[MOAB-dev] commit/MOAB: danwu: Allow a parallel MOAB build with netcdf (but without pnetcdf) to use Zoltan partition for MPAS reader.
commits-noreply at bitbucket.org
Fri Nov 8 11:08:45 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/a3774594bf19/
Changeset: a3774594bf19
Branch: master
User: danwu
Date: 2013-11-08 18:07:42
Summary: Allow a parallel MOAB build with netcdf (but without pnetcdf) to use Zoltan partition for MPAS reader.
Affected #: 2 files
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 6a73e31..54ba598 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -4,7 +4,7 @@
#include "moab/SpectralMeshTool.hpp"
#include "MBTagConventions.hpp"
-#if HAVE_ZOLTAN
+#ifdef HAVE_ZOLTAN
#include "MBZoltan.hpp"
#endif
@@ -971,7 +971,7 @@ ErrorCode NCHelperMPAS::redistribute_local_cells(int start_cell_idx)
// If possible, apply Zoltan partition
if (_readNC->partMethod == ScdParData::RCBZOLTAN) {
-#if defined(USE_MPI) && defined(PNETCDF_FILE) && defined(HAVE_ZOLTAN)
+#if defined(USE_MPI) && defined(HAVE_ZOLTAN)
// Read x coordinates of cell centers
int xCellVarId;
int success = NCFUNC(inq_varid)(_fileId, "xCell", &xCellVarId);
diff --git a/test/parallel/mpastrvpart.cpp b/test/parallel/mpastrvpart.cpp
index 7ff375a..b42f11e 100644
--- a/test/parallel/mpastrvpart.cpp
+++ b/test/parallel/mpastrvpart.cpp
@@ -16,14 +16,14 @@ static const char example[] = STRINGIFY(MESHDIR) "/io/mpasx1.642.t.2.nc";
void test_read_onevar_trivial();
void test_read_onevar_trivial_no_mixed_elements();
void test_read_onevar_rcbzoltan();
void test_read_onevar_rcbzoltan_no_mixed_elements();
#endif
void test_read_mesh_parallel_trivial();
void test_read_mesh_parallel_trivial_no_mixed_elements();
void test_read_mesh_parallel_rcbzoltan();
void test_read_mesh_parallel_rcbzoltan_no_mixed_elements();
#endif
@@ -50,14 +50,14 @@ int main(int argc, char* argv[])
result += RUN_TEST(test_read_onevar_trivial);
result += RUN_TEST(test_read_onevar_trivial_no_mixed_elements);
result += RUN_TEST(test_read_onevar_rcbzoltan);
result += RUN_TEST(test_read_onevar_rcbzoltan_no_mixed_elements);
#endif
result += RUN_TEST(test_read_mesh_parallel_trivial);
result += RUN_TEST(test_read_mesh_parallel_trivial_no_mixed_elements);
result += RUN_TEST(test_read_mesh_parallel_rcbzoltan);
result += RUN_TEST(test_read_mesh_parallel_rcbzoltan_no_mixed_elements);
#endif
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
