[MOAB-dev] Fortran interface to MOAB
Tim Tautges
tautges at mcs.anl.gov
Tue Oct 22 14:57:21 CDT 2013
Look in examples/old/itaps, and make sure to configure with a fortran compiler (imesh is turned on by default). You
make have to use a makefile more like in examples/makefile (the MOAB_LIBS_LINK variable should contain moab's imesh
library, though you may have to add the Fortran runtime libraries to that link statement, assuming you use the C++
linker). I'll make a note to update the examples so it's clearer how to do Fortran.
- tim
On 10/22/2013 02:47 PM, kanaev at ibrae.ac.ru wrote:
> Hello MOAB-dev,
> I intend to call MOAB subroutines in Fortran 77 code.
> How i have to configure MOAB before make?
> Should i use only iMesh for that purpose?
> Can i ask you for a Fortran version of GetEntities.cpp simple example and correspondant makefile?
> Thanks,
> Anton Kanaev
> The Nuclear Safety Institute (IBRAE)
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
