[MOAB-dev] commit/MOAB: iulian07: fix parallel builds configured without mbzoltan
Vijay S. Mahadevan vijay.m at gmail.com
Sun Oct 20 11:35:19 CDT 2013
Thanks for the fix Iulian. Just a simple preprocessor check for zoltan
configuration got left out crashing all non-zoltan builds.
Can we please initiate buildbot checks after every commit? Is there a
way to even do this or do we have to wait till end of the day for
confirmation ? These could be as simple as running "git pull; make
check" on the different builds. MOAB master needs to be stable since
PETSc master relies on it in certain daily configurations.
Vijay
On Sun, Oct 20, 2013 at 9:34 AM,  <commits-noreply at bitbucket.org> wrote:
> 1 new commit in MOAB:
> https://bitbucket.org/fathomteam/moab/commits/8dbdd2de6148/
> Changeset:   8dbdd2de6148
> Branch:      master
> User:        iulian07
> Date:        2013-10-20 16:32:07
> Summary:     fix parallel builds configured without mbzoltan
> if build in parallel, without zoltan, the guards will allow only trivial
> partition for MPAS meshes
> Affected #:  1 file
> diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
> index 35fdb2b..497c7f1 100644
> --- a/src/io/NCHelperMPAS.cpp
> +++ b/src/io/NCHelperMPAS.cpp
> @@ -302,6 +302,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
>  #ifdef USE_MPI
> +#ifdef HAVE_ZOLTAN
>    int& partMethod = _readNC->partMethod;
>    if (partMethod==ScdParData::RCBZOLTAN && procs >=2) // it does not make sense to partition
>      // if the number of processors is less than 2; trivial partition is good enough
> @@ -331,12 +332,16 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
>      nLocalCells = localGidCells.size();
>    else {
> -#endif  /* use mpi */
> +#endif /* this is end for HAVE_ZOLTAN */
> +#endif  /* if use mpi */
> +    /* without zoltan, only trivial partition is possible */
>      start_cell_idx++; // 0 based -> 1 based
>      localGidCells.insert(start_cell_idx, start_cell_idx + nLocalCells - 1);
>  #ifdef USE_MPI
> +#ifdef HAVE_ZOLTAN
> -#endif
> +#endif /* end for HAVE_ZOLTAN */
> +#endif /* end for USE_MPI */
>    // Read number of edges on each local cell, to calculate actual maxEdgesPerCell
>    int nEdgesOnCellVarId;
>    int success = NCFUNC(inq_varid)(_fileId, "nEdgesOnCell", &nEdgesOnCellVarId);
> Repository URL: https://bitbucket.org/fathomteam/moab/
> This is a commit notification from bitbucket.org. You are receiving
> this because you have the service enabled, addressing the recipient of
> this email.
