located
- double abs_eps = 0.0);
- /* \brief Interpolate data from the source mesh onto points
- * All entities/points or, if tuple_list is input, only those points
- * are interpolated from the source mesh. Application should
- * allocate enough memory in interp_vals to hold interpolation results.
- * If normalization is requested, technique used depends on the coupling
- * method.
- * \param method Interpolation/normalization method
- * \param tag Tag on source mesh holding data to be interpolated
- * \param interp_vals Memory holding interpolated data; if NULL, data is written to same tag on target ents
- * \param point_indices If non-NULL, a set of indices of points input to
- * locate_points at which to interpolate; if NULL, interpolates at all points
- * input to locate_points
- * \param normalize If true, normalization is done according to method
- ErrorCode interpolate(/*DataCoupler::Method*/ int method,
- Tag tag,
- double *interp_vals = NULL,
- std::vector<int> *point_indices = NULL,
- bool normalize = true);
- * method.
- * \param tag_name Tag name on source mesh holding data to be interpolated
- const std::string &tag_name,
- /* \brief Interpolate data from multiple tags
- * In this variant, multiple tags, possibly with multiple interpolation
- * methods, are specified. Sum of values in points_per_method should be
- * the number of points in tl or, if NULL, targetPts.
- * method.
- * \param methods Vector of Interpolation/normalization methods
- * \param tag_names Names of tag being interpolated for each method
- * \param points_per_method Number of points for each method
- * \param num_methods Length of vectors in previous 3 arguments
- ErrorCode interpolate(/*DataCoupler::Method*/ int *methods,
- const std::string *tag_names,
- int num_methods,
- * method.
- Tag *tag_names,
- int num_methods,
- /* Get functions */
- inline SpatialLocator *spatial_locator() {return myLocator;}
- inline int my_id() const {return myId;}
- inline const Range &target_ents() const {return targetEnts;}
- inline Range &target_ents() {return targetEnts;}
- inline int get_dim() const {return myDim;}
-private:
- /* \brief MOAB instance
- Interface *mbImpl;
- /* \brief ParallelComm object for this coupler
- ParallelComm *myPcomm;
- /* \brief SpatialLocator for local mesh
- SpatialLocator *myLocator;
- /* \brief error object used to set last error on interface
- Error *mError;
- /* \brief Id of this coupler
- int myId;
- /* \brief Range of target entities
- Range targetEnts;
- // entity dimension
- int myDim;
- inline ErrorCode DataCoupler::interpolate(/*DataCoupler::Method*/ int method,
- Tag tag,
- bool normalize)
- // no point indices input,
- int num_pts = (point_indices ? point_indices->size() : targetEnts.size());
- return interpolate(&method, &tag, &num_pts, 1,
- interp_vals, point_indices, normalize);
-} // namespace moab
-#endif
diff --git a/tools/mbcoupler/Makefile.am b/tools/mbcoupler/Makefile.am
index ea32ff9..25a58c2 100644
--- a/tools/mbcoupler/Makefile.am
+++ b/tools/mbcoupler/Makefile.am
@@ -9,7 +9,6 @@ AM_CPPFLAGS += -DSRCDIR=$(srcdir) \
-I$(top_srcdir)/src \
-I$(top_builddir)/src \
-I$(top_srcdir)/src/parallel \
- -I$(top_srcdir)/src/LocalDiscretization \
-I$(top_srcdir)/src/moab/point_locater/lotte \
-I$(top_srcdir)/test \
-I$(top_srcdir)/itaps \
@@ -24,12 +23,10 @@ LDADD = libmbcoupler.la $(top_builddir)/src/libMOAB.la $(top_builddir)/itaps/ime
libmbcoupler_la_SOURCES = \
Coupler.cpp \
- DataCoupler.cpp \
ElemUtil.cpp
libmbcoupler_la_include_HEADERS = \
Coupler.hpp \
- DataCoupler.hpp \
ElemUtil.hpp
libmbcoupler_la_includedir = $(includedir)
https://bitbucket.org/fathomteam/moab/commits/26aaf74c29bb/
Changeset: 26aaf74c29bb
Branch: deformed-mesh-remap
User: tautges
Date: 2013-11-28 02:28:11
Summary: Revert "Make a DeformMeshRemap class and implement through that."
This reverts commit e2e1ffac2d54df97b21e5185f41108cf194042ab.
Affected #: 1 file
diff --git a/examples/DeformMeshRemap.cpp b/examples/DeformMeshRemap.cpp
index fac83ae..55ac3cc 100644
--- a/examples/DeformMeshRemap.cpp
+++ b/examples/DeformMeshRemap.cpp
@@ -17,7 +17,6 @@
#include "MBTagConventions.hpp"
#include <iostream>
-#include <set>
#include <assert.h>
@@ -38,212 +37,11 @@ const int SOLID_SETNO = 100, FLUID_SETNO = 200;
Interface *mb;
#define RR(a) if (MB_SUCCESS != rval) {cout << a << endl; return MB_FAILURE;}
-const bool debug = true;
-class DeformMeshRemap
-public:
- //! enumerator for solid/fluid, master/slave
- enum {MASTER=0, SLAVE, SOLID, FLUID};
- //! constructor
- DeformMeshRemap(Interface *impl) : mbImpl(impl), masterSet(0), slaveSet(0), xNew(0), xNewName("xnew") {}
- //! destructor
- ~DeformMeshRemap();
- //! execute the deformed mesh process
- ErrorCode execute();
- //! add a set number
- ErrorCode add_set_no(int fluid_or_solid, int set_no);
- //! remove a set number
- ErrorCode remove_set_no(int fluid_or_solid, int set_no);
- //! get the set numbers
- ErrorCode get_set_nos(int fluid_or_solid, std::set<int> &set_nos) const;
- //! get the xNew tag handle
- inline Tag x_new() const {return xNew;}
- //! get the tag name
- std::string x_new_name() const {return xNewName;}
- //! set the tag name
- void x_new_name(const std::string &name) {xNewName = name;}
- //! get/set the file name
- std::string get_file_name(int m_or_s) const;
- void set_file_name(int m_or_s, const std::string &name);
-private:
- //! apply a known deformation to the solid elements, putting the results in the xNew tag; also
- //! write current coordinates to the xNew tag for fluid elements
- ErrorCode deform_master(Range &fluid_elems, Range &solid_elems);
- //! read a file and establish proper ranges
- ErrorCode read_file(int m_or_s, string &fname, EntityHandle &seth);
- //! write the input tag to the coordinates for the vertices in the input elems
- ErrorCode write_to_coords(Range &elems, Tag tagh);
- //! write the tag to the vertices, then save to the specified file
- ErrorCode write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename);
- //! moab interface
- //! material set numbers for fluid materials
- std::set<int> fluidSetNos;
- //! material set numbers for solid materials
- std::set<int> solidSetNos;
- //! sets defining master/slave meshes
- EntityHandle masterSet, slaveSet;
- //! sets in master/slave meshes
- Range fluidSets[2], solidSets[2];
- //! elements in master/slave meshes
- Range fluidElems[2], solidElems[2];
- //! filenames for master/slave meshes
- std::string masterFileName, slaveFileName;
- //! tag used for new positions
- Tag xNew;
- //! tag name used for new positions
- std::string xNewName;
-inline ErrorCode DeformMeshRemap::add_set_no(int f_or_s, int set_no)
- std::set<int> *this_set;
- switch (f_or_s) {
- case FLUID:
- this_set = &fluidSetNos; break;
- case SOLID:
- this_set = &solidSetNos; break;
- default:
- assert(false && "f_or_s should be FLUID or SOLID.");
- return MB_FAILURE;
- this_set->insert(set_no);
-inline ErrorCode DeformMeshRemap::remove_set_no(int f_or_s, int set_no)
- switch (f_or_s) {
- case FLUID:
- case SOLID:
- default:
- std::set<int>::iterator sit = this_set->find(set_no);
- if (sit != this_set->end()) {
- this_set->erase(*sit);
-inline ErrorCode DeformMeshRemap::get_set_nos(int f_or_s, std::set<int> &set_nos) const
- const std::set<int> *this_set;
- switch (f_or_s) {
- case FLUID:
- case SOLID:
- default:
- set_nos = *this_set;
-ErrorCode DeformMeshRemap::execute()
- // read master/slave files and get fluid/solid material sets
- ErrorCode rval = read_file(MASTER, masterFileName, masterSet);
- if (MB_SUCCESS != rval) return rval;
- rval = read_file(SLAVE, slaveFileName, slaveSet);
- // deform the master's solid mesh, put results in a new tag
- rval = deform_master(fluidElems[MASTER], solidElems[MASTER]); RR("");
- if (debug) write_and_save(solidElems[MASTER], masterSet, xNew, "deformed.vtk");
- LloydSmoother *ll = new LloydSmoother(mbImpl, NULL, fluidElems[MASTER], xNew);
- rval = ll->perform_smooth();
- cout << "Lloyd smoothing required " << ll->num_its() << " iterations." << endl;
- if (debug) write_and_save(fluidElems[MASTER], masterSet, xNew, "smoothed.vtk");
- delete ll;
-std::string DeformMeshRemap::get_file_name(int m_or_s) const
- switch (m_or_s) {
- case MASTER:
- return masterFileName;
- case SLAVE:
- return slaveFileName;
- default:
- assert(false && "m_or_s should be MASTER or SLAVE.");
- return std::string();
-void DeformMeshRemap::set_file_name(int m_or_s, const std::string &name)
- switch (m_or_s) {
- case MASTER:
- masterFileName = name; break;
- case SLAVE:
- slaveFileName = name; break;
- default:
-DeformMeshRemap::~DeformMeshRemap()
- // delete the tag
- mbImpl->tag_delete(xNew);
int main(int argc, char **argv) {
+ EntityHandle master, slave;
ErrorCode rval;
ProgOptions po("Deformed mesh options");
@@ -258,34 +56,49 @@ int main(int argc, char **argv) {
slavef = string(MESH_DIR) + string("/rodtri.g");
mb = new Core();
+ // read master/slave files and get fluid/solid material sets
+ Range fluids[2], solids[2], solid_elems[2], fluid_elems[2];
+ rval = read_file(masterf, master, solids[0], solid_elems[0], fluids[0], fluid_elems[0]); RR("");
+ rval = read_file(slavef, slave, solids[1], solid_elems[1], fluids[1], fluid_elems[1]); RR("");
- DeformMeshRemap dfr(mb);
- dfr.set_file_name(DeformMeshRemap::MASTER, masterf);
- dfr.set_file_name(DeformMeshRemap::SLAVE, slavef);
- rval = dfr.add_set_no(DeformMeshRemap::SOLID, SOLID_SETNO); RR("Failed to add solid set no.");
- rval = dfr.add_set_no(DeformMeshRemap::FLUID, FLUID_SETNO); RR("Failed to add fluid set no.");
+ // deform the master's solid mesh, put results in a new tag
+ Tag xnew;
+ rval = deform_master(fluid_elems[0], solid_elems[0], xnew); RR("");
+ if (debug) write_and_save(solid_elems[0], master, xnew, "deformed.vtk");
- rval = dfr.execute();
- return rval;
+ LloydSmoother *ll = new LloydSmoother(mb, NULL, fluid_elems[0], xnew);
+ if (debug) write_and_save(fluid_elems[0], master, xnew, "smoothed.vtk");
+ delete ll;
+ delete mb;
+ return MB_SUCCESS;
-ErrorCode DeformMeshRemap::write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename)
+ErrorCode write_and_save(Range &ents, EntithHanlde seth, Tag tagh, const char *filename)
- ErrorCode rval = write_to_coords(ents, tagh); RR("");
- rval = mbImpl->write_file(filename, NULL, NULL, &seth, 1); RR("");
+ rval = write_to_coords(ents, tagh); RR("");
+ rval = mb->write_file("deformed.vtk", NULL, NULL, &seth, 1); RR("");
return rval;
-ErrorCode DeformMeshRemap::write_to_coords(Range &elems, Tag tagh)
+ErrorCode write_to_coords(Range &elems, Tag tagh)
// write the tag to coordinates
Range verts;
- ErrorCode rval = mbImpl->get_adjacencies(elems, 0, false, verts, Interface::UNION);
+ ErrorCode rval = mb->get_adjacencies(elems, 0, false, verts, Interface::UNION);
RR("Failed to get adj vertices.");
std::vector<double> coords(3*verts.size());
- rval = mbImpl->tag_get_data(tagh, verts, &coords[0]);
+ rval = mb->tag_get_data(tagh, verts, &coords[0]);
RR("Failed to get tag data.");
- rval = mbImpl->set_coords(verts, &coords[0]);
+ rval = mb->set_coords(verts, &coords[0]);
RR("Failed to set coordinates.");
return MB_SUCCESS;
@@ -302,92 +115,83 @@ void deform_func(double *xold, double *xnew)
xnew[1] = xold[1] + yfrac * (1.0 + xfrac) * 0.05;
-ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems)
+ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, Tag &xnew)
// create the tag
- ErrorCode rval = mbImpl->tag_get_handle("", 3, MB_TYPE_DOUBLE, xNew, MB_TAG_CREAT|MB_TAG_DENSE);
+ ErrorCode rval = mb->tag_get_handle("", 3, MB_TYPE_DOUBLE, xnew, MB_TAG_CREAT|MB_TAG_DENSE);
Range verts;
- rval = mbImpl->get_adjacencies(fluid_elems, 0, false, verts, Interface::UNION);
+ rval = mb->get_adjacencies(fluid_elems, 0, false, verts, Interface::UNION);
RR("Failed to get vertices.");
std::vector<double> coords(3*verts.size(), 0.0);
- rval = mbImpl->get_coords(verts, &coords[0]);
+ rval = mb->get_coords(verts, &coords[0]);
RR("Failed to get vertex coords.");
- rval = mbImpl->tag_set_data(xNew, verts, &coords[0]);
+ rval = mb->tag_set_data(xnew, verts, &coords[0]);
RR("Failed to set xnew tag on fluid verts.");
// get all the vertices and coords in the solid
verts.clear();
- rval = mbImpl->get_adjacencies(solid_elems, 0, false, verts, Interface::UNION);
+ rval = mb->get_adjacencies(solid_elems, 0, false, verts, Interface::UNION);
coords.resize(3*verts.size(), 0.0);
unsigned int num_verts = verts.size();
for (unsigned int i = 0; i < num_verts; i++)
deform_func(&coords[3*i], &coords[3*i]);
// set the new tag to those coords
RR("Failed to set tag data.");
return MB_SUCCESS;
-ErrorCode DeformMeshRemap::read_file(int m_or_s, string &fname, EntityHandle &seth)
+ErrorCode read_file(string &fname, EntityHandle &seth,
+ Range &solids, Range &solid_elems, Range &fluids, Range &fluid_elems)
// create meshset
- ErrorCode rval = mbImpl->create_meshset(0, seth);
+ ErrorCode rval = mb->create_meshset(0, seth);
RR("Couldn't create master/slave set.");
- rval = mbImpl->load_file(fname.c_str(), &seth);
+ rval = mb->load_file(fname.c_str(), &seth);
RR("Couldn't load master/slave mesh.");
// get material sets for solid/fluid
Tag tagh;
- rval = mbImpl->tag_get_handle(MATERIAL_SET_TAG_NAME, tagh); RR("Couldn't get material set tag name.");
- for (std::set<int>::iterator sit = solidSetNos.begin(); sit != solidSetNos.end(); sit++) {
- Range sets;
- int set_no = *sit;
- const void *setno_ptr = &set_no;
- rval = mbImpl->get_entities_by_type_and_tag(seth, MBENTITYSET, &tagh, &setno_ptr, 1, sets);
- if (sets.empty()) rval = MB_FAILURE;
- RR("Couldn't get any solid sets.");
- solidSets[m_or_s].merge(sets);
+ rval = mb->tag_get_handle(MATERIAL_SET_TAG_NAME, tagh); RR("Couldn't get material set tag name.");
+ const void *setno_ptr = &SOLID_SETNO;
+ rval = mb->get_entities_by_type_and_tag(seth, MBENTITYSET, &tagh, &setno_ptr, 1, solids);
+ if (solids.empty()) rval = MB_FAILURE;
+ RR("Couldn't get any solid sets.");
// get solid entities, and dimension
Range tmp_range;
- for (Range::iterator rit = solidSets[m_or_s].begin(); rit != solidSets[m_or_s].end(); rit++) {
- rval = mbImpl->get_entities_by_handle(*rit, tmp_range, true);
+ for (Range::iterator rit = solids.begin(); rit != solids.end(); rit++) {
+ rval = mb->get_entities_by_handle(*rit, tmp_range, true);
RR("Failed to get entities in solid.");
- int dim = mbImpl->dimension_from_handle(*tmp_range.rbegin());
+ int dim = mb->dimension_from_handle(*tmp_range.rbegin());
assert(dim > 0 && dim < 4);
- solidElems[m_or_s] = tmp_range.subset_by_dimension(dim);
- for (std::set<int>::iterator sit = fluidSetNos.begin(); sit != fluidSetNos.end(); sit++) {
- Range sets;
- RR("Couldn't get any fluid sets.");
- fluidSets[m_or_s].merge(sets);
+ solid_elems = tmp_range.subset_by_dimension(dim);
- // get fluid entities, and dimension
- tmp_range.clear();
- for (Range::iterator rit = fluidSets[m_or_s].begin(); rit != fluidSets[m_or_s].end(); rit++) {
+ setno_ptr = &FLUID_SETNO;
+ rval = mb->get_entities_by_type_and_tag(seth, MBENTITYSET, &tagh, &setno_ptr, 1, fluids);
+ if (fluids.empty()) rval = MB_FAILURE;
+ RR("Couldn't get any fluid sets.");
+ for (Range::iterator rit = fluids.begin(); rit != fluids.end(); rit++) {
+ rval = mb->get_entities_by_dimension(*rit, dim, fluid_elems, true);
RR("Failed to get entities in fluid.");
- fluidElems[m_or_s] = tmp_range.subset_by_dimension(dim);
+ if (mb->dimension_from_handle(*fluid_elems.begin()) != dim) {
+ rval = MB_FAILURE;
+ RR("Fluid and solid elements must be same dimension.");
return MB_SUCCESS;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
