[MOAB-dev] commit/MOAB: iulian07: simplify padding in MPAS
commits-noreply at bitbucket.org
Fri Oct 25 23:44:59 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/20d0be3f6985/
Changeset: 20d0be3f6985
Branch: master
User: iulian07
Date: 2013-10-26 06:39:46
Summary: simplify padding in MPAS
the vertices are already processed for padding, no need to check them
again
Affected #: 2 files
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 8d94e3d..404619d 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -402,7 +402,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
// Create local cells, either unpadded or padded
if (noMixedElements) {
- rval = create_padded_local_cells(vertices_on_local_cells, num_edges_on_local_cells, start_vertex, faces);
+ rval = create_padded_local_cells(vertices_on_local_cells, start_vertex, faces);
ERRORR(rval, "Failed to create padded local cells for MPAS mesh.");
else {
@@ -1397,7 +1397,6 @@ ErrorCode NCHelperMPAS::create_local_cells(const std::vector<int>& vertices_on_l
ErrorCode NCHelperMPAS::create_padded_local_cells(const std::vector<int>& vertices_on_local_cells,
- const std::vector<int>& num_edges_on_local_cells,
EntityHandle start_vertex, Range& faces)
Interface*& mbImpl = _readNC->mbImpl;
@@ -1430,21 +1429,15 @@ ErrorCode NCHelperMPAS::create_padded_local_cells(const std::vector<int>& vertic
std::copy(localGidCells.begin(), localGidCells.end(), gid_data);
// Set connectivity array with proper local vertices handles
+ // vertices_on_local_cells array was already corrected to have the last vertices padded
+ // no need for extra checks considering
for (int cell_idx = 0; cell_idx < nLocalCells; cell_idx++) {
- int num_edges = num_edges_on_local_cells[cell_idx];
- for (int i = 0; i < num_edges; i++) {
+ for (int i = 0; i < maxEdgesPerCell; i++) {
EntityHandle global_vert_id = vertices_on_local_cells[cell_idx * maxEdgesPerCell + i]; // 1 based
int local_vert_idx = localGidVerts.index(global_vert_id); // 0 based
assert(local_vert_idx != -1);
conn_arr_local_cells[cell_idx * maxEdgesPerCell + i] = start_vertex + local_vert_idx;
- // Padding: fill connectivity array with last vertex handle
- if (num_edges < maxEdgesPerCell) {
- EntityHandle last_vert_id = conn_arr_local_cells[cell_idx * maxEdgesPerCell + num_edges - 1];
- for (int i = num_edges; i < maxEdgesPerCell; i++)
- conn_arr_local_cells[cell_idx * maxEdgesPerCell + i] = last_vert_id;
return MB_SUCCESS;
diff --git a/src/io/NCHelperMPAS.hpp b/src/io/NCHelperMPAS.hpp
index aa8e972..0f053bc 100644
--- a/src/io/NCHelperMPAS.hpp
+++ b/src/io/NCHelperMPAS.hpp
@@ -64,7 +64,6 @@ private:
//! Create local cells with padding (padded cells will have the same number of edges)
ErrorCode create_padded_local_cells(const std::vector<int>& vertices_on_local_cells,
EntityHandle start_vertex, Range& faces);
//! Create gather set vertices
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
