[MOAB-dev] problem with exchange_ghost_cells
Iulian Grindeanu
iulian at mcs.anl.gov
Mon Nov 18 09:52:50 CST 2013
Thank you, Lorenzo, for reporting it;
I have tried with the latest repo, and indeed, it hangs out with mesh.h5m.
I have tried with bridge dimension 0 and 1, and it seems to get out of ghosting;
So for bridge dimension 2 that you are using, there is a problem.
if (pcomm->rank() == 0)
std::cout<<pcomm->rank()<<" Exchange ghost cells"<<std::endl;
result = pcomm->exchange_ghost_cells(dim, 1 ,1,0,true,true);
assert(MB_SUCCESS==result);
In the meantime, can you use bridge 0 or 1?
Iulian
----- Original Message -----
| Dear all,
| I’m writing to inform you all of a problem with MOAB in parallel that
| bothers me a lot.
| Sometimes after reading a parallel .h5m mesh file and resolving
| shared entities the execution hangs while exchanging ghost cells.
| The issue arises randomly but I noticed a clear tendency to occur
| when the number of elements in each partition decreases, that is,
| given the same mesh, when the number of partition increases.
| Here attached is a simple code that should allow you to reproduce the
| issue (I tried to run both with 4.6.0 and trunk and obtain the same
| behavior).
| mesh.h5m and mesh_ok.h5m are two different 16 part partitions of the
| same mesh (a 3D tetrahedral elements mesh).
| While with mesh_ok.h5m the code works perfectly, using mesh.h5m it
| hangs, meaning that the process with rank 1 does not return from
| exchange_ghost_cells if the code is executed in parallel with 16
| processors (mpiexec -n 16 <reader_exec_name>).
| The weird thing is that the code works if executed on less that 16
| processors
| Any help is appreciated. Thanks in advance.
| Lorenzo
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131118/1129dbf2/attachment.html>
