[MOAB-dev] Fortran interface to MOAB
Vijay S. Mahadevan vijay.m at gmail.com
Tue Oct 22 15:21:59 CDT 2013
It might still be useful to get the iMesh 2003 Fortran bindings in
place so that fortran users dont have to screw around with cray
pointers. Else, if there is considerable interest, we can just
generate the interfaces for these methods based on C-routine
signatures. For the near term, the 2003 bindings would be the way to
go.
Vijay
On Tue, Oct 22, 2013 at 2:57 PM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> Look in examples/old/itaps, and make sure to configure with a fortran
> compiler (imesh is turned on by default).  You make have to use a makefile
> more like in examples/makefile (the MOAB_LIBS_LINK variable should contain
> moab's imesh library, though you may have to add the Fortran runtime
> libraries to that link statement, assuming you use the C++ linker).  I'll
> make a note to update the examples so it's clearer how to do Fortran.
> - tim
> On 10/22/2013 02:47 PM, kanaev at ibrae.ac.ru wrote:
>> Hello MOAB-dev,
>> I intend to call MOAB subroutines in Fortran 77 code.
>> How i have to configure MOAB before make?
>> Should i use only iMesh for that purpose?
>> Can i ask you for a Fortran version of GetEntities.cpp simple example and
>> correspondant makefile?
>> Thanks,
>> Anton Kanaev
>> The Nuclear Safety Institute (IBRAE)
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
