[MOAB-dev] Build failed in Jenkins: moab_par #667
jenkins-ci at mcs.anl.gov
Wed Oct 30 09:01:41 CDT 2013
See <https://jenkins-ci.mcs.anl.gov/job/moab_par/667/>
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on churn.mcs.anl.gov in workspace <https://jenkins-ci.mcs.anl.gov/job/moab_par/ws/>
Checkout:moab_par / <https://jenkins-ci.mcs.anl.gov/job/moab_par/ws/> - hudson.remoting.Channel at 3437c7c0:churn.mcs.anl.gov
Using strategy: Default
Last Built Revision: Revision c854f98ea45dfef7b07cf3d2e1b2de5f8b9b7285 (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
ERROR: Problem fetching from origin / origin - could be unavailable. Continuing anyway
hudson.plugins.git.GitException: Command "git fetch -t origin +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: error: The requested URL returned error: 503 while accessing https://fathom:nopass@bitbucket.org/fathomteam/moab.git/info/refs
fatal: HTTP request failed
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:774)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:740)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.fetch(CliGitAPIImpl.java:161)
at hudson.plugins.git.GitAPI.fetch(GitAPI.java:230)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:793)
at hudson.plugins.git.GitSCM.access$000(GitSCM.java:57)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:977)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:942)
at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2348)
at hudson.remoting.UserRequest.perform(UserRequest.java:118)
at hudson.remoting.UserRequest.perform(UserRequest.java:48)
at hudson.remoting.Request$2.run(Request.java:326)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1146)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:679)
ERROR: Could not fetch from any repository
hudson.util.IOException2: remote file operation failed: <https://jenkins-ci.mcs.anl.gov/job/moab_par/ws/> at hudson.remoting.Channel at 3437c7c0:churn.mcs.anl.gov
at hudson.FilePath.act(FilePath.java:861)
at hudson.FilePath.act(FilePath.java:838)
at hudson.plugins.git.GitSCM.determineRevisionToBuild(GitSCM.java:942)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1108)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1342)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:683)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:588)
at hudson.model.Run.execute(Run.java:1567)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:237)
Caused by: java.io.IOException: Could not fetch from any repository
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:986)
