[MOAB-dev] problem with exchange_ghost_cells
Lorenzo Alessio Botti bottilorenzo at gmail.com
Mon Nov 18 08:10:33 CST 2013
Dear all,
I’m writing to inform you all of a problem with MOAB in parallel that bothers me a lot.
Sometimes after reading a parallel .h5m mesh file and resolving shared entities the execution hangs while exchanging ghost cells.
The issue arises randomly but I noticed a clear tendency to occur when the number of elements in each partition decreases, that is, given the same mesh, when the number of partition increases.
Here attached is a simple code that should allow you to reproduce the issue (I tried to run both with 4.6.0 and trunk and obtain the same behavior).
mesh.h5m and mesh_ok.h5m are two different 16 part partitions of the same mesh (a 3D tetrahedral elements mesh).
While with mesh_ok.h5m the code works perfectly, using mesh.h5m it hangs, meaning that the process with rank 1 does not return from exchange_ghost_cells if the code is executed in parallel with 16 processors (mpiexec -n 16 <reader_exec_name>).
The weird thing is that the code works if executed on less that 16 processors
Any help is appreciated. Thanks in advance.
Lorenzo
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131118/e3ae7438/attachment-0003.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131118/e3ae7438/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131118/e3ae7438/attachment-0005.obj>
