[MOAB-dev] commit/MOAB: 4 new changesets
    commits-noreply at bitbucket.org
    Tue Nov 12 23:57:54 CST 2013
4 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/31889427adeb/
Changeset:   31889427adeb
Branch:      None
User:        iulian07
Date:        2013-11-13 06:57:34
Summary:     use FileOptions class to set up the arguments
It is much nicer, and it also has help automatically:
for example, diffusion -h does this:
 diffusion -h
Simulate a transport problem in a semi-Lagrangian formulation
This program simulates a transport problem on a sphere according to a benchmark from a Nair & Lauritzen paper.
It starts with a partitioned mesh on a sphere, add a tracer, and steps through.
The flow reverses after half time, and it should return to original configuration, if the integration was exact.
Usage: diffusion --help | [options]
Options:
  -h [--help]       : Show full help text
  -g [--gtolerance] <val>: geometric absolute tolerance (used for point concidence on the sphere)
  -i [--input_file] <arg>: input mesh file, partitioned
  -O [--extra_read_options] <arg>: extra read options
  -f [--field_type] <int>: field type--  1: quasi-smooth; 2: smooth; 3: slotted cylinders (non-smooth)
  -n [--num_steps] <int>: number of  steps
  -w [--write_debug_files]: write debugging files during simulation
  -v [--write_velocity_files]: Reorder mesh to group entities by partition
  -p [--write_result_in_parallel]: write tracer result files
Affected #:  1 file
diff --git a/tools/mbcslam/diffusion.cpp b/tools/mbcslam/diffusion.cpp
index ed1d120..378473e 100644
--- a/tools/mbcslam/diffusion.cpp
+++ b/tools/mbcslam/diffusion.cpp
@@ -39,6 +39,10 @@ on the sphere; see CSLAM Utils case1
 #include "CslamUtils.hpp"
+const char BRIEF_DESC[] =
+    "Simulate a transport problem in a semi-Lagrangian formulation\n";
+std::ostringstream LONG_DESC;
 // non smooth scalar field
 // some input data
 double gtol = 1.e-9; // this is for geometry tolerance
@@ -51,7 +55,7 @@ double T = 5;
 int case_number = 1; // 1, 2 (non-divergent) 3 divergent
 moab::Tag corrTag;
-bool noWrite = false;
+bool writeFiles = false;
 bool parallelWrite = false;
 bool velocity = false;
 int field_type = 1 ; // 1 quasi smooth, 2 - smooth, 3 non-smooth,
@@ -395,7 +399,7 @@ ErrorCode compute_tracer_case1(Interface * mb, Intx2MeshOnSphere & worker, Entit
   // lagr and euler are preserved
   EntityHandle covering_set;
   rval = worker.create_departure_mesh_3rd_alg(lagr_set, covering_set);
-  if (!noWrite) // so if write
+  if (writeFiles) // so if write
     std::stringstream newTracer;
     newTracer << "Tracer" << rank << "_" << tStep << ".vtk";
@@ -414,7 +418,7 @@ ErrorCode compute_tracer_case1(Interface * mb, Intx2MeshOnSphere & worker, Entit
   rval = worker.intersect_meshes(covering_set, euler_set, out_set);
   CHECK_ERR(rval);
     std::stringstream intx_mesh;
     intx_mesh << "Intx" << rank << "_" << tStep << ".vtk";
@@ -440,7 +444,7 @@ ErrorCode compute_tracer_case1(Interface * mb, Intx2MeshOnSphere & worker, Entit
     rval = mb->write_file(resTrace.str().c_str(), 0, "PARALLEL=WRITE_PART", &euler_set, 1, &tagElem, 1);
     std::stringstream newIntx;
     newIntx << "newIntx" << rank << "_" << tStep << ".vtk";
@@ -484,68 +488,49 @@ int main(int argc, char **argv)
   MPI_Init(&argc, &argv);
+  LONG_DESC << "This program simulates a transport problem on a sphere"
+        " according to a benchmark from a Nair & Lauritzen paper.\n"
+        << "It starts with a partitioned mesh on a sphere, add a tracer, and steps through.\n" <<
+        "The flow reverses after half time, and it should return to original configuration, if the integration was exact. ";
+  ProgOptions opts(LONG_DESC.str(), BRIEF_DESC);
-  std::string extra_read_opts;
   // read a homme file, partitioned in 16 so far
   std::string fileN= TestDir + "/HN16.h5m";
   const char *filename_mesh1 = fileN.c_str();
-  if (argc > 1)
-    int index = 1;
-    while (index < argc)
-      if (!strcmp(argv[index], "-gtol")) // this is for geometry tolerance
-        gtol = atof(argv[++index]);
-      if (!strcmp(argv[index], "-input"))
-        filename_mesh1 = argv[++index];
-      if (!strcmp(argv[index], "-O"))
-        extra_read_opts = std::string(argv[++index]);
-      if (!strcmp(argv[index], "-f"))
-        field_type = atoi(argv[++index]);
-      if (!strcmp(argv[index], "-ns"))
-        numSteps = atoi(argv[++index]);
-      if (!strcmp(argv[index], "-nw"))
-        noWrite = true;
-      if (!strcmp(argv[index], "-v"))
-        velocity = true;
-      if (!strcmp(argv[index], "-pw"))
-        parallelWrite = true;
-      if (!strcmp(argv[index], "-h"))
-        std::cout << "usage: -gtol <tol> -input <file> -O <extra_read_opts> -v (output velocities) \n   "
-        <<    "-f <field_type> -h (this help) -ns <numSteps> -pw (parallel write) -nw (no dbg write) \n";
-        std::cout << " field type: 1: quasi-smooth; 2: smooth; 3: slotted cylinders (non-smooth)\n";
-        return 0;
-      index++;
+  opts.addOpt<double>("gtolerance,g",
+      "geometric absolute tolerance (used for point concidence on the sphere)", >ol);
+  std::string input_file;
+  opts.addOpt<std::string>("input_file,i", "input mesh file, partitioned",
+      &input_file);
+  std::string extra_read_opts;
+  opts.addOpt<std::string>("extra_read_options,O", "extra read options ",
+        &extra_read_opts);
+  //int field_type;
+  opts.addOpt<int>("field_type,f",
+        "field type--  1: quasi-smooth; 2: smooth; 3: slotted cylinders (non-smooth)", &field_type);
+  opts.addOpt<int>("num_steps,n",
+          "number of  steps ", &numSteps);
+  //bool reorder = false;
+  opts.addOpt<void>("write_debug_files,w", "write debugging files during simulation ",
+        &writeFiles);
+  opts.addOpt<void>("write_velocity_files,v", "Reorder mesh to group entities by partition",
+     &velocity);
+  opts.addOpt<void>("write_result_in_parallel,p", "write tracer result files",
+     ¶llelWrite);
+  opts.parseCommandLine(argc, argv);
+  if (!input_file.empty())
+    filename_mesh1=input_file.c_str();
   // read in parallel, in the "euler_set", the initial mesh
-  std::string opts = std::string("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION")+
+  std::string optsRead = std::string("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION")+
             std::string(";PARALLEL_RESOLVE_SHARED_ENTS")+extra_read_opts;
   Core moab;
   Interface & mb = moab;
@@ -554,7 +539,7 @@ int main(int argc, char **argv)
   rval = mb.create_meshset(MESHSET_SET, euler_set);
   CHECK_ERR(rval);
-  rval = mb.load_file(filename_mesh1, &euler_set, opts.c_str());
+  rval = mb.load_file(filename_mesh1, &euler_set, optsRead.c_str());
   ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
   CHECK_ERR(rval);
@@ -569,7 +554,7 @@ int main(int argc, char **argv)
     std::cout << " case 1: use -gtol " << gtol <<
         " -R " << radius << " -input " << filename_mesh1 <<  " -f " << field_type <<
         " numSteps: " << numSteps << "\n";
-    std::cout<<" write debug results: " << (noWrite ? "no" : "yes") << "\n";
+    std::cout<<" write debug results: " << (writeFiles ? "yes" : "no") << "\n";
     std::cout<< " write tracer in parallel: " << ( parallelWrite ? "yes" : "no") << "\n";
     std::cout <<" output velocity: " << (velocity? "yes" : "no") << "\n";
https://bitbucket.org/fathomteam/moab/commits/ce159c7e5cb7/
Changeset:   ce159c7e5cb7
Branch:      None
User:        iulian07
Summary:     report area of the intersection polygons;
Affected #:  1 file
diff --git a/tools/mbcslam/Intx2MeshOnSphere.cpp b/tools/mbcslam/Intx2MeshOnSphere.cpp
index 7ea5854..a1d786b 100644
--- a/tools/mbcslam/Intx2MeshOnSphere.cpp
+++ b/tools/mbcslam/Intx2MeshOnSphere.cpp
@@ -452,6 +452,7 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
   std::vector<double> newValues(rs2.size(), 0.);// initialize with 0 all of them
   // area of the polygon * conc on red (old) current quantity
   // finaly, divide by the area of the red
+  double check_intx_area=0.;
   for (Range::iterator it= polys.begin(); it!=polys.end(); it++)
     EntityHandle poly=*it;
@@ -465,6 +466,7 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
     // big assumption here, red and blue are "parallel" ;we should have an index from
     // blue to red (so a deformed blue corresponds to an arrival red)
     double areap = area_spherical_element(mb, poly, R);
+    check_intx_area+=areap;
     // so the departure cell at time t (blueIndex) covers a portion of a redCell
     // that quantity will be transported to the redCell at time t+dt
     // the blue corresponds to a red arrival
@@ -535,10 +537,17 @@ ErrorCode Intx2MeshOnSphere::update_tracer_data(EntityHandle out_set, Tag & tagE
   ERRORR(rval, "can't set new values tag");
   double total_mass=0.;
+  double total_intx_area =0;
   int mpi_err = MPI_Reduce(&total_mass_local, &total_mass, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD);
   if (MPI_SUCCESS != mpi_err) return MB_FAILURE;
+  // now reduce total area
+  mpi_err = MPI_Reduce(&check_intx_area, &total_intx_area, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD);
+  if (MPI_SUCCESS != mpi_err) return MB_FAILURE;
   if (my_rank==0)
     std::cout <<"total mass now:" << total_mass << "\n";
+    std::cout <<"check: total intersection area: (4 * M_PI * R^2): " << total_intx_area << "\n";
   if (remote_cells)
https://bitbucket.org/fathomteam/moab/commits/9f8346f39e8a/
Changeset:   9f8346f39e8a
Branch:      None
User:        iulian07
Summary:     side number for padded polygons
the only problem is the edge between last node and first node;
Affected #:  1 file
diff --git a/src/Core.cpp b/src/Core.cpp
index ad6bdda..a6e6cfd 100644
--- a/src/Core.cpp
+++ b/src/Core.cpp
@@ -2971,7 +2971,7 @@ ErrorCode Core::side_number(const EntityHandle parent,
     return (0 == temp_result ? MB_SUCCESS : MB_FAILURE);
   else if (TYPE_FROM_HANDLE(parent) == MBPOLYGON) {
-      // find location of 1st vertex
+      // find location of 1st vertex; this works even for padded vertices
     const EntityHandle *first_v = std::find(parent_conn, parent_conn+num_parent_vertices,
                                               child_conn[0]);
     if (first_v == parent_conn+num_parent_vertices) return MB_ENTITY_NOT_FOUND;
@@ -2990,11 +2990,23 @@ ErrorCode Core::side_number(const EntityHandle parent,
       else return MB_ENTITY_NOT_FOUND;
     else if (TYPE_FROM_HANDLE(child) == MBEDGE) {
+      // determine the actual number of vertices, for the padded case
+      // the padded case could be like ABCDEFFF; num_parent_vertices=8, actual_num_parent_vertices=6
+      int actual_num_parent_vertices = num_parent_vertices;
+      while(actual_num_parent_vertices>=3 &&
+          (parent_conn[actual_num_parent_vertices-2] ==parent_conn[actual_num_parent_vertices-1] ) )
+        actual_num_parent_vertices--;
       if (parent_conn[(sd_number+1)%num_parent_vertices] == child_conn[1])
         sense = 1;
       else if (parent_conn[(sd_number+num_parent_vertices-1)%num_parent_vertices] ==
-               child_conn[1])
+               child_conn[1]) // this will also cover edge AF for padded case, side will be 0, sense -1
         sense = -1;
+      // if edge FA in above example, we should return sd_number = 5, sense 1
+      else if ((sd_number==actual_num_parent_vertices-1) && (child_conn[1]==parent_conn[0]))
+        sense =1;
+      else
+        return MB_ENTITY_NOT_FOUND;
       return MB_SUCCESS;
https://bitbucket.org/fathomteam/moab/commits/1bbc73aca065/
Changeset:   1bbc73aca065
Branch:      master
User:        iulian07
Summary:     use zoltan partitioning for intx_mpas
assumes that the build is configured with zoltan
it is launched in serial as a test here, so it should not matter for
make check
Affected #:  1 file
diff --git a/tools/mbcslam/intx_mpas.cpp b/tools/mbcslam/intx_mpas.cpp
index 6888cb3..570c97f 100644
--- a/tools/mbcslam/intx_mpas.cpp
+++ b/tools/mbcslam/intx_mpas.cpp
@@ -121,7 +121,7 @@ int main(int argc, char **argv)
-  std::string fileN= TestDir + "/mpas_p8.h5m";
+  std::string fileN= TestDir + "/io/mpasx1.642.t.2.nc";
   bool flux_form = false;
   if (argc > 1)
@@ -164,8 +164,8 @@ int main(int argc, char **argv)
   // start copy
-            std::string(";PARALLEL_RESOLVE_SHARED_ENTS")+extra_read_opts;
+  std::string opts = std::string("PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN")+
+            std::string(";PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=;")+extra_read_opts;
   Core moab;
   EntityHandle euler_set;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
