[MOAB-dev] commit/MOAB: danwu: For consistency, add macro HAVE_ZOLTAN to top-level AM_CPPFLAGS in configure.ac (similar to NETCDF_FILE and HDF5_FILE). Also remove it from src/Makefile.am, src/io/Makefile.am, and test/parallel/Makefile.am.
commits-noreply at bitbucket.org
Fri Nov 8 10:31:32 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/a26cddd7e512/
Changeset: a26cddd7e512
Branch: master
User: danwu
Date: 2013-11-08 17:31:18
Summary: For consistency, add macro HAVE_ZOLTAN to top-level AM_CPPFLAGS in configure.ac (similar to NETCDF_FILE and HDF5_FILE). Also remove it from src/Makefile.am, src/io/Makefile.am, and test/parallel/Makefile.am.
Affected #: 4 files
diff --git a/configure.ac b/configure.ac
index 937385d..bdc225b 100644
--- a/configure.ac
+++ b/configure.ac
@@ -698,7 +698,7 @@ if test "xyes" = "x$WITH_ZOLTAN"; then
[#include <stdlib.h>])
CPPFLAGS="$old_CPPFLAGS"
AC_LANG_POP([C++])
# Build LDFLAGS for Zoltan
found=no
if test "x" != "x$ZOLTAN_DIR"; then
@@ -720,7 +720,7 @@ if test "xyes" = "x$WITH_ZOLTAN"; then
ZOLTAN_LIB_FLAGS="$ZOLTAN_LIB_FLAGS -L$ZOLTAN_DIR"
fi
fi
# Test for Zoltan library, possibly requiring parmetis
old_LDFLAGS="$LDFLAGS"
LDFLAGS="$LDFLAGS $ZOLTAN_LIB_FLAGS"
@@ -731,7 +731,9 @@ if test "xyes" = "x$WITH_ZOLTAN"; then
[AC_MSG_ERROR([zoltan library not found or not usable. Perhaps you need to specify --with-parmetis=@<:@DIR@:>@?])],
[-lparmetis -lmetis])])
LDFLAGS="$old_LDFLAGS"
+ # Define macro HAVE_ZOLTAN
+ AM_CPPFLAGS="$AM_CPPFLAGS -DHAVE_ZOLTAN"
fi
AC_SUBST(ZOLTAN_LIBS)
diff --git a/src/Makefile.am b/src/Makefile.am
index 3a86984..64b8a0f 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -28,7 +28,6 @@ AM_CPPFLAGS += -DIS_BUILDING_MB \
# The directory in which to install headers
libMOAB_la_includedir = $(includedir)
# The list of source files, and any header files that do not need to be installed
libMOAB_la_SOURCES = \
AdaptiveKDTree.cpp \
@@ -205,23 +204,24 @@ nobase_libMOAB_la_include_HEADERS = \
MOAB_FCDefs.h \
MBCN_protos.h \
MBTagConventions.hpp
if ENABLE_mbzoltan
libMOAB_la_SOURCES += $(srcdir)/../tools/mbzoltan/MBZoltan.cpp
nobase_libMOAB_la_include_HEADERS += $(srcdir)/../tools/mbzoltan/MBZoltan.hpp
- AM_CPPFLAGS += $(ZOLTAN_INC_FLAGS) -DHAVE_ZOLTAN
+ AM_CPPFLAGS += $(ZOLTAN_INC_FLAGS)
# not sure yet if this is needed; will see when linking io reader (MPAS so far)
# the tool mbpart needed it, and it just includes MBZoltan.hpp; so it needs ways to find
# the libraries zoltan depends on
libMOAB_la_LIBADD += $(ZOLTAN_LIBS) $(ZOLTAN_LIB_FLAGS)
endif
if HAVE_CGM
AM_CPPFLAGS += @CGM_CPPFLAGS@ -DCGM @MOAB_CGM_DEFINES@
endif
MBCN_protos.h: MBCN.h $(top_srcdir)/itaps/mkprotos.sh
$(AM_V_GEN)$(top_srcdir)/itaps/mkprotos.sh MBCN MOAB $< $@ MOAB_FCDefs.h
MOAB_FCDefs.h: FCDefs.h
$(AM_V_GEN)cd .. && ./config.status src/MOAB_FCDefs.h
diff --git a/src/io/Makefile.am b/src/io/Makefile.am
index 968f47f..60caa48 100644
--- a/src/io/Makefile.am
+++ b/src/io/Makefile.am
@@ -40,8 +40,9 @@ endif
endif
if ENABLE_mbzoltan
- AM_CPPFLAGS += -DHAVE_ZOLTAN -I$(srcdir)/../../tools/mbzoltan $(ZOLTAN_INC_FLAGS)
+ AM_CPPFLAGS += -I$(srcdir)/../../tools/mbzoltan $(ZOLTAN_INC_FLAGS)
endif
if HDF5_FILE
libmoabio_la_LIBADD += mhdf/libmhdf.la
MOAB_HDF5_SRCS = HDF5Common.cpp \
@@ -58,6 +59,7 @@ if HDF5_FILE
else
MOAB_HDF5_SRCS =
endif
if CCMIO_FILE
MOAB_CCMIO_SRCS = WriteCCMIO.cpp WriteCCMIO.hpp ReadCCMIO.cpp ReadCCMIO.hpp
libmoabio_la_LIBADD += $(CCMIO_LIBS)
@@ -142,7 +144,5 @@ libmoabio_la_SOURCES = \
$(MOAB_DAMSEL_SRCS) \
$(MOAB_CGM_SRCS)
libmoabio_la_includedir = $(includedir)
nobase_libmoabio_la_include_HEADERS = moab/ExoIIInterface.hpp
diff --git a/test/parallel/Makefile.am b/test/parallel/Makefile.am
index 648c829..6dd3207 100644
--- a/test/parallel/Makefile.am
+++ b/test/parallel/Makefile.am
@@ -24,10 +24,6 @@ if ENABLE_mbcslam
AM_CPPFLAGS += -I$(top_srcdir)/tools/mbcslam
endif
-if ENABLE_mbzoltan
-endif
# Run parallel tests in parallel
if USE_MPIEXEC
LOG_COMPILER = ${MPIEXEC}
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
