[MOAB-dev] Trouble Creating AEntities
Iulian Grindeanu
iulian at mcs.anl.gov
Mon Oct 14 18:01:59 CDT 2013
Hi Chris,
Then my second guess is that you use 4.6.2
There is an issue with adjacencies with MBPOLYGON in 462;
Can you use MBQUAD for type? Or upgrade to current version?
Iulian
----- Original Message -----
| Tim:
| I tried your code:
| Range faces, edges;
| result = iface->get_entities_by_dimension(0, 2, faces);
| result = iface->get_adjacencies(faces, 1, true, edges,
| Interface::UNION);
| and it didn't solve the problem.
| Iulian:
| My element creation code is:
| //! read/create elements
| ErrorCode create_elements(int nx, int ny, int num_elems, EntityHandle
| start_vertex, EntityHandle &start_elem, Range &read_ents)
| // get the entity type being read
| EntityType ent_type = MBPOLYGON;
| // get the number of vertices per entity
| int verts_per_elem = 4;
| // Create the element sequence; passes back a pointer to the internal
| storage for connectivity and the
| // starting entity handle
| EntityHandle* conn_array;
| ErrorCode result = readiface->get_element_connect( num_elems,
| verts_per_elem, ent_type,1, start_elem, conn_array );
| if (MB_SUCCESS != result) return result;
| // read connectivity into conn_array directly
| for (int i=0 ; i<nx ; i++) {
| for (int j=0 ; j<ny ; j++) {
| int l = SCONV(j,ny)*nx + SCONV(i,nx) ;
| conn_array[verts_per_elem*l] = start_vertex + SCONV(j,ny)*nx +
| SCONV(i,nx);
| conn_array[verts_per_elem*l+1] = start_vertex + SCONV(j,ny)*nx +
| SCONV(i-1,nx);
| conn_array[verts_per_elem*l+2] = start_vertex + SCONV(j-1,ny)*nx +
| SCONV(i-1,nx);
| conn_array[verts_per_elem*l+3] = start_vertex + SCONV(j-1,ny)*nx +
| SCONV(i,nx);
| // notify MOAB of the new elements
| result = readiface->update_adjacencies(start_elem, num_elems,
| verts_per_elem, conn_array);
| // add elements to read_ents
| if (num_elems) read_ents.insert(start_elem, start_elem+num_elems-1);
| return MB_SUCCESS;
| This does call update_adjacencies (readiface is my instance of
| ReadUtilIface).
| -Chris
| On Mon, Oct 14, 2013 at 3:21 PM, Iulian Grindeanu <
| iulian at mcs.anl.gov > wrote:
| | Hello,
| | Did you call ReadUtil::update_adjacencies?
| | If you create some elements, when you do the first adjacency call,
| | the internal adjacencies are created.
| | If you create more elements after the first adjacency call, you
| | have
| | to call "update_adjacencies" for the new elements created,
| | otherwise
| | the up-vertex adjacencies are not updated.
| | This is my guess, it is hard to figure why it is not working for
| | you
| | with the limited info you sent :(
| | Best Regards,
| | Iulian
| | | Hey MOAB-Dev,
| | | I am having trouble creating AEntities for a simple 2D planar
| | | mesh.
| | | I
| | | adapted ReadTemplate.cpp to create a mesh generator and it
| | | appears
| | | to be working fine (vertices are all present with correct
| | | vertex-vertex and vertex-face adjacencies and positions, faces
| | | are
| | | all present with correct vertex connectivity). However, when I
| | | try
| | | to create AEntities (ie edges) using the following code (iface is
| | | my
| | | Core instance):
| | | Range verts;
| | | result = iface->get_entities_by_type(0, MBVERTEX, verts);
| | | result = MeshTopoUtil(iface).construct_aentities(verts);
| | | //get edge entities, by type
| | | Range edges;
| | | rval = iface->get_entities_by_type(0, MBEDGE, edges);
| | | assert(rval == MB_SUCCESS);
| | | cout << "Number of edges is " << edges.size() << endl;
| | | I get the following output:
| | | Number of edges is 0
| | | Also, attempting to get vertex-edge adjacencies or bridge
| | | adjacencies
| | | through edges returns null sets.
| | | Any ideas as to what is going wrong?
| | | -Chris
| | | Chris Eldred
| | | DOE Computational Science Graduate Fellow
| | | Graduate Student, Atmospheric Science, Colorado State University
| | | B.S. Applied Computational Physics, Carnegie Mellon University,
| | | 2009
| | | chris.eldred at gmail.com / celdred at atmos.colostate.edu
| Chris Eldred
| B.S. Applied Computational Physics, Carnegie Mellon University, 2009
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20131014/e20097be/attachment-0001.html>
