[MOAB-dev] commit/MOAB: danwu: Optimize gather set code for MPAS reader. Use Range as the element type for gather_set_cells_with_n_edges array, instead of using vector. In create_gather_set_edges(), vertices_on_gather_set_edges can use MOAB allocated memory storage for conn_arr_gather_set_edges. In create_padded_gather_set_cells(), vertices_on_gather_set_cells can use MOAB allocated memory storage for conn_arr_gather_set_cells.
commits-noreply at bitbucket.org
Fri Nov 1 16:26:29 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/6aedff57f7ca/
Changeset: 6aedff57f7ca
Branch: master
User: danwu
Date: 2013-11-01 22:26:16
Summary: Optimize gather set code for MPAS reader. Use Range as the element type for gather_set_cells_with_n_edges array, instead of using vector. In create_gather_set_edges(), vertices_on_gather_set_edges can use MOAB allocated memory storage for conn_arr_gather_set_edges. In create_padded_gather_set_cells(), vertices_on_gather_set_cells can use MOAB allocated memory storage for conn_arr_gather_set_cells.
Affected #: 1 file
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 64c8ebf..6a73e31 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -380,18 +380,17 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
ERRORS(success, "Failed on wait_all.");
#endif
- // correct the connectivity array, replace the padded vertices with the last vertices in the
- // corresponding elements; sometimes the padded vertices are 0, sometimes a big vertex id
- // make sure they are consistent to our padded option
- for (int i=0; i<nLocalCells; i++)
- int nVertsInCell=num_edges_on_local_cells[i];
- int indxInConn=i*maxEdgesPerCell;
- for (int j=nVertsInCell; j<maxEdgesPerCell; j++)
- vertices_on_local_cells[indxInConn+j]=vertices_on_local_cells[indxInConn+nVertsInCell-1];
+ // Correct local cell vertices array, replace the padded vertices with the last vertices
+ // in the corresponding cells; sometimes the padded vertices are 0, sometimes a large
+ // vertex id. Make sure they are consistent to our padded option
+ for (int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++) {
+ int num_edges = num_edges_on_local_cells[local_cell_idx];
+ int idx_in_local_vert_arr = local_cell_idx * maxEdgesPerCell;
+ int last_vert_idx = vertices_on_local_cells[idx_in_local_vert_arr + num_edges - 1];
+ for (int i = num_edges; i < maxEdgesPerCell; i++)
+ vertices_on_local_cells[idx_in_local_vert_arr + i] = last_vert_idx;
// Create local vertices
EntityHandle start_vertex;
ErrorCode rval = create_local_vertices(vertices_on_local_cells, start_vertex);
@@ -978,7 +977,7 @@ ErrorCode NCHelperMPAS::redistribute_local_cells(int start_cell_idx)
int success = NCFUNC(inq_varid)(_fileId, "xCell", &xCellVarId);
ERRORS(success, "Failed to get variable id of xCell.");
std::vector<double> xCell(nLocalCells);
- NCDF_SIZE read_start = static_cast<NCDF_SIZE>(start_cell_idx-1);
+ NCDF_SIZE read_start = static_cast<NCDF_SIZE>(start_cell_idx - 1);
NCDF_SIZE read_count = static_cast<NCDF_SIZE>(nLocalCells);
success = NCFUNCAG(_vara_double)(_fileId, xCellVarId, &read_start, &read_count, &xCell[0]);
ERRORS(success, "Failed to read xCell data.");
@@ -1188,8 +1187,7 @@ ErrorCode NCHelperMPAS::create_local_vertices(const std::vector<int>& vertices_o
return MB_SUCCESS;
-ErrorCode NCHelperMPAS::create_local_edges(EntityHandle start_vertex,
- const std::vector<int>& num_edges_on_local_cells)
+ErrorCode NCHelperMPAS::create_local_edges(EntityHandle start_vertex, const std::vector<int>& num_edges_on_local_cells)
Interface*& mbImpl = _readNC->mbImpl;
Tag& mGlobalIdTag = _readNC->mGlobalIdTag;
@@ -1238,16 +1236,16 @@ ErrorCode NCHelperMPAS::create_local_edges(EntityHandle start_vertex,
#endif
- // correct local edges in the same way as padded polygons, pad list with last edges in connectivity
- int nEdgesInCell=num_edges_on_local_cells[i];
- for (int j=nEdgesInCell; j<maxEdgesPerCell; j++)
- edges_on_local_cells[indxInConn+j]=edges_on_local_cells[indxInConn+nEdgesInCell-1];
+ // Correct local cell edges array in the same way as local cell vertices array, replace the
+ // padded edges with the last edges in the corresponding cells
+ int idx_in_local_edge_arr = local_cell_idx * maxEdgesPerCell;
+ int last_edge_idx = edges_on_local_cells[idx_in_local_edge_arr + num_edges - 1];
+ edges_on_local_cells[idx_in_local_edge_arr + i] = last_edge_idx;
// Collect local edges
std::sort(edges_on_local_cells.begin(), edges_on_local_cells.end());
std::copy(edges_on_local_cells.rbegin(), edges_on_local_cells.rend(), range_inserter(localGidEdges));
@@ -1320,8 +1318,9 @@ ErrorCode NCHelperMPAS::create_local_edges(EntityHandle start_vertex,
#endif
- // Populate connectivity for local edges
- // Convert in-place from int to EntityHandle type (reading backward is the trick)
+ // Populate connectivity data for local edges
+ // Convert in-place from int (stored in the first half) to EntityHandle
+ // Reading backward is the trick
for (int edge_vert = nLocalEdges * 2 - 1; edge_vert >= 0; edge_vert--) {
int global_vert_idx = vertices_on_local_edges[edge_vert]; // Global vertex index, 1 based
int local_vert_idx = localGidVerts.index(global_vert_idx); // Local vertex index, 0 based
@@ -1341,6 +1340,7 @@ ErrorCode NCHelperMPAS::create_local_cells(const std::vector<int>& vertices_on_l
// Divide local cells into groups based on the number of edges
Range local_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
+ // Insert larger values before smaller ones to increase efficiency
for (int i = nLocalCells - 1; i >= 0; i--) {
int num_edges = num_edges_on_local_cells[i];
local_cells_with_n_edges[num_edges].insert(localGidCells[i]); // Global cell index
@@ -1381,7 +1381,7 @@ ErrorCode NCHelperMPAS::create_local_cells(const std::vector<int>& vertices_on_l
// Set connectivity array with proper local vertices handles
for (int j = 0; j < num_group_cells; j++) {
- int global_cell_idx = (int)local_cells_with_n_edges[num_edges_per_cell][j]; // Global cell index, 1 based
+ EntityHandle global_cell_idx = local_cells_with_n_edges[num_edges_per_cell][j]; // Global cell index, 1 based
int local_cell_idx = localGidCells.index(global_cell_idx); // Local cell index, 0 based
assert(local_cell_idx != -1);
@@ -1391,11 +1391,11 @@ ErrorCode NCHelperMPAS::create_local_cells(const std::vector<int>& vertices_on_l
for (int k = 0; k < num_edges_per_cell; k++) {
- EntityHandle global_vert_id = vertices_on_local_cells[local_cell_idx * maxEdgesPerCell + k];
- int idx_vertex = localGidVerts.index(global_vert_id);
- assert(idx_vertex != -1);
+ EntityHandle global_vert_idx = vertices_on_local_cells[local_cell_idx * maxEdgesPerCell + k]; // Global vertex index, 1 based
+ int local_vert_idx = localGidVerts.index(global_vert_idx); // Local vertex index, 0 based
+ assert(local_vert_idx != -1);
conn_arr_local_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
- start_vertex + idx_vertex;
+ start_vertex + local_vert_idx;
@@ -1552,40 +1552,46 @@ ErrorCode NCHelperMPAS::create_gather_set_edges(EntityHandle gather_set, EntityH
// Create gather set edges
EntityHandle start_edge;
- EntityHandle* conn_arr_gather_edges = NULL;
+ EntityHandle* conn_arr_gather_set_edges = NULL;
// Don't need to specify allocation number here, because we know enough edges were created before
- ErrorCode rval = _readNC->readMeshIface->get_element_connect(nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_edges);
+ ErrorCode rval = _readNC->readMeshIface->get_element_connect(nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_set_edges);
ERRORR(rval, "Failed to create edges.");
// Add edges to the gather set
- Range gather_edges_range(start_edge, start_edge + nEdges - 1);
- rval = mbImpl->add_entities(gather_set, gather_edges_range);
+ Range gather_set_edges_range(start_edge, start_edge + nEdges - 1);
+ rval = mbImpl->add_entities(gather_set, gather_set_edges_range);
ERRORR(rval, "Failed to add edges to the gather set.");
// Read vertices on each edge
int verticesOnEdgeVarId;
int success = NCFUNC(inq_varid)(_fileId, "verticesOnEdge", &verticesOnEdgeVarId);
ERRORS(success, "Failed to get variable id of verticesOnEdge.");
- std::vector<int> vertices_on_gather_edges(nEdges * 2);
+ // Utilize the memory storage pointed by conn_arr_gather_set_edges
+ int* vertices_on_gather_set_edges = (int*) conn_arr_gather_set_edges;
NCDF_SIZE read_starts[2] = {0, 0};
NCDF_SIZE read_counts[2] = {static_cast<NCDF_SIZE>(nEdges), 2};
#ifdef PNETCDF_FILE
// Enter independent I/O mode, since this read is only for the gather processor
success = NCFUNC(begin_indep_data)(_fileId);
ERRORS(success, "Failed to begin independent I/O mode.");
- success = NCFUNCG(_vara_int)(_fileId, verticesOnEdgeVarId, read_starts, read_counts, &vertices_on_gather_edges[0]);
+ success = NCFUNCG(_vara_int)(_fileId, verticesOnEdgeVarId, read_starts, read_counts, vertices_on_gather_set_edges);
ERRORS(success, "Failed to read verticesOnEdge data.");
success = NCFUNC(end_indep_data)(_fileId);
ERRORS(success, "Failed to end independent I/O mode.");
#else
#endif
- std::copy(vertices_on_gather_edges.begin(), vertices_on_gather_edges.end(), conn_arr_gather_edges);
- for (int i = 0; i < 2 * nEdges; i++)
+ // Populate connectivity data for gather set edges
+ for (int edge_vert = nEdges * 2 - 1; edge_vert >= 0; edge_vert--) {
+ int gather_set_vert_idx = vertices_on_gather_set_edges[edge_vert]; // Global vertex index, 1 based
+ gather_set_vert_idx--; // 1 based -> 0 based
// Connectivity array is shifted by where the gather set vertices start
- conn_arr_gather_edges[i] += gather_set_start_vertex - 1;
+ conn_arr_gather_set_edges[edge_vert] = gather_set_start_vertex + gather_set_vert_idx;
return MB_SUCCESS;
@@ -1598,19 +1604,19 @@ ErrorCode NCHelperMPAS::create_gather_set_cells(EntityHandle gather_set, EntityH
int nEdgesOnCellVarId;
int success = NCFUNC(inq_varid)(_fileId, "nEdgesOnCell", &nEdgesOnCellVarId);
ERRORS(success, "Failed to get variable id of nEdgesOnCell.");
- std::vector<int> num_edges_on_gather_cells(nCells);
+ std::vector<int> num_edges_on_gather_set_cells(nCells);
NCDF_SIZE read_start = 0;
NCDF_SIZE read_count = static_cast<NCDF_SIZE>(nCells);
#ifdef PNETCDF_FILE
- success = NCFUNCG(_vara_int)(_fileId, nEdgesOnCellVarId, &read_start, &read_count, &num_edges_on_gather_cells[0]);
+ success = NCFUNCG(_vara_int)(_fileId, nEdgesOnCellVarId, &read_start, &read_count, &num_edges_on_gather_set_cells[0]);
ERRORS(success, "Failed to read nEdgesOnCell data.");
#else
#endif
@@ -1618,52 +1624,57 @@ ErrorCode NCHelperMPAS::create_gather_set_cells(EntityHandle gather_set, EntityH
int verticesOnCellVarId;
success = NCFUNC(inq_varid)(_fileId, "verticesOnCell", &verticesOnCellVarId);
ERRORS(success, "Failed to get variable id of verticesOnCell.");
- std::vector<int> vertices_on_gather_cells(nCells * maxEdgesPerCell);
+ std::vector<int> vertices_on_gather_set_cells(nCells * maxEdgesPerCell);
- NCDF_SIZE read_counts[2] = {static_cast<NCDF_SIZE>(nCells), maxEdgesPerCell};
+ NCDF_SIZE read_counts[2] = {static_cast<NCDF_SIZE>(nCells), static_cast<NCDF_SIZE>(maxEdgesPerCell)};
#ifdef PNETCDF_FILE
- success = NCFUNCG(_vara_int)(_fileId, verticesOnCellVarId, read_starts, read_counts, &vertices_on_gather_cells[0]);
+ success = NCFUNCG(_vara_int)(_fileId, verticesOnCellVarId, read_starts, read_counts, &vertices_on_gather_set_cells[0]);
ERRORS(success, "Failed to read verticesOnCell data.");
#else
#endif
// Divide gather set cells into groups based on the number of edges
- std::vector<int> gather_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
- for (int i = 0; i < nCells; i++) {
- int num_edges = num_edges_on_gather_cells[i];
- gather_cells_with_n_edges[num_edges].push_back(i + 1); // 0 based -> 1 based
+ Range gather_set_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
+ // Insert larger values before smaller values to increase efficiency
+ for (int i = nCells - 1; i >= 0; i--) {
+ int num_edges = num_edges_on_gather_set_cells[i];
+ gather_set_cells_with_n_edges[num_edges].insert(i + 1); // 0 based -> 1 based
// Create gather set cells
- EntityHandle* conn_arr_gather_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
+ EntityHandle* conn_arr_gather_set_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
for (int num_edges_per_cell = 3; num_edges_per_cell <= maxEdgesPerCell; num_edges_per_cell++) {
- int num_group_cells = gather_cells_with_n_edges[num_edges_per_cell].size();
+ int num_group_cells = gather_set_cells_with_n_edges[num_edges_per_cell].size();
if (num_group_cells > 0) {
EntityHandle start_element;
ErrorCode rval = _readNC->readMeshIface->get_element_connect(num_group_cells, num_edges_per_cell, MBPOLYGON, 0, start_element,
- conn_arr_gather_cells_with_n_edges[num_edges_per_cell], num_group_cells);
+ conn_arr_gather_set_cells_with_n_edges[num_edges_per_cell], num_group_cells);
ERRORR(rval, "Failed to create cells.");
// Add cells to the gather set
- Range gather_cells_range(start_element, start_element + num_group_cells - 1);
- rval = mbImpl->add_entities(gather_set, gather_cells_range);
+ Range gather_set_cells_range(start_element, start_element + num_group_cells - 1);
+ rval = mbImpl->add_entities(gather_set, gather_set_cells_range);
ERRORR(rval, "Failed to add cells to the gather set.");
- int gather_cell_idx = gather_cells_with_n_edges[num_edges_per_cell][j]; // Global cell index, 1 based
- gather_cell_idx--; // 1 based -> 0 based
+ int gather_set_cell_idx = gather_set_cells_with_n_edges[num_edges_per_cell][j]; // Global cell index, 1 based
+ gather_set_cell_idx--; // 1 based -> 0 based
+ for (int k = 0; k < num_edges_per_cell; k++) {
+ EntityHandle gather_set_vert_idx = vertices_on_gather_set_cells[gather_set_cell_idx * maxEdgesPerCell + k]; // Global vertex index, 1 based
- for (int k = 0; k < num_edges_per_cell; k++)
- conn_arr_gather_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
- (gather_set_start_vertex - 1) + vertices_on_gather_cells[gather_cell_idx * maxEdgesPerCell + k];
+ conn_arr_gather_set_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
+ gather_set_start_vertex + gather_set_vert_idx;
@@ -1679,64 +1690,73 @@ ErrorCode NCHelperMPAS::create_padded_gather_set_cells(EntityHandle gather_set,
#ifdef PNETCDF_FILE
#else
#endif
+ // Create gather set cells
+ EntityHandle start_element;
+ EntityHandle* conn_arr_gather_set_cells = NULL;
+ // Don't need to specify allocation number here, because we know enough cells were created before
+ ErrorCode rval = _readNC->readMeshIface->get_element_connect(nCells, maxEdgesPerCell, MBPOLYGON, 0, start_element, conn_arr_gather_set_cells);
+ ERRORR(rval, "Failed to create cells.");
+ // Add cells to the gather set
+ Range gather_set_cells_range(start_element, start_element + nCells - 1);
+ ERRORR(rval, "Failed to add cells to the gather set.");
// Read vertices on each gather set cell (connectivity)
+ // Utilize the memory storage pointed by conn_arr_gather_set_cells
+ int* vertices_on_gather_set_cells = (int*) conn_arr_gather_set_cells;
#ifdef PNETCDF_FILE
+ success = NCFUNCG(_vara_int)(_fileId, verticesOnCellVarId, read_starts, read_counts, vertices_on_gather_set_cells);
#else
#endif
- // Create gather set cells
- EntityHandle start_element;
- EntityHandle* conn_arr_gather_cells = NULL;
- // Don't need to specify allocation number here, because we know enough cells were created before
- ErrorCode rval = _readNC->readMeshIface->get_element_connect(nCells, maxEdgesPerCell, MBPOLYGON, 0, start_element, conn_arr_gather_cells);
- ERRORR(rval, "Failed to create cells.");
- // Add cells to the gather set
- Range gather_cells_range(start_element, start_element + nCells - 1);
- ERRORR(rval, "Failed to add cells to the gather set.");
- for (int gather_cell_idx = 0; gather_cell_idx < nCells; gather_cell_idx++) {
- int num_edges = num_edges_on_gather_cells[gather_cell_idx];
- for (int i = 0; i < num_edges; i++)
- // Connectivity array is shifted by where the gather set vertices start
- conn_arr_gather_cells[gather_cell_idx * maxEdgesPerCell + i] = (gather_set_start_vertex - 1) + vertices_on_gather_cells[gather_cell_idx * maxEdgesPerCell + i];
- // Padding: fill connectivity array with last vertex handle
- EntityHandle last_vert_handle = conn_arr_gather_cells[gather_cell_idx * maxEdgesPerCell + num_edges - 1];
+ // Correct gather set cell vertices array in the same way as local cell vertices array,
+ // replace the padded vertices with the last vertices in the corresponding cells
+ for (int gather_set_cell_idx = 0; gather_set_cell_idx < nCells; gather_set_cell_idx++) {
+ int num_edges = num_edges_on_gather_set_cells[gather_set_cell_idx];
+ int idx_in_gather_set_vert_arr = gather_set_cell_idx * maxEdgesPerCell;
+ int last_vert_idx = vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + num_edges - 1];
- conn_arr_gather_cells[gather_cell_idx * maxEdgesPerCell + i] = last_vert_handle;
+ vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + i] = last_vert_idx;
+ // Populate connectivity data for gather set cells
+ for (int cell_vert = nCells * maxEdgesPerCell - 1; cell_vert >= 0; cell_vert--) {
+ int gather_set_vert_idx = vertices_on_gather_set_cells[cell_vert]; // Global vertex index, 1 based
+ // Connectivity array is shifted by where the gather set vertices start
+ conn_arr_gather_set_cells[cell_vert] = gather_set_start_vertex + gather_set_vert_idx;
return MB_SUCCESS;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
