[MOAB-dev] commit/MOAB: 11 new changesets
    commits-noreply at bitbucket.org
    Wed Oct  2 11:38:42 CDT 2013
11 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/5012686b4467/
Changeset:   5012686b4467
Branch:      None
User:        tautges
Date:        2013-09-12 23:29:44
Summary:     Merged fathomteam/moab into master
Affected #:  81 files
diff --git a/.gitignore b/.gitignore
index 967aaa7..d3721c3 100644
--- a/.gitignore
+++ b/.gitignore
@@ -1,99 +1,132 @@
-MOABConfig.cmake
-moab.files
-config/test-driver
-moab.config
-moab.includes
-moab.creator*
-*.ccm
-*.cub
+*.a
 aclocal.m4
 autom4te.cache/
-config.h
-config.h.in
-config.log
-config.lt
-config.status
+bin
+bin/*
+*.ccm
 config/config.guess
 config/config.sub
 config/depcomp
+config.h
+config.h.in
 config/install-sh
 config/libtool.m4
+config.log
+config.lt
 config/ltmain.sh
+config/lt~obsolete.m4
 config/ltoptions.m4
 config/ltsugar.m4
 config/ltversion.m4
-config/lt~obsolete.m4
 config/missing
+config.status
+config/test-driver
 configure
+.cproject
+*.cub
+.deps
 doc/config.tex
 doc/dev.dox
-doc/user.dox
 doc/user/*
+doc/user.dox
 examples/examples.make
+examples/FileRead
+examples/GeomSetHierarchy
+examples/GetEntities
+examples/*.h5m
+examples/HelloMoabPar
+examples/itaps/FindConnectF
+examples/itaps/ListSetsNTagsCXX
+examples/itaps/ListSetsNTagsF90
+examples/itaps/TagIterateC
+examples/itaps/TagIterateF
+examples/KDTree
+examples/ObbTree
+examples/ReduceExchangeTags
+examples/SetsNTags
+examples/SkinMesh
+examples/SurfArea
+examples/TestExodusII
+include
+include/*
 itaps/iBase_f.h
 itaps/igeom/FBiGeom-Defs.inc
+itaps/igeom/FBiGeom_protos.h
+itaps/igeom/testgeom
+itaps/igeom/testSmooth2
+itaps/igeom/testSmoothGeom
+itaps/imesh/FindAdjacencyF90
 itaps/imesh/iMesh-Defs.inc
+itaps/imesh/iMesh_extensions_protos.h
 itaps/imesh/iMeshP_extensions_protos.h
 itaps/imesh/iMeshP_protos.h
-itaps/imesh/iMesh_extensions_protos.h
 itaps/imesh/iMesh_protos.h
+itaps/imesh/MOAB_iMesh_extensions_tests
+itaps/imesh/MOAB_iMeshP_unit_tests
+itaps/imesh/MOAB_iMesh_unit_tests
+itaps/imesh/partest
+itaps/imesh/ScdMeshF77
+itaps/imesh/ScdMeshF90
+itaps/imesh/testc_cbind
+*.la
+*.la
+*.lai
+lib
+lib/*
+.libs
 libtool
+*.lo
+*.log
+makefile
+Makefile
+*/Makefile
+*/**/Makefile
+*/**/Makefile.in
+*/Makefile.in
+Makefile.in
+moab.config
+MOABConfig.cmake
+moab.creator*
+moab.files
+moab.includes
 moab.make
+*.o
+.project
+*.rej
+share/*
+share/doc/moab
+share/man/man1
+*.so
 src/FCDefs.h
+src/io/mhdf/h5minfo
+src/io/mhdf/h5mvalidate
 src/MBCN_protos.h
-src/MOAB_FCDefs.h
 src/moab/EntityHandle.hpp
-src/moab/Version.h
+src/MOAB_FCDefs.h
 src/moab/stamp-h2
 src/moab/stamp-h3
+src/moab/Version.h
 src/parallel/moab_mpi_config.h
 src/parallel/stamp-h4
 src/stamp-h5
 stamp-h1
-tools/mbcoupler/tests/
-tools/mbzoltan/Config.moab
-tools/vtkMOABReader/CMakeLists.txt
-tools/vtkMOABReaderNew/CMakeLists.txt
-.deps
-Makefile.in
-Makefile
-*/Makefile.in
-*/Makefile
-*/**/Makefile.in
-*/**/Makefile
-.libs
-*.o
-*.log
-*.lo
-*.la
-*.a
-*.so
-include/*
-lib/*
-share/*
-bin/*
-examples/HelloMoabPar
-examples/TestExodusII
-itaps/igeom/FBiGeom_protos.h
-itaps/igeom/testSmooth2
-itaps/igeom/testSmoothGeom
-itaps/igeom/testgeom
-itaps/imesh/FindAdjacencyF90
-itaps/imesh/MOAB_iMeshP_unit_tests
-itaps/imesh/ScdMeshF77
-itaps/imesh/ScdMeshF90
-itaps/imesh/partest
 test/adaptive_kd_tree_tests
 test/bsp_tree_poly_test
 test/bsp_tree_test
-test/*.gen
+test/CMakeLists.txt
 test/coords_connect_iterate
 test/cropvol_test
 test/dual/dual_test
+test/elem_eval_test
 test/file_options_test
+test/*.g
+test/*.g
+test/*.gen
+test/*.gen
 test/geom_util_test
 test/gttool_test
+test/gttool_test
 test/h5file/dump_sets
 test/h5file/h5legacy
 test/h5file/h5partial
@@ -102,13 +135,14 @@ test/h5file/h5regression
 test/h5file/h5sets_test
 test/h5file/h5test
 test/h5file/h5varlen
-test/*.g
 test/homxform_test
+test/io/*.ccmg
+test/io/ccmio_test
 test/io/cub_file_test
 test/io/exodus_test
+test/io/*.g
 test/io/gmsh_test
 test/io/ideas_test
-test/io/*.g
 test/io/nastran_test
 test/io/read_cgm_test
 test/io/read_nc
@@ -133,7 +167,6 @@ test/obb_test
 test/oldinc/test_oldinc
 test/read_mpas_nc
 test/parallel/*.h5m
-test/parallel/*.vtk
 test/parallel/mbparallelcomm_test
 test/parallel/mhdf_parallel
 test/parallel/mpastrvpart
@@ -142,6 +175,8 @@ test/parallel/par_intx_sph
 test/parallel/parallel_hdf5_test
 test/parallel/parallel_unit_tests
 test/parallel/parallel_write_test
+test/parallel/par_coupler_test
+test/parallel/par_intx_sph
 test/parallel/parmerge
 test/parallel/partcheck
 test/parallel/pcomm_serial
@@ -152,39 +187,68 @@ test/parallel/scdtest
 test/parallel/structured3
 test/parallel/uber_parallel_test
 test/parallel/ucdtrvpart
+test/parallel/*.vtk
 test/perf/adj_time
 test/perf/perf
 test/perf/perftool
+test/perf/point_in_elem
+test/perf/runtest
 test/perf/seqperf
 test/perf/tstt_perf_binding
+test/perf/point_location/elem_eval_time
+test/perf/point_location/point_location
 test/range_test
 test/reorder_test
 test/scdseq_test
 test/scd_test_partn
 test/seq_man_test
+test/spatial_locator_test
+test/test_boundbox
 test/tag_test
 test/test_adj
 test/test_prog_opt
+test/TestRunner.hpp
 test/var_len_test
 test/var_len_test_no_template
 test/xform_test
+tools/dagmc/dagmc_preproc
 tools/dagmc/pt_vol_test
+tools/dagmc/quads_to_tris
 tools/dagmc/ray_fire_test
 tools/dagmc/test_geom
 tools/dagmc/update_coords
+tools/hexmodops
+tools/mbconvert
 tools/mbcoupler/*.h5m
+tools/mbcoupler/*.g
+tools/mbcoupler/tests/
 tools/mbcslam/case1_test
 tools/mbcslam/intersect1.h5m
-tools/mbcslam/intx.vtk
 tools/mbcslam/intx1.vtk
 tools/mbcslam/intx_in_plane_test
 tools/mbcslam/intx_on_sphere_test
+tools/mbcslam/intx.vtk
 tools/mbcslam/lagr.h5m
-tools/mbcslam/spec_visu_test
 tools/mbcslam/spectral.vtk
+tools/mbcslam/spec_visu_test
 tools/mbcslam/spherical_area_test
-.project
-.cproject
-examples/*.h5m
-examples/ReduceExchangeTags
+tools/mbdepth
+tools/mbgsets
+tools/mbmem
+tools/mbsize
+tools/mbskin
+tools/mbsurfplot
+tools/mbtagprop
+tools/mbzoltan/Config.moab
+tools/spheredecomp
+tools/vtkMOABReader/CMakeLists.txt
+tools/vtkMOABReaderNew/CMakeLists.txt
+tools/vtkMOABReaderNew/CMakeCache.txt
+tools/vtkMOABReaderNew/CMakeFiles/*
+tools/vtkMOABReaderNew/cmake_install.cmake
+tools/vtkMOABReaderNew/vtkMoabReaderPlugin.qrc
+tools/vtkMOABReaderNew/vtkMoabReaderPluginInit.cxx
+tools/vtkMOABReaderNew/vtkMoabReaderPlugin_Plugin.cxx
+tools/vtkMOABReaderNew/vtkMoabReaderPlugin_Plugin.h
+tools/vtkMOABReaderNew/vtkSMvtkMoabReaderPluginInstantiator.cxx
+tools/vtkMOABReaderNew/vtkSMvtkMoabReaderPluginInstantiator.h
diff --git a/itaps/igeom/FBiGeom_MOAB.cpp b/itaps/igeom/FBiGeom_MOAB.cpp
index cb889bd..7fcd2b1 100644
--- a/itaps/igeom/FBiGeom_MOAB.cpp
+++ b/itaps/igeom/FBiGeom_MOAB.cpp
@@ -4,7 +4,7 @@
 #include "moab/GeomTopoTool.hpp"
 #include "moab/OrientedBoxTreeTool.hpp"
 #include "moab/CartVect.hpp"
-#include "FileOptions.hpp"
+#include "moab/FileOptions.hpp"
 #include "MBTagConventions.hpp"
 #include <stdlib.h>
 #include <cstring>
diff --git a/itaps/imesh/iMeshP_MOAB.cpp b/itaps/imesh/iMeshP_MOAB.cpp
index e554fba..51254ca 100644
--- a/itaps/imesh/iMeshP_MOAB.cpp
+++ b/itaps/imesh/iMeshP_MOAB.cpp
@@ -4,7 +4,7 @@
 #include "moab/Range.hpp"
 #include "moab/CN.hpp"
 #include "moab/MeshTopoUtil.hpp"
 #include "moab/ParallelComm.hpp"
 #include "MBParallelConventions.h"
 #include "MBIter.hpp"
diff --git a/itaps/imesh/iMesh_MOAB.cpp b/itaps/imesh/iMesh_MOAB.cpp
index d09fec1..68c0b72 100644
--- a/itaps/imesh/iMesh_MOAB.cpp
+++ b/itaps/imesh/iMesh_MOAB.cpp
@@ -4,7 +4,7 @@
 #include "moab/ScdInterface.hpp"
 #include "iMesh_MOAB.hpp"
@@ -3303,7 +3303,7 @@ void iMesh_createStructuredMesh(iMesh_Instance instance,
   ScdBox *scd_box;
   rval = scdi->construct_box(HomCoord(local_dims[0], local_dims[1], (-1 != local_dims[2] ? local_dims[2] : 0), 1),
                              HomCoord(local_dims[3], local_dims[4], (-1 != local_dims[5] ? local_dims[5] : 0), 1),
-                             NULL, 0, scd_box);
+                             NULL, 0, scd_box, NULL, NULL, (vert_gids ? true : false));
   CHKERR(rval, "Trouble creating scd vertex sequence.");
     // set the global box parameters
diff --git a/src/Core.cpp b/src/Core.cpp
index 57ff342..476fdca 100644
--- a/src/Core.cpp
+++ b/src/Core.cpp
@@ -83,7 +83,7 @@
 #include "ExoIIUtil.hpp"
 #include "EntitySequence.hpp"
 #ifdef LINUX
 # include <dlfcn.h>
 # include <dirent.h>
@@ -1153,11 +1153,11 @@ ErrorCode Core::get_connectivity_by_type(const EntityType type,
 ErrorCode  Core::get_connectivity(const EntityHandle *entity_handles,
                                       const int num_handles,
                                       Range &connectivity,
-                                      bool topological_connectivity) const
+                                      bool corners_only) const
   std::vector<EntityHandle> tmp_connect;
   ErrorCode result = get_connectivity(entity_handles, num_handles, tmp_connect,
-                                        topological_connectivity);
+                                        corners_only);
   if (MB_SUCCESS != result) return result;
   std::sort( tmp_connect.begin(), tmp_connect.end() );
@@ -1169,7 +1169,7 @@ ErrorCode  Core::get_connectivity(const EntityHandle *entity_handles,
                                   std::vector<EntityHandle> &connectivity,
-                                  bool topological_connectivity,
+                                  bool corners_only,
                                   std::vector<int> *offsets) const
   connectivity.clear(); // this seems wrong as compared to other API functions,
@@ -1182,7 +1182,7 @@ ErrorCode  Core::get_connectivity(const EntityHandle *entity_handles,
   int len;
   if (offsets) offsets->push_back(0);
   for (int i = 0; i < num_handles; ++i) {
-    rval = get_connectivity( entity_handles[i], conn, len, topological_connectivity, &tmp_storage );
+    rval = get_connectivity( entity_handles[i], conn, len, corners_only, &tmp_storage );
     if (MB_SUCCESS != rval)
       return rval;
     connectivity.insert( connectivity.end(), conn, conn + len );
@@ -1195,7 +1195,7 @@ ErrorCode  Core::get_connectivity(const EntityHandle *entity_handles,
 ErrorCode Core::get_connectivity(const EntityHandle entity_handle,
                                      const EntityHandle*& connectivity,
                                      int& number_nodes,
                                      std::vector<EntityHandle>* storage) const
   ErrorCode status;
@@ -1222,7 +1222,7 @@ ErrorCode Core::get_connectivity(const EntityHandle entity_handle,
   return static_cast<const ElementSequence*>(seq)->get_connectivity(entity_handle,
                                                               connectivity,
                                                               number_nodes,
-                                                              topological_connectivity,
+                                                              corners_only,
                                                               storage);
@@ -2896,9 +2896,11 @@ ErrorCode Core::list_entity(const EntityHandle entity) const
   if (multiple != 0)
     std::cout << "   (MULTIPLE = " << multiple << ")" << std::endl;
+  result = print_entity_tags(std::string(), entity, MB_TAG_DENSE);
   std::cout << std::endl;
-  return MB_SUCCESS;
+  return result;
 ErrorCode Core::convert_entities( const EntityHandle meshset,
@@ -3598,16 +3600,21 @@ void Core::print(const EntityHandle ms_handle, const char *prefix,
     // print all sparse tags
+  print_entity_tags(indent_prefix, ms_handle, MB_TAG_SPARSE);
+ErrorCode Core::print_entity_tags(std::string indent_prefix, const EntityHandle handle, TagType tp) const
   std::vector<Tag> set_tags;
-  ErrorCode result = this->tag_get_tags_on_entity(ms_handle, set_tags);
-  std::cout << indent_prefix << "Sparse tags:" << std::endl;
+  ErrorCode result = this->tag_get_tags_on_entity(handle, set_tags);
+  std::cout << indent_prefix << (tp == MB_TAG_SPARSE ? "Sparse tags:" : "Dense tags:") << std::endl;
   indent_prefix += "  ";
   for (std::vector<Tag>::iterator vit = set_tags.begin();
        vit != set_tags.end(); vit++) {
     TagType this_type;
     result = this->tag_get_type(*vit, this_type);
-    if (MB_SUCCESS != result || MB_TAG_SPARSE != this_type) continue;
+    if (MB_SUCCESS != result || tp != this_type) continue;
     DataType this_data_type;
     result = this->tag_get_data_type(*vit, this_data_type);
     int this_size;
@@ -3622,7 +3629,7 @@ void Core::print(const EntityHandle ms_handle, const char *prefix,
     if (MB_SUCCESS != result) continue;
     switch (this_data_type) {
       case MB_TYPE_INTEGER:
-        result = this->tag_get_data(*vit, &ms_handle, 1, &int_vals[0]);
+        result = this->tag_get_data(*vit, &handle, 1, &int_vals[0]);
         std::cout << indent_prefix << tag_name << " = ";
         if (this_size < 10)
@@ -3631,7 +3638,7 @@ void Core::print(const EntityHandle ms_handle, const char *prefix,
         break;
       case MB_TYPE_DOUBLE:
-        result = this->tag_get_data(*vit, &ms_handle, 1, &dbl_vals[0]);
+        result = this->tag_get_data(*vit, &handle, 1, &dbl_vals[0]);
         if (this_size < 10)
@@ -3640,7 +3647,7 @@ void Core::print(const EntityHandle ms_handle, const char *prefix,
         break;
       case MB_TYPE_HANDLE:
-        result = this->tag_get_data(*vit, &ms_handle, 1, &hdl_vals[0]);
+        result = this->tag_get_data(*vit, &handle, 1, &hdl_vals[0]);
         if (this_size < 10)
@@ -3651,7 +3658,7 @@ void Core::print(const EntityHandle ms_handle, const char *prefix,
       case MB_TYPE_OPAQUE:
         if (NAME_TAG_SIZE == this_size) {
           char dum_tag[NAME_TAG_SIZE];
-          result = this->tag_get_data(*vit, &ms_handle, 1, &dum_tag);
+          result = this->tag_get_data(*vit, &handle, 1, &dum_tag);
             // insert NULL just in case there isn't one
           dum_tag[NAME_TAG_SIZE-1] = '\0';
@@ -3662,6 +3669,8 @@ void Core::print(const EntityHandle ms_handle, const char *prefix,
         break;
+  return MB_SUCCESS;
 ErrorCode Core::check_adjacencies()
diff --git a/src/FileOptions.cpp b/src/FileOptions.cpp
index f2a4477..380a491 100644
--- a/src/FileOptions.cpp
+++ b/src/FileOptions.cpp
@@ -18,7 +18,7 @@
  *\date 2007-08-21
 #include <ctype.h>
 #include <stdlib.h>
diff --git a/src/FileOptions.hpp b/src/FileOptions.hpp
deleted file mode 100644
index 85b3eef..0000000
--- a/src/FileOptions.hpp
+++ /dev/null
@@ -1,248 +0,0 @@
- * MOAB, a Mesh-Oriented datABase, is a software component for creating,
- * storing and accessing finite element mesh data.
- * Copyright 2004 Sandia Corporation.  Under the terms of Contract
- * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
- * retains certain rights in this software.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
-/**\file FileOptions.hpp
- *\author Jason Kraftcheck (kraftche at cae.wisc.edu)
- *\date 2007-08-21
-#ifndef FILE_OPTIONS_HPP
-#define FILE_OPTIONS_HPP
-#include <string>
-#include <vector>
-#include "moab/Types.hpp"
-namespace moab {
-/**\brief Parse options string passed to file IO routines
- * This is a utility class used by file-IO-related code to
- * parse the options string passed to Core::load_file and
- * Core::write_file
-class FileOptions {
-public:
-  /*\param options_string The concatenation of a list of
-   *          options, separated either by the default separator
-   *          (semicolon) with a custom separator specified at
-   *          the beginning of the string (semicolon followed by
-   *          destired separator character.)
-  FileOptions( const char* option_string );
-  FileOptions( const FileOptions& copy );
-  FileOptions& operator=( const FileOptions& copy );
-  ~FileOptions();
-  /**\brief Check for option with no value
-   * Check for an option w/out a value.
-   *\param name The option name
-   *\return - MB_SUCCESS if option is found
-   *        - MB_TYPE_OUT_OF_RANGE if options is found, but has value
-   *        - MB_ENTITY_NOT_FOUND if option is not found.
-  ErrorCode get_null_option( const char* name ) const;
-  /**\brief Check for option with boolean (true/false, yes/no) value.
-   * Check for an option with a true/false value.  Allowable values
-   * are "true", "false", "yes", "no", "1", "0", "on", "off".
-   *\param default_value The value to return if the option is not specified.
-   *\param value The resulting value.  This argument is set to the passed
-   *            default value if the option is not found.
-   *\return - MB_TYPE_OUT_OF_RANGE if options is found, but has an invalid value
-   *        - MB_SUCCESS otherwise
-  ErrorCode get_toggle_option( const char* name,
-                               bool default_value,
-                               bool& value ) const;
-  /**\brief Check for option with an integer value.
-   * Check for an option with an integer value
-   *\param value Output. The value.
-   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not have an integer value
-  ErrorCode get_int_option( const char* name, int& value ) const;
-  /**\brief Check for option with an integer value.  Accept option with no value.
-   * Check for an option with an integer value.
-   * If the option is found but has no value specified, then
-   * pass back the user-specified default value.
-   *\NOTE:  This function will not pass back the default_val, but will instead
-   *        return MB_ENTITY_NOT_FOUND if the option is not specified at all.
-   *        The default value is returned only when the option is specified,
-   *        but is specified w/out a value.
-   *\param default_val The default value for the option.
-   *        - MB_TYPE_OUT_OF_RANGE if options is found but has a value that cannot be parsed as an int
-  ErrorCode get_int_option( const char* name, int default_val, int& value ) const;
-  /**\brief Check for option with a double value.
-   * Check for an option with a double value
-   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not have a double value
-  ErrorCode get_real_option( const char* name, double& value ) const;
-  /**\brief Check for option with any value.
-   * Check for an option with any value.
-   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not have a value
-  ErrorCode get_str_option( const char* name, std::string& value ) const;
-   *\param value The option value, or an empty string if no value.
-   *\return MB_SUCCESS or MB_ENTITY_NOT_FOUND
-  ErrorCode get_option( const char* name, std::string& value ) const;
-  /**\brief Check the string value of an option
-   * Check which of a list of possible values a string option contains.
-   *\param values A NULL-terminated array of C-style strings enumerating
-   *              the possible option values.
-   *\param index  Output: The index into <code>values</code> for the
-   *              option value.
-   *\return MB_SUCCESS if matched name and value.
-   *        MB_ENTITY_NOT_FOUND if the option was not specified
-   *        MB_FAILURE if the option value is not in the input <code>values</code> array.
-  ErrorCode match_option( const char* name, const char* const* values, int& index ) const;
-  /**\brief Check if an option matches a string value
-   * Check if the value for an option is the passed string.
-   *\param value The expected value.
-   *        MB_FAILURE if the option value doesn't match the passed string/
-  ErrorCode match_option( const char* name, const char* value) const;
-  /**\brief Check for option for which the value is a list of ints
-   * Check for an option which is an int list.  The value is expected to
-   * be a comma-separated list of int ranges, where an int range can be
-   * either a single integer value or a range of integer values separated
-   * by a dash ('-').
-   *\param values Output. The list of integer values.
-   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not contain an ID list
-  ErrorCode get_ints_option( const char* name, std::vector<int>& values) const;
-  /**\brief Check for option for which the value is a list of doubles
-   * Check for an option which is a double list.  The value is expected to
-   * be a comma-separated list of double values
-   *\param values Output. The list of double values.
-  ErrorCode get_reals_option( const char* name, std::vector<double>& values) const;
-  /**\brief Check for option for which the value is a list of strings
-   * Check for an option which is a string list.  The value is expected to
-   * be a comma-separated list of string values, with no embedded spaces or commas.
-   *\param values Output. The list of string values.
-   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not contain a string list
-  ErrorCode get_strs_option( const char* name, std::vector<std::string>& values) const;
-  /** number of options */
-  inline unsigned size() const
-    { return mOptions.size(); }
-  /** true if no options */
-  inline bool empty() const
-    { return mOptions.empty(); }
-  /** Get list of options */
-  void get_options( std::vector<std::string>& list ) const;
-  /** Check if all options have been looked at */
-  bool all_seen() const;
-  /** Mark all options as seen.  USed for non-root procs during bcast-delete read */
-  void mark_all_seen() const;
-  /** Get first unseen option */
-  ErrorCode get_unseen_option( std::string& value ) const;
-private:
-  ErrorCode get_option( const char* name, const char*& value) const;
-  char* mData;
-  std::vector<const char*> mOptions;
-  mutable std::vector<bool> mSeen;
-    /** Case-insensitive compare of name with option value. */
-  static bool compare( const char* name, const char* option );
-} // namespace moab
-#endif
diff --git a/src/Makefile.am b/src/Makefile.am
index 7cebb7c..ab5077a 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -41,6 +41,7 @@ libMOAB_la_SOURCES = \
   BitPage.hpp \
   BitTag.cpp \
   BitTag.hpp \
+  BoundBox.cpp \
   BSPTree.cpp \
   BSPTreePoly.cpp \
   CN.cpp \
@@ -57,7 +58,6 @@ libMOAB_la_SOURCES = \
   Factory.cpp \
   FBEngine.cpp \
   FileOptions.cpp \
-  FileOptions.hpp \
   GeomUtil.cpp \
   GeomTopoTool.cpp \
   HigherOrderFactory.cpp \
@@ -75,16 +75,10 @@ libMOAB_la_SOURCES = \
   OrientedBox.cpp \
   OrientedBox.hpp \
   OrientedBoxTreeTool.cpp \
-  moab/point_locater/lotte/minmax.h \
-  moab/point_locater/lotte/extrafindpt.h \
   lotte/poly.c \
-  moab/point_locater/lotte/poly.h \
   lotte/findpt.c \
-  moab/point_locater/lotte/findpt.h \
   lotte/errmem.c \
-  moab/point_locater/lotte/errmem.h \
   lotte/tensor.c \
-  moab/point_locater/lotte/tensor.h \
   PolyElementSeq.cpp \
   PolyElementSeq.hpp \
   ProgOptions.cpp \
@@ -146,12 +140,14 @@ libMOAB_la_SOURCES = \
 # The list of header files which are to be installed
 nobase_libMOAB_la_include_HEADERS = \
   moab/AdaptiveKDTree.hpp \
+  moab/BoundBox.hpp \
   moab/BSPTree.hpp \
   moab/BSPTreePoly.hpp \
   moab/CN.hpp \
   moab/CartVect.hpp \
   moab/Compiler.hpp \
   moab/Core.hpp \
+  moab/CpuTimer.hpp \
   moab/DualTool.hpp \
   moab/Error.hpp \
   moab/GeomTopoTool.hpp \
@@ -160,6 +156,7 @@ nobase_libMOAB_la_include_HEADERS = \
   moab/EntityType.hpp \
   moab/EntityHandle.hpp \
   moab/FBEngine.hpp \
+  moab/FileOptions.hpp \
   moab/Forward.hpp \
   moab/GeomUtil.hpp \
   moab/Interface.hpp \
@@ -172,10 +169,6 @@ nobase_libMOAB_la_include_HEADERS = \
   moab/point_locater/element_maps/linear_tet_map.hpp  \
   moab/point_locater/element_maps/spectral_hex_map.hpp  \
   moab/point_locater/element_maps/quadratic_hex_map.hpp  \
-  moab/point_locater/lotte/types.h  \
   moab/point_locater/point_locater.hpp \
   moab/point_locater/parametrizer.hpp \
   moab/Matrix3.hpp \
diff --git a/src/ScdInterface.cpp b/src/ScdInterface.cpp
index 1441e51..4dd7c5b 100644
--- a/src/ScdInterface.cpp
+++ b/src/ScdInterface.cpp
@@ -145,11 +145,13 @@ ErrorCode ScdInterface::construct_box(HomCoord low, HomCoord high, const double
   rval = create_scd_sequence(low, high, MBVERTEX, 0, new_box);
   ERRORR(rval, "Trouble creating scd vertex sequence.");
-  if (num_coords && coords) {
-      // set the vertex coordinates
-    double *xc, *yc, *zc;
-    rval = new_box->get_coordinate_arrays(xc, yc, zc);
-    ERRORR(rval, "Couldn't get vertex coordinate arrays.");
+    // set the vertex coordinates
+  double *xc, *yc, *zc;
+  rval = new_box->get_coordinate_arrays(xc, yc, zc);
+  ERRORR(rval, "Couldn't get vertex coordinate arrays.");
+  if (coords && num_coords) {
     unsigned int i = 0;
     for (int kl = low[2]; kl <= high[2]; kl++) {
@@ -165,6 +167,23 @@ ErrorCode ScdInterface::construct_box(HomCoord low, HomCoord high, const double
+  else {
+    unsigned int i = 0;
+    for (int kl = low[2]; kl <= high[2]; kl++) {
+      for (int jl = low[1]; jl <= high[1]; jl++) {
+        for (int il = low[0]; il <= high[0]; il++) {
+          xc[i] = (double) il;
+          if (new_box->box_size()[1])
+            yc[i] = (double) jl;
+          else yc[i] = 0.0;
+          if (new_box->box_size()[2])
+            zc[i] = (double) kl;
+          else zc[i] = 0.0;
+          i++;
     // create element sequence
   Core *mbcore = dynamic_cast<Core*>(mbImpl);
diff --git a/src/io/NCHelperEuler.cpp b/src/io/NCHelperEuler.cpp
index e5b3f08..ca86127 100644
--- a/src/io/NCHelperEuler.cpp
+++ b/src/io/NCHelperEuler.cpp
@@ -1,6 +1,6 @@
 #include "NCHelperEuler.hpp"
 #include "moab/ReadUtilIface.hpp"
 #include <cmath>
 #include <sstream>
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index dd555ff..a234450 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -1,6 +1,6 @@
 #include "NCHelperFV.hpp"
 #include <cmath>
 #include <sstream>
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index f883bd7..4f2ac51 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -1,6 +1,6 @@
 #include "NCHelperHOMME.hpp"
 #include "moab/SpectralMeshTool.hpp"
 #include <cmath>
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 45d1b00..c0605e8 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -1,6 +1,6 @@
 #include "NCHelperMPAS.hpp"
diff --git a/src/io/ReadABAQUS.cpp b/src/io/ReadABAQUS.cpp
index 1c44057..b3a37d0 100644
--- a/src/io/ReadABAQUS.cpp
+++ b/src/io/ReadABAQUS.cpp
@@ -36,7 +36,7 @@
 #include "AffineXform.hpp"
 // #include "abaqus_order.h"
 namespace moab {
diff --git a/src/io/ReadCCMIO.cpp b/src/io/ReadCCMIO.cpp
index 3161425..ec53b6c 100644
--- a/src/io/ReadCCMIO.cpp
+++ b/src/io/ReadCCMIO.cpp
@@ -11,7 +11,7 @@
 #include "Internals.hpp"
 #include "ReadCCMIO.hpp"
diff --git a/src/io/ReadCGM.cpp b/src/io/ReadCGM.cpp
index 02f748e..a610d4a 100644
--- a/src/io/ReadCGM.cpp
+++ b/src/io/ReadCGM.cpp
@@ -37,7 +37,7 @@
 #include "moab/Interface.hpp"
diff --git a/src/io/ReadDamsel.cpp b/src/io/ReadDamsel.cpp
index 8d1bcfe..f02f0ea 100644
--- a/src/io/ReadDamsel.cpp
+++ b/src/io/ReadDamsel.cpp
@@ -13,7 +13,7 @@
 #include "moab/Error.hpp"
diff --git a/src/io/ReadGCRM.cpp b/src/io/ReadGCRM.cpp
index 19d789e..0b86bd6 100644
--- a/src/io/ReadGCRM.cpp
+++ b/src/io/ReadGCRM.cpp
@@ -15,7 +15,7 @@
 #include "moab/ReaderIface.hpp"
 #define ERRORR(rval, str) \
     if (MB_SUCCESS != rval) {readMeshIface->report_error("%s", str); return rval;}
diff --git a/src/io/ReadHDF5.cpp b/src/io/ReadHDF5.cpp
index 916b69a..c707380 100644
--- a/src/io/ReadHDF5.cpp
+++ b/src/io/ReadHDF5.cpp
@@ -38,7 +38,7 @@
 #include "ReadHDF5.hpp"
 #ifdef HDF5_PARALLEL
 #  include <H5FDmpi.h>
 #  include <H5FDmpio.h>
diff --git a/src/io/ReadMCNP5.cpp b/src/io/ReadMCNP5.cpp
index c05ed41..b290f75 100644
--- a/src/io/ReadMCNP5.cpp
+++ b/src/io/ReadMCNP5.cpp
@@ -18,7 +18,7 @@
 #include "Internals.hpp" // for MB_START_ID
 #include <iostream>
 #include <sstream>
diff --git a/src/io/ReadNASTRAN.cpp b/src/io/ReadNASTRAN.cpp
index 6534417..47a8780 100644
--- a/src/io/ReadNASTRAN.cpp
+++ b/src/io/ReadNASTRAN.cpp
@@ -27,7 +27,7 @@
 #include "FileTokenizer.hpp"
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index 50225df..a27a89d 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -3,7 +3,7 @@
   if (MB_SUCCESS != rval) { readMeshIface->report_error("%s", str); return rval; }
diff --git a/src/io/ReadNCDF.cpp b/src/io/ReadNCDF.cpp
index c69b3b5..01e98aa 100644
--- a/src/io/ReadNCDF.cpp
+++ b/src/io/ReadNCDF.cpp
@@ -38,7 +38,7 @@
 #include "exodus_order.h"
 #include "moab/AdaptiveKDTree.hpp"
diff --git a/src/io/ReadSTL.cpp b/src/io/ReadSTL.cpp
index 4ba085d..59bd80b 100644
--- a/src/io/ReadSTL.cpp
+++ b/src/io/ReadSTL.cpp
@@ -25,7 +25,7 @@
 #include "SysUtil.hpp"
 #include <errno.h>
diff --git a/src/io/ReadSmf.cpp b/src/io/ReadSmf.cpp
index 0970d71..eac232e 100644
--- a/src/io/ReadSmf.cpp
+++ b/src/io/ReadSmf.cpp
@@ -28,7 +28,7 @@
 static inline int streq(const char *a,const char *b) { return strcmp(a,b)==0; }
diff --git a/src/io/ReadTemplate.cpp b/src/io/ReadTemplate.cpp
index 309a71e..97f70ce 100644
--- a/src/io/ReadTemplate.cpp
+++ b/src/io/ReadTemplate.cpp
@@ -8,7 +8,7 @@
 #include <cstdio>
 #include <assert.h>
diff --git a/src/io/ReadTetGen.cpp b/src/io/ReadTetGen.cpp
index 72197fb..1d6609a 100644
--- a/src/io/ReadTetGen.cpp
+++ b/src/io/ReadTetGen.cpp
@@ -2,7 +2,7 @@
 #include <iostream>
 #include <fstream>
diff --git a/src/io/ReadVtk.cpp b/src/io/ReadVtk.cpp
index ac3b9e4..2936a85 100644
--- a/src/io/ReadVtk.cpp
+++ b/src/io/ReadVtk.cpp
@@ -28,7 +28,7 @@
 #include "VtkUtil.hpp"
diff --git a/src/io/Tqdcfr.cpp b/src/io/Tqdcfr.cpp
index b930ab6..717f43a 100644
--- a/src/io/Tqdcfr.cpp
+++ b/src/io/Tqdcfr.cpp
@@ -16,7 +16,7 @@
 #include "Tqdcfr.hpp"
 #include "moab/Core.hpp"
 #include <iostream>
 #include <string>
diff --git a/src/io/WriteDamsel.hpp b/src/io/WriteDamsel.hpp
index 8902f08..fff9e8b 100644
--- a/src/io/WriteDamsel.hpp
+++ b/src/io/WriteDamsel.hpp
@@ -26,7 +26,7 @@
 #include "moab/WriterIface.hpp"
 #include "RangeSeqIntersectIter.hpp"
 #include "DamselUtil.hpp"
 #include "damsel.h"
diff --git a/src/io/WriteGmsh.cpp b/src/io/WriteGmsh.cpp
index aac3d38..7d4e2f7 100644
--- a/src/io/WriteGmsh.cpp
+++ b/src/io/WriteGmsh.cpp
@@ -5,7 +5,7 @@
 #include "moab/WriteUtilIface.hpp"
 #include "GmshUtil.hpp"
 #include <fstream>
diff --git a/src/io/WriteHDF5.cpp b/src/io/WriteHDF5.cpp
index 839c455..337cb96 100644
--- a/src/io/WriteHDF5.cpp
+++ b/src/io/WriteHDF5.cpp
@@ -48,17 +48,12 @@
 #include "moab/Version.h"
+#include "moab/CpuTimer.hpp"
 #include "IODebugTrack.hpp"
 #include "mhdf.h"
-#ifdef USE_MPI
-#define RUNTIME MPI_Wtime()
-#else
-#define RUNTIME (clock()/(double)CLOCKS_PER_SEC)
-#endif
 /* Access HDF5 file handle for debugging
 #include <H5Fpublic.h>
 struct file { uint32_t magic; hid_t handle; };
@@ -100,15 +95,6 @@ struct file { uint32_t magic; hid_t handle; };
 namespace moab {
-class CpuTimer {
-private:
-  double atBirth, atLast;
-public:
-  CpuTimer() : atBirth(RUNTIME), atLast(atBirth) {}
-  double since_birth() { return (atLast = RUNTIME) - atBirth; };
-  double elapsed() { double tmp = atLast; return (atLast = RUNTIME) - tmp; }
 template <typename T> inline
 void VALGRIND_MAKE_VEC_UNDEFINED( std::vector<T>& v ) {
     VALGRIND_MAKE_MEM_UNDEFINED( &v[0], v.size() * sizeof(T) );
@@ -601,7 +587,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
   topState.end(result);
   CHK_MB_ERR_0(result);
-  times[GATHER_TIME] = timer.elapsed();
+  times[GATHER_TIME] = timer.time_elapsed();
   //if (nodeSet.range.size() == 0)
   //  return error(MB_ENTITY_NOT_FOUND);
@@ -650,7 +636,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
     return error(result);
-  times[CREATE_TIME] = timer.elapsed();
+  times[CREATE_TIME] = timer.time_elapsed();
   dbgOut.tprint(1,"Writing Nodes.\n");
     // Write node coordinates
@@ -662,7 +648,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
-  times[COORD_TIME] = timer.elapsed();
+  times[COORD_TIME] = timer.time_elapsed();
   dbgOut.tprint(1,"Writing connectivity.\n");
@@ -674,7 +660,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
-  times[CONN_TIME] = timer.elapsed();
+  times[CONN_TIME] = timer.time_elapsed();
   dbgOut.tprint(1,"Writing sets.\n");
@@ -684,7 +670,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
   debug_barrier();
-  times[SET_TIME] = timer.elapsed();
+  times[SET_TIME] = timer.time_elapsed();
   dbgOut.tprint(1,"Writing adjacencies.\n");
     // Write adjacencies
@@ -701,7 +687,7 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
-  times[ADJ_TIME] = timer.elapsed();
+  times[ADJ_TIME] = timer.time_elapsed();
   dbgOut.tprint(1,"Writing tags.\n");
@@ -716,9 +702,9 @@ ErrorCode WriteHDF5::write_file_impl( const char* filename,
-  times[TAG_TIME] = timer.elapsed();
+  times[TAG_TIME] = timer.time_elapsed();
-  times[TOTAL_TIME] = timer.since_birth();
+  times[TOTAL_TIME] = timer.time_since_birth();
   if (cputime) {
     print_times( times );
@@ -1374,7 +1360,7 @@ ErrorCode WriteHDF5::write_sets( double* times )
     mhdf_closeData( filePtr, table, &status );
     CHK_MHDF_ERR_0(status);
-    times[SET_PARENT] = timer.elapsed();
+    times[SET_PARENT] = timer.time_elapsed();
     track.all_reduce();
@@ -1393,7 +1379,7 @@ ErrorCode WriteHDF5::write_sets( double* times )
-    times[SET_CHILD] = timer.elapsed();
+    times[SET_CHILD] = timer.time_elapsed();
     track.all_reduce();
@@ -1415,7 +1401,7 @@ ErrorCode WriteHDF5::write_sets( double* times )
-    times[SET_CONTENT] = timer.elapsed();
+    times[SET_CONTENT] = timer.time_elapsed();
     track.all_reduce();
   assert( ranged_sets.size() + null_stripped_sets.size() == set_sizes.size() );
@@ -1544,7 +1530,7 @@ ErrorCode WriteHDF5::write_sets( double* times )
-  times[SET_META] = timer.elapsed();
+  times[SET_META] = timer.time_elapsed();
   track_meta.all_reduce();
   return MB_SUCCESS;
@@ -1881,7 +1867,7 @@ ErrorCode WriteHDF5::write_tag( const TagDesc& tag_data,
   if (array_len == MB_VARIABLE_LENGTH && tag_data.write_sparse) {
     dbgOut.printf( 2, "Writing sparse data for var-len tag: \"%s\"\n", name.c_str() );
     rval = write_var_len_tag( tag_data, name, moab_type, hdf5_type, elem_size );
-    times[VARLEN_TAG_TIME] += timer.elapsed();
+    times[VARLEN_TAG_TIME] += timer.time_elapsed();
   else {
     int data_len = elem_size;
@@ -1890,7 +1876,7 @@ ErrorCode WriteHDF5::write_tag( const TagDesc& tag_data,
     if (tag_data.write_sparse) {
       dbgOut.printf( 2, "Writing sparse data for tag: \"%s\"\n", name.c_str() );
       rval = write_sparse_tag( tag_data, name, moab_type, hdf5_type, data_len );
-      times[SPARSE_TAG_TIME] += timer.elapsed();
+      times[SPARSE_TAG_TIME] += timer.time_elapsed();
     for (size_t i = 0; MB_SUCCESS == rval && i < tag_data.dense_list.size(); ++i) {
       const ExportSet* set = find( tag_data.dense_list[i] );
@@ -1901,7 +1887,7 @@ ErrorCode WriteHDF5::write_tag( const TagDesc& tag_data,
       rval = write_dense_tag( tag_data, *set, name, moab_type, hdf5_type, data_len );
       subState.end(rval);
-    times[DENSE_TAG_TIME] += timer.elapsed();
+    times[DENSE_TAG_TIME] += timer.time_elapsed();
   H5Tclose( hdf5_type );
diff --git a/src/io/WriteSTL.cpp b/src/io/WriteSTL.cpp
index 62644a6..45718d8 100644
--- a/src/io/WriteSTL.cpp
+++ b/src/io/WriteSTL.cpp
@@ -25,7 +25,7 @@
 #include <stdio.h>
diff --git a/src/io/WriteSmf.cpp b/src/io/WriteSmf.cpp
index 0a09b8b..9d7f5f0 100644
--- a/src/io/WriteSmf.cpp
+++ b/src/io/WriteSmf.cpp
@@ -40,7 +40,7 @@
 namespace moab {
diff --git a/src/io/WriteVtk.cpp b/src/io/WriteVtk.cpp
index 03e95e4..bfda520 100644
--- a/src/io/WriteVtk.cpp
+++ b/src/io/WriteVtk.cpp
@@ -41,7 +41,7 @@
 #define INS_ID(stringvar, prefix, id) \
diff --git a/src/lotte/errmem.c b/src/lotte/errmem.c
index 0196d83..b890bce 100644
--- a/src/lotte/errmem.c
+++ b/src/lotte/errmem.c
@@ -1,6 +1,7 @@
 #include <stdio.h>
 #include <stdlib.h>
 #include <stdarg.h>
+#include "moab/FindPtFuncs.h"
 void fail(const char *fmt, ...)
diff --git a/src/lotte/findpt.c b/src/lotte/findpt.c
index 00fe8b7..160c7ab 100644
--- a/src/lotte/findpt.c
+++ b/src/lotte/findpt.c
@@ -5,12 +5,10 @@
 #include <float.h>
 #include <string.h>  /* for memcpy */
-#include "errmem.h"
-#include "types.h"
-#include "minmax.h"
-#include "poly.h"
-#include "tensor.h"
-#include "extrafindpt.h"
+const unsigned opt_no_constraints_2 = 3+1;
+const unsigned opt_no_constraints_3 = 9+3+1;
    Lobatto Polynomial Bounds
@@ -484,14 +482,6 @@ static void obbox_free_3(obbox_data_3 *p)
   free(p);
-typedef struct {
-  real x[2], A[4], axis_bnd[4];
-} obbox_2;
-typedef struct {
-  real x[3], A[9], axis_bnd[6];
-} obbox_3;
 int obbox_axis_test_2(const obbox_2 *p, const real x[2])
   return (x[0]<p->axis_bnd[0] || x[0]>p->axis_bnd[1] ||
@@ -767,34 +757,6 @@ void obbox_calc_3(const obbox_data_3 *p, real tol,
-typedef struct {
-  unsigned hash_n;
-  real bnd[4]; /* bounds for all elements */
-  real fac[2]; /* fac[i] = hash_n / (bnd[2*i+1]-bnd[2*i]) */
-  obbox_2 *obb; /* obb[nel] -- bounding box info for each element */
-  uint *offset; /* hash table -- for cell i,j:
-                         uint index = j*hash_n+i,
-                                  b = offset[index  ],
-                                  e = offset[index+1];
-                         elements in cell are
-                           offset[b], offset[b+1], ..., offset[e-1] */
-  unsigned max; /* maximum # of elements in any cell */
-} hash_data_2;
-typedef struct {
-  unsigned hash_n;
-  real bnd[6]; /* bounds for all elements */
-  real fac[3]; /* fac[i] = hash_n / (bnd[2*i+1]-bnd[2*i]) */
-  obbox_3 *obb; /* obb[nel] -- bounding box info for each element */
-  uint *offset; /* hash table -- for cell i,j,k:
-                         uint index = (k*hash_n+j)*hash_n+i,
-} hash_data_3;
 static int ifloor(real x)
@@ -1885,12 +1847,6 @@ double opt_findpt_2(opt_data_2 *p, const real *const elx[2],
-typedef struct {
-  uint el;
-  real r[3];
-  real dist;
-} findpt_listel;
 /* heap sort on A[0:n-1] with key A[i]->dist
    precondition: n!=0 */
 static void findpt_list_sort(findpt_listel **A, unsigned n)
@@ -1925,34 +1881,6 @@ static void findpt_list_sort(findpt_listel **A, unsigned n)
-typedef struct {
-  const real *xw[2];   /* geometry data */
-  real *z[2];          /* lobatto nodes */
-  lagrange_data ld[2]; /* interpolation, derivative weights & data */
-  unsigned nptel;      /* nodes per element */
-  hash_data_2 *hash;   /* geometric hashing data */
-  findpt_listel *list, **sorted, **end; /* pre-allocated list of elements to
-                                           check (found by hashing), and
-                                           pre-allocated list of pointers into
-                                           the first list for sorting */
-  opt_data_2 *od; /* data for the optimization algorithm */
-  real *od_work;
-} findpt_data_2;
-typedef struct {
-  const real *xw[3];   /* geometry data */
-  real *z[3];          /* lobatto nodes */
-  lagrange_data ld[3]; /* interpolation, derivative weights & data */
-  hash_data_3 *hash;   /* geometric hashing data */
-  opt_data_3 *od; /* data for the optimization algorithm */
-  real *od_work;
-} findpt_data_3;
 findpt_data_2 *findpt_setup_2(
           const real *const xw[2], const unsigned n[2], uint nel,
           uint max_hash_size, real bbox_tol)
diff --git a/src/lotte/poly.c b/src/lotte/poly.c
index 6b5cba6..b8a93b7 100644
--- a/src/lotte/poly.c
+++ b/src/lotte/poly.c
@@ -5,8 +5,7 @@
 #include <float.h>
-#include "types.h"
   For brevity's sake, some names have been shortened
@@ -354,15 +353,6 @@ void lagrange_weights_deriv(const real *z, unsigned n,
      lagrange_free(&p);  // deallocate memory allocated by setup
-typedef struct {
-  unsigned n;                /* number of Lagrange nodes            */
-  const real *z;             /* Lagrange nodes (user-supplied)      */
-  real *J, *D, *D2;          /* weights for 0th,1st,2nd derivatives */
-  real *J_z0, *D_z0, *D2_z0; /* ditto at z[0]   (computed at setup) */
-  real *J_zn, *D_zn, *D2_zn; /* ditto at z[n-1] (computed at setup) */
-  real *w, *d, *u0, *v0, *u1, *v1, *u2, *v2; /* work data            */
-} lagrange_data;
 void lagrange_0(lagrange_data *p, real x)
   unsigned i, n=p->n;
diff --git a/src/lotte/tensor.c b/src/lotte/tensor.c
index 19e54b7..510dc38 100644
--- a/src/lotte/tensor.c
+++ b/src/lotte/tensor.c
@@ -1,4 +1,4 @@
-#include "types.h"
    Matrix-Matrix Multiplication
diff --git a/src/moab/CartVect.hpp b/src/moab/CartVect.hpp
index 383f8e4..a249fef 100644
--- a/src/moab/CartVect.hpp
+++ b/src/moab/CartVect.hpp
@@ -1,18 +1,3 @@
 #ifndef MB_CART_VECT_HPP
 #define MB_CART_VECT_HPP
@@ -24,8 +9,6 @@ namespace moab {
  * \brief Cartesian Vector
- * \author Jason Kraftcheck
- * \date July, 2006
 class CartVect
@@ -67,6 +50,8 @@ class CartVect
       { d[0] *= s; d[1] *= s; d[2] *= s; return *this; }
     inline CartVect& operator/=( double s )
       { d[0] /= s; d[1] /= s; d[2] /= s; return *this; }
+  inline bool operator==(const CartVect& v ) const
+      { return d[0] == v[0] && d[1] == v[1] && d[2] == v[2]; }
     inline double length() const; //!< vector length
diff --git a/src/moab/Core.hpp b/src/moab/Core.hpp
index efa17e3..4bb86c8 100644
--- a/src/moab/Core.hpp
+++ b/src/moab/Core.hpp
@@ -221,7 +221,7 @@ public:
           \param entity_handle EntityHandle to get connectivity of.
           \param connectivity Vector in which connectivity of <em>entity_handle</em> is returned.
           Should contain MeshVertices.
-          \param topological_connectivity If true, higher order nodes are ignored.
+          \param corners_only If true, higher order nodes are ignored.
           Example: \code
           std::vector<EntityHandle> conn;
@@ -229,7 +229,7 @@ public:
     virtual ErrorCode  get_connectivity(const EntityHandle *entity_handles,
-                                        bool topological_connectivity = false,
+                                        bool corners_only = false,
                                         std::vector<int> *offsets = NULL) const;
     //! Gets the connectivity for a vector of elements
@@ -238,14 +238,14 @@ public:
-                                        bool topological_connectivity = false) const;
+                                        bool corners_only = false) const;
     //! Gets the connectivity for elements
     /** Same as vector-based version except range is returned (unordered!)
   virtual ErrorCode get_connectivity( const Range& entity_handles,
     //! Gets a pointer to constant connectivity data of <em>entity_handle</em>
       /** Sets <em>number_nodes</em> equal to the number of nodes of the <em>
@@ -273,7 +273,7 @@ public:
     virtual ErrorCode  get_connectivity( const EntityHandle entity_handle,
                                            const EntityHandle *&connectivity,
                                            int &num_nodes,
                                            std::vector<EntityHandle>* storage = 0
                                           ) const;
@@ -1134,6 +1134,8 @@ public:
   void print(const EntityHandle handle, const char *prefix,
              bool first_call = true) const;
+  ErrorCode print_entity_tags(std::string indent_prefix, const EntityHandle handle, TagType tp) const;
   virtual ErrorCode get_last_error(std::string& info) const;
   virtual std::string get_error_string(const ErrorCode code) const;
diff --git a/src/moab/CpuTimer.hpp b/src/moab/CpuTimer.hpp
new file mode 100644
index 0000000..cdda903
--- /dev/null
+++ b/src/moab/CpuTimer.hpp
@@ -0,0 +1,63 @@
+#ifndef CPUTIMER_HPP
+#define CPUTIMER_HPP
+#ifdef USE_MPI
+#  include "moab_mpi.h"
+#else
+#  include <sys/resource.h>
+#endif
+namespace moab
+class CpuTimer {
+private:
+  double tAtBirth, tAtLast;
+  double mAtBirth, mAtLast;
+  long rssAtBirth, rssAtLast;
+  double runtime();
+  long runmem();
+public:
+  CpuTimer() : tAtBirth(runtime()), tAtLast(tAtBirth) {}
+  double time_since_birth() { return (tAtLast = runtime()) - tAtBirth; };
+  double time_elapsed() { double tmp = tAtLast; return (tAtLast = runtime()) - tmp; }
+  long mem_since_birth() {return (mAtLast=runmem()) - mAtBirth;}
+  long mem_elapsed() {long tmp = mAtLast; return (mAtLast=runmem()) - tmp;}
+    inline double CpuTimer::runtime()
+#if defined(_MSC_VER) || defined(__MINGW32__)
+      return (double)clock() / CLOCKS_PER_SEC;
+#elif defined(USE_MPI)
+      return MPI_Wtime();
+#else
+      struct rusage r_usage;
+      getrusage(RUSAGE_SELF, &r_usage);
+      double utime = (double)r_usage.ru_utime.tv_sec +
+          ((double)r_usage.ru_utime.tv_usec/1.e6);
+      double stime = (double)r_usage.ru_stime.tv_sec +
+          ((double)r_usage.ru_stime.tv_usec/1.e6);
+      return utime + stime;
+#endif
+    inline long CpuTimer::runmem()
+      return 0;
+      return 0;
+#else
+      mAtLast = r_usage.ru_maxrss;
+      return mAtLast;
+#endif
+#endif
diff --git a/src/moab/FileOptions.hpp b/src/moab/FileOptions.hpp
index 0000000..85b3eef
--- /dev/null
+++ b/src/moab/FileOptions.hpp
@@ -0,0 +1,248 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation.  Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+/**\file FileOptions.hpp
+ *\author Jason Kraftcheck (kraftche at cae.wisc.edu)
+ *\date 2007-08-21
+#ifndef FILE_OPTIONS_HPP
+#define FILE_OPTIONS_HPP
+#include <string>
+#include <vector>
+#include "moab/Types.hpp"
+namespace moab {
+/**\brief Parse options string passed to file IO routines
+ * This is a utility class used by file-IO-related code to
+ * parse the options string passed to Core::load_file and
+ * Core::write_file
+class FileOptions {
+public:
+  /*\param options_string The concatenation of a list of
+   *          options, separated either by the default separator
+   *          (semicolon) with a custom separator specified at
+   *          the beginning of the string (semicolon followed by
+   *          destired separator character.)
+  FileOptions( const char* option_string );
+  FileOptions( const FileOptions& copy );
+  FileOptions& operator=( const FileOptions& copy );
+  ~FileOptions();
+  /**\brief Check for option with no value
+   * Check for an option w/out a value.
+   *\param name The option name
+   *\return - MB_SUCCESS if option is found
+   *        - MB_TYPE_OUT_OF_RANGE if options is found, but has value
+   *        - MB_ENTITY_NOT_FOUND if option is not found.
+  ErrorCode get_null_option( const char* name ) const;
+  /**\brief Check for option with boolean (true/false, yes/no) value.
+   * Check for an option with a true/false value.  Allowable values
+   * are "true", "false", "yes", "no", "1", "0", "on", "off".
+   *\param default_value The value to return if the option is not specified.
+   *\param value The resulting value.  This argument is set to the passed
+   *            default value if the option is not found.
+   *\return - MB_TYPE_OUT_OF_RANGE if options is found, but has an invalid value
+   *        - MB_SUCCESS otherwise
+  ErrorCode get_toggle_option( const char* name,
+                               bool default_value,
+                               bool& value ) const;
+  /**\brief Check for option with an integer value.
+   * Check for an option with an integer value
+   *\param value Output. The value.
+   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not have an integer value
+  ErrorCode get_int_option( const char* name, int& value ) const;
+  /**\brief Check for option with an integer value.  Accept option with no value.
+   * Check for an option with an integer value.
+   * If the option is found but has no value specified, then
+   * pass back the user-specified default value.
+   *\NOTE:  This function will not pass back the default_val, but will instead
+   *        return MB_ENTITY_NOT_FOUND if the option is not specified at all.
+   *        The default value is returned only when the option is specified,
+   *        but is specified w/out a value.
+   *\param default_val The default value for the option.
+   *        - MB_TYPE_OUT_OF_RANGE if options is found but has a value that cannot be parsed as an int
+  ErrorCode get_int_option( const char* name, int default_val, int& value ) const;
+  /**\brief Check for option with a double value.
+   * Check for an option with a double value
+   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not have a double value
+  ErrorCode get_real_option( const char* name, double& value ) const;
+  /**\brief Check for option with any value.
+   * Check for an option with any value.
+   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not have a value
+  ErrorCode get_str_option( const char* name, std::string& value ) const;
+   *\param value The option value, or an empty string if no value.
+   *\return MB_SUCCESS or MB_ENTITY_NOT_FOUND
+  ErrorCode get_option( const char* name, std::string& value ) const;
+  /**\brief Check the string value of an option
+   * Check which of a list of possible values a string option contains.
+   *\param values A NULL-terminated array of C-style strings enumerating
+   *              the possible option values.
+   *\param index  Output: The index into <code>values</code> for the
+   *              option value.
+   *\return MB_SUCCESS if matched name and value.
+   *        MB_ENTITY_NOT_FOUND if the option was not specified
+   *        MB_FAILURE if the option value is not in the input <code>values</code> array.
+  ErrorCode match_option( const char* name, const char* const* values, int& index ) const;
+  /**\brief Check if an option matches a string value
+   * Check if the value for an option is the passed string.
+   *\param value The expected value.
+   *        MB_FAILURE if the option value doesn't match the passed string/
+  ErrorCode match_option( const char* name, const char* value) const;
+  /**\brief Check for option for which the value is a list of ints
+   * Check for an option which is an int list.  The value is expected to
+   * be a comma-separated list of int ranges, where an int range can be
+   * either a single integer value or a range of integer values separated
+   * by a dash ('-').
+   *\param values Output. The list of integer values.
+   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not contain an ID list
+  ErrorCode get_ints_option( const char* name, std::vector<int>& values) const;
+  /**\brief Check for option for which the value is a list of doubles
+   * Check for an option which is a double list.  The value is expected to
+   * be a comma-separated list of double values
+   *\param values Output. The list of double values.
+  ErrorCode get_reals_option( const char* name, std::vector<double>& values) const;
+  /**\brief Check for option for which the value is a list of strings
+   * Check for an option which is a string list.  The value is expected to
+   * be a comma-separated list of string values, with no embedded spaces or commas.
+   *\param values Output. The list of string values.
+   *        - MB_TYPE_OUT_OF_RANGE if options is found, but does not contain a string list
+  ErrorCode get_strs_option( const char* name, std::vector<std::string>& values) const;
+  /** number of options */
+  inline unsigned size() const
+    { return mOptions.size(); }
+  /** true if no options */
+  inline bool empty() const
+    { return mOptions.empty(); }
+  /** Get list of options */
+  void get_options( std::vector<std::string>& list ) const;
+  /** Check if all options have been looked at */
+  bool all_seen() const;
+  /** Mark all options as seen.  USed for non-root procs during bcast-delete read */
+  void mark_all_seen() const;
+  /** Get first unseen option */
+  ErrorCode get_unseen_option( std::string& value ) const;
+private:
+  ErrorCode get_option( const char* name, const char*& value) const;
+  char* mData;
+  std::vector<const char*> mOptions;
+  mutable std::vector<bool> mSeen;
+    /** Case-insensitive compare of name with option value. */
+  static bool compare( const char* name, const char* option );
+} // namespace moab
+#endif
This diff is so big that we needed to truncate the remainder.
https://bitbucket.org/fathomteam/moab/commits/a91108ec4055/
Changeset:   a91108ec4055
Branch:      None
User:        tautges
Date:        2013-09-12 23:37:24
Affected #:  2 files
diff --git a/src/BoundBox.cpp b/src/BoundBox.cpp
index 0000000..cb34330
--- /dev/null
+++ b/src/BoundBox.cpp
@@ -0,0 +1,78 @@
+#include "moab/Interface.hpp"
+#include "moab/BoundBox.hpp"
+namespace moab
+    ErrorCode BoundBox::update(Interface &iface, const Range& elems)
+      ErrorCode rval;
+      bMin = CartVect(HUGE_VAL);
+      bMax = CartVect(-HUGE_VAL);
+      CartVect coords;
+      EntityHandle const *conn, *conn2;
+      int len, len2;
+      Range::const_iterator i;
+        // vertices
+      const Range::const_iterator elem_begin = elems.lower_bound( MBEDGE );
+      for (i = elems.begin(); i != elem_begin; ++i) {
+        rval = iface.get_coords( &*i, 1, coords.array() );
+        if (MB_SUCCESS != rval)
+          return rval;
+        update_min(coords.array());
+        update_max(coords.array());
+        // elements with vertex-handle connectivity list
+      const Range::const_iterator poly_begin = elems.lower_bound( MBPOLYHEDRON, elem_begin );
+      std::vector<EntityHandle> dum_vector;
+      for (i = elem_begin; i != poly_begin; ++i) {
+        rval = iface.get_connectivity( *i, conn, len, true, &dum_vector);
+          return rval;
+        for (int j = 0; j < len; ++j) {
+          rval = iface.get_coords( conn+j, 1, coords.array() );
+            return rval;
+        // polyhedra
+      const Range::const_iterator set_begin  = elems.lower_bound( MBENTITYSET, poly_begin );
+      for (i = poly_begin; i != set_begin; ++i) {
+        rval = iface.get_connectivity( *i, conn, len, true );
+          return rval;
+          rval = iface.get_connectivity( conn[j], conn2, len2 );
+          for (int k = 0; k < len2; ++k) {
+            rval = iface.get_coords( conn2+k, 1, coords.array() );
+              return rval;
+        // sets
+      BoundBox box;
+      for (i = set_begin; i != elems.end(); ++i) {
+        Range tmp_elems;
+        rval = iface.get_entities_by_handle(*i, tmp_elems);
+        if (MB_SUCCESS != rval) return rval;
+        rval = box.update(iface, tmp_elems);
+        update(box);
diff --git a/src/moab/BoundBox.hpp b/src/moab/BoundBox.hpp
index 0000000..9400944
--- /dev/null
+++ b/src/moab/BoundBox.hpp
@@ -0,0 +1,177 @@
+#ifndef BOUND_BOX_HPP
+#define BOUND_BOX_HPP
+#include "moab/CartVect.hpp"
+#include <cfloat>
+namespace moab {
+    class BoundBox {
+  public:
+      BoundBox() : bMin(DBL_MAX), bMax(-DBL_MAX) {}
+      BoundBox(const CartVect &min, const CartVect &max) :
+              bMin(min), bMax(max) {}
+      BoundBox(const double *corners);
+      ~BoundBox() {}
+      bool contains_point(const double *point, const double tol = 0.0) const;
+      bool contains_box(const BoundBox &b, const double tol = 0.0) const;
+      void compute_center(CartVect ¢er);
+      void update(const BoundBox &other_box);
+      void update(const double *coords);
+      ErrorCode update(Interface &iface, const Range& elems);
+      ErrorCode update(Interface &iface, const EntityHandle ent);
+      void update_min(const BoundBox &other_box);
+      void update_min(const double *coords);
+      void update_max(const BoundBox &other_box);
+      void update_max(const double *coords);
+        /** \brief Return the diagonal length of this box
+      double diagonal_length() const;
+        /** \brief Return the square of the diagonal length of this box
+      double diagonal_squared() const;
+        /** \brief Return square of distance from box, or zero if inside
+         * \param from_point Point from which you want distance_sq
+      double distance_squared(const double *from_point) const;
+        /** \brief Return distance from box, or zero if inside
+      double distance(const double *from_point) const;
+      BoundBox &operator=(const BoundBox &from) {
+        bMin = from.bMin;
+        bMax = from.bMax;
+        return *this;
+      inline bool operator==(const BoundBox &box) const {
+        return (bMin == box.bMin && bMax == box.bMax);
+      CartVect bMin, bMax;
+    inline BoundBox::BoundBox(const double *corners)
+        // relies on CartVect being Plain Old Data, no virtual table
+      double *arr = bMin.array();
+      for (int i = 0; i < 6; i++)
+        arr[i] = corners[i];
+    inline bool BoundBox::contains_point(const double *point, const double tol) const {
+      if (point[0] < bMin[0]-tol || point[0] > bMax[0]+tol ||
+          point[1] < bMin[1]-tol || point[1] > bMax[1]+tol ||
+          point[2] < bMin[2]-tol || point[2] > bMax[2]+tol)
+        return false;
+      else return true;
+    inline bool BoundBox::contains_box(const BoundBox &b, const double tol) const {
+      if (b.bMin[0] < bMin[0]-tol || b.bMax[0] > bMax[0]+tol ||
+          b.bMin[1] < bMin[1]-tol || b.bMax[1] > bMax[1]+tol ||
+          b.bMin[2] < bMin[2]-tol || b.bMax[2] > bMax[2]+tol)
+        return false;
+      else return true;
+    inline void BoundBox::update(const BoundBox &other_box)
+      update_min(other_box);
+      update_max(other_box);
+    inline void BoundBox::update(const double *coords)
+      update_min(coords);
+      update_max(coords+3);
+    inline void BoundBox::update_min(const BoundBox &other_box)
+      bMin[0] = std::min(bMin[0], other_box.bMin[0]);
+      bMin[1] = std::min(bMin[1], other_box.bMin[1]);
+      bMin[2] = std::min(bMin[2], other_box.bMin[2]);
+    inline void BoundBox::update_min(const double *coords)
+      bMin[0] = std::min(bMin[0], coords[0]);
+      bMin[1] = std::min(bMin[1], coords[1]);
+      bMin[2] = std::min(bMin[2], coords[2]);
+    inline void BoundBox::update_max(const BoundBox &other_box)
+      bMax[0] = std::max(bMax[0], other_box.bMax[0]);
+      bMax[1] = std::max(bMax[1], other_box.bMax[1]);
+      bMax[2] = std::max(bMax[2], other_box.bMax[2]);
+    inline void BoundBox::update_max(const double *coords)
+      bMax[0] = std::max(bMax[0], coords[0]);
+      bMax[1] = std::max(bMax[1], coords[1]);
+      bMax[2] = std::max(bMax[2], coords[2]);
+    inline void BoundBox::compute_center(CartVect ¢er){
+      center = 0.5 * (bMin + bMax);
+    inline std::ostream &operator<<(std::ostream& out, const BoundBox &box) {
+      out << "Min: ";
+      out << box.bMin;
+      out << ", Max: ";
+      out << box.bMax;
+      return out;
+    inline ErrorCode BoundBox::update(Interface &iface, const EntityHandle ent)
+      Range tmp_range(ent, ent);
+      return update(iface, tmp_range);
+    inline double BoundBox::distance_squared(const double *from_point) const
+      double dist_sq = 0.0;
+      for (int i = 0; i < 3; ++i) {
+        if (from_point[i] < bMin[i])
+          dist_sq += (bMin[i] - from_point[i]) * (bMin[i] - from_point[i]);
+        else if (from_point[i] > bMax[i])
+          dist_sq += (bMax[i] - from_point[i]) * (bMax[i] - from_point[i]);
+      return dist_sq;
+    inline double BoundBox::distance(const double *from_point) const
+      double dist_sq = distance_squared(from_point);
+      return sqrt(dist_sq);
+    inline double BoundBox::diagonal_length() const
+      if (DBL_MAX == bMax[0] || DBL_MAX == bMax[1] || DBL_MAX == bMax[2] ||
+          DBL_MAX == bMin[0] || DBL_MAX == bMin[1] || DBL_MAX == bMin[2]) return DBL_MAX;
+      return (bMax - bMin).length();
+    inline double BoundBox::diagonal_squared() const
+      return (bMax - bMin).length_squared();
+#endif
https://bitbucket.org/fathomteam/moab/commits/00c578e5a49f/
Changeset:   00c578e5a49f
Branch:      None
User:        tautges
Date:        2013-09-12 23:53:37
Summary:     Adding a Lloyd smoother tool, and a test of it.
Affected #:  6 files
index d3721c3..5aac80a 100644
--- a/.gitignore
+++ b/.gitignore
@@ -155,6 +155,7 @@ test/io/vtk_test
 test/kd_tree_test
 test/kd_tree_time
 test/kd_tree_tool
+test/lloyd_smoother_test
 test/mbcn_test
 test/mbfacet_test
 test/mbground_test
diff --git a/src/LloydSmoother.cpp b/src/LloydSmoother.cpp
index 0000000..49177d0
--- /dev/null
+++ b/src/LloydSmoother.cpp
@@ -0,0 +1,220 @@
+#include "moab/LloydSmoother.hpp"
+#include "moab/Error.hpp"
+#include "moab/Skinner.hpp"
+#include "moab/CN.hpp"
+#ifdef USE_MPI
+#include "moab/ParallelComm.hpp"
+#endif
+#include <iostream>
+#define RR(a) if (MB_SUCCESS != rval) {        \
+    errorHandler->set_last_error(a);                \
+    return rval;}
+namespace moab {
+LloydSmoother::LloydSmoother(Interface *impl, ParallelComm *pc, Range &elms, Tag ftag,
+                             double at, double rt)
+        : mbImpl(impl), myPcomm(pc), myElems(elms), fixedTag(ftag), absTol(at), relTol(rt),
+          reportIts(0), numIts(0), iCreatedTag(false)
+  ErrorCode rval = mbImpl->query_interface(errorHandler);
+  if (rval) throw rval;
+LloydSmoother::~LloydSmoother()
+  if (iCreatedTag && fixedTag) {
+    ErrorCode rval = mbImpl->tag_delete(fixedTag);
+ErrorCode LloydSmoother::perform_smooth()
+  ErrorCode rval;
+    // first figure out tolerance to use
+  if (0 > absTol) {
+      // no tolerance set - get one relative to bounding box around elements
+    BoundBox bb;
+    rval = bb.update(*mbImpl, myElems);
+    RR("Failed to compute bounding box around elements.");
+    absTol = relTol * bb.diagonal_length();
+    // initialize if we need to
+  rval = initialize();
+  RR("Failed to initialize.");
+    // get all vertices
+  Range verts;
+  rval = mbImpl->get_adjacencies(myElems, 0, false, verts, Interface::UNION);
+  RR("Failed to get all vertices.");
+    // perform Lloyd relaxation:
+    // 1. setup: set vertex centroids from vertex coords; filter to owned verts; get fixed tags
+    // get all verts coords into tag; don't need to worry about filtering out fixed verts,
+    // we'll just be setting to their fixed coords
+  std::vector<double> vcentroids(3*verts.size());
+  rval = mbImpl->get_coords(verts, &vcentroids[0]); RR("Failed to get vert coords.");
+  Tag centroid;
+  rval = mbImpl->tag_get_handle("", 3, MB_TYPE_DOUBLE, centroid, MB_TAG_CREAT | MB_TAG_DENSE);
+  RR("Couldn't get tag handle.");
+  rval = mbImpl->tag_set_data(centroid, verts, &vcentroids[0]); RR("Failed setting centroid tag.");
+  Range owned_verts, shared_owned_verts;
+#ifdef USE_MPI
+    // filter verts down to owned ones and get fixed tag for them
+  if (myPcomm->size() > 1) {
+    rval = myPcomm->filter_pstatus(verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_verts);
+    RR("Failed to filter on pstatus.");
+      // get shared owned verts, for exchanging tags
+    rval = myPcomm->filter_pstatus(owned_verts, PSTATUS_SHARED, PSTATUS_AND, -1, &shared_owned_verts);
+    RR("Failed to filter for shared owned.");
+      // workaround: if no shared owned verts, put a non-shared one in the list, to prevent exchanging tags
+      // for all shared entities
+    if (shared_owned_verts.empty()) shared_owned_verts.insert(*verts.begin());
+  else
+    owned_verts = verts;
+#else
+#endif
+  std::vector<unsigned char> fix_tag(owned_verts.size());
+  rval = mbImpl->tag_get_data(fixedTag, owned_verts, &fix_tag[0]); RR("Failed to get fixed tag.");
+    // now fill vcentroids array with positions of just owned vertices, since those are the ones
+    // we're actually computing
+  vcentroids.resize(3*owned_verts.size());
+  rval = mbImpl->tag_get_data(centroid, owned_verts, &vcentroids[0]); RR("Failed to get centroid tag.");
+    // some declarations for later iterations
+  std::vector<double> fcentroids(3*myElems.size()); // fcentroids for element centroids
+  std::vector<double> ctag(3*CN::MAX_NODES_PER_ELEMENT);  // temporary coordinate storage for verts bounding an element
+  const EntityHandle *conn;  // const ptr & size to elem connectivity
+  int nconn;
+  Range::iterator eit, vit;  // for iterating over elems, verts
+  int e, v;  // for indexing into centroid vectors
+  std::vector<EntityHandle> adj_elems;  // used in vertex iteration
+    // 2. while !converged
+  double resid = DBL_MAX;
+  numIts = 0;
+  while (resid > absTol) {
+    numIts++;
+    resid = 0.0;
+    // 2a. foreach elem: centroid = sum(vertex centroids)/num_verts_in_cell
+    for (eit = myElems.begin(), e = 0; eit != myElems.end(); eit++, e++) {
+        // get verts for this elem
+      rval = mbImpl->get_connectivity(*eit, conn, nconn); RR("Failed to get connectivity.");
+        // get centroid tags for those verts
+      rval = mbImpl->tag_get_data(centroid, conn, nconn, &ctag[0]); RR("Failed to get centroid.");
+      fcentroids[3*e+0] = fcentroids[3*e+1] = fcentroids[3*e+2] = 0.0;
+      for (v = 0; v < nconn; v++) {
+        fcentroids[3*e+0] += ctag[3*v+0];
+        fcentroids[3*e+1] += ctag[3*v+1];
+        fcentroids[3*e+2] += ctag[3*v+2];
+      for (v = 0; v < 3; v++) fcentroids[3*e+v] /= nconn;
+    rval = mbImpl->tag_set_data(centroid, myElems, &fcentroids[0]); RR("Failed to set elem centroid.");
+      // 2b. foreach owned vertex:
+    for (vit = owned_verts.begin(), v = 0; vit != owned_verts.end(); vit++, v++) {
+        // if !fixed
+      if (fix_tag[v]) continue;
+        // vertex centroid = sum(cell centroids)/ncells
+      adj_elems.clear();
+      rval = mbImpl->get_adjacencies(&(*vit), 1, 2, false, adj_elems); RR("Failed getting adjs.");
+      rval = mbImpl->tag_get_data(centroid, &adj_elems[0], adj_elems.size(), &fcentroids[0]);
+      RR("Failed to get elem centroid.");
+      double vnew[] = {0.0, 0.0, 0.0};
+      for (e = 0; e < (int)adj_elems.size(); e++) {
+        vnew[0] += fcentroids[3*e+0];
+        vnew[1] += fcentroids[3*e+1];
+        vnew[2] += fcentroids[3*e+2];
+      for (e = 0; e < 3; e++) vnew[e] /= adj_elems.size();
+      double delta = (CartVect(vnew)-CartVect(&vcentroids[3*v])).length();
+      resid = (v ? std::max(resid, delta) : delta);
+      for (e = 0; e < 3; e++) vcentroids[3*v+e] = vnew[e];
+      // set the centroid tag; having them only in vcentroids array isn't enough, as vertex centroids are
+      // accessed randomly in loop over faces
+    rval = mbImpl->tag_set_data(centroid, owned_verts, &vcentroids[0]); RR("Failed to set vertex centroid.");
+#ifdef USE_MPI
+    // 2c. exchange tags on owned verts
+      rval = pcomm->exchange_tags(centroid, shared_owned_verts); RR("Failed to exchange tags.");
+#endif
+    if (reportIts && !(numIts%reportIts)) {
+      double global_max = resid;
+#ifdef USE_MPI
+        // global reduce for maximum delta, then report it
+        MPI_Reduce(&resid, &global_max, 1, MPI_DOUBLE, MPI_MAX, 0, myPcomm->comm());
+      if (!pcomm->rank())
+#endif
+        std::cout << "Max residual = " << global_max << std::endl;
+  } // end while
+    // write the tag back onto vertex coordinates
+  rval = mbImpl->set_coords(owned_verts, &vcentroids[0]); RR("Failed to set vertex coords.");
+ErrorCode LloydSmoother::initialize()
+  ErrorCode rval = MB_SUCCESS;
+    // first, check for tag; if we don't have it, make one and mark skin as fixed
+  if (!fixedTag) {
+    unsigned char fixed = 0x0;
+    rval = mbImpl->tag_get_handle("", 1, MB_TYPE_OPAQUE, fixedTag, MB_TAG_DENSE|MB_TAG_CREAT, &fixed);
+    RR("Trouble making fixed tag.");
+    iCreatedTag = true;
+      // get the skin; get facets, because we might need to filter on shared entities
+    Skinner skinner(mbImpl);
+    Range skin, skin_verts;
+    rval = skinner.find_skin(0, myElems, false, skin);
+    RR("Unable to find skin.");
+#ifdef USE_MPI
+      // need to do a little extra if we're working in parallel
+    if (myPcomm) {
+        // filter out ghost and interface facets
+      rval = myPcomm->filter_pstatus(skin, PSTATUS_GHOST|PSTATUS_INTERFACE, PSTATUS_NOT);
+      RR("Failed to filter on shared status.");
+#endif
+      // get the vertices from those entities
+    rval = mbImpl->get_adjacencies(skin, 0, false, skin_verts, Interface::UNION);
+    RR("Trouble getting vertices.");
+      // mark them fixed
+    std::vector<unsigned char> marks(skin.size(), 0x1);
+    rval = mbImpl->tag_set_data(fixedTag, skin_verts, &marks[0]);
+    RR("Unable to set tag on skin.");
index ab5077a..3fb67b1 100644
@@ -63,6 +63,7 @@ libMOAB_la_SOURCES = \
   HomXform.cpp \
   Internals.hpp \
+  LloydSmoother.cpp \
   MBCNArrays.hpp \
   MergeMesh.cpp \
   MeshSet.cpp \
@@ -161,6 +162,7 @@ nobase_libMOAB_la_include_HEADERS = \
   moab/GeomUtil.hpp \
   moab/EigenDecomp.hpp \
+  moab/LloydSmoother.hpp \
   moab/point_locater/tree/common_tree.hpp \
   moab/point_locater/tree/element_tree.hpp \
   moab/point_locater/tree/bvh_tree.hpp \
diff --git a/src/moab/LloydSmoother.hpp b/src/moab/LloydSmoother.hpp
index 0000000..5ab9771
--- /dev/null
+++ b/src/moab/LloydSmoother.hpp
@@ -0,0 +1,145 @@
+/** @class LloydSmoother.cpp \n
+ * \brief Perform Lloyd relaxation on a mesh and its dual \n
+ * Briefly, Lloyd relaxation is a technique to smooth out a mesh.  The centroid of each cell is computed from its
+ * vertex positions, then vertices are placed at the average of their connected cells' centroids, and the process
+ * iterates until convergence.
+ * In the parallel algorithm, an extra ghost layer of cells is exchanged.  This allows us to compute the centroids
+ * for boundary cells on each processor where they appear; this eliminates the need for one round of data exchange
+ * (for those centroids) between processors.  New vertex positions must be sent from owning processors to processors
+ * sharing those vertices.  Convergence is measured as the maximum distance moved by any vertex.
+#ifndef LLOYDSMOOTHER_HPP
+#define LLOYDSMOOTHER_HPP
+namespace moab {
+class ParallelComm;
+class Error;
+class LloydSmoother
+public:
+    /* \brief Constructor
+     * Bare constructor, data input to this class through methods.
+     * \param impl The MOAB instance for this smoother
+  LloydSmoother(Interface *impl);
+     * Convenience constructor, data input directly
+     * \param pcomm The ParallelComm instance by which this mesh is parallel
+     * \param elems The mesh to be smoothed
+     * \param fixed_tag The tag marking which vertices are fixed
+     * \param abs_tol Absolute tolerance measuring convergence
+     * \param rel_tol Relative tolerance measuring convergence
+  LloydSmoother(Interface *impl, ParallelComm *pc, Range &elems, Tag fixed_tag = 0,
+                double abs_tol = -1.0, double rel_tol = 1.0e-6);
+    /* \brief Destructor
+  ~LloydSmoother();
+    /* \brief perform smoothing operation
+  ErrorCode perform_smooth();
+    /* \brief get instance
+  Interface *mb_impl() {return mbImpl;}
+    /* \brief get/set ParallelComm
+  ParallelComm *pcomm() {return myPcomm;}
+  void pcomm(ParallelComm *pc) {myPcomm = pc;}
+    /* \brief get/set elements
+  Range &elems() {return myElems;}
+  const Range &elems() const {return myElems;}
+    /* \brief get/set fixed tag
+  Tag fixed_tag() {return fixedTag;}
+  void fixed_tag(Tag fixed) {fixedTag = fixed;}
+    /* \brief get/set tolerance
+  double abs_tol() {return absTol;}
+  void abs_tol(double tol) {absTol = tol;}
+  double rel_tol() {return relTol;}
+  void rel_tol(double tol) {relTol = tol;}
+    /* \brief get/set numIts
+  int num_its() {return numIts;}
+  void num_its(int num) {numIts = num;}
+    /* \brief get/set reportIts
+  int report_its() {return reportIts;}
+  void report_its(int num) {reportIts = num;}
+private:
+    //- initialize some things in certain cases
+  ErrorCode initialize();
+    //- MOAB instance
+  Interface *mbImpl;
+    //- ParallelComm
+  ParallelComm *myPcomm;
+    //- elements to smooth
+  Range myElems;
+    //- tag marking which vertices are fixed, 0 = not fixed, otherwise fixed
+  Tag fixedTag;
+    //- tolerances
+  double absTol, relTol;
+    //- error handler for this class
+  Error *errorHandler;
+    //- number of iterations between reporting
+  int reportIts;
+    //- number of iterations taken during smooth
+  int numIts;
+    //- keep track of whether I created the fixed tag
+  bool iCreatedTag;
+#endif
diff --git a/test/Makefile.am b/test/Makefile.am
index 9566338..dffb8f9 100644
--- a/test/Makefile.am
+++ b/test/Makefile.am
@@ -45,7 +45,8 @@ TESTS = range_test \
 	reorder_test \
 	test_prog_opt \
 	coords_connect_iterate \
-        test_boundbox
+        test_boundbox \
+	lloyd_smoother_test
 if HDF5_FILE
   TESTS += mbfacet_test \
@@ -139,6 +140,7 @@ coords_connect_iterate_SOURCES = coords_connect_iterate.cpp
 coords_connect_iterate_CPPFLAGS = $(AM_CPPFLAGS) $(CPPFLAGS)
 test_boundbox_SOURCES = test_boundbox.cpp
+lloyd_smoother_test_SOURCES = lloyd_smoother_test.cpp
 if PARALLEL
 moab_test_CPPFLAGS += -I$(top_srcdir)/src/parallel
diff --git a/test/lloyd_smoother_test.cpp b/test/lloyd_smoother_test.cpp
index 0000000..8d88112
--- /dev/null
+++ b/test/lloyd_smoother_test.cpp
@@ -0,0 +1,41 @@
+#include "moab/Core.hpp"
+#include "TestUtil.hpp"
+#ifdef MESHDIR
+std::string TestDir( STRINGIFY(MESHDIR) );
+#else
+std::string TestDir(".");
+#endif
+std::string filename = TestDir + "/surfrandomtris-4part.h5m";
+using namespace moab;
+int main(int argc, char**argv)
+  if (argc > 1) filename = std::string(argv[1]);
+  Core mb;
+  ErrorCode rval = mb.load_file(filename.c_str());
+  CHECK_ERR(rval);
+  Range elems;
+  rval = mb.get_entities_by_dimension(0, 3, elems);
+  CHECK_ERR(rval);
+  if (elems.empty()) {
+    rval = mb.get_entities_by_dimension(0, 2, elems);
+    CHECK_ERR(rval);
+    std::cout << "Mesh must have faces or regions for this test." << std::endl;
+    CHECK_ERR(MB_FAILURE);
+  LloydSmoother ll(&mb, NULL, elems);
+  ll.report_its(10);
+  rval = ll.perform_smooth();
+  CHECK_ERR(rval);
+  std::cout << "Mesh smoothed in " << ll.num_its() << " iterations." << std::endl;
https://bitbucket.org/fathomteam/moab/commits/da78fb058113/
Changeset:   da78fb058113
Branch:      None
User:        tautges
Date:        2013-09-13 00:36:32
Summary:     Adding ability to smooth based on a tag instead of coords.
Affected #:  3 files
index 49177d0..09546b5 100644
--- a/src/LloydSmoother.cpp
@@ -17,9 +17,9 @@
 namespace moab {
-LloydSmoother::LloydSmoother(Interface *impl, ParallelComm *pc, Range &elms, Tag ftag,
-                             double at, double rt)
-        : mbImpl(impl), myPcomm(pc), myElems(elms), fixedTag(ftag), absTol(at), relTol(rt),
+LloydSmoother::LloydSmoother(Interface *impl, ParallelComm *pc, Range &elms, Tag ctag,
+                             Tag ftag, double at, double rt)
+        : mbImpl(impl), myPcomm(pc), myElems(elms), coordsTag(ctag), fixedTag(ftag), absTol(at), relTol(rt),
@@ -62,7 +62,12 @@ ErrorCode LloydSmoother::perform_smooth()
-  rval = mbImpl->get_coords(verts, &vcentroids[0]); RR("Failed to get vert coords.");
+  if (!coordsTag) {
+  else {
+    rval = mbImpl->tag_get_data(coordsTag, verts, &vcentroids[0]); RR("Failed to get vert coords tag values.");
   Tag centroid;
@@ -174,7 +179,13 @@ ErrorCode LloydSmoother::perform_smooth()
   } // end while
-  rval = mbImpl->set_coords(owned_verts, &vcentroids[0]); RR("Failed to set vertex coords.");
+  if (!coordsTag) {
+  else {
+    rval = mbImpl->tag_set_data(coordsTag, owned_verts, &vcentroids[0]);
+    RR("Failed to set vert coords tag values.");
   return MB_SUCCESS;
index 5ab9771..4f8570a 100644
--- a/src/moab/LloydSmoother.hpp
@@ -35,13 +35,15 @@ public:
-     * \param pcomm The ParallelComm instance by which this mesh is parallel
+     * \param pc The ParallelComm instance by which this mesh is parallel
+     * \param cds_tag If specified, this tag is used to get/set coordinates, rather than
+     *     true vertex coordinates
-  LloydSmoother(Interface *impl, ParallelComm *pc, Range &elems, Tag fixed_tag = 0,
+  LloydSmoother(Interface *impl, ParallelComm *pc, Range &elems, Tag cds_tag = 0, Tag fixed_tag = 0,
@@ -80,6 +82,14 @@ public:
+    /* \brief get/set coords tag
+  Tag coords_tag() {return coordsTag;}
+  void coords_tag(Tag coords) {coordsTag = coords;}
@@ -121,6 +131,9 @@ private:
   Range myElems;
+    //- tag for coordinates; if zero, true vertex coords are used
+  Tag coordsTag;
   Tag fixedTag;
index 8d88112..662732b 100644
--- a/test/lloyd_smoother_test.cpp
@@ -1,5 +1,6 @@
 #ifdef MESHDIR
@@ -31,11 +32,47 @@ int main(int argc, char**argv)
-  LloydSmoother ll(&mb, NULL, elems);
+    // get the vertex positions and set on an intermediate tag, to test smoothing for
+    // a tag instead of for coords
+  Tag ctag;
+  rval = mb.tag_get_handle("vcentroid", 3, MB_TYPE_DOUBLE, ctag, MB_TAG_CREAT|MB_TAG_DENSE);
+  CHECK_ERR(rval);
+  Range verts;
+  rval = mb.get_entities_by_dimension(0, 0, verts);
+  CHECK_ERR(rval);
+  std::vector<double> coords(3*verts.size());
+  rval = mb.get_coords(verts, &coords[0]);
+  CHECK_ERR(rval);
+  rval = mb.tag_set_data(ctag, verts, &coords[0]);
+  CHECK_ERR(rval);
+  LloydSmoother ll(&mb, NULL, elems, ctag);
   ll.report_its(10);
   CHECK_ERR(rval);
+    // now, set vertex coords to almost their converged positions, then re-smooth; should take fewer
+    // iterations
+  std::vector<double> new_coords(3*verts.size());
+  rval = mb.tag_get_data(ctag, verts, &new_coords[0]);
+  CHECK_ERR(rval);
+  unsigned int i;
+  Range::iterator vit;
+  for (vit = verts.begin(), i = 0; vit != verts.end(); vit++, i+=3) {
+    CartVect old_pos(&coords[i]), new_pos(&new_coords[i]);
+    CartVect almost_pos = old_pos + .99 * (new_pos - old_pos);
+    almost_pos.get(&new_coords[i]);
+  rval = mb.set_coords(verts, &new_coords[0]);
+  CHECK_ERR(rval);
+  LloydSmoother ll2(&mb, NULL, elems);
+  ll2.report_its(10);
+  rval = ll2.perform_smooth();
+  CHECK_ERR(rval);
+  std::cout << "Mesh smoothed in " << ll2.num_its() << " iterations." << std::endl;
https://bitbucket.org/fathomteam/moab/commits/c1d28fa90048/
Changeset:   c1d28fa90048
Branch:      None
User:        tautges
Date:        2013-09-17 00:29:43
Summary:     Adding deformed mesh example.
Affected #:  2 files
diff --git a/examples/DeformMeshRemap.cpp b/examples/DeformMeshRemap.cpp
index 0000000..ddb3f3a
--- /dev/null
+++ b/examples/DeformMeshRemap.cpp
@@ -0,0 +1,180 @@
+/** @example DeformMeshRemap.cpp
+ * Description: Account for mesh deformation of a solid due to structural mechanics\n
+ * In this example there are two meshes, a "master" and "slave" mesh.  In the master mesh,
+ * the solid material is deformed, to mimic what happens when a solid heats up and deforms.
+ * The fluid mesh is smoothed to account for those deformations, and tags on the fluid are
+ * remapped to those new positions.  Then mesh positions and state variables are transferred
+ * to the slave mesh, mimicing another mesh used by some other physics.
+ * To run: ./DeformMeshRemap [<master_meshfile><slave_meshfile>]\n
+ * (default values can run if users don't specify the mesh files)
+#include "moab/Range.hpp"
+#include "MBTagConventions.hpp"
+#include <assert.h>
+using namespace std;
+#ifndef MESH_DIR
+#define MESH_DIR "."
+#endif
+ErrorCode read_file(string &fname, EntityHandle &seth,
+                    Range &solids, Range &solid_elems, Range &fluids, Range &fluid_elems);
+void deform_func(double *xold, double *xnew);
+ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, Tag &xnew);
+ErrorCode smooth_master(int dim, Tag xnew, EntityHandle &master, Range &fluids);
+ErrorCode write_to_coords(Range &elems, Tag tagh);
+string trimeshf = string(MESH_DIR) + string("/rodtri.g");
+string quadmeshf = string(MESH_DIR) + string("/rodquad.g");
+const int SOLID_SETNO = 100, FLUID_SETNO = 200;
+Interface *mb;
+#define RR(a) if (MB_SUCCESS != rval) {cout << a << endl; return MB_FAILURE;}
+int main(int /*argc*/, char **/*argv*/) {
+  EntityHandle master, slave;
+  ErrorCode rval;
+  mb = new Core();
+    // read master/slave files and get fluid/solid material sets
+  Range fluids[2], solids[2], solid_elems[2], fluid_elems[2];
+  rval = read_file(quadmeshf, master, solids[0], solid_elems[0], fluids[0], fluid_elems[0]); RR("");
+  rval = read_file(trimeshf, slave, solids[1], solid_elems[1], fluids[1], fluid_elems[1]); RR("");
+    // deform the master's solid mesh, put results in a new tag
+  Tag xnew;
+  rval = deform_master(fluid_elems[0], solid_elems[0], xnew); RR("");
+  rval = write_to_coords(solid_elems[0], xnew); RR("");
+  rval = mb->write_file("deformed.vtk", NULL, NULL, &master, 1); RR("");
+    // smooth the master mesh
+  LloydSmoother *ll = new LloydSmoother(mb, NULL, fluid_elems[0], xnew);
+  rval = ll->perform_smooth();
+  RR("Failed in lloyd smoothing.");
+  cout << "Lloyd smoothing required " << ll->num_its() << " iterations." << endl;
+  rval = mb->write_file("smoothed.vtk", NULL, NULL, &master, 1); RR("");
+  delete ll;
+  delete mb;
+  return MB_SUCCESS;
+    // write the tag to coordinates
+  Range verts;
+  ErrorCode rval = mb->get_adjacencies(elems, 0, false, verts, Interface::UNION);
+  RR("Failed to get adj vertices.");
+  rval = mb->tag_get_data(tagh, verts, &coords[0]);
+  RR("Failed to get tag data.");
+  rval = mb->set_coords(verts, &coords[0]);
+  RR("Failed to set coordinates.");
+  const double RODWIDTH = 0.2, RODHEIGHT = 0.5;
+    // function: origin is at middle base of rod, and is .5 high
+    // top of rod is (0,.55) on left and (.2,.6) on right
+  double delx = 0.5*RODWIDTH;
+  double xfrac = (xold[0] + .5*RODWIDTH)/RODWIDTH, yfrac = xold[1]/RODHEIGHT;
+  xnew[0] = xold[0] + yfrac * delx;
+  xnew[1] = xold[1] + yfrac * (1.0 + xfrac) * 0.05;
+    // deform elements with an analytic function
+    // create the tag
+  ErrorCode rval = mb->tag_get_handle("", 3, MB_TYPE_DOUBLE, xnew, MB_TAG_CREAT|MB_TAG_DENSE);
+  RR("Failed to create xnew tag.");
+    // get all the vertices and coords in the fluid, set xnew to them
+  Range verts;
+  rval = mb->get_adjacencies(fluid_elems, 0, false, verts, Interface::UNION);
+  RR("Failed to get vertices.");
+  std::vector<double> coords(3*verts.size(), 0.0);
+  rval = mb->get_coords(verts, &coords[0]);
+  RR("Failed to get vertex coords.");
+  rval = mb->tag_set_data(xnew, verts, &coords[0]);
+  RR("Failed to set xnew tag on fluid verts.");
+    // get all the vertices and coords in the solid
+  verts.clear();
+  rval = mb->get_adjacencies(solid_elems, 0, false, verts, Interface::UNION);
+  coords.resize(3*verts.size(), 0.0);
+  unsigned int num_verts = verts.size();
+  for (unsigned int i = 0; i < num_verts; i++)
+    deform_func(&coords[3*i], &coords[3*i]);
+    // set the new tag to those coords
+  RR("Failed to set tag data.");
+    // create meshset
+  ErrorCode rval = mb->create_meshset(0, seth);
+  RR("Couldn't create master/slave set.");
+  rval = mb->load_file(fname.c_str(), &seth);
+  RR("Couldn't load master/slave mesh.");
+    // get material sets for solid/fluid
+  Tag tagh;
+  rval = mb->tag_get_handle(MATERIAL_SET_TAG_NAME, tagh); RR("Couldn't get material set tag name.");
+  const void *setno_ptr = &SOLID_SETNO;
+  rval = mb->get_entities_by_type_and_tag(seth, MBENTITYSET, &tagh, &setno_ptr, 1, solids);
+  if (solids.empty()) rval = MB_FAILURE;
+  RR("Couldn't get any solid sets.");
+    // get solid entities, and dimension
+  Range tmp_range;
+  for (Range::iterator rit = solids.begin(); rit != solids.end(); rit++) {
+    rval = mb->get_entities_by_handle(*rit, tmp_range, true);
+    RR("Failed to get entities in solid.");
+  int dim = mb->dimension_from_handle(*tmp_range.rbegin());
+  assert(dim > 0 && dim < 4);
+  solid_elems = tmp_range.subset_by_dimension(dim);
+  setno_ptr = &FLUID_SETNO;
+  rval = mb->get_entities_by_type_and_tag(seth, MBENTITYSET, &tagh, &setno_ptr, 1, fluids);
+  if (fluids.empty()) rval = MB_FAILURE;
+  RR("Couldn't get any fluid sets.");
+  for (Range::iterator rit = fluids.begin(); rit != fluids.end(); rit++) {
+    rval = mb->get_entities_by_dimension(*rit, dim, fluid_elems, true);
+    RR("Failed to get entities in fluid.");
+  if (mb->dimension_from_handle(*fluid_elems.begin()) != dim) {
+    rval = MB_FAILURE;
+    RR("Fluid and solid elements must be same dimension.");
diff --git a/examples/makefile b/examples/makefile
index 3b848d2..fbd4412 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -4,7 +4,7 @@ include ${MOAB_DIR}/lib/iMesh-Defs.inc
 .SUFFIXES: .o .cpp .F90
-# MESH_DIR is the top-level MOAB source directory, used to locate mesh files that come with MOAB source
+# MESH_DIR is the directory containing mesh files that come with MOAB source
 MESH_DIR="../MeshFiles/unittest"
 EXAMPLES = HelloMOAB GetEntities SetsNTags StructuredMeshSimple DirectAccessWithHoles DirectAccessNoHoles
@@ -47,6 +47,9 @@ HelloParMOAB: HelloParMOAB.o
 TestExodusII: TestExodusII.o
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
+DeformMeshRemap: DeformMeshRemap.o
+	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
 clean:
 	rm -rf *.o ${EXAMPLES} ${PAREXAMPLES} ${EXOIIEXAMPLES}
https://bitbucket.org/fathomteam/moab/commits/a8f966f4e3ff/
Changeset:   a8f966f4e3ff
Branch:      None
User:        tautges
Date:        2013-09-18 00:44:23
Summary:     Adding option processing to DeformMeshRemap, and making
parallel optional in LloydRelaxation example.
Affected #:  2 files
index ddb3f3a..55ac3cc 100644
--- a/examples/DeformMeshRemap.cpp
@@ -13,6 +13,7 @@
+#include "moab/ProgOptions.hpp"
 #include <iostream>
@@ -32,39 +33,48 @@ ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, Tag &xnew);
-string trimeshf = string(MESH_DIR) + string("/rodtri.g");
-string quadmeshf = string(MESH_DIR) + string("/rodquad.g");
 Interface *mb;
-int main(int /*argc*/, char **/*argv*/) {
+int main(int argc, char **argv) {
   ErrorCode rval;
+  ProgOptions po("Deformed mesh options");
+  po.addOpt<std::string> ("master,m", "Specify the master meshfile name" );
+  po.addOpt<std::string> ("slave,s", "Specify the slave meshfile name" );
+  po.parseCommandLine(argc, argv);
+  std::string foo;
+  string masterf, slavef;
+  if(!po.getOpt("master", &masterf))
+    masterf = string(MESH_DIR) + string("/rodquad.g");
+  if(!po.getOpt("slave", &slavef))
+    slavef = string(MESH_DIR) + string("/rodtri.g");
   mb = new Core();
-  rval = read_file(quadmeshf, master, solids[0], solid_elems[0], fluids[0], fluid_elems[0]); RR("");
-  rval = read_file(trimeshf, slave, solids[1], solid_elems[1], fluids[1], fluid_elems[1]); RR("");
+  rval = read_file(masterf, master, solids[0], solid_elems[0], fluids[0], fluid_elems[0]); RR("");
+  rval = read_file(slavef, slave, solids[1], solid_elems[1], fluids[1], fluid_elems[1]); RR("");
   Tag xnew;
-  rval = write_to_coords(solid_elems[0], xnew); RR("");
-  rval = mb->write_file("deformed.vtk", NULL, NULL, &master, 1); RR("");
+  if (debug) write_and_save(solid_elems[0], master, xnew, "deformed.vtk");
+  if (debug) write_and_save(fluid_elems[0], master, xnew, "smoothed.vtk");
-  rval = mb->write_file("smoothed.vtk", NULL, NULL, &master, 1); RR("");
+    // map new locations to slave
   delete ll;
   delete mb;
@@ -72,6 +82,13 @@ int main(int /*argc*/, char **/*argv*/) {
   return MB_SUCCESS;
+ErrorCode write_and_save(Range &ents, EntithHanlde seth, Tag tagh, const char *filename)
+  rval = write_to_coords(ents, tagh); RR("");
+  rval = mb->write_file("deformed.vtk", NULL, NULL, &seth, 1); RR("");
+  return rval;
diff --git a/examples/LloydRelaxation.cpp b/examples/LloydRelaxation.cpp
index 0cf9d1e..34002cd 100644
--- a/examples/LloydRelaxation.cpp
+++ b/examples/LloydRelaxation.cpp
@@ -14,8 +14,10 @@
  * in the current directory (H5M format must be used since the file is written in parallel).
-#include "moab/ParallelComm.hpp"
-#include "MBParallelConventions.h"
+#ifdef USE_MPI
+#  include "moab/ParallelComm.hpp"
+#  include "MBParallelConventions.h"
+#endif
@@ -30,7 +32,7 @@ string test_file_name = string(MESH_DIR) + string("/surfrandomtris-4part.h5m");
 #define RC if (MB_SUCCESS != rval) return rval
-ErrorCode perform_lloyd_relaxation(ParallelComm *pc, Range &verts, Range &cells, Tag fixed,
+ErrorCode perform_lloyd_relaxation(Interface *mb, Range &verts, Range &cells, Tag fixed,
                                    int num_its, int report_its);
@@ -38,7 +40,9 @@ int main(int argc, char **argv)
   int num_its = 10;
   int report_its = 1;
+#ifdef USE_MPI
   MPI_Init(&argc, &argv);
+#endif
     // need option handling here for input filename
   if (argc > 1){
@@ -49,10 +53,13 @@ int main(int argc, char **argv)
   // get MOAB and ParallelComm instances
   Interface *mb = new Core;
   if (NULL == mb) return 1;
+  int nprocs = 1;
+#ifdef USE_MPI
   // get the ParallelComm instance
-  ParallelComm* pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
-  int nprocs = pcomm->size();
+  ParallelComm *pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
+  nprocs = pcomm->size();
+#endif
   string options;
   if (nprocs > 1) // if reading in parallel, need to tell it how
     options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1;DEBUG_IO=0;DEBUG_PIO=0";
@@ -76,34 +83,45 @@ int main(int argc, char **argv)
     // ok to mark non-owned skin vertices too, I won't move those anyway
     // use MOAB's skinner class to find the skin
   Skinner skinner(mb);
-  rval = skinner.find_skin(faces, true, skin_verts); RC; // 'true' param indicates we want vertices back, not faces
+  rval = skinner.find_skin(0, faces, true, skin_verts); RC; // 'true' param indicates we want vertices back, not faces
   std::vector<int> fix_tag(skin_verts.size(), 1); // initialized to 1 to indicate fixed
   rval = mb->tag_set_data(fixed, skin_verts, &fix_tag[0]); RC;
     // now perform the Lloyd relaxation
-  rval = perform_lloyd_relaxation(pcomm, verts, faces, fixed, num_its, report_its); RC;
+  rval = perform_lloyd_relaxation(mb, verts, faces, fixed, num_its, report_its); RC;
     // delete fixed tag, since we created it here
   rval = mb->tag_delete(fixed); RC;
     // output file, using parallel write
-  rval = mb->write_file("lloydfinal.h5m", NULL, "PARALLEL=WRITE_PART"); RC;
+#ifdef USE_MPI
+  options = "PARALLEL=WRITE_PART";
+#endif
+  rval = mb->write_file("lloydfinal.h5m", NULL, options.c_str()); RC;
     // delete MOAB instance
   delete mb;
+#ifdef USE_MPI
   MPI_Finalize();
+#endif
   return 0;
-ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &faces, Tag fixed,
+ErrorCode perform_lloyd_relaxation(Interface *mb, Range &verts, Range &faces, Tag fixed,
   ErrorCode rval;
-  Interface *mb = pcomm->get_moab();
+  int nprocs = 1;
+#ifdef USE_MPI
+  ParallelComm *pcomm = ParallelComm::get_pcomm(mb, 0);
+#endif
@@ -120,8 +138,10 @@ ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &fac
   if (nprocs > 1) {
+#ifdef USE_MPI
     rval = pcomm->filter_pstatus(verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_verts);
     if (rval != MB_SUCCESS) return rval;
+#endif
   else
@@ -133,11 +153,13 @@ ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &fac
   rval = mb->tag_get_data(centroid, owned_verts, &vcentroids[0]); RC;
+#ifdef USE_MPI
   rval = pcomm->get_shared_entities(-1, shared_owned_verts, 0, false, true); RC;
+#endif
   std::vector<double> fcentroids(3*faces.size()); // fcentroids for face centroids
@@ -195,16 +217,22 @@ ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &fac
     if (nprocs > 1) {
+#ifdef USE_MPI
       rval = pcomm->exchange_tags(centroid, shared_owned_verts); RC;
+#endif
     if (!(nit%report_its)) {
       double global_max = mxdelta;
+      int myrank = 0;
+#ifdef USE_MPI
       if (nprocs > 1)
         MPI_Reduce(&mxdelta, &global_max, 1, MPI_DOUBLE, MPI_MAX, 0, pcomm->comm());
-      if (1 == nprocs || !pcomm->rank())
+      myrank = pcomm->rank();
+#endif
+      if (1 == nprocs || !myrank)
         cout << "Max delta = " << global_max << endl;
https://bitbucket.org/fathomteam/moab/commits/13f6ad9ea2c7/
Changeset:   13f6ad9ea2c7
Branch:      None
User:        tautges
Date:        2013-09-18 01:09:49
Summary:     Merge branch '00c578e' into deformed-mesh-remap
Conflicts:
	src/Makefile.am
	test/Makefile.am
Affected #:  6 files
diff --git a/.gitignore b/.gitignore
--- a/.gitignore
+++ b/.gitignore
 test/kd_tree_test
 test/kd_tree_time
 test/kd_tree_tool
 test/mbcn_test
 test/mbfacet_test
 test/mbground_test
--- /dev/null
@@ -0,0 +1,220 @@
+#ifdef USE_MPI
+#endif
+    return rval;}
+namespace moab {
+  ErrorCode rval;
+  if (0 > absTol) {
+    BoundBox bb;
+  Range verts;
+  Tag centroid;
+#ifdef USE_MPI
+  else
+#else
+#endif
+  int nconn;
+  numIts = 0;
+    numIts++;
+    resid = 0.0;
+        // if !fixed
+#ifdef USE_MPI
+#endif
+#ifdef USE_MPI
+#endif
+  } // end while
+  if (!fixedTag) {
+#ifdef USE_MPI
+    if (myPcomm) {
+#endif
diff --git a/src/Makefile.am b/src/Makefile.am
index dc0c3f2..4249153 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -65,6 +65,7 @@ libMOAB_la_SOURCES = \
   HigherOrderFactory.cpp \
   HomXform.cpp \
   Internals.hpp \
   MBCNArrays.hpp \
   MergeMesh.cpp \
   MeshSet.cpp \
@@ -167,6 +168,7 @@ nobase_libMOAB_la_include_HEADERS = \
   moab/Forward.hpp \
   moab/GeomUtil.hpp \
   moab/Interface.hpp \
--- /dev/null
@@ -0,0 +1,145 @@
+namespace moab {
+class Error;
+public:
+  ~LloydSmoother();
+private:
+    //- MOAB instance
+    //- ParallelComm
+  Range myElems;
+  Tag fixedTag;
+    //- tolerances
+  int reportIts;
+  int numIts;
+  bool iCreatedTag;
+#endif
index e4d591f..622c86c 100644
@@ -48,7 +48,8 @@ TESTS = range_test \
 	elem_eval_test \
 	spatial_locator_test \
-	test_boundbox
+        test_boundbox \
 if HDF5_FILE
@@ -144,6 +145,7 @@ coords_connect_iterate_SOURCES = coords_connect_iterate.cpp
 if PARALLEL
--- /dev/null
@@ -0,0 +1,41 @@
+#ifdef MESHDIR
+#else
+#endif
+  Core mb;
+  CHECK_ERR(rval);
+  Range elems;
+  CHECK_ERR(rval);
+    CHECK_ERR(rval);
+  CHECK_ERR(rval);
https://bitbucket.org/fathomteam/moab/commits/5048df95db0f/
Changeset:   5048df95db0f
Branch:      None
User:        tautges
Date:        2013-09-18 01:11:03
Summary:     Merge branch 'da78fb058' into deformed-mesh-remap
Affected #:  3 files
@@ -17,9 +17,9 @@
 namespace moab {
+  if (!coordsTag) {
+  else {
   Tag centroid;
   } // end while
+  if (!coordsTag) {
+  else {
   return MB_SUCCESS;
   Range myElems;
+  Tag coordsTag;
   Tag fixedTag;
@@ -1,5 +1,6 @@
 #ifdef MESHDIR
+  Tag ctag;
+  CHECK_ERR(rval);
+  Range verts;
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
   ll.report_its(10);
   CHECK_ERR(rval);
+    // iterations
+  CHECK_ERR(rval);
+  unsigned int i;
+  CHECK_ERR(rval);
+  CHECK_ERR(rval);
https://bitbucket.org/fathomteam/moab/commits/a1b3900d27b0/
Changeset:   a1b3900d27b0
Branch:      None
User:        tautges
Date:        2013-09-18 01:12:54
Summary:     Merge branch 'c1d28fa' into deformed-mesh-remap
Conflicts:
	examples/makefile
Affected #:  2 files
--- /dev/null
@@ -0,0 +1,180 @@
+#ifndef MESH_DIR
+#endif
+Interface *mb;
+  ErrorCode rval;
+  mb = new Core();
+  Tag xnew;
+  delete ll;
+  delete mb;
+  Range verts;
+    // create the tag
+  Range verts;
+  verts.clear();
+    // create meshset
+  Tag tagh;
+  Range tmp_range;
index ff5876c..87c0132 100644
@@ -48,6 +48,8 @@ TestExodusII: TestExodusII.o
 point_in_elem_search: point_in_elem_search.o
 clean:
https://bitbucket.org/fathomteam/moab/commits/530265f9a39c/
Changeset:   530265f9a39c
Branch:      None
User:        tautges
Date:        2013-09-18 01:13:16
Summary:     Merge branch 'a8f966f' into deformed-mesh-remap
Affected #:  2 files
@@ -13,6 +13,7 @@
 #include <iostream>
 Interface *mb;
   ErrorCode rval;
+  std::string foo;
   mb = new Core();
   Tag xnew;
   delete ll;
   delete mb;
   return MB_SUCCESS;
+  return rval;
@@ -14,8 +14,10 @@
+#ifdef USE_MPI
+#endif
   int num_its = 10;
   int report_its = 1;
+#ifdef USE_MPI
+#endif
   if (argc > 1){
+  int nprocs = 1;
+#ifdef USE_MPI
+#endif
   string options;
+#ifdef USE_MPI
+#endif
   delete mb;
+#ifdef USE_MPI
   MPI_Finalize();
+#endif
   return 0;
   ErrorCode rval;
+  int nprocs = 1;
+#ifdef USE_MPI
+#endif
   if (nprocs > 1) {
+#ifdef USE_MPI
+#endif
   else
+#ifdef USE_MPI
+#endif
     if (nprocs > 1) {
+#ifdef USE_MPI
+#endif
+      int myrank = 0;
+#ifdef USE_MPI
       if (nprocs > 1)
+#endif
https://bitbucket.org/fathomteam/moab/commits/e2e1ffac2d54/
Changeset:   e2e1ffac2d54
Branch:      deformed-mesh-remap
User:        tautges
Date:        2013-10-02 18:38:22
Summary:     Make a DeformMeshRemap class and implement through that.
Affected #:  1 file
index 55ac3cc..fac83ae 100644
@@ -17,6 +17,7 @@
 #include <iostream>
+#include <set>
 #include <assert.h>
@@ -37,11 +38,212 @@ const int SOLID_SETNO = 100, FLUID_SETNO = 200;
 Interface *mb;
+const bool debug = true;
+class DeformMeshRemap
+public:
+    //! enumerator for solid/fluid, master/slave
+  enum {MASTER=0, SLAVE, SOLID, FLUID};
+    //! constructor
+  DeformMeshRemap(Interface *impl) : mbImpl(impl), masterSet(0), slaveSet(0), xNew(0), xNewName("xnew") {}
+    //! destructor
+  ~DeformMeshRemap();
+    //! execute the deformed mesh process
+  ErrorCode execute();
+    //! add a set number
+  ErrorCode add_set_no(int fluid_or_solid, int set_no);
+    //! remove a set number
+  ErrorCode remove_set_no(int fluid_or_solid, int set_no);
+    //! get the set numbers
+  ErrorCode get_set_nos(int fluid_or_solid, std::set<int> &set_nos) const;
+    //! get the xNew tag handle
+  inline Tag x_new() const {return xNew;}
+    //! get the tag name
+  std::string x_new_name() const {return xNewName;}
+    //! set the tag name
+  void x_new_name(const std::string &name) {xNewName = name;}
+    //! get/set the file name
+  std::string get_file_name(int m_or_s) const;
+  void set_file_name(int m_or_s, const std::string &name);
+private:
+    //! apply a known deformation to the solid elements, putting the results in the xNew tag; also
+    //! write current coordinates to the xNew tag for fluid elements
+  ErrorCode deform_master(Range &fluid_elems, Range &solid_elems);
+    //! read a file and establish proper ranges
+  ErrorCode read_file(int m_or_s, string &fname, EntityHandle &seth);
+    //! write the input tag to the coordinates for the vertices in the input elems
+  ErrorCode write_to_coords(Range &elems, Tag tagh);
+    //! write the tag to the vertices, then save to the specified file
+  ErrorCode write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename);
+    //! moab interface
+    //! material set numbers for fluid materials
+  std::set<int> fluidSetNos;
+    //! material set numbers for solid materials
+  std::set<int> solidSetNos;
+    //! sets defining master/slave meshes
+  EntityHandle masterSet, slaveSet;
+    //! sets in master/slave meshes
+  Range fluidSets[2], solidSets[2];
+    //! elements in master/slave meshes
+  Range fluidElems[2], solidElems[2];
+    //! filenames for master/slave meshes
+  std::string masterFileName, slaveFileName;
+    //! tag used for new positions
+  Tag xNew;
+    //! tag name used for new positions
+  std::string xNewName;
+inline ErrorCode DeformMeshRemap::add_set_no(int f_or_s, int set_no)
+  std::set<int> *this_set;
+  switch (f_or_s) {
+    case FLUID:
+        this_set = &fluidSetNos; break;
+    case SOLID:
+        this_set = &solidSetNos; break;
+    default:
+        assert(false && "f_or_s should be FLUID or SOLID.");
+        return MB_FAILURE;
+  this_set->insert(set_no);
+inline ErrorCode DeformMeshRemap::remove_set_no(int f_or_s, int set_no)
+  switch (f_or_s) {
+    case FLUID:
+    case SOLID:
+    default:
+  std::set<int>::iterator sit = this_set->find(set_no);
+  if (sit != this_set->end()) {
+    this_set->erase(*sit);
+inline ErrorCode DeformMeshRemap::get_set_nos(int f_or_s, std::set<int> &set_nos) const
+  const std::set<int> *this_set;
+  switch (f_or_s) {
+    case FLUID:
+    case SOLID:
+    default:
+  set_nos = *this_set;
+ErrorCode DeformMeshRemap::execute()
+  ErrorCode rval = read_file(MASTER, masterFileName, masterSet);
+  rval = read_file(SLAVE, slaveFileName, slaveSet);
+  rval = deform_master(fluidElems[MASTER], solidElems[MASTER]); RR("");
+  if (debug) write_and_save(solidElems[MASTER], masterSet, xNew, "deformed.vtk");
+  LloydSmoother *ll = new LloydSmoother(mbImpl, NULL, fluidElems[MASTER], xNew);
+  if (debug) write_and_save(fluidElems[MASTER], masterSet, xNew, "smoothed.vtk");
+  delete ll;
+std::string DeformMeshRemap::get_file_name(int m_or_s) const
+  switch (m_or_s) {
+    case MASTER:
+        return masterFileName;
+    case SLAVE:
+        return slaveFileName;
+    default:
+        assert(false && "m_or_s should be MASTER or SLAVE.");
+        return std::string();
+void DeformMeshRemap::set_file_name(int m_or_s, const std::string &name)
+  switch (m_or_s) {
+    case MASTER:
+        masterFileName = name; break;
+    case SLAVE:
+        slaveFileName = name; break;
+    default:
+DeformMeshRemap::~DeformMeshRemap()
+    // delete the tag
+  mbImpl->tag_delete(xNew);
-  EntityHandle master, slave;
   ErrorCode rval;
@@ -56,49 +258,34 @@ int main(int argc, char **argv) {
   mb = new Core();
-    // read master/slave files and get fluid/solid material sets
-  Range fluids[2], solids[2], solid_elems[2], fluid_elems[2];
-  rval = read_file(masterf, master, solids[0], solid_elems[0], fluids[0], fluid_elems[0]); RR("");
-  rval = read_file(slavef, slave, solids[1], solid_elems[1], fluids[1], fluid_elems[1]); RR("");
-    // deform the master's solid mesh, put results in a new tag
-  Tag xnew;
-  rval = deform_master(fluid_elems[0], solid_elems[0], xnew); RR("");
-  if (debug) write_and_save(solid_elems[0], master, xnew, "deformed.vtk");
+  DeformMeshRemap dfr(mb);
+  dfr.set_file_name(DeformMeshRemap::MASTER, masterf);
+  dfr.set_file_name(DeformMeshRemap::SLAVE, slavef);
+  rval = dfr.add_set_no(DeformMeshRemap::SOLID, SOLID_SETNO); RR("Failed to add solid set no.");
+  rval = dfr.add_set_no(DeformMeshRemap::FLUID, FLUID_SETNO); RR("Failed to add fluid set no.");
-    // smooth the master mesh
-  LloydSmoother *ll = new LloydSmoother(mb, NULL, fluid_elems[0], xnew);
-  rval = ll->perform_smooth();
-  RR("Failed in lloyd smoothing.");
-  cout << "Lloyd smoothing required " << ll->num_its() << " iterations." << endl;
-  if (debug) write_and_save(fluid_elems[0], master, xnew, "smoothed.vtk");
-    // map new locations to slave
-  delete ll;
-  delete mb;
-  return MB_SUCCESS;
+  rval = dfr.execute();
+  return rval;
-ErrorCode write_and_save(Range &ents, EntithHanlde seth, Tag tagh, const char *filename)
+ErrorCode DeformMeshRemap::write_and_save(Range &ents, EntityHandle seth, Tag tagh, const char *filename)
-  rval = write_to_coords(ents, tagh); RR("");
-  rval = mb->write_file("deformed.vtk", NULL, NULL, &seth, 1); RR("");
+  ErrorCode rval = write_to_coords(ents, tagh); RR("");
+  rval = mbImpl->write_file(filename, NULL, NULL, &seth, 1); RR("");
   return rval;
-ErrorCode write_to_coords(Range &elems, Tag tagh)
+ErrorCode DeformMeshRemap::write_to_coords(Range &elems, Tag tagh)
   Range verts;
-  ErrorCode rval = mb->get_adjacencies(elems, 0, false, verts, Interface::UNION);
+  ErrorCode rval = mbImpl->get_adjacencies(elems, 0, false, verts, Interface::UNION);
-  rval = mb->tag_get_data(tagh, verts, &coords[0]);
+  rval = mbImpl->tag_get_data(tagh, verts, &coords[0]);
-  rval = mb->set_coords(verts, &coords[0]);
+  rval = mbImpl->set_coords(verts, &coords[0]);
   return MB_SUCCESS;
@@ -115,83 +302,92 @@ void deform_func(double *xold, double *xnew)
-ErrorCode deform_master(Range &fluid_elems, Range &solid_elems, Tag &xnew)
+ErrorCode DeformMeshRemap::deform_master(Range &fluid_elems, Range &solid_elems)
     // create the tag
-  ErrorCode rval = mb->tag_get_handle("", 3, MB_TYPE_DOUBLE, xnew, MB_TAG_CREAT|MB_TAG_DENSE);
+  ErrorCode rval = mbImpl->tag_get_handle("", 3, MB_TYPE_DOUBLE, xNew, MB_TAG_CREAT|MB_TAG_DENSE);
   Range verts;
-  rval = mb->get_adjacencies(fluid_elems, 0, false, verts, Interface::UNION);
+  rval = mbImpl->get_adjacencies(fluid_elems, 0, false, verts, Interface::UNION);
-  rval = mb->get_coords(verts, &coords[0]);
+  rval = mbImpl->get_coords(verts, &coords[0]);
-  rval = mb->tag_set_data(xnew, verts, &coords[0]);
+  rval = mbImpl->tag_set_data(xNew, verts, &coords[0]);
   verts.clear();
-  rval = mb->get_adjacencies(solid_elems, 0, false, verts, Interface::UNION);
+  rval = mbImpl->get_adjacencies(solid_elems, 0, false, verts, Interface::UNION);
   return MB_SUCCESS;
-ErrorCode read_file(string &fname, EntityHandle &seth,
-                    Range &solids, Range &solid_elems, Range &fluids, Range &fluid_elems)
+ErrorCode DeformMeshRemap::read_file(int m_or_s, string &fname, EntityHandle &seth)
     // create meshset
-  ErrorCode rval = mb->create_meshset(0, seth);
+  ErrorCode rval = mbImpl->create_meshset(0, seth);
-  rval = mb->load_file(fname.c_str(), &seth);
+  rval = mbImpl->load_file(fname.c_str(), &seth);
   Tag tagh;
-  rval = mb->tag_get_handle(MATERIAL_SET_TAG_NAME, tagh); RR("Couldn't get material set tag name.");
-  const void *setno_ptr = &SOLID_SETNO;
-  rval = mb->get_entities_by_type_and_tag(seth, MBENTITYSET, &tagh, &setno_ptr, 1, solids);
-  if (solids.empty()) rval = MB_FAILURE;
-  RR("Couldn't get any solid sets.");
+  rval = mbImpl->tag_get_handle(MATERIAL_SET_TAG_NAME, tagh); RR("Couldn't get material set tag name.");
+  for (std::set<int>::iterator sit = solidSetNos.begin(); sit != solidSetNos.end(); sit++) {
+    Range sets;
+    int set_no = *sit;
+    const void *setno_ptr = &set_no;
+    rval = mbImpl->get_entities_by_type_and_tag(seth, MBENTITYSET, &tagh, &setno_ptr, 1, sets);
+    if (sets.empty()) rval = MB_FAILURE;
+    solidSets[m_or_s].merge(sets);
   Range tmp_range;
-  for (Range::iterator rit = solids.begin(); rit != solids.end(); rit++) {
-    rval = mb->get_entities_by_handle(*rit, tmp_range, true);
+  for (Range::iterator rit = solidSets[m_or_s].begin(); rit != solidSets[m_or_s].end(); rit++) {
+    rval = mbImpl->get_entities_by_handle(*rit, tmp_range, true);
-  int dim = mb->dimension_from_handle(*tmp_range.rbegin());
+  int dim = mbImpl->dimension_from_handle(*tmp_range.rbegin());
-  solid_elems = tmp_range.subset_by_dimension(dim);
+  solidElems[m_or_s] = tmp_range.subset_by_dimension(dim);
-  setno_ptr = &FLUID_SETNO;
-  rval = mb->get_entities_by_type_and_tag(seth, MBENTITYSET, &tagh, &setno_ptr, 1, fluids);
-  if (fluids.empty()) rval = MB_FAILURE;
-  RR("Couldn't get any fluid sets.");
-  for (Range::iterator rit = fluids.begin(); rit != fluids.end(); rit++) {
-    rval = mb->get_entities_by_dimension(*rit, dim, fluid_elems, true);
-    RR("Failed to get entities in fluid.");
+  for (std::set<int>::iterator sit = fluidSetNos.begin(); sit != fluidSetNos.end(); sit++) {
+    Range sets;
+    fluidSets[m_or_s].merge(sets);
-  if (mb->dimension_from_handle(*fluid_elems.begin()) != dim) {
-    rval = MB_FAILURE;
-    RR("Fluid and solid elements must be same dimension.");
+    // get fluid entities, and dimension
+  tmp_range.clear();
+  for (Range::iterator rit = fluidSets[m_or_s].begin(); rit != fluidSets[m_or_s].end(); rit++) {
+  fluidElems[m_or_s] = tmp_range.subset_by_dimension(dim);
   return MB_SUCCESS;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
