[MOAB-dev] moab builds configured with cgm
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Wed Nov  6 10:28:30 CST 2013
According to Jane, the correct version to use is
https://svn.mcs.anl.gov/repos/ITAPS/cgm/tags/13.1.1
I changed those "tru" builds to this tag/version, for the tonight's buildbot.
Iulian
----- Original Message -----
| Hi, Iulian:
| Just a reminder: The recent cgm13.1 build which was the trunk before
| I moved cgm14.0 to trunk is now under tags/13.1.1, with info as
| following:
| Path: 13.1.1
| URL: https://svn.mcs.anl.gov/repos/ITAPS/cgm/tags/13.1.1
| Repository Root: https://svn.mcs.anl.gov/repos/ITAPS
| Repository UUID: 6162379e-bd28-0410-9a7d-b7f4dcfcad3c
| Revision: 6093
| Node Kind: directory
| Last Changed Author: janehu
| Last Changed Rev: 6086
| Last Changed Date: 2013-11-04 12:37:29 -0600 (Mon, 04 Nov 2013)
| current branch/cgm13.1 has info as following:
| Path: cgm13.1
| URL: https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/cgm13.1
| Revision: 6093
| Last Changed Rev: 6066
| Last Changed Date: 2013-09-11 12:36:04 -0500 (Wed, 11 Sep 2013)
| Please build as you think proper.
| Jane Hu
| Asst. Researcher
| Dept. of Engineering Physics
| UW @ Madison
| "And we know that for those who love God, that is, for those who are
| called according to his purpose, all things are working together for
| good." (Romans 8:28)
| On Wednesday, November 6, 2013 9:45 AM, Iulian Grindeanu
| <iulian at mcs.anl.gov> wrote:
| Hello,
| Sorry for the buildbot errors for the past two days.
| For the time being, I changed the builds configured with cgm/trunk
| version
| Most of these builds have "tru" in their name (from trunk, not from
| true :)
| http://gnep.mcs.anl.gov:8010/waterfall?category=moab
| All these builds will be built against
| https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/cgm13.1 version of
| cgm, starting tonight.
| We will let you know when these builds will be configured against
| cgm/trunk version.
| Iulian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131106/bcbae410/attachment-0001.html>
