[MOAB-dev] commit/MOAB: iulian07: reformat the gs.cpp and TupleList.cpp files
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Wed Nov 27 11:30:29 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b1a44624eb2c/
Changeset:   b1a44624eb2c
Branch:      master
User:        iulian07
Date:        2013-11-27 18:27:17
Summary:     reformat the gs.cpp and TupleList.cpp files
format the files according to moab suggestions,
tabs are replaced with 2 spaces, and avoid using the comma separator
between instructions, to make it easier to read (for me :)
nothing should change in the logic, and all tests pass in parallel
Affected #:  2 files
diff --git a/src/parallel/TupleList.cpp b/src/parallel/TupleList.cpp
index ad5b055..bf08946 100644
--- a/src/parallel/TupleList.cpp
+++ b/src/parallel/TupleList.cpp
@@ -9,496 +9,574 @@
 namespace moab {
-  void fail(const char *fmt, ...)
-    va_list ap;
-    va_start(ap, fmt);
-    vfprintf(stderr, fmt, ap);
-    va_end(ap);
-    exit(1);
+void fail(const char *fmt, ...)
+  va_list ap;
+  va_start(ap, fmt);
+  vfprintf(stderr, fmt, ap);
+  va_end(ap);
+  exit(1);
-  TupleList::buffer::buffer(size_t sz)
-    ptr = NULL;
-    buffSize=0;
-    this->buffer_init_(sz, __FILE__);
+TupleList::buffer::buffer(size_t sz)
+  ptr = NULL;
+  buffSize = 0;
+  this->buffer_init_(sz, __FILE__);
-  TupleList::buffer::buffer()
-    buffSize=0;
-    ptr = NULL;
+TupleList::buffer::buffer()
+  buffSize = 0;
+  ptr = NULL;
-  void TupleList::buffer::buffer_init_(size_t sizeIn, const char *file)
+void TupleList::buffer::buffer_init_(size_t sizeIn, const char *file)
+  this->buffSize = sizeIn;
+  void *res = malloc(this->buffSize);
+  if (!res && buffSize > 0)
+    fail("%s: allocation of %d bytes failed\n", file, (int) buffSize);
+  ptr = (char*) res;
+void TupleList::buffer::buffer_reserve_(size_t min, const char *file)
+  if (this->buffSize < min)
-    this->buffSize = sizeIn;
-    void *res = malloc(this->buffSize);
-    if (!res && buffSize > 0)
-      fail("%s: allocation of %d bytes failed\n",file,(int)buffSize);
+    size_t newSize = this->buffSize;
+    newSize += newSize / 2 + 1;
+    if (newSize < min)
+      newSize = min;
+    void *res = realloc(ptr, newSize);
+    if (!res && newSize > 0)
+      fail("%s: allocation of %d bytes failed\n", file, (int) this->buffSize);
     ptr = (char*) res;
+    this->buffSize = newSize;
-  void TupleList::buffer::buffer_reserve_(size_t min, const char *file)
-    if(this->buffSize < min) {
-      size_t newSize = this->buffSize;
-      newSize += newSize/2 + 1;
-      if (newSize < min) newSize = min;
-      void *res = realloc (ptr, newSize);
-      if (!res && newSize > 0)
-	fail("%s: allocation of %d bytes failed\n",file,(int)this->buffSize);
-      ptr = (char*) res;
-      this->buffSize = newSize;
+void TupleList::buffer::reset()
+  free(ptr);
+  ptr = NULL;
+  buffSize = 0;
-  void TupleList::buffer::reset ()
-    free(ptr);
-    ptr = NULL;
-    buffSize = 0;
+TupleList::TupleList(uint p_mi, uint p_ml, uint p_mul, uint p_mr, uint p_max)
+  vi = NULL;
+  vl = NULL;
+  vul = NULL;
+  vr = NULL;
+  initialize(p_mi, p_ml, p_mul, p_mr, p_max);
-  TupleList::TupleList(uint p_mi, uint p_ml,
-		       uint p_mul, uint p_mr, uint p_max)
-    vi = NULL;
-    vl = NULL;
-    vul = NULL;
-    vr = NULL;
-    initialize (p_mi, p_ml, p_mul, p_mr, p_max);
+TupleList::TupleList()
+  vi = NULL;
+  vl = NULL;
+  vul = NULL;
+  vr = NULL;
+  disableWriteAccess();
-  TupleList::TupleList()
+// Allocates space for the tuple list in memory according to parameters
+void TupleList::initialize(uint p_mi, uint p_ml, uint p_mul, uint p_mr,
+    uint p_max)
+  this->n = 0;
+  this->max = p_max;
+  this->mi = p_mi;
+  this->ml = p_ml;
+  this->mul = p_mul;
+  this->mr = p_mr;
+  size_t sz;
+  if (max * mi > 0)
+    sz = max * mi * sizeof(sint);
+    void *resi = malloc(sz);
+    if (!resi && max * mi > 0)
+      fail("%s: allocation of %d bytes failed\n", __FILE__, (int) sz);
+    vi = (sint*) resi;
+  else
     vi = NULL;
+  if (max * ml > 0)
+    sz = max * ml * sizeof(slong);
+    void *resl = malloc(sz);
+    if (!resl && max * ml > 0)
+    vl = (slong*) resl;
+  else
     vl = NULL;
+  if (max * mul > 0)
+    sz = max * mul * sizeof(ulong);
+    void *resu = malloc(sz);
+    if (!resu && max * mul > 0)
+    vul = (ulong*) resu;
+  else
     vul = NULL;
-    vr = NULL;
-    disableWriteAccess();
+  if (max * mr > 0)
+    sz = max * mr * sizeof(realType);
+    void *resr = malloc(sz);
+    if (!resr && max * ml > 0)
+    vr = (realType*) resr;
+  else
+    vr = NULL;
-  // Allocates space for the tuple list in memory according to parameters
-  void TupleList::initialize (uint p_mi, uint p_ml,
-    this->n = 0;
-    this->max = p_max;
-    this->mi = p_mi;
-    this->ml = p_ml;
-    this->mul = p_mul;
-    this->mr = p_mr;
-    size_t sz;
-    if (max*mi > 0) {
-      sz = max*mi*sizeof(sint);
-      void *resi = malloc(sz);
-      if(!resi && max*mi > 0)
-	fail("%s: allocation of %d bytes failed\n",__FILE__,(int)sz);
-      vi = (sint*) resi;
-    } else
-      vi = NULL;
-    if (max*ml > 0) {
-      sz = max*ml*sizeof(slong);
-      void *resl = malloc(sz);
-      if(!resl && max*ml > 0)
-      vl = (slong*) resl;
-    } else
-      vl = NULL;
-    if (max*mul > 0) {
-      sz = max*mul*sizeof(ulong);
-      void *resu = malloc(sz);
-      if(!resu && max*mul > 0)
-      vul = (ulong*) resu;
-    } else
-      vul = NULL;
-    if (max*mr > 0) {
-      sz = max*mr*sizeof(realType);
-      void *resr = malloc(sz);
-      if(!resr && max*ml > 0)
-      vr=(realType*) resr;
-    } else
-      vr = NULL;
-    //Begin with write access disabled
-    this->disableWriteAccess();
-    //Set read variables
-    vi_rd = vi; vl_rd = vl; vul_rd = vul; vr_rd = vr;
+  //Begin with write access disabled
+  this->disableWriteAccess();
-  // Resizes a tuplelist to the given uint max
-  ErrorCode TupleList::resize(uint maxIn)
-    this->max = maxIn;
-    size_t sz;
+  //Set read variables
+  vi_rd = vi;
+  vl_rd = vl;
+  vul_rd = vul;
+  vr_rd = vr;
-    if (vi || (max*mi > 0)){
-      void *resi = realloc(vi, sz);
-      if(!resi && max*mi > 0){
-	return moab::MB_MEMORY_ALLOCATION_FAILED;
-    if (vl || (max*ml > 0)){
-      void *resl = realloc(vl, sz);
-      if(!resl && max*ml > 0){
-    if (vul || (max*mul > 0)){
-      void *resu = realloc(vul, sz);
-      if(!resu && max*mul > 0){
+// Resizes a tuplelist to the given uint max
+ErrorCode TupleList::resize(uint maxIn)
+  this->max = maxIn;
+  size_t sz;
+  if (vi || (max * mi > 0))
+    void *resi = realloc(vi, sz);
+      return moab::MB_MEMORY_ALLOCATION_FAILED;
-    if (vr || (max*mr > 0)){
-      void *resr = realloc(vr, sz);
-      if(!resr && max*mr > 0){
-      vr = (realType*) resr;
+  if (vl || (max * ml > 0))
+    void *resl = realloc(vl, sz);
-    //Set the write variables if necessary
-    if(writeEnabled){
-      vi_wr = vi; vl_wr = vl; vul_wr = vul; vr_wr = vr;
+  if (vul || (max * mul > 0))
+    void *resu = realloc(vul, sz);
-    return moab::MB_SUCCESS;
-  // Frees the memory used by the tuplelist
-  void TupleList::reset()
+  if (vr || (max * mr > 0))
-    //free up the pointers
-    free(vi);
-    free(vl);
-    free(vul);
-    free(vr);
-    //Set them all to null
-    vr = NULL;
-    vi = NULL;
-    vul = NULL;
-    vl = NULL;
-    //Set the read and write pointers to null
-    vi_rd =  NULL;  vl_rd = NULL;
-    vul_rd = NULL;  vr_rd = NULL;
+    void *resr = realloc(vr, sz);
+    if (!resr && max * mr > 0)
-  // Increments n; if n>max, increase the size of the tuplelist
-  void TupleList::reserve()
+  vi_rd = vi;
+  vl_rd = vl;
+  vul_rd = vul;
+  vr_rd = vr;
+  //Set the write variables if necessary
+  if (writeEnabled)
-    n++;
-    while (n>max)
-      resize((max ? max+max/2+1 : 2));
-    last_sorted = -1;
+    vi_wr = vi;
+    vl_wr = vl;
+    vul_wr = vul;
+    vr_wr = vr;
+  return moab::MB_SUCCESS;
-  // Given the value and the position in the field, finds the index of the tuple
-  // to which the value belongs
-  int TupleList::find(unsigned int key_num, sint value)
-    ulong uvalue = (ulong) value;
-    if (!(key_num>mi)) {
-      // Binary search: only if the tuple_list is sorted
-      if (last_sorted==(int)key_num) {
-	int lb=0, ub=n, index;		// lb=lower bound, ub=upper bound, index=mid
-	for (;lb<=ub;) {
-	  index = (lb+ub)/2;
-	  if (vi[index*mi+key_num] == (long)uvalue)
-	    return index;
-	  else if (vi[index*mi+key_num] > (long)uvalue)
-	    ub = index-1;
-	  else if (vi[index*mi+key_num] < (long)uvalue)
-	    lb = index+1;
-      else {
-	// Sequential search: if tuple_list is not sorted
-	for (long index = 0; index<n; index++) {
-	    return index;
-    return -1;	// If the value wasn't present or an invalid key was given
+// Frees the memory used by the tuplelist
+void TupleList::reset()
+  //free up the pointers
+  free(vi);
+  free(vl);
+  free(vul);
+  free(vr);
+  //Set them all to null
+  vr = NULL;
+  vi = NULL;
+  vul = NULL;
+  vl = NULL;
+  //Set the read and write pointers to null
+  vi_rd = NULL;
+  vl_rd = NULL;
+  vul_rd = NULL;
+  vr_rd = NULL;
-  int TupleList::find(unsigned int key_num, slong value)
-    if (!(key_num>ml)) {
-      if (last_sorted-mi==key_num) {
-	for (;lb<=ub;) {
-	  if(vl[index*ml+key_num] == (long)uvalue)
-	    return index;
-	  else if (vl[index*ml+key_num] > (long)uvalue)
-	    ub = index-1;
-	  else if (vl[index*ml+key_num] < (long)uvalue)
-	    lb = index+1;
+// Increments n; if n>max, increase the size of the tuplelist
+void TupleList::reserve()
+  n++;
+  while (n > max)
+    resize((max ? max + max / 2 + 1 : 2));
+  last_sorted = -1;
+// Given the value and the position in the field, finds the index of the tuple
+// to which the value belongs
+int TupleList::find(unsigned int key_num, sint value)
+  ulong uvalue = (ulong) value;
+  if (!(key_num > mi))
+    // Binary search: only if the tuple_list is sorted
+    if (last_sorted == (int) key_num)
+      int lb = 0, ub = n, index; // lb=lower bound, ub=upper bound, index=mid
+      for (; lb <= ub;)
+        index = (lb + ub) / 2;
+        if (vi[index * mi + key_num] == (long) uvalue)
+          return index;
+        else if (vi[index * mi + key_num] > (long) uvalue)
+          ub = index - 1;
+        else if (vi[index * mi + key_num] < (long) uvalue)
+          lb = index + 1;
-      else {
-	for (uint index = 0; index<n; index++) {
-	  if (vl[index*ml+key_num] == (long)uvalue)
-	    return index;
+    else
+      // Sequential search: if tuple_list is not sorted
+      for (long index = 0; index < n; index++)
+          return index;
+  return -1; // If the value wasn't present or an invalid key was given
-  int TupleList::find(unsigned int key_num, ulong value)
-    if (!(key_num>mul)) {
-      if (last_sorted-mi-ml==key_num) {
-	int lb=0, ub=n-1, index;	// lb=lower bound, ub=upper bound, index=mid
-	for (;lb<=ub;) {
-	  if (vul[index*mul+key_num] == value)
-	    return index;
-	  else if (vul[index*mul+key_num] > value)
-	    ub=index-1;
-	  else if (vul[index*mul+key_num] < value)
-	    lb=index+1;
+int TupleList::find(unsigned int key_num, slong value)
+  if (!(key_num > ml))
+    if (last_sorted - mi == key_num)
+      for (; lb <= ub;)
+        if (vl[index * ml + key_num] == (long) uvalue)
+          return index;
+        else if (vl[index * ml + key_num] > (long) uvalue)
+          ub = index - 1;
+        else if (vl[index * ml + key_num] < (long) uvalue)
+          lb = index + 1;
-      else {
-	    return index;
+    else
+      for (uint index = 0; index < n; index++)
+          return index;
-  int TupleList::find(unsigned int key_num, realType value)
+int TupleList::find(unsigned int key_num, ulong value)
+  if (!(key_num > mul))
-    if (!key_num>mr) {
-      // Sequential search: TupleList cannot be sorted by reals
-        if (vr[index*mr+key_num] == value)
+    if (last_sorted - mi - ml == key_num)
+      int lb = 0, ub = n - 1, index; // lb=lower bound, ub=upper bound, index=mid
+      for (; lb <= ub;)
+        if (vul[index * mul + key_num] == value)
+          return index;
+        else if (vul[index * mul + key_num] > value)
+          ub = index - 1;
+        else if (vul[index * mul + key_num] < value)
+          lb = index + 1;
+    else
           return index;
-  sint TupleList::get_sint(unsigned int index, unsigned int m)
+int TupleList::find(unsigned int key_num, realType value)
+  if (!key_num > mr)
-    if (mi>m && n>index)
-      return vi[index*mi+m];
-    return 0;
+    // Sequential search: TupleList cannot be sorted by reals
+      if (vr[index * mr + key_num] == value)
+        return index;
-  slong TupleList::get_int(unsigned int index, unsigned int m)
-    if (ml>m && n>index)
-      return vl[index*ml+m];
-    return 0;
+sint TupleList::get_sint(unsigned int index, unsigned int m)
+  if (mi > m && n > index)
+    return vi[index * mi + m];
+  return 0;
-  ulong TupleList::get_ulong(unsigned int index, unsigned int m)
-    if (mul>m && n>index)
-      return vul[index*mul+m];
-    return 0;
+slong TupleList::get_int(unsigned int index, unsigned int m)
+  if (ml > m && n > index)
+    return vl[index * ml + m];
+  return 0;
-  realType TupleList::get_double(unsigned int index, unsigned int m)
-    if (mr>m && n>index)
-      return vr[index*mr+m];
-    return 0;
+ulong TupleList::get_ulong(unsigned int index, unsigned int m)
+  if (mul > m && n > index)
+    return vul[index * mul + m];
+  return 0;
-  ErrorCode TupleList::get(unsigned int index, const sint *&sp,
-			   const slong *&ip, const ulong *&lp,
-			   const realType *&dp)
-    if (index <= n){
-      if (mi) *&sp = &vi[index*mi];
-      else *&sp = NULL;
-      if (ml) *&ip = &vl[index*ml];
-      else *&ip = NULL;
-      if (mul) *&lp = &vul[index*mul];
-      else *&lp = NULL;
-      if (mr) *&dp = &vr[index*mr];
-      else *&dp = NULL;
-      return MB_SUCCESS;
-    return MB_FAILURE;
+realType TupleList::get_double(unsigned int index, unsigned int m)
+  if (mr > m && n > index)
+    return vr[index * mr + m];
+  return 0;
-  unsigned int TupleList::push_back(sint *sp, slong *ip,
-				    ulong *lp, realType *dp)
+ErrorCode TupleList::get(unsigned int index, const sint *&sp, const slong *&ip,
+    const ulong *&lp, const realType *&dp)
+  if (index <= n)
-    reserve();
     if (mi)
-      memcpy(&vi[mi*(n-1)], sp, mi*sizeof(sint));
+      *&sp = &vi[index * mi];
+    else
+      *&sp = NULL;
     if (ml)
-      memcpy(&vl[ml*(n-1)], ip, ml*sizeof(long));
+      *&ip = &vl[index * ml];
+    else
+      *&ip = NULL;
     if (mul)
-      memcpy(&vul[mul*(n-1)], lp, mul*sizeof(ulong));
+      *&lp = &vul[index * mul];
+    else
+      *&lp = NULL;
     if (mr)
-      memcpy(&vr[mr*(n-1)], dp, mr*sizeof(realType));
+      *&dp = &vr[index * mr];
+    else
+      *&dp = NULL;
-    last_sorted = -1;
-    return n-1;
+    return MB_SUCCESS;
+  return MB_FAILURE;
-  void TupleList::enableWriteAccess()
-    writeEnabled = true;
-    last_sorted = -1;
+unsigned int TupleList::push_back(sint *sp, slong *ip, ulong *lp, realType *dp)
+  reserve();
+  if (mi)
+    memcpy(&vi[mi * (n - 1)], sp, mi * sizeof(sint));
+  if (ml)
+    memcpy(&vl[ml * (n - 1)], ip, ml * sizeof(long));
+  if (mul)
+    memcpy(&vul[mul * (n - 1)], lp, mul * sizeof(ulong));
+  if (mr)
+    memcpy(&vr[mr * (n - 1)], dp, mr * sizeof(realType));
+  last_sorted = -1;
+  return n - 1;
-  void TupleList::disableWriteAccess()
-    writeEnabled = false;
-    vi_wr = NULL; vl_wr = NULL;
-    vul_wr= NULL; vr_wr = NULL;
+void TupleList::enableWriteAccess()
+  writeEnabled = true;
+  last_sorted = -1;
+  vi_wr = vi;
+  vl_wr = vl;
+  vul_wr = vul;
+  vr_wr = vr;
-  void TupleList::getTupleSize(uint &mi_out, uint &ml_out,
-		      uint &mul_out, uint &mr_out) const
-    mi_out = mi; ml_out = ml;
-    mul_out = mul; mr_out = mr;
+void TupleList::disableWriteAccess()
+  writeEnabled = false;
+  vi_wr = NULL;
+  vl_wr = NULL;
+  vul_wr = NULL;
+  vr_wr = NULL;
-  uint TupleList::inc_n()
-    //Check for direct write access
-    if(!writeEnabled){
-      enableWriteAccess();
-    n++;
-    return n;
+void TupleList::getTupleSize(uint &mi_out, uint &ml_out, uint &mul_out,
+    uint &mr_out) const
+  mi_out = mi;
+  ml_out = ml;
+  mul_out = mul;
+  mr_out = mr;
-  void TupleList::set_n(uint n_in)
+uint TupleList::inc_n()
+  //Check for direct write access
+  if (!writeEnabled)
-    //Check for direct write access;
-    n = n_in;
+    enableWriteAccess();
+  n++;
+  return n;
-  void TupleList::print(const char *name) const
+void TupleList::set_n(uint n_in)
+  //Check for direct write access;
-    std::cout<<"Printing Tuple " << name << "==================="<<std::endl;
-    unsigned long i=0,l=0,ul=0,r=0;
-    for(uint k=0; k<n; k++){
-      for(uint j=0; j<mi; j++){
-	std::cout<<vi[i++]<<" | ";
-      for(uint j=0; j<ml; j++){
-	std::cout<<vl[l++]<<" | ";
-      for(uint j=0; j<mul; j++){
-	std::cout<<vul[ul++]<<" | ";
-      for(uint j=0; j<mr; j++){
-	std::cout<<vr[r++]<<" | ";
-      std::cout<<std::endl;
-    std::cout<<"======================================="<<std::endl<<std::endl;
+  n = n_in;
-  void TupleList::permute(uint *perm, void *work)
+void TupleList::print(const char *name) const
+  std::cout << "Printing Tuple " << name << "===================" << std::endl;
+  unsigned long i = 0, l = 0, ul = 0, r = 0;
+  for (uint k = 0; k < n; k++)
-    const unsigned int_size  = mi*sizeof(sint),
-      long_size = ml*sizeof(slong),
-      ulong_size = mul*sizeof(ulong),
-      real_size = mr*sizeof(realType);
-    if(mi) {
-      uint *p=perm, *pe=p+n; char *sorted=(char *)work;
-      while(p!=pe) memcpy((void *)sorted,&vi[mi*(*p++)],int_size),sorted+=int_size;
-      memcpy(vi,work,int_size*n);
+    for (uint j = 0; j < mi; j++)
+      std::cout << vi[i++] << " | ";
-    if(ml) {
-      while(p!=pe) memcpy((void *)sorted,&vl[ml*(*p++)],long_size),sorted+=long_size;
-      memcpy(vl,work,long_size*n);
+    for (uint j = 0; j < ml; j++)
+      std::cout << vl[l++] << " | ";
-    if(mul) {
-      while(p!=pe) memcpy((void *)sorted,&vul[mul*(*p++)],ulong_size),sorted+=ulong_size;
-      memcpy(vul,work,ulong_size*n);
+    for (uint j = 0; j < mul; j++)
+      std::cout << vul[ul++] << " | ";
-    if(mr) {
-      while(p!=pe) memcpy((void *)sorted,&vr[mr*(*p++)],real_size),sorted+=real_size;
-      memcpy(vr,work,real_size*n);
+    for (uint j = 0; j < mr; j++)
+      std::cout << vr[r++] << " | ";
+    std::cout << std::endl;
-# define umax_2(a, b) (((a)>(b)) ? (a):(b))
+  std::cout << "=======================================" << std::endl
+      << std::endl;
-  ErrorCode TupleList::sort(uint key, TupleList::buffer *buf)
-    const unsigned int_size =  mi*sizeof(sint);
-    const unsigned long_size = ml*sizeof(slong);
-    const unsigned ulong_size = mul*sizeof(ulong);
-    const unsigned real_size = mr*sizeof(realType);
-    const unsigned width = umax_2(umax_2(int_size,long_size),
-				  umax_2(ulong_size,real_size));
-    const unsigned data_size = key>=mi?
-                               sizeof(SortData<long>):
-                               sizeof(SortData<uint>);
-    uint work_min= n * umax_2(2*data_size,sizeof(sint)+width);
-    uint *work;
-    buf->buffer_reserve(work_min);
-    work = (uint *)buf->ptr;
-    if(key<mi)
-      index_sort((uint *)&vi[key],        n, mi,  work,  (SortData<uint>*)work);
-    else if (key < mi+ml)
-      index_sort((long*)&vl[key-mi],      n, ml,  work, (SortData<long>*)work);
-    else if (key < mi + ml + mul)
-      index_sort((ulong*)&vul[key-mi-ml], n, mul, work, (SortData<ulong>*)work);
-    else
-      return MB_NOT_IMPLEMENTED;
+void TupleList::permute(uint *perm, void *work)
+  const unsigned int_size = mi * sizeof(sint), long_size = ml * sizeof(slong),
+      ulong_size = mul * sizeof(ulong), real_size = mr * sizeof(realType);
+  if (mi)
+    uint *p = perm, *pe = p + n;
+    char *sorted = (char *) work;
+    while (p != pe)
+      memcpy((void *) sorted, &vi[mi * (*p++)], int_size), sorted += int_size;
+    memcpy(vi, work, int_size * n);
+  if (ml)
+    while (p != pe)
+      memcpy((void *) sorted, &vl[ml * (*p++)], long_size), sorted += long_size;
+    memcpy(vl, work, long_size * n);
+  if (mul)
+    while (p != pe)
+      memcpy((void *) sorted, &vul[mul * (*p++)], ulong_size), sorted +=
+          ulong_size;
+    memcpy(vul, work, ulong_size * n);
+  if (mr)
+    while (p != pe)
+      memcpy((void *) sorted, &vr[mr * (*p++)], real_size), sorted += real_size;
+    memcpy(vr, work, real_size * n);
-    permute(work,work+n);
+# define umax_2(a, b) (((a)>(b)) ? (a):(b))
-    if(!writeEnabled) last_sorted = key;
+ErrorCode TupleList::sort(uint key, TupleList::buffer *buf)
+  const unsigned int_size = mi * sizeof(sint);
+  const unsigned long_size = ml * sizeof(slong);
+  const unsigned ulong_size = mul * sizeof(ulong);
+  const unsigned real_size = mr * sizeof(realType);
+  const unsigned width = umax_2(umax_2(int_size,long_size),
+      umax_2(ulong_size,real_size));
+  const unsigned data_size =
+      key >= mi ? sizeof(SortData<long> ) : sizeof(SortData<uint> );
+  uint work_min = n * umax_2(2*data_size,sizeof(sint)+width);
+  uint *work;
+  buf->buffer_reserve(work_min);
+  work = (uint *) buf->ptr;
+  if (key < mi)
+    index_sort((uint *) &vi[key], n, mi, work, (SortData<uint>*) work);
+  else if (key < mi + ml)
+    index_sort((long*) &vl[key - mi], n, ml, work, (SortData<long>*) work);
+  else if (key < mi + ml + mul)
+    index_sort((ulong*) &vul[key - mi - ml], n, mul, work,
+        (SortData<ulong>*) work);
+  else
+    return MB_NOT_IMPLEMENTED;
+  permute(work, work + n);
+    last_sorted = key;
 #undef umax_2
 #define DIGIT_BITS   8
 #define DIGIT_VALUES (1<<DIGIT_BITS)
 #define DIGIT_MASK   ((Value)(DIGIT_VALUES-1))
@@ -517,24 +595,24 @@ namespace moab {
 #define COUNT_DIGIT_32(n,i) COUNT_DIGIT_16(n,i); COUNT_DIGIT_16(n,i+16)
 #define COUNT_DIGIT_64(n,i) COUNT_DIGIT_32(n,i); COUNT_DIGIT_32(n,i+32)
 template<class Value>
 Value TupleList::radix_count(const Value *A, const Value *end, Index stride,
-			     Index count[DIGITS][DIGIT_VALUES])
+    Index count[DIGITS][DIGIT_VALUES])
   Value bitorkey = 0;
-  memset(count,0,COUNT_SIZE*sizeof(Index));
-  do {
-    Value val=*A;
-    bitorkey|=val;
-    COUNT_DIGIT_64(DIGITS,0);
+  memset(count, 0, COUNT_SIZE * sizeof(Index));
+  do
+    Value val = *A;
+    bitorkey |= val;
+    COUNT_DIGIT_64(DIGITS, 0);
     // above macro expands to:
     //if(DIGITS> 0) count[ 0][val&DIGIT_MASK]++, val>>=DIGIT_BITS;
     //if(DIGITS> 1) count[ 1][val&DIGIT_MASK]++, val>>=DIGIT_BITS;
     //if(DIGITS>63) count[63][val&DIGIT_MASK]++, val>>=DIGIT_BITS;
-  } while(A+=stride,A!=end);
+  } while (A += stride, A != end);
   return bitorkey;
@@ -548,157 +626,225 @@ Value TupleList::radix_count(const Value *A, const Value *end, Index stride,
 void TupleList::radix_offsets(Index *c)
-  Index sum=0, t, *ce=c+DIGIT_VALUES;
-  do t=*c, *c++ = sum, sum+=t; while(c!=ce);
+  Index sum = 0, t, *ce = c + DIGIT_VALUES;
+  do
+    t = *c, *c++ = sum, sum += t;
+  while (c != ce);
-unsigned TupleList::radix_zeros(Value bitorkey, Index count[DIGITS][DIGIT_VALUES],
-                            unsigned *shift, Index **offsets)
-  unsigned digits=0, sh=0; Index *c = &count[0][0];
-  do {
-    if(bitorkey&DIGIT_MASK) *shift++ = sh, *offsets++ = c, ++digits,
-                            radix_offsets(c);
-  } while(bitorkey>>=DIGIT_BITS,sh+=DIGIT_BITS,c+=DIGIT_VALUES,sh!=VALUE_BITS);
+unsigned TupleList::radix_zeros(Value bitorkey,
+    Index count[DIGITS][DIGIT_VALUES], unsigned *shift, Index **offsets)
+  unsigned digits = 0, sh = 0;
+  Index *c = &count[0][0];
+  do
+    if (bitorkey & DIGIT_MASK)
+      *shift++ = sh, *offsets++ = c, ++digits, radix_offsets(c);
+  } while (bitorkey >>= DIGIT_BITS,sh += DIGIT_BITS,c += DIGIT_VALUES,sh
+      != VALUE_BITS);
   return digits;
 void TupleList::radix_index_pass_b(const Value *A, Index n, Index stride,
-                               unsigned sh, Index *off, SortData<Value> *out)
+    unsigned sh, Index *off, SortData<Value> *out)
-  Index i=0;
-  do {
+  Index i = 0;
+  do
     Value v = *A;
-    SortData<Value> *d = &out[off[(v>>sh)&DIGIT_MASK]++];
-    d->v=v, d->i=i++;
-  } while(A+=stride,i!=n);
+    SortData<Value> *d = &out[off[(v >> sh) & DIGIT_MASK]++];
+    d->v = v, d->i = i++;
+  } while (A += stride, i != n);
-void TupleList::radix_index_pass_m(const SortData<Value> *src, const SortData<Value> *end,
+void TupleList::radix_index_pass_m(const SortData<Value> *src,
+    const SortData<Value> *end, unsigned sh, Index *off, SortData<Value> *out)
-  do {
-    SortData<Value> *d = &out[off[(src->v>>sh)&DIGIT_MASK]++];
-    d->v=src->v,d->i=src->i;
-  } while(++src!=end);
+  do
+    SortData<Value> *d = &out[off[(src->v >> sh) & DIGIT_MASK]++];
+    d->v = src->v, d->i = src->i;
+  } while (++src != end);
-void TupleList::radix_index_pass_e(const SortData<Value> *src, const SortData<Value> *end,
-                               Index *out)
+void TupleList::radix_index_pass_e(const SortData<Value> *src,
+    const SortData<Value> *end, unsigned sh, Index *off, Index *out)
-  do out[off[(src->v>>sh)&DIGIT_MASK]++]=src->i; while(++src!=end);
+  do
+    out[off[(src->v >> sh) & DIGIT_MASK]++] = src->i;
+  while (++src != end);
 void TupleList::radix_index_pass_be(const Value *A, Index n, Index stride,
-				    unsigned sh, Index *off, Index *out)
+    unsigned sh, Index *off, Index *out)
-  Index i=0;
-  do out[off[(*A>>sh)&DIGIT_MASK]++]=i++; while(A+=stride,i!=n);
+  Index i = 0;
+  do
+    out[off[(*A >> sh) & DIGIT_MASK]++] = i++;
+  while (A += stride, i != n);
 void TupleList::radix_index_sort(const Value *A, Index n, Index stride,
-				 Index *idx, SortData<Value> *work)
+    Index *idx, SortData<Value> *work)
   Index count[DIGITS][DIGIT_VALUES];
-  Value bitorkey = radix_count(A, A+n*stride, stride, count);
-  unsigned shift[DIGITS]; Index *offsets[DIGITS];
-  unsigned digits = radix_zeros(bitorkey,count,shift,offsets);
-  if(digits==0) {
-    Index i=0; do *idx++=i++; while(i!=n);
-  } else if(digits==1) {
-    radix_index_pass_be(A,n,stride,shift[0],offsets[0],idx);
-  } else {
-    SortData<Value> *src, *dst; unsigned d;
-    if((digits&1)==0) dst=work,src=dst+n;
-                 else src=work,dst=src+n;
-    radix_index_pass_b(A,n,stride,shift[0],offsets[0],src);
-    for(d=1;d!=digits-1;++d) {
+  Value bitorkey = radix_count(A, A + n * stride, stride, count);
+  unsigned shift[DIGITS];
+  Index *offsets[DIGITS];
+  unsigned digits = radix_zeros(bitorkey, count, shift, offsets);
+  if (digits == 0)
+    Index i = 0;
+    do
+      *idx++ = i++;
+    while (i != n);
+  else if (digits == 1)
+    radix_index_pass_be(A, n, stride, shift[0], offsets[0], idx);
+  else
+    SortData<Value> *src, *dst;
+    unsigned d;
+    if ((digits & 1) == 0)
+      dst = work, src = dst + n;
+    else
+      src = work, dst = src + n;
+    radix_index_pass_b(A, n, stride, shift[0], offsets[0], src);
+    for (d = 1; d != digits - 1; ++d)
       SortData<Value> *t;
-      radix_index_pass_m(src,src+n,shift[d],offsets[d],dst);
-      t=src,src=dst,dst=t;
+      radix_index_pass_m(src, src + n, shift[d], offsets[d], dst);
+      t = src, src = dst, dst = t;
-    radix_index_pass_e(src,src+n,shift[d],offsets[d],idx);
+    radix_index_pass_e(src, src + n, shift[d], offsets[d], idx);
 void TupleList::merge_index_sort(const Value *A, const Index An, Index stride,
-  SortData<Value> *const buf[2]={work+An,work};
-  Index n=An, base=-n, odd=0, c=0, b=1;
-  Index i=0;
-  for(;;) {
+  SortData<Value> * const buf[2] = { work + An, work };
+  Index n = An, base = -n, odd = 0, c = 0, b = 1;
+  Index i = 0;
+  for (;;)
     SortData<Value> *p;
-    if((c&1)==0) {
-      base+=n, n+=(odd&1), c|=1, b^=1;
-      while(n>3) odd<<=1,odd|=(n&1),n>>=1,c<<=1,b^=1;
-    } else
-      base-=n-(odd&1),n<<=1,n-=(odd&1),odd>>=1,c>>=1;
-    if(c==0) break;
-    p = buf[b]+base;
-    if(n==2) {
-      Value v[2]; v[0]=*A,A+=stride,v[1]=*A,A+=stride;
-      if(v[1]<v[0]) p[0].v=v[1],p[0].i=i+1, p[1].v=v[0],p[1].i=i  ;
-               else p[0].v=v[0],p[0].i=i  , p[1].v=v[1],p[1].i=i+1;
-      i+=2;
-    } else if(n==3) {
-      Value v[3]; v[0]=*A,A+=stride,v[1]=*A,A+=stride,v[2]=*A,A+=stride;
-      if(v[1]<v[0]) {
-        if(v[2]<v[1])        p[0].v=v[2],p[1].v=v[1],p[2].v=v[0],
-                             p[0].i=i+2 ,p[1].i=i+1 ,p[2].i=i   ;
-        else { if(v[2]<v[0]) p[0].v=v[1],p[1].v=v[2],p[2].v=v[0],
-                             p[0].i=i+1 ,p[1].i=i+2 ,p[2].i=i   ;
-                        else p[0].v=v[1],p[1].v=v[0],p[2].v=v[2],
-                             p[0].i=i+1 ,p[1].i=i   ,p[2].i=i+2 ; }
-      } else {
-        if(v[2]<v[0])        p[0].v=v[2],p[1].v=v[0],p[2].v=v[1],
-                             p[0].i=i+2 ,p[1].i=i   ,p[2].i=i+1 ;
-        else { if(v[2]<v[1]) p[0].v=v[0],p[1].v=v[2],p[2].v=v[1],
-                             p[0].i=i   ,p[1].i=i+2 ,p[2].i=i+1 ;
-                        else p[0].v=v[0],p[1].v=v[1],p[2].v=v[2],
-                             p[0].i=i   ,p[1].i=i+1 ,p[2].i=i+2 ; }
+    if ((c & 1) == 0)
+      base += n, n += (odd & 1), c |= 1, b ^= 1;
+      while (n > 3)
+        odd <<= 1, odd |= (n & 1), n >>= 1, c <<= 1, b ^= 1;
+    else
+      base -= n - (odd & 1), n <<= 1, n -= (odd & 1), odd >>= 1, c >>= 1;
+    if (c == 0)
+      break;
+    p = buf[b] + base;
+    if (n == 2)
+      Value v[2];
+      v[0] = *A, A += stride, v[1] = *A, A += stride;
+      if (v[1] < v[0])
+        p[0].v = v[1], p[0].i = i + 1, p[1].v = v[0], p[1].i = i;
+      else
+        p[0].v = v[0], p[0].i = i, p[1].v = v[1], p[1].i = i + 1;
+      i += 2;
+    else if (n == 3)
+      Value v[3];
+      v[0] = *A, A += stride, v[1] = *A, A += stride, v[2] = *A, A += stride;
+      if (v[1] < v[0])
+        if (v[2] < v[1])
+          p[0].v = v[2], p[1].v = v[1], p[2].v = v[0], p[0].i = i + 2, p[1].i =
+              i + 1, p[2].i = i;
+        else
+          if (v[2] < v[0])
+            p[0].v = v[1], p[1].v = v[2], p[2].v = v[0], p[0].i = i + 1, p[1].i =
+                i + 2, p[2].i = i;
+          else
+            p[0].v = v[1], p[1].v = v[0], p[2].v = v[2], p[0].i = i + 1, p[1].i =
+                i, p[2].i = i + 2;
-      i+=3;
-    } else {
-      const Index na = n>>1, nb = (n+1)>>1;
-      const SortData<Value> *ap = buf[b^1]+base, *ae = ap+na;
-      SortData<Value> *bp = p+na, *be = bp+nb;
-      for(;;) {
-        if(bp->v<ap->v) {
-          *p++=*bp++;
-          if(bp!=be) continue;
-          do *p++=*ap++; while(ap!=ae);
+      else
+        if (v[2] < v[0])
+          p[0].v = v[2], p[1].v = v[0], p[2].v = v[1], p[0].i = i + 2, p[1].i =
+              i, p[2].i = i + 1;
+        else
+          if (v[2] < v[1])
+            p[0].v = v[0], p[1].v = v[2], p[2].v = v[1], p[0].i = i, p[1].i = i
+                + 2, p[2].i = i + 1;
+          else
+            p[0].v = v[0], p[1].v = v[1], p[2].v = v[2], p[0].i = i, p[1].i = i
+                + 1, p[2].i = i + 2;
+      i += 3;
+    else
+      const Index na = n >> 1, nb = (n + 1) >> 1;
+      const SortData<Value> *ap = buf[b ^ 1] + base, *ae = ap + na;
+      SortData<Value> *bp = p + na, *be = bp + nb;
+      for (;;)
+        if (bp->v < ap->v)
+          *p++ = *bp++;
+          if (bp != be)
+            continue;
+          do
+            *p++ = *ap++;
+          while (ap != ae);
           break;
-        } else {
-          *p++=*ap++;
-          if(ap==ae) break;
+        else
+          *p++ = *ap++;
+          if (ap == ae)
+            break;
-    const SortData<Value> *p = buf[0], *pe = p+An;
-    do *idx++ = (p++)->i; while(p!=pe);
+    const SortData<Value> *p = buf[0], *pe = p + An;
+    do
+      *idx++ = (p++)->i;
+    while (p != pe);
-void TupleList::index_sort(const Value *A, Index n, Index stride,
+void TupleList::index_sort(const Value *A, Index n, Index stride, Index *idx,
+    SortData<Value> *work)
-  if(n<DIGIT_VALUES) {
-    if(n==0) return;
-    if(n==1) *idx=0;
-    else     merge_index_sort(A,n,stride,idx,work);
-  } else     radix_index_sort(A,n,stride,idx,work);
+  if (n < DIGIT_VALUES)
+    if (n == 0)
+      return;
+    if (n == 1)
+      *idx = 0;
+    else
+      merge_index_sort(A, n, stride, idx, work);
+  else
+    radix_index_sort(A, n, stride, idx, work);
 #undef DIGIT_BITS
@@ -710,6 +856,5 @@ void TupleList::index_sort(const Value *A, Index n, Index stride,
 #undef COUNT_SIZE
 #undef sort_data_long
 } //namespace
This diff is so big that we needed to truncate the remainder.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
