[MOAB-dev] commit/MOAB: iulian07: include EigenDecomp into Matrix3 and move Push F90 example into imesh
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Wed Nov 27 10:30:24 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/095efb6f6939/
Changeset:   095efb6f6939
Branch:      master
User:        iulian07
Date:        2013-11-27 17:24:48
Summary:     include EigenDecomp into Matrix3 and move Push F90 example into imesh
so remove EigenDecomp.hpp from the repostory, and
move parallel fortran90 example into itaps/imesh
The advantage is that the autotools will figure out the correct
compiling and linking
the parallel test can be done after compiling (or make check) as before,
mpiexec -np 2 Push...
For the time being, the file is still in example folder
The compiling instructions work on mpi+gcc, but intel compiler on fusion was
still unhappy.
Affected #:  6 files
diff --git a/itaps/imesh/Makefile.am b/itaps/imesh/Makefile.am
index 647b8c1..d8a81eb 100644
--- a/itaps/imesh/Makefile.am
+++ b/itaps/imesh/Makefile.am
@@ -38,6 +38,9 @@ if PARALLEL
 #  check_PROGRAMS += partest iMeshP_unit_tests moabtest
   check_PROGRAMS += partest MOAB_iMeshP_unit_tests
+if ENABLE_FORTRAN
+  check_PROGRAMS += PushParMeshIntoMoabF90
+endif
 #  moabtest_SOURCES = moabtest.F
 #  check_PROGRAMS += ftest
@@ -69,6 +72,9 @@ ScdMeshF77_DEPENDENCIES = $(TESTDEPS)
 FindAdjacencyF90_SOURCES = FindAdjacencyF90.F90
 FindAdjacencyF90_DEPENDENCIES = $(TESTDEPS)
+PushParMeshIntoMoabF90_SOURCES = PushParMeshIntoMoabF90.F90
+PushParMeshIntoMoabF90_DEPENDENCIES = $(TESTDEPS)
 lib_LTLIBRARIES = libiMesh.la
 libiMesh_la_includedir = $(includedir)
diff --git a/itaps/imesh/PushParMeshIntoMoabF90.F90 b/itaps/imesh/PushParMeshIntoMoabF90.F90
new file mode 100644
index 0000000..46d577a
--- /dev/null
+++ b/itaps/imesh/PushParMeshIntoMoabF90.F90
@@ -0,0 +1,283 @@
+! PushParMeshIntoMoabF90: push parallel mesh into moab, F90 version
+! This program shows how to push a mesh into MOAB in parallel from Fortran90, with sufficient
+! information to resolve boundary sharing and exchange a layer of ghost information.
+! To successfully link this example, you need to specify FCFLAGS that include:
+!    a) -DUSE_MPI, and
+!    b) flags required to link Fortran90 MPI programs with the C++ compiler; these flags
+!       can often be found on your system by inspecting the output of 'mpif90 -show'
+! For example, using gcc, the link line looks like:
+!   make MOAB_DIR=<moab install dir> FCFLAGS="-DUSE_MPI -I/usr/lib/openmpi/include -pthread -I/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl" PushParMeshIntoMoabF90
+! Usage: PushParMeshIntoMoab
+program PushParMeshIntoMoab
+  use ISO_C_BINDING
+  implicit none
+#include "mpif.h"
+#ifdef USE_MPI
+#  include "iMeshP_f.h"
+#else
+#  include "iMesh_f.h"
+#endif
+  ! declarations
+  ! imesh is the instance handle
+  iMesh_Instance imesh
+  ! NUMV, NUME, NVPERE are the hardwired here; these are for the whole mesh,
+  ! local mesh determined later
+  integer NUMV, NUME, NVPERE
+  parameter (NUMV = 8)   ! # vertices in whole mesh
+  parameter (NUME = 6)   ! # elements in whole mesh
+  parameter (NVPERE = 4) ! # vertices per element
+  ! ents, verts will be arrays storing vertex/entity handles
+  iBase_EntityHandle, pointer :: ents, verts
+  iBase_EntitySetHandle root_set
+  TYPE(C_PTR) :: vertsPtr, entsPtr
+  ! storage for vertex positions, element connectivity indices, global vertex ids
+  real*8 coords(0:3*NUMV-1)
+  integer iconn(0:4*NUME-1), gids(0:NUMV-1)
+  ! local variables
+  integer lgids(0:NUMV-1), lconn(0:4*NUME-1)
+  real*8 lcoords(0:3*NUMV-1)
+  integer lnumv, lvids(0:NUMV-1), gvids(0:NUMV-1)
+  integer lvpe, ltp ! lvpe = # vertices per entity, ltp = element type
+  integer ic, ie, iv, istart, iend, ierr, indv, lnume, rank, sz
+#ifdef USE_MPI
+  ! local variables for parallel runs
+  iMeshP_PartitionHandle imeshp
+  ! integer MPI_COMM_WORLD
+#endif
+  ! vertex positions, latlon coords, (lat, lon, lev), fortran ordering
+  ! (first index varying fastest)
+  data coords / &
+       0.0, -45.0,   0.0,  90.0, -45.0,   0.0, 180.0, -45.0,   0.0, 270.0, -45.0,   0.0, &
+       0.0,  45.0,   0.0,  90.0,  45.0,   0.0, 180.0,  45.0,   0.0, 270.0,  45.0,   0.0 /
+  ! quad index numbering, each quad ccw, sides then bottom then top
+  data iconn / &
+       0, 1, 5, 4,  &
+       1, 2, 6, 5,  &
+       2, 3, 7, 6,  &
+       3, 0, 4, 7,  &
+       0, 3, 2, 1,  &
+       4, 5, 6, 7 /
+  data lvpe /4/ ! quads in this example
+  data ltp / iMesh_QUADRILATERAL / ! from iBase_f.h
+  ! initialize global vertex ids
+  do iv = 0, NUMV-1
+     lgids(iv) = iv+1
+  end do
+#ifdef USE_MPI
+  ! init the parallel partition
+  call MPI_INIT(ierr)
+  call MPI_COMM_SIZE(MPI_COMM_WORLD, sz, ierr)
+  call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr)
+  ! compute starting/ending element numbers
+  lnume = NUME / sz
+  istart = rank * lnume
+  iend = istart + lnume - 1
+  if (rank .eq. sz-1) then
+     iend = NUME-1
+     lnume = iend - istart + 1
+  endif
+#else
+  ! set the starting/ending element numbers
+  istart = 0
+  iend = NUME-1
+  lnume = NUME
+#endif
+  ! for my elements, figure out which vertices I use and accumulate local indices and coords
+  ! lvids stores the local 0-based index for each vertex; -1 means vertex i isn't used locally
+  ! also build up connectivity indices for local elements, in lconn
+  do iv = 0, NUMV-1
+     lvids(iv) = -1
+  end do
+  lnumv = -1
+  do ie = istart, iend
+     do iv = 0, lvpe-1
+        indv = iconn(lvpe*ie + iv)
+        if (lvids(indv) .eq. -1) then
+           lnumv = lnumv + 1 ! increment local # verts
+           do ic = 0, 2 ! cache local coords
+              lcoords(3*lnumv+ic) = coords(3*indv+ic)
+           end do
+           lvids(indv) = lnumv
+           gvids(lnumv) = 1+indv
+        end if
+        lconn(lvpe*(ie-istart)+iv) = lvids(indv)
+     end do  ! do iv
+  end do  ! do ie
+  lnumv = lnumv + 1
+  ! now create the mesh; this also initializes parallel sharing and ghost exchange
+  imesh = 0
+  imeshp = 0
+  call create_mesh(imesh, imeshp, MPI_COMM_WORLD, lnumv, lnume, gvids, lvpe, ltp, lcoords, lconn, &
+       vertsPtr, entsPtr, ierr)
+  call c_f_pointer(vertsPtr, verts, [lnumv])
+  call c_f_pointer(entsPtr, ents, [lnume])
+  ! get/report number of vertices, elements
+  call iMesh_getRootSet(%VAL(imesh), root_set, ierr)
+  iv = 0
+  ie = 0
+#ifdef USE_MPI
+  call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_VERTEX), iv, ierr)
+  call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_FACE), ie, ierr)
+  if (rank .eq. 0) then
+     write(0,*) "Number of vertices = ", iv
+     write(0,*) "Number of entities = ", ie
+  endif
+#else
+  call iMesh_getNumOfTypeAll(%VAL(imesh), %VAL(root_set), %VAL(iBase_VERTEX), iv, ierr)
+  call iMesh_getNumOfTypeAll(%VAL(imesh), %VAL(root_set), %VAL(iBase_FACE), ie, ierr)
+#endif
+  ! from here, can use verts and ents as (1-based) arrays of entity handles for input to other iMesh functions
+  call MPI_FINALIZE(ierr)
+  stop
+end program PushParMeshIntoMoab
+subroutine create_mesh( &
+  !     interfaces
+     imesh, imeshp, &
+  !     input
+     comm, numv, nume, vgids, nvpe, tp, posn, iconn, &
+  !     output
+  ! create a mesh with numv vertices and nume elements, with elements of type tp
+  ! vertices have positions in posn (3 coordinates each, interleaved xyzxyz...), indexed from 0
+  ! elements have nvpe vertices per entity, with connectivity indices stored in iconn, referencing
+  ! vertices using 0-based indices; vertex and entity handles are output in arrays passed in
+  ! if imesh/imeshp are 0, imesh/imeshp are initialized in this subroutine
+  use ISO_C_BINDING
+  implicit none
+#ifdef USE_MPI
+#  include "mpif.h"
+#else
+#endif
+  ! subroutine arguments
+  integer numv, nume, nvpe, vgids(0:*), iconn(0:*), ierr, tp
+  real*8 posn(0:*)
+#ifdef USE_MPI
+  integer comm
+#endif
+  ! local variables
+  integer comm_sz, comm_rank, numa, numo, iv, ie
+  TYPE(C_PTR) :: statsPtr
+  integer, allocatable, target :: stats(:)
+  iBase_TagHandle tagh
+  integer i
+  iBase_EntityHandle, pointer :: verts(:), ents(:)
+  iBase_EntityHandle, allocatable :: conn(:)
+#ifdef USE_MPI
+  IBASE_HANDLE_T mpi_comm_c
+  TYPE(C_PTR) :: partsPtr
+  iMeshP_PartHandle, pointer :: parts(:)
+  iMeshP_PartHandle part
+  integer partsa, partso
+#endif
+  ! create the Mesh instance
+  if (imesh .eq. 0) then
+     call iMesh_newMesh("MOAB", imesh, ierr)
+  end if
+#ifdef USE_MPI
+  if (imeshp .eq. 0) then
+     call iMeshP_getCommunicator(%VAL(imesh), MPI_COMM_WORLD, mpi_comm_c, ierr)
+     call iMeshP_createPartitionAll(%VAL(imesh), %VAL(mpi_comm_c), imeshp, ierr)
+     call iMeshP_createPart(%VAL(imesh), %VAL(imeshp), part, ierr)
+  else
+     partsa = 0
+     call iMeshP_getLocalParts(%VAL(imesh), %VAL(imeshp), partsPtr, partsa, partso, ierr)
+     call c_f_pointer(partsPtr, parts, [partso])
+     part = parts(1)
+  end if
+  call MPI_COMM_RANK(comm, comm_rank, ierr)
+  call MPI_COMM_SIZE(comm, comm_sz, ierr)
+#endif
+  ! create the vertices, all in one call
+  numa = 0
+  call iMesh_createVtxArr(%VAL(imesh), %VAL(numv), %VAL(iBase_INTERLEAVED), posn, %VAL(3*numv), &
+       vertsPtr, numa, numo, ierr)
+  ! fill in the connectivity array, based on indexing from iconn
+  allocate (conn(0:nvpe*nume-1))
+  call c_f_pointer(vertsPtr, verts, [numv])
+  do i = 0, nvpe*nume-1
+     conn(i) = verts(1+iconn(i))
+  end do
+  ! create the elements
+  numa = 0
+  allocate(stats(0:nume-1))
+  statsPtr = C_LOC(stats(0))
+  call iMesh_createEntArr(%VAL(imesh), %VAL(tp), conn, %VAL(nvpe*nume), &
+       entsPtr, numa, numo, statsPtr, numa, numo, ierr)
+  deallocate(stats)
+  deallocate(conn)
+#ifdef USE_MPI
+  ! take care of parallel stuff
+  ! add entities to part, using iMesh
+  call c_f_pointer(entsPtr, ents, [numo])
+  call iMesh_addEntArrToSet(%VAL(imesh), ents, %VAL(numo), %VAL(part), ierr)
+  ! set global ids on vertices, needed for sharing between procs
+  call iMesh_getTagHandle(%VAL(imesh), "GLOBAL_ID", tagh, ierr, %VAL(9))
+  if (iBase_SUCCESS .ne. ierr) then
+     ! didn't get handle, need to create the tag
+     call iMesh_createTag(%VAL(imesh), "GLOBAL_ID", %VAL(iBase_INTEGER), tagh, ierr, %VAL(9))
+  end if
+  call iMesh_setIntArrData(%VAL(imesh), verts, %VAL(numv), %VAL(tagh), vgids, %VAL(numv), ierr)
+  ! now resolve shared verts and exchange ghost cells
+  call iMeshP_syncMeshAll(%VAL(imesh), %VAL(imeshp), ierr)
+  if (comm_rank .eq. 0) then
+     write(0,*) "After syncMeshAll:"
+     write(0,*) "   Number of vertices = ", iv
+     write(0,*) "   Number of entities = ", ie
+  endif
+  call iMeshP_createGhostEntsAll(%VAL(imesh), %VAL(imeshp), %VAL(2), %VAL(1), %VAL(1), %VAL(0), ierr)
+     write(0,*) "After createGhostEntsAll:"
+  endif
+#endif
+  return
+end subroutine create_mesh
diff --git a/src/Makefile.am b/src/Makefile.am
index 64b8a0f..0eb07c5 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -157,7 +157,6 @@ nobase_libMOAB_la_include_HEADERS = \
   moab/GeomTopoTool.hpp \
   moab/HigherOrderFactory.hpp \
   moab/HomXform.hpp \
-  moab/EigenDecomp.hpp \
   moab/EntityType.hpp \
   moab/EntityHandle.hpp \
   moab/FBEngine.hpp \
diff --git a/src/OrientedBox.cpp b/src/OrientedBox.cpp
index caab7d1..0932952 100644
--- a/src/OrientedBox.cpp
+++ b/src/OrientedBox.cpp
@@ -274,7 +274,7 @@ ErrorCode OrientedBox::compute_from_vertices( OrientedBox& result,
     // Get axes (Eigenvectors) from covariance matrix
   double lambda[3];
-  EigenDecomp( a, lambda, result.axis );
+  moab::Matrix::EigenDecomp( a, lambda, result.axis );
     // Calculate center and extents of box given orientation defined by axes
   return box_from_axes( result, instance, vertices );
@@ -369,7 +369,7 @@ ErrorCode OrientedBox::compute_from_covariance_data(
     // get axes (Eigenvectors) from covariance matrix
   double lamda[3];
-  EigenDecomp( data.matrix, lamda, result.axis );
+  moab::Matrix::EigenDecomp( data.matrix, lamda, result.axis );
     // We now have only the axes.  Calculate proper center
     // and extents for enclosed points.
diff --git a/src/moab/EigenDecomp.hpp b/src/moab/EigenDecomp.hpp
deleted file mode 100644
index 12110eb..0000000
--- a/src/moab/EigenDecomp.hpp
+++ /dev/null
@@ -1,165 +0,0 @@
- * MOAB, a Mesh-Oriented datABase, is a software component for creating,
- * storing and accessing finite element mesh data.
- * Copyright 2004 Sandia Corporation.  Under the terms of Contract
- * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
- * retains certain rights in this software.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
-#ifndef MB_EIGENDECOMP_HPP
-#define MB_EIGENDECOMP_HPP
-#include <math.h>
-#include <iostream>
-namespace moab {
-//TODO: is this copied code actually able to be licensed
-//TODO: Actually should have license text here, not link
-// Copied from "Visualization Toolkit"
-//  Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
-//  All rights reserved.
-//  See Copyright.txt or http://www.kitware.com/Copyright.htm for details.
-// Jacobi iteration for the solution of eigenvectors/eigenvalues of a nxn
-// real symmetric matrix. Square nxn matrix a; size of matrix in n;
-// output eigenvalues in w; and output eigenvectors in v. Resulting
-// eigenvalues/vectors are sorted in decreasing order; eigenvectors are
-// normalized.
-// TODO: Remove this
-#define VTK_ROTATE(a,i,j,k,l) g=a[i][j];h=a[k][l];a[i][j]=g-s*(h+g*tau);\
-        a[k][l]=h+s*(g-h*tau)
-//TODO: Refactor this method into subroutines
-//use a namespace { }  with no name to
-//contain subroutines so that the compiler
-//automatically inlines them.
-template< typename Matrix, typename Vector>
-ErrorCode EigenDecomp( const Matrix & _a,
-                       double w[3],
-                       Vector v[3] ) {
-  const int MAX_ROTATIONS = 20;
-  const double one_ninth = 1./9;
-  int i, j, k, iq, ip, numPos;
-  double tresh, theta, tau, t, sm, s, h, g, c, tmp;
-  double b[3], z[3];
-  Matrix a( _a);
-  // initialize
-  for (ip=0; ip<3; ip++) {
-    for (iq=0; iq<3; iq++){
-      v[ip][iq] = 0.0;
-    v[ip][ip] = 1.0;
-    b[ip] = w[ip] = a[ip][ip];
-    z[ip] = 0.0;
-  // begin rotation sequence
-  for (i=0; i<MAX_ROTATIONS; i++){
-    sm = 0.0;
-    for (ip=0; ip<2; ip++){
-      for (iq=ip+1; iq<3; iq++){ sm += fabs(a[ip][iq]); }
-    if ( sm == 0.0 ){ break; }
-    // first 3 sweeps
-    tresh = (i < 3)? 0.2*sm*one_ninth : 0.0;
-    for (ip=0; ip<2; ip++) {
-      for (iq=ip+1; iq<3; iq++) {
-        g = 100.0*fabs(a[ip][iq]);
-        // after 4 sweeps
-        if ( i > 3 && (fabs(w[ip])+g) == fabs(w[ip])
-        	   && (fabs(w[iq])+g) == fabs(w[iq])) {
-          a[ip][iq] = 0.0;
-        else if ( fabs(a[ip][iq]) > tresh) {
-          h = w[iq] - w[ip];
-          if ( (fabs(h)+g) == fabs(h)){ t = (a[ip][iq]) / h; }
-          else {
-            theta = 0.5*h / (a[ip][iq]);
-            t = 1.0 / (fabs(theta)+sqrt(1.0+theta*theta));
-            if (theta < 0.0) { t = -t;}
-          c = 1.0 / sqrt(1+t*t);
-          s = t*c;
-          tau = s/(1.0+c);
-          h = t*a[ip][iq];
-          z[ip] -= h;
-          z[iq] += h;
-          w[ip] -= h;
-          w[iq] += h;
-          a[ip][iq]=0.0;
-          // ip already shifted left by 1 unit
-          for (j = 0;j <= ip-1;j++) { VTK_ROTATE(a,j,ip,j,iq); }
-          // ip and iq already shifted left by 1 unit
-          for (j = ip+1;j <= iq-1;j++) { VTK_ROTATE(a,ip,j,j,iq); }
-          // iq already shifted left by 1 unit
-          for (j=iq+1; j<3; j++) { VTK_ROTATE(a,ip,j,iq,j); }
-          for (j=0; j<3; j++) { VTK_ROTATE(v,j,ip,j,iq); }
-      b[ip] += z[ip];
-      w[ip] = b[ip];
-      z[ip] = 0.0;
-  //// this is NEVER called
-  if ( i >= MAX_ROTATIONS ) {
-      std::cerr << "Matrix3D: Error extracting eigenfunctions" << std::endl;
-      return MB_FAILURE;
-  // sort eigenfunctions                 these changes do not affect accuracy
-  for (j=0; j<2; j++){                  // boundary incorrect
-    k = j;
-    tmp = w[k];
-    for (i=j+1; i<3; i++){                // boundary incorrect, shifted already
-      if (w[i] >= tmp){                  // why exchage if same?
-        k = i;
-        tmp = w[k];
-    if (k != j){
-      w[k] = w[j];
-      w[j] = tmp;
-      for (i=0; i<3; i++){
-        tmp = v[i][j];
-        v[i][j] = v[i][k];
-        v[i][k] = tmp;
-  // insure eigenvector consistency (i.e., Jacobi can compute vectors that
-  // are negative of one another (.707,.707,0) and (-.707,-.707,0). This can
-  // reek havoc in hyperstreamline/other stuff. We will select the most
-  // positive eigenvector.
-  int ceil_half_n = (3 >> 1) + (3 & 1);
-    for (numPos=0, i=0; i<3; i++) {
-      if ( v[i][j] >= 0.0 ) { numPos++; }
-//    if ( numPos < ceil(double(n)/double(2.0)) )
-    if ( numPos < ceil_half_n) {
-      for(i=0; i<3; i++) { v[i][j] *= -1.0; }
-  return MB_SUCCESS;
-} // namespace moab
-#endif //MB_EIGENDECOMP_HPP
diff --git a/src/moab/Matrix3.hpp b/src/moab/Matrix3.hpp
index 08d38da..0272159 100644
--- a/src/moab/Matrix3.hpp
+++ b/src/moab/Matrix3.hpp
@@ -24,7 +24,8 @@
 #define MOAB_MATRIX3_HPP
 #include "moab/Types.hpp"
-#include "moab/EigenDecomp.hpp"
+//#include "moab/EigenDecomp.hpp"
+#include <iostream>
 #include "moab/CartVect.hpp"
 #include <iosfwd>
@@ -121,6 +122,142 @@ namespace Matrix{
 	   res[ 2] = v[0] * m(2,0) + v[1] * m(2,1) + v[2] * m(2,2);
 	   return res;
+	// moved from EigenDecomp.hpp
+	// Jacobi iteration for the solution of eigenvectors/eigenvalues of a nxn
+	// real symmetric matrix. Square nxn matrix a; size of matrix in n;
+	// output eigenvalues in w; and output eigenvectors in v. Resulting
+	// eigenvalues/vectors are sorted in decreasing order; eigenvectors are
+	// normalized.
+	// TODO: Remove this
+	#define VTK_ROTATE(a,i,j,k,l) g=a[i][j];h=a[k][l];a[i][j]=g-s*(h+g*tau);\
+	        a[k][l]=h+s*(g-h*tau)
+	//TODO: Refactor this method into subroutines
+	//use a namespace { }  with no name to
+	//contain subroutines so that the compiler
+	//automatically inlines them.
+	template< typename Matrix, typename Vector>
+	ErrorCode EigenDecomp( const Matrix & _a,
+	                       double w[3],
+	                       Vector v[3] ) {
+	  const int MAX_ROTATIONS = 20;
+	  const double one_ninth = 1./9;
+	  int i, j, k, iq, ip, numPos;
+	  double tresh, theta, tau, t, sm, s, h, g, c, tmp;
+	  double b[3], z[3];
+	  Matrix a( _a);
+	  // initialize
+	  for (ip=0; ip<3; ip++) {
+	    for (iq=0; iq<3; iq++){
+	      v[ip][iq] = 0.0;
+	    v[ip][ip] = 1.0;
+	    b[ip] = w[ip] = a[ip][ip];
+	    z[ip] = 0.0;
+	  // begin rotation sequence
+	  for (i=0; i<MAX_ROTATIONS; i++){
+	    sm = 0.0;
+	    for (ip=0; ip<2; ip++){
+	      for (iq=ip+1; iq<3; iq++){ sm += fabs(a[ip][iq]); }
+	    if ( sm == 0.0 ){ break; }
+	    // first 3 sweeps
+	    tresh = (i < 3)? 0.2*sm*one_ninth : 0.0;
+	    for (ip=0; ip<2; ip++) {
+	      for (iq=ip+1; iq<3; iq++) {
+	        g = 100.0*fabs(a[ip][iq]);
+	        // after 4 sweeps
+	        if ( i > 3 && (fabs(w[ip])+g) == fabs(w[ip])
+	             && (fabs(w[iq])+g) == fabs(w[iq])) {
+	          a[ip][iq] = 0.0;
+	        else if ( fabs(a[ip][iq]) > tresh) {
+	          h = w[iq] - w[ip];
+	          if ( (fabs(h)+g) == fabs(h)){ t = (a[ip][iq]) / h; }
+	          else {
+	            theta = 0.5*h / (a[ip][iq]);
+	            t = 1.0 / (fabs(theta)+sqrt(1.0+theta*theta));
+	            if (theta < 0.0) { t = -t;}
+	          c = 1.0 / sqrt(1+t*t);
+	          s = t*c;
+	          tau = s/(1.0+c);
+	          h = t*a[ip][iq];
+	          z[ip] -= h;
+	          z[iq] += h;
+	          w[ip] -= h;
+	          w[iq] += h;
+	          a[ip][iq]=0.0;
+	          // ip already shifted left by 1 unit
+	          for (j = 0;j <= ip-1;j++) { VTK_ROTATE(a,j,ip,j,iq); }
+	          // ip and iq already shifted left by 1 unit
+	          for (j = ip+1;j <= iq-1;j++) { VTK_ROTATE(a,ip,j,j,iq); }
+	          // iq already shifted left by 1 unit
+	          for (j=iq+1; j<3; j++) { VTK_ROTATE(a,ip,j,iq,j); }
+	          for (j=0; j<3; j++) { VTK_ROTATE(v,j,ip,j,iq); }
+	      b[ip] += z[ip];
+	      w[ip] = b[ip];
+	      z[ip] = 0.0;
+	  //// this is NEVER called
+	  if ( i >= MAX_ROTATIONS ) {
+	      std::cerr << "Matrix3D: Error extracting eigenfunctions" << std::endl;
+	      return MB_FAILURE;
+	  // sort eigenfunctions                 these changes do not affect accuracy
+	  for (j=0; j<2; j++){                  // boundary incorrect
+	    k = j;
+	    tmp = w[k];
+	    for (i=j+1; i<3; i++){                // boundary incorrect, shifted already
+	      if (w[i] >= tmp){                  // why exchage if same?
+	        k = i;
+	        tmp = w[k];
+	    if (k != j){
+	      w[k] = w[j];
+	      w[j] = tmp;
+	      for (i=0; i<3; i++){
+	        tmp = v[i][j];
+	        v[i][j] = v[i][k];
+	        v[i][k] = tmp;
+	  // insure eigenvector consistency (i.e., Jacobi can compute vectors that
+	  // are negative of one another (.707,.707,0) and (-.707,-.707,0). This can
+	  // reek havoc in hyperstreamline/other stuff. We will select the most
+	  // positive eigenvector.
+	  int ceil_half_n = (3 >> 1) + (3 & 1);
+	    for (numPos=0, i=0; i<3; i++) {
+	      if ( v[i][j] >= 0.0 ) { numPos++; }
+	//    if ( numPos < ceil(double(n)/double(2.0)) )
+	    if ( numPos < ceil_half_n) {
+	      for(i=0; i<3; i++) { v[i][j] *= -1.0; }
+	  return MB_SUCCESS;
 } //namespace Matrix
 class Matrix3  {
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
