[MOAB-dev] commit/MOAB: danwu: Thanks for Jayesh to find this bug. ParallelComm::gather_data() does not correctly handle the case when the gather set cell entities are not contiguous (e.g. MPAS gather set cells created without NO_MIXED_ELEMENTS read option). The destination of memcpy() is only for the first sequence of the cells, while the source is for all cells, causing invalid write and stack smashing. To fix it, we use a temp buffer for memcpy(), and then set tag data on each sequence of cells separately.
    commits-noreply at bitbucket.org
    Mon Nov  4 16:23:22 CST 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/6ada315d6b44/
Changeset:   6ada315d6b44
Branch:      master
User:        danwu
Date:        2013-11-04 23:23:10
Summary:     Thanks for Jayesh to find this bug. ParallelComm::gather_data() does not correctly handle the case when the gather set cell entities are not contiguous  (e.g. MPAS gather set cells created without NO_MIXED_ELEMENTS read option). The destination of memcpy() is only for the first sequence of the cells, while the source is for all cells, causing invalid write and stack smashing. To fix it, we use a temp buffer for memcpy(), and then set tag data on each sequence of cells separately.
Affected #:  1 file
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index e83653b..efc4fa1 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -8735,24 +8735,24 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
     ErrorCode rval = mbImpl->tag_get_bytes(tag_handle, bytes_per_tag);
     if (rval != MB_SUCCESS) return rval;
-    int sz_buffer = sizeof(int)+gather_ents.size()*(sizeof(int)+bytes_per_tag);
+    int sz_buffer = sizeof(int) + gather_ents.size()*(sizeof(int) + bytes_per_tag);
     void* senddata = malloc(sz_buffer);
     ((int*)senddata)[0] = (int) gather_ents.size();
-    int * ptr_int = (int*)senddata+1;
+    int * ptr_int = (int*)senddata + 1;
     rval = mbImpl->tag_get_data(id_tag, gather_ents, (void*)ptr_int);
-    ptr_int = (int*)(senddata)+1+gather_ents.size();
-    rval = mbImpl->tag_get_data(tag_handle, gather_ents,(void*)ptr_int);
+    ptr_int = (int*)(senddata) + 1 + gather_ents.size();
+    rval = mbImpl->tag_get_data(tag_handle, gather_ents, (void*)ptr_int);
     std::vector<int> displs(proc_config().proc_size(), 0);
     MPI_Gather(&sz_buffer, 1, MPI_INT, &displs[0], 1, MPI_INT, 0, comm());
     std::vector<int> recvcnts(proc_config().proc_size(), 0);
     std::copy(displs.begin(), displs.end(), recvcnts.begin());
     std::partial_sum(displs.begin(), displs.end(), displs.begin());
-    std::vector<int>::iterator lastM1 = displs.end()-1;
+    std::vector<int>::iterator lastM1 = displs.end() - 1;
     std::copy_backward(displs.begin(), lastM1, displs.end());
     //std::copy_backward(displs.begin(), --displs.end(), displs.end());
     displs[0] = 0;
-    if (rank()!=0)
+    if (rank() != 0)
       MPI_Gatherv(senddata, sz_buffer, MPI_BYTE, NULL, NULL, NULL, MPI_BYTE, 0, comm());
     else {
       Range gents;
@@ -8761,19 +8761,51 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
       void* recvbuf = malloc(recvbuffsz);
       MPI_Gatherv(senddata, sz_buffer, MPI_BYTE, recvbuf, &recvcnts[0], &displs[0], MPI_BYTE, 0, comm());
-      void *gvals;
-      int count;
-      rval = mbImpl->tag_iterate(tag_handle, gents.begin(), gents.end(), count, gvals);
+      void* gvals = NULL;
+      // If gents is contiguous, gathered values will be directly copied to its tag space
+      if (gents.psize() == 1) {
+        int count;
+        rval = mbImpl->tag_iterate(tag_handle, gents.begin(), gents.end(), count, gvals);
+        assert(NULL != gvals);
+        assert(count == (int)gents.size());
+      // If gents is not contiguous, gathered values will be copied to a temp buffer first
+      else if (gents.psize() > 1) {
+        gvals = new (std::nothrow) char[gents.size() * bytes_per_tag];
       for (int i = 0; i != (int)size(); ++i) {
-	int numents = *(int*)(((char*)recvbuf)+displs[i]);
-	int* id_ptr = (int*)(((char*)recvbuf)+displs[i]+sizeof(int));
-	char* val_ptr = (char*)(id_ptr+numents);
-	for (int j=0; j != numents; ++j) {
-	  int idx = id_ptr[j];
-	  memcpy((char*)gvals+(idx-1)*bytes_per_tag, val_ptr+j*bytes_per_tag, bytes_per_tag);
+        int numents = *(int*)(((char*)recvbuf) + displs[i]);
+        int* id_ptr = (int*)(((char*)recvbuf) + displs[i] + sizeof(int));
+        char* val_ptr = (char*)(id_ptr + numents);
+        for (int j = 0; j != numents; ++j) {
+          int idx = id_ptr[j];
+          memcpy((char*)gvals + (idx - 1)*bytes_per_tag, val_ptr + j*bytes_per_tag, bytes_per_tag);
+      // If gents is not contiguous, set tag data (stored in the temp buffer) on each sequence separately
+      if (gents.psize() > 1) {
+        Range::iterator iter = gents.begin();
+        size_t start_idx = 0;
+        while (iter != gents.end()) {
+          int count;
+          void* ptr;
+          rval = mbImpl->tag_iterate(tag_handle, iter, gents.end(), count, ptr);
+          for (int i = 0; i < count; i++)
+            ((char*)ptr)[i] = ((char*)gvals)[start_idx + i];
+          iter += count;
+          start_idx += count;
+        assert(start_idx == gents.size());
+        // Delete the temp buffer
+        delete (char*)gvals;
     return MB_SUCCESS;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
