[MOAB-dev] commit/MOAB: danwu: Rename NCHelper::init_dims_with_no_cvars_info() to init_dims_with_no_coord_vars_info(), and apply it in NCHelperMPAS::init_mesh_vals(), to create dummy tags for MPAS dimensions that do not have corresponding coordinate variables. Also, in NCHelper::read_variable_to_set_allocate(), there is no need to allocate space for the dummy tags.
commits-noreply at bitbucket.org
Wed Oct 30 17:00:23 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/94adffe2308e/
Changeset: 94adffe2308e
Branch: master
User: danwu
Date: 2013-10-30 23:00:09
Summary: Rename NCHelper::init_dims_with_no_cvars_info() to init_dims_with_no_coord_vars_info(), and apply it in NCHelperMPAS::init_mesh_vals(), to create dummy tags for MPAS dimensions that do not have corresponding coordinate variables. Also, in NCHelper::read_variable_to_set_allocate(), there is no need to allocate space for the dummy tags.
Affected #: 6 files
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 5f621d7..b5e4df7 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -306,7 +306,7 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
- std::set<std::string>& dummyVarNames = _readNC->dummyVarNames;;
+ std::set<std::string>& dummyVarNames = _readNC->dummyVarNames;
Interface*& mbImpl = _readNC->mbImpl;
DebugOutput& dbgOut = _readNC->dbgOut;
@@ -316,8 +316,11 @@ ErrorCode NCHelper::read_variable_to_set(std::vector<ReadNC::VarData>& vdatas, s
// Finally, read into that space
int success;
for (unsigned int i = 0; i < vdatas.size(); i++) {
- if (dummyVarNames.find(vdatas[i].varName) != dummyVarNames.end() )
- continue; // This is a dummy one, we don't have it; we created it for the dummy tag
+ // This is a dummy variable, we don't have it; we created it for the dummy tag
+ // No need to read tag data for it
+ if (dummyVarNames.find(vdatas[i].varName) != dummyVarNames.end())
+ continue;
for (unsigned int t = 0; t < tstep_nums.size(); t++) {
void* data = vdatas[i].varDatas[t];
@@ -652,7 +655,7 @@ ErrorCode NCHelper::create_attrib_string(const std::map<std::string, ReadNC::Att
return MB_SUCCESS;
-void NCHelper::init_dims_with_no_cvars_info()
+void NCHelper::init_dims_with_no_coord_vars_info()
std::vector<std::string>& dimNames = _readNC->dimNames;
@@ -660,24 +663,23 @@ void NCHelper::init_dims_with_no_cvars_info()
// Hack: look at all dimensions, and see if we have one that does not appear in the list of varInfo names
- // right now, candidates are ncol and nbnd
- // for them, create dummy tags
- for (unsigned int i = 0; i < dimNames.size(); i++)
- // If there is a var with this name, skip, we are fine; if not, create a varInfo...
+ // Right now, candidates are from unstructured meshes, such as ncol(HOMME) and nCells(MPAS)
+ // For them, create dummy tags
+ for (unsigned int i = 0; i < dimNames.size(); i++) {
+ // If there is a variable with this dimension name, skip, we are fine; if not, create a dummy varInfo
if (varInfo.find(dimNames[i]) != varInfo.end())
- continue; // We already have a variable with this dimension name
+ continue;
int sizeTotalVar = varInfo.size();
std::string var_name(dimNames[i]);
- ReadNC::VarData &data = varInfo[var_name];
+ ReadNC::VarData& data = varInfo[var_name];
data.varName = std::string(var_name);
- data.varId =sizeTotalVar;
+ data.varId = sizeTotalVar;
data.varTags.resize(1, 0);
data.varDataType = NC_DOUBLE; // Could be int, actually, but we do not really need the type
data.varDims.resize(1);
- data.varDims[0]= (int)i;
- data.numAtts=0;
+ data.varDims[0] = (int)i;
+ data.numAtts = 0;
data.entLoc = ReadNC::ENTLOCSET;
dbgOut.tprintf(2, "Dummy varInfo created for dimension %s\n", dimNames[i].c_str());
dummyVarNames.insert(dimNames[i]);
@@ -686,12 +688,23 @@ void NCHelper::init_dims_with_no_cvars_info()
ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
std::vector<int>& dimLens = _readNC->dimLens;
ErrorCode rval = MB_SUCCESS;
+ // No need to allocate tag space for it
+ if (dummyVarNames.find(vdatas[i].varName) != dummyVarNames.end()) {
+ if (!vdatas[i].varTags[0]) {
+ rval = get_tag_to_set(vdatas[i], 0, vdatas[i].varTags[0]);
+ ERRORR(rval, "Trouble getting dummy tag.");
+ continue;
if ((std::find(vdatas[i].varDims.begin(), vdatas[i].varDims.end(), tDim) != vdatas[i].varDims.end()))
vdatas[i].has_t = true;
@@ -710,15 +723,12 @@ ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>&
// Set up the dimensions and counts
// First variable dimension is time, if it exists
- if (vdatas[i].has_t)
- if (vdatas[i].varDims.size() != 1)
+ if (vdatas[i].has_t) {
+ if (vdatas[i].varDims.size() != 1) {
vdatas[i].readStarts[t].push_back(tstep_nums[t]);
vdatas[i].readCounts[t].push_back(1);
- else
+ else {
vdatas[i].readStarts[t].push_back(0);
vdatas[i].readCounts[t].push_back(tstep_nums.size());
@@ -739,10 +749,12 @@ ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>&
std::size_t sz = 1;
for (std::size_t idx = 0; idx != vdatas[i].readCounts[t].size(); idx++)
sz *= vdatas[i].readCounts[t][idx];
vdatas[i].sz = sz;
switch (vdatas[i].varDataType) {
case NC_BYTE:
case NC_CHAR:
@@ -760,6 +772,7 @@ ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>&
std::cerr << "Unrecognized data type for tag " << std::endl;
rval = MB_FAILURE;
if (vdatas[i].varDims.size() <= 1)
break;
@@ -779,8 +792,7 @@ ErrorCode ScdNCHelper::check_existing_mesh() {
// Check against parameters
// When ghosting is used, this check might fail (to be updated later)
- if (num_verts > 0)
+ if (num_verts > 0) {
int expected_verts = (lDims[3] - lDims[0] + 1) * (lDims[4] - lDims[1] + 1) * (-1 == lDims[2] ? 1 : lDims[5] - lDims[2] + 1);
if (num_verts != expected_verts) {
ERRORR(MB_FAILURE, "Number of vertices doesn't match.");
@@ -796,8 +808,7 @@ ErrorCode ScdNCHelper::check_existing_mesh() {
// The expected number of elements calculated below is incorrect (to be updated later)
- if (num_elems > 0)
+ if (num_elems > 0) {
int expected_elems = (lDims[3] - lDims[0]) * (lDims[4] - lDims[1]) * (-1 == lDims[2] ? 1 : lDims[5] - lDims[2]);
if (num_elems != expected_elems) {
ERRORR(MB_FAILURE, "Number of elements doesn't match.");
@@ -990,6 +1001,7 @@ ErrorCode ScdNCHelper::read_scd_variable_setup(std::vector<std::string>& var_nam
vdatas[i].readStarts.resize(tstep_nums.size());
vdatas[i].readCounts.resize(tstep_nums.size());
for (unsigned int i = 0; i < vsetdatas.size(); i++) {
if ((std::find(vsetdatas[i].varDims.begin(), vsetdatas[i].varDims.end(), tDim) != vsetdatas[i].varDims.end())
&& (vsetdatas[i].varDims.size() != 1)) {
diff --git a/src/io/NCHelper.hpp b/src/io/NCHelper.hpp
index 4982b4c..f3d1875 100644
--- a/src/io/NCHelper.hpp
+++ b/src/io/NCHelper.hpp
@@ -58,9 +58,9 @@ protected:
std::string& attString,
std::vector<int>& attLen);
- //! Init info for dimensions that don't have corresponding
- //! coordinate variables - this info is used for creating tags
- void init_dims_with_no_cvars_info();
+ //! Initialize information for dimensions that don't have corresponding
+ //! coordinate variables - this information is used for creating dummy tags
+ void init_dims_with_no_coord_vars_info();
private:
//! Used by read_variable_to_set()
diff --git a/src/io/NCHelperEuler.cpp b/src/io/NCHelperEuler.cpp
index 369aa29..48056c6 100644
--- a/src/io/NCHelperEuler.cpp
+++ b/src/io/NCHelperEuler.cpp
@@ -451,8 +451,8 @@ ErrorCode NCHelperEuler::init_mesh_vals()
dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
- // Hack: create dummy tags, if needed, for variables with no corresponding variables
- init_dims_with_no_cvars_info();
+ // Hack: create dummy tags, if needed, for dimensions with no corresponding coordinate variables
+ init_dims_with_no_coord_vars_info();
return MB_SUCCESS;
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index 7f4142e..253d598 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -452,8 +452,8 @@ ErrorCode NCHelperFV::init_mesh_vals()
- // Hack: create dummy tags, if needed, for dimensions with no corresponding variables
return MB_SUCCESS;
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index f750e78..154d61d 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -160,8 +160,8 @@ ErrorCode NCHelperHOMME::init_mesh_vals()
vd.entLoc = ReadNC::ENTLOCVERT;
+ // Hack: create dummy tags for dimensions (like ncol) with no corresponding coordinate variables
return MB_SUCCESS;
@@ -548,6 +548,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_setup(std::vector<std::string>& var_n
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 550988b..64c8ebf 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -135,6 +135,9 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
vd.entLoc = ReadNC::ENTLOCFACE;
+ // Hack: create dummy tags for dimensions (like nCells) with no corresponding coordinate variables
return MB_SUCCESS;
@@ -516,6 +519,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_setup(std::vector<std::string>& var_na
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
