[MOAB-dev] commit/MOAB: iulian07: repartition changes for MPAS reader
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Mon Oct 28 09:03:12 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b2de259e368a/
Changeset:   b2de259e368a
Branch:      master
User:        iulian07
Date:        2013-10-28 14:59:10
Summary:     repartition changes for MPAS reader
use the import/export directly from Zoltan, to establish what global ids are
exported (leaving the processor) and what global ids are coming in (imported)
build using that info the global cell id range.
eliminate the need of a crystal router call.
Affected #:  1 file
diff --git a/tools/mbzoltan/MBZoltan.cpp b/tools/mbzoltan/MBZoltan.cpp
index 6b92b4f..7590ac9 100644
--- a/tools/mbzoltan/MBZoltan.cpp
+++ b/tools/mbzoltan/MBZoltan.cpp
@@ -23,6 +23,7 @@
 #include <iostream>
 #include <assert.h>
 #include <sstream>
+#include <algorithm>
 #include "MBZoltan.hpp"
 #include "moab/Interface.hpp"
@@ -297,8 +298,8 @@ ErrorCode  MBZoltan::repartition(std::vector<double> & x,std::vector<double>&y,
   int retval = myZZ->Set_Param("NUM_GLOBAL_PARTITIONS", buff);
   if (ZOLTAN_OK != retval) return MB_FAILURE;
-    // request only partition assignments
-  retval = myZZ->Set_Param("RETURN_LISTS", "PARTITION ASSIGNMENTS");
+    // request all, import and export
+  retval = myZZ->Set_Param("RETURN_LISTS", "ALL");
@@ -314,11 +315,12 @@ ErrorCode  MBZoltan::repartition(std::vector<double> & x,std::vector<double>&y,
   int changes;
   int numGidEntries;
   int numLidEntries;
-  int dumnum1;
-  ZOLTAN_ID_PTR dum_local, dum_global;
-  int *dum1, *dum2;
-  int num_assign;
-  ZOLTAN_ID_PTR assign_gid, assign_lid;
+  int num_import;
+  ZOLTAN_ID_PTR import_global_ids, import_local_ids;
+  int * import_procs;
+  int * import_to_part;
+  int num_export;
+  ZOLTAN_ID_PTR export_global_ids, export_local_ids;
   int *assign_procs, *assign_parts;
   if (rank ==0)
@@ -326,8 +328,8 @@ ErrorCode  MBZoltan::repartition(std::vector<double> & x,std::vector<double>&y,
       " method for " << nprocs << " processors..." << std::endl;
   retval = myZZ->LB_Partition(changes, numGidEntries, numLidEntries,
-                              dumnum1, dum_global, dum_local, dum1, dum2,
-                              num_assign, assign_gid, assign_lid,
+                              num_import, import_global_ids, import_local_ids, import_procs, import_to_part,
+                              num_export, export_global_ids, export_local_ids,
                               assign_procs, assign_parts);
@@ -337,34 +339,15 @@ ErrorCode  MBZoltan::repartition(std::vector<double> & x,std::vector<double>&y,
     t = clock();
+  std::sort(import_global_ids, import_global_ids+num_import, std::greater<int> ());
+  std::sort(export_global_ids, export_global_ids+num_export, std::greater<int> ());
-  for (size_t i=0; i<x.size(); i++)
-    sendToProcs.push_back(assign_procs[i]);
-  // free some memory after we are done
-  delete myZZ;
-  myZZ = NULL;
-  // free memory used by Zoltan
-  // form tuples for Gids!
-  TupleList gidProcs;
-    // allocate a TupleList of that size
-  gidProcs.initialize(1, 1, 0, 0, x.size()*2);// to account for some imbalances
-  gidProcs.enableWriteAccess();
-  for (size_t i = 0;i <sendToProcs.size(); i++)
-    gidProcs.vi_wr[i]=sendToProcs[i];
-    gidProcs.vl_wr[i]=StartID+i;
-    gidProcs.inc_n();
-  // now do a transfer
-  (mbpc->proc_config().crystal_router())->gs_transfer(1, gidProcs, 0);
-  // after this, every gidProc should contain the gids sent from other processes
-  int receivedGIDs=gidProcs.get_n();
-  for (int j=0;j<receivedGIDs; j++)
-    localGIDs.insert(gidProcs.vl_wr[j]);
+  Range iniGids((EntityHandle)StartID, (EntityHandle)StartID+x.size()-1);
+  Range imported, exported;
+  std::copy(import_global_ids, import_global_ids+num_import, range_inserter(imported));
+  std::copy(export_global_ids, export_global_ids+num_export, range_inserter(exported));
+  localGIDs=subtract(iniGids, exported);
+  localGIDs=unite(localGIDs, imported);
   return MB_SUCCESS;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
