[MOAB-dev] commit/MOAB: 5 new changesets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue May 7 11:01:14 CDT 2013
5 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/e38337a1e926/
Changeset:   e38337a1e926
Branch:      None
User:        iulian07
Date:        2013-04-24 21:23:31
Summary:     Merge branch 'master' of bitbucket.org:fathomteam/moab
Affected #:  5 files
diff --git a/examples/DirectAccessNoHoles.cpp b/examples/DirectAccessNoHoles.cpp
new file mode 100644
index 0000000..445c517
--- /dev/null
+++ b/examples/DirectAccessNoHoles.cpp
@@ -0,0 +1,179 @@
+/** @example DirectAccess.cpp \n
+ * \brief Use direct access to MOAB data to avoid calling through API \n
+ * This example creates a 1d row of quad elements, with a user-specified number of "holes" (missing quads) in the row:
+ *  |      |      |      |(hole)|      |      |      |(hole)|      | ...
+ * This makes (nholes+1) contiguous runs of quad handles in the handle space
+ * This example shows how to use the xxx_iterate functions in MOAB (xxx = coords, connect, tag, adjacencies) to get
+ * direct pointer access to MOAB internal storage, which can be used without calling through the MOAB API.
+ *    -#  Initialize MOAB \n
+ *    -#  Create a quad mesh with holes, as depicted above
+ *    -#  Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad (tag3)
+ *    -#  Get connectivity, coordinate, tag1 iterators
+ *    -#  Iterate through quads, computing midpoint based on vertex positions, set on quad-based tag1
+ *    -#  Set up map from starting quad handle for a chunk to struct of (tag1_ptr, tag2_ptr, tag3_ptr), pointers to
+ *        the dense tag storage for those tags for the chunk
+ *    -#  Iterate through vertices, summing positions into tag2 on connected quads and incrementing vertex count
+ *    -#  Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and tag2
+ * <b>To compile</b>: \n
+ *    make DirectAccessWithHoles MOAB_DIR=<installdir>  \n
+ * <b>To run</b>: ./DirectAccess [-nquads <# quads>] [-holes <# holes>]\n
+#include "moab/Core.hpp"
+#include "moab/ProgOptions.hpp"
+#include "moab/ReadUtilIface.hpp"
+#include <map>
+#include <iostream>
+#include <assert.h>
+// Error routines for use with MOAB API
+#define CHKERR(CODE, MSG) do {if (MB_SUCCESS != (CODE)) {std::string errstr;  mbImpl->get_last_error(errstr);   \
+        std::cerr << errstr << std::endl; std::cerr << MSG << std::endl; return CODE;}} while(false)
+using namespace moab;
+ErrorCode create_mesh_no_holes(Interface *mbImpl, int nquads);
+int main(int argc, char **argv)
+    // get MOAB instance
+  Interface *mbImpl = new Core;
+  if (NULL == mbImpl) return 1;
+  int nquads = 1000;
+    // parse options
+  ProgOptions opts;
+  opts.addOpt<int>(std::string("nquads,n"), std::string("Number of quads in the mesh (default = 1000"), &nquads);
+  opts.parseCommandLine(argc, argv);
+    // create simple structured mesh with hole, but using unstructured representation
+  ErrorCode rval = create_mesh_no_holes(mbImpl, nquads); CHKERR(rval, "Trouble creating mesh.");
+    // get all vertices and non-vertex entities
+  Range verts, quads;
+  rval = mbImpl->get_entities_by_handle(0, quads); CHKERR(rval, "Getting all entities.");
+  verts = quads.subset_by_dimension(0);
+  quads -= verts;
+    // create tag1 (element-based avg), tag2 (vertex-based avg), tag3 (# connected verts)
+  Tag tag1, tag2, tag3;
+  rval = mbImpl->tag_get_handle("tag1", 3, MB_TYPE_DOUBLE, tag1, MB_TAG_DENSE | MB_TAG_CREAT); CHKERR(rval, "Creating tag1.");
+  double def_val[3] = {0.0, 0.0, 0.0}; // need a default value for tag2 because we sum into it
+  rval = mbImpl->tag_get_handle("tag2", 3, MB_TYPE_DOUBLE, tag2, MB_TAG_DENSE | MB_TAG_CREAT, def_val); CHKERR(rval, "Creating tag2.");
+  int def_val_int = 0;  // need a default value for tag3 because we increment it
+  rval = mbImpl->tag_get_handle("tag3", 1, MB_TYPE_INTEGER, tag3, MB_TAG_DENSE | MB_TAG_CREAT, &def_val_int); CHKERR(rval, "Creating tag3.");
+    // Get pointers to connectivity, coordinate, tag, and adjacency arrays; each of these returns a count,
+    // which should be compared to the # entities you expect to verify there's only one chunk (no holes)
+  int count, vpere;
+  EntityHandle *conn_ptr;
+  rval = mbImpl->connect_iterate(quads.begin(), quads.end(), conn_ptr, vpere, count); CHKERR(rval, "connect_iterate.");
+  assert(count == (int) quads.size()); // should end up with just one contiguous chunk of quads
+  double *x_ptr, *y_ptr, *z_ptr;
+  rval = mbImpl->coords_iterate(verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count); CHKERR(rval, "coords_iterate.");
+  assert(count == (int) verts.size()); // should end up with just one contiguous chunk of vertices
+  double *tag1_ptr, *tag2_ptr;
+  int *tag3_ptr;
+  rval = mbImpl->tag_iterate(tag1, quads.begin(), quads.end(), count, (void*&)tag1_ptr); CHKERR(rval, "tag1_iterate.");
+  rval = mbImpl->tag_iterate(tag2, quads.begin(), quads.end(), count, (void*&)tag2_ptr); CHKERR(rval, "tag2_iterate.");
+  rval = mbImpl->tag_iterate(tag3, quads.begin(), quads.end(), count, (void*&)tag3_ptr); CHKERR(rval, "tag3_iterate.");
+  const std::vector<EntityHandle> **adjs_ptr;
+  rval = mbImpl->adjacencies_iterate(verts.begin(), verts.end(), adjs_ptr, count); CHKERR(rval, "adjacencies_iterate.");
+    // Start_ handles used to compute indices into vertex/quad arrays; can use direct subtraction because we know
+    // there aren't any holes in the handle spaces for verts or quads
+  EntityHandle start_vert = *verts.begin(), start_quad = *quads.begin();
+    // iterate over elements, computing tag1 from coords positions
+  for (int i = 0; i < nquads; i++) {
+    tag1_ptr[3*i+0] = tag1_ptr[3*i+1] = tag1_ptr[3*i+2] = 0.0; // initialize position for this element
+    for (int j = 0; j < vpere; j++) { // loop over vertices in this element
+      int v_index = conn_ptr[vpere*i+j] - start_vert; // vert index is just the offset from start vertex
+      tag1_ptr[3*i+0] += x_ptr[v_index];
+      tag1_ptr[3*i+1] += y_ptr[v_index]; // sum vertex positions into tag1...
+      tag1_ptr[3*i+2] += z_ptr[v_index];
+    tag1_ptr[3*i+0] /= vpere;
+    tag1_ptr[3*i+1] /= vpere; // then normalize
+    tag1_ptr[3*i+2] /= vpere;
+  } // loop over elements in chunk
+    // Iterate through vertices, summing positions into tag2 on connected elements and incrementing vertex count
+  for (int v = 0; v < count; v++) {
+    const std::vector<EntityHandle> *avec = *(adjs_ptr+v);
+    for (std::vector<EntityHandle>::const_iterator ait = avec->begin(); ait != avec->end(); ait++) {
+        // *ait is the quad handle, its index is computed by subtracting the start quad handle
+      int a_ind = *ait - start_quad;
+      tag2_ptr[3*a_ind+0] += x_ptr[v];   // tag on each element is 3 doubles, x/y/z
+      tag2_ptr[3*a_ind+1] += y_ptr[v];
+      tag2_ptr[3*a_ind+2] += z_ptr[v];
+      tag3_ptr[a_ind]++;  // increment the vertex count
+    // Normalize tag2 by vertex count (tag3); loop over elements using same approach as before
+    // At the same time, compare values of tag1 and tag2
+  for (Range::iterator q_it = quads.begin(); q_it != quads.end(); q_it++) {
+    int i = *q_it - start_quad;
+    for (int j = 0; j < 3; j++) tag2_ptr[3*i+j] /= (double)tag3_ptr[i];  // normalize by # verts
+    if (tag1_ptr[3*i] != tag2_ptr[3*i] || tag1_ptr[3*i+1] != tag2_ptr[3*i+1] || tag1_ptr[3*i+2] != tag2_ptr[3*i+2])
+      std::cout << "Tag1, tag2 disagree for element " << *q_it + i << std::endl;
+    // Ok, we're done, shut down MOAB
+  delete mbImpl;
+  return 0;
+    // first make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are numbered in layers
+  ReadUtilIface *read_iface;
+  ErrorCode rval = mbImpl->query_interface(read_iface); CHKERR(rval, "query_interface");
+  std::vector<double *> coords;
+  EntityHandle start_vert, start_elem, *connect;
+    // create verts, num is 4(nquads+1) because they're in a 1d row; will initialize coords in loop over quads later
+  rval = read_iface->get_node_coords (3, 2*(nquads+1), 0, start_vert, coords); CHKERR(rval, "get_node_arrays");
+    // create quads
+  rval = read_iface->get_element_connect(nquads, 4, MBQUAD, 0, start_elem, connect); CHKERR(rval, "get_element_connect");
+    coords[0][2*i] = coords[0][2*i+1] = (double) i; // x values are all i
+    coords[1][2*i] = 0.0; coords[1][2*i+1] = 1.0; // y coords
+    coords[2][2*i] = coords[2][2*i+1] = (double) 0.0; // z values, all zero (2d mesh)
+    EntityHandle quad_v = start_vert + 2*i;
+    for (int j = 0; j < 4; j++) connect[4*i+j] = quad_v+j; // connectivity of each quad is a sequence starting from quad_v
+    // last two vertices
+  coords[0][2*nquads] = coords[0][2*nquads+1] = (double) nquads;
+  coords[1][2*nquads] = 0.0; coords[1][2*nquads+1] = 1.0; // y coords
+  coords[2][2*nquads] = coords[2][2*nquads+1] = (double) 0.0; // z values, all zero (2d mesh)
+    // call a vertex-quad adjacencies function to generate vertex-element adjacencies in MOAB
+  Range dum_range;
+  rval = mbImpl->get_adjacencies(&start_vert, 1, 2, false, dum_range); CHKERR(rval, "get_adjacencies");
+  assert(!dum_range.empty());
+  return MB_SUCCESS;
diff --git a/examples/DirectAccessWithHoles.cpp b/examples/DirectAccessWithHoles.cpp
index 0000000..524c30f
--- /dev/null
+++ b/examples/DirectAccessWithHoles.cpp
@@ -0,0 +1,239 @@
+#include <map>
+ErrorCode create_mesh_with_holes(Interface *mbImpl, int nquads, int nholes);
+struct tag_struct {double *avg_ptr; int *nv_ptr;};
+  int nquads = 1000, nholes = 1;
+    // parse options
+  ProgOptions opts;
+  opts.addOpt<int>(std::string("holes,H"), std::string("Number of holes in the element handle space (default = 1"), &nholes);
+  if (nholes >= nquads) {
+    std::cerr << "Number of holes needs to be < number of elements." << std::endl;
+    return 1;
+  ErrorCode rval = create_mesh_with_holes(mbImpl, nquads, nholes); CHKERR(rval, "Trouble creating mesh.");
+  Range verts, elems;
+  rval = mbImpl->get_entities_by_handle(0, elems); CHKERR(rval, "Getting all entities.");
+  verts = elems.subset_by_dimension(0);
+  elems -= verts;
+    // Get connectivity, coordinate, tag, and adjacency iterators
+  double *x_ptr, *y_ptr, *z_ptr, *tag1_ptr, *tag2_ptr;
+  int *tag3_ptr;
+    // First vertex is at start of range (ranges are sorted), and is offset for vertex index calculation
+  EntityHandle first_vert = *verts.begin();
+    // When iterating over elements, each chunk can have a different # vertices; also, count tells you how many
+    // elements are in the current chunk
+  int vpere, count;
+    // Get coordinates iterator, just need this once because we know verts handle space doesn't have holes
+    // Iterate through elements, computing midpoint based on vertex positions, set on element-based tag1
+    // Control loop by iterator over elem range
+  Range::iterator e_it = elems.begin();
+  while (e_it != elems.end()) {
+      // get conn_ptr, tag1_ptr for next contiguous chunk of element handles, and coords pointers for all verts
+    rval = mbImpl->connect_iterate(e_it, elems.end(), conn_ptr, vpere, count); CHKERR(rval, "connect_iterate.");
+    rval = mbImpl->tag_iterate(tag1, e_it, elems.end(), count, (void*&)tag1_ptr); CHKERR(rval, "tag1_iterate.");
+      // iterate over elements in this chunk
+    for (int i = 0; i < count; i++) {
+      tag1_ptr[0] = tag1_ptr[1] = tag1_ptr[2] = 0.0; // initialize position for this element
+        int v_index = conn_ptr[j] - first_vert; // vert index is just the offset from first vertex
+        tag1_ptr[0] += x_ptr[v_index];
+        tag1_ptr[1] += y_ptr[v_index]; // sum vertex positions into tag1...
+        tag1_ptr[2] += z_ptr[v_index];
+      tag1_ptr[0] /= vpere;
+      tag1_ptr[1] /= vpere; // then normalize
+      tag1_ptr[2] /= vpere;
+        // done with this element; advance connect_ptr and tag1_ptr to next element
+      conn_ptr += vpere;
+      tag1_ptr += 3;
+      // done with chunk; advance range iterator by count; will skip over gaps in range
+    e_it += count;
+  } // while loop over all elements
+    // Iterate over chunks the same as elements, even though we know we have only one chunk here, just to show
+    // how it's done
+    // Create a std::map from EntityHandle (first entity handle in chunk) to
+    // tag_struct (ptrs to start of avg/#verts tags for that chunk); then for a given entity handle, we can quickly
+    // find the chunk it's in using map::lower_bound; could have set up this map in earlier loop over elements, but do
+    // it here for clarity
+  std::map< EntityHandle, tag_struct> elem_map;
+  e_it = elems.begin();
+    tag_struct ts = {NULL, NULL};
+    rval = mbImpl->tag_iterate(tag2, e_it, elems.end(), count, (void*&)ts.avg_ptr); CHKERR(rval, "tag2_iterate.");
+    rval = mbImpl->tag_iterate(tag3, e_it, elems.end(), count, (void*&)ts.nv_ptr); CHKERR(rval, "tag3_iterate.");
+    elem_map[*e_it] = ts;
+    e_it += count;
+  Range::iterator v_it = verts.begin();
+  Range dum_range;
+  rval = mbImpl->get_adjacencies(&(*v_it), 1, 2, false, dum_range); CHKERR(rval, "get_adjacencies");
+  while (v_it != verts.end()) {
+      // get coords ptrs, adjs_ptr; can't set tag2_ptr by direct access, because of hole in element handle space
+    rval = mbImpl->coords_iterate(v_it, verts.end(), x_ptr, y_ptr, z_ptr, count); CHKERR(rval, "coords_iterate.");
+    rval = mbImpl->adjacencies_iterate(v_it, verts.end(), adjs_ptr, count); CHKERR(rval, "adjacencies_iterate.");
+          // get chunk that this element resides in; upper_bound points to the first element strictly > key, so get that and decrement
+          // (would work the same as lower_bound with an if-test and decrement)
+        std::map<EntityHandle, tag_struct>::iterator mit = elem_map.upper_bound(*ait); mit--;
+          // index of *ait in that chunk
+        int a_ind = *ait - (*mit).first;
+        tag_struct ts = (*mit).second;
+        ts.avg_ptr[3*a_ind]   += x_ptr[v];   // tag on each element is 3 doubles, x/y/z
+        ts.avg_ptr[3*a_ind+1] += y_ptr[v];
+        ts.avg_ptr[3*a_ind+2] += z_ptr[v];
+        ts.nv_ptr[a_ind]++;  // increment the vertex count
+    v_it += count;
+    // Normalize tag2 by vertex count; loop over elements using same approach as before
+    rval = mbImpl->tag_iterate(tag2, e_it, elems.end(), count, (void*&)tag2_ptr); CHKERR(rval, "tag2_iterate.");
+    rval = mbImpl->tag_iterate(tag3, e_it, elems.end(), count, (void*&)tag3_ptr); CHKERR(rval, "tag3_iterate.");
+        std::cout << "Tag1, tag2 disagree for element " << *e_it + i << std::endl;
+    e_it += count;
+  delete mbImpl;
+  return 0;
+    // create verts, num is 4(nquads+1) because they're in a 1d row; will initialize coords in loop over elems later
+    // create elems
+    // now delete nholes elements, spaced approximately equally through mesh, so contiguous size is about nquads/(nholes+1)
+    // reinterpret start_elem as the next element to be deleted
+  int de = nquads / (nholes + 1);
+  for (int i = 0; i < nholes; i++) {
+    start_elem += de;
+    rval = mbImpl->delete_entities(&start_elem, 1); CHKERR(rval, "delete_entities");
diff --git a/examples/makefile b/examples/makefile
index 4ec6154..fd6585e 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -21,6 +21,12 @@ HelloMoabPar: HelloMoabPar.o
 TestExodusII: TestExodusII.o
 	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
+DirectAccessWithHoles: DirectAccessWithHoles.o
+	${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
+DirectAccessNoHoles: DirectAccessNoHoles.o
 .cpp.o :
 	${MOAB_CXX} ${MOAB_CXXFLAGS} ${MOAB_INCLUDES} -DMESH_DIR=\"${MESH_DIR}\" -c $<
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index d7bcb35..774f7a6 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -2321,6 +2321,10 @@ ErrorCode ReadNC::init_FVCDscd_vals(const FileOptions &opts, EntityHandle file_s
       dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
+  // hack: create dummy tags, if needed, for dimensions like nbnd
+  // with no corresponding variables
+  init_dims_with_no_cvars_info();
   return MB_SUCCESS;
@@ -2699,9 +2703,39 @@ ErrorCode ReadNC::init_EulSpcscd_vals(const FileOptions &opts, EntityHandle file
+  // hack: create dummy tags, if needed, for variables like nbnd
   return MB_SUCCESS;
+void ReadNC::init_dims_with_no_cvars_info() {
+  // hack: look at all dimensions, and see if we have one that does not appear in the list of varInfo names
+  // right now, candidates are ncol and nbnd
+  // for them, create dummy tags
+  for (unsigned int i=0; i<dimNames.size(); i++)
+    // if there is a var with this name, skip, we are fine; if not, create a varInfo...
+    if ( varInfo.find(dimNames[i])!=varInfo.end())
+      continue; // we already have a variable with this dimension name
+    int sizeTotalVar = varInfo.size();
+    std::string var_name(dimNames[i]);
+    VarData &data = varInfo[var_name];
+    data.varName = std::string(var_name);
+    data.varId =sizeTotalVar;
+    data.varTags.resize(1, 0);
+    data.varDataType = NC_DOUBLE; // could be int, actually, but we do not really need the type
+    data.varDims.resize(1);
+    data.varDims[0]= (int)i;
+    data.numAtts=0;
+    data.entLoc = ENTLOCSET;
+    dbgOut.tprintf(2, "Dummy varInfo created for dimension %s\n", dimNames[i].c_str());
+    dummyVarNames.insert(dimNames[i]);
 ErrorCode ReadNC::init_HOMMEucd_vals() {
   ErrorCode rval;
   unsigned int idx;
@@ -2812,29 +2846,10 @@ ErrorCode ReadNC::init_HOMMEucd_vals() {
   // don't read coordinates of columns until we actually create the mesh
-  // hack: look at all dimensions, and see if we have one that does not appear in the list of varInfo names
-  // right now, candidates are ncol and nbnd
-  // for them, create dummy tags
-  for (unsigned int i=0; i<dimNames.size(); i++)
-    // if there is a var with this name, skip, we are fine; if not, create a varInfo...
-    if ( varInfo.find(dimNames[i])!=varInfo.end())
-      continue; // we already have a variable with this dimension name
+  // hack: create dummy tags, if needed, for variables like ncol and nbnd
-    int sizeTotalVar = varInfo.size();
-    std::string var_name(dimNames[i]);
-    VarData &data = varInfo[var_name];
-    data.varName = std::string(var_name);
-    data.varId =sizeTotalVar;
-    data.varTags.resize(1, 0);
-    data.varDataType = NC_DOUBLE; // could be int, actually, but we do not really need the type
-    data.varDims.resize(1);
-    data.varDims[0]= (int)i;
-    data.numAtts=0;
-    data.entLoc = ENTLOCSET;
-    dbgOut.tprintf(2, "Dummy varInfo created for dimension %s\n", dimNames[i].c_str());
-    dummyVarNames.insert(dimNames[i]);
   return MB_SUCCESS;
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index d5a18eb..7bc07d5 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -236,6 +236,10 @@ private:
   //! create COORDS tag for quads coordinate
   ErrorCode create_quad_coordinate_tag(EntityHandle file_set);
+  //! Init info for dimensions that don't have corresponding
+  //! coordinate variables - this info is used for creating tags
+  void init_dims_with_no_cvars_info();
   ErrorCode init_HOMMEucd_vals();
   ErrorCode create_ucd_verts_quads(const FileOptions &opts, EntityHandle tmp_set, Range &quads);
https://bitbucket.org/fathomteam/moab/commits/dd971866630a/
Changeset:   dd971866630a
Branch:      None
User:        iulian07
Date:        2013-04-25 19:59:20
Summary:     Merge branch 'master' of bitbucket.org:iulian07/moab
Affected #:  0 files
https://bitbucket.org/fathomteam/moab/commits/12a0b8de1e11/
Changeset:   12a0b8de1e11
Branch:      None
User:        iulian07
Date:        2013-05-07 16:16:22
Affected #:  9 files
diff --git a/config/compiler.m4 b/config/compiler.m4
index ce00d10..18df411 100644
--- a/config/compiler.m4
+++ b/config/compiler.m4
@@ -126,6 +126,8 @@ fi
 if test "xno" != "x$CHECK_FC"; then
   AC_PROG_FC
   AC_PROG_F77
+  AC_F77_LIBRARY_LDFLAGS
+  AC_FC_LIBRARY_LDFLAGS
 fi
 ]) # FATHOM_CHECK_COMPILERS
diff --git a/configure.ac b/configure.ac
index 66fcf81..1524b06 100644
--- a/configure.ac
+++ b/configure.ac
@@ -67,6 +67,14 @@ if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FC"; then
   AC_FC_WRAPPERS
 fi
+if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FLIBS"; then
+   LIBS="$LIBS $FLIBS"
+fi
+if test "xyes" = "x$ENABLE_FORTRAN" && test "x" != "x$FCLIBS"; then
+   LIBS="$LIBS $FCLIBS"
+fi
 #                           Check for need for extra flags to support cray pointers
@@ -1163,6 +1171,8 @@ AC_SUBST([EXPORT_LTFLAGS])
 AC_SUBST([EXPORT_LDFLAGS])
 AC_SUBST([AM_CXXFLAGS])
 AC_SUBST([AM_CFLAGS])
+  AC_SUBST([AM_FCFLAGS])
+  AC_SUBST([AM_FFLAGS])
 AC_SUBST([DISTCHECK_CONFIGURE_FLAGS])
 AC_ARG_VAR([FC], [FORTRAN compiler command])
index 445c517..340efae 100644
--- a/examples/DirectAccessNoHoles.cpp
@@ -1,31 +1,30 @@
-/** @example DirectAccess.cpp \n
+/** @example DirectAccessNoHoles.cpp \n
- * This example creates a 1d row of quad elements, with a user-specified number of "holes" (missing quads) in the row:
+ * This example creates a 1d row of quad elements, such that all quad and vertex handles
+ * are contiguous in the handle space and in the database.  Then it shows how to get access
+ * to pointers to MOAB-native data for vertex coordinates, quad connectivity, tag storage,
+ * and vertex to quad adjacency lists.  This allows applications to access this data directly
+ * without going through MOAB's API.  In cases where the mesh is not changing (or only mesh
+ * vertices are moving), this can save significant execution time in applications.
- *  |      |      |      |(hole)|      |      |      |(hole)|      | ...
- * This makes (nholes+1) contiguous runs of quad handles in the handle space
- * This example shows how to use the xxx_iterate functions in MOAB (xxx = coords, connect, tag, adjacencies) to get
- * direct pointer access to MOAB internal storage, which can be used without calling through the MOAB API.
- *    -#  Create a quad mesh with holes, as depicted above
+ *    -#  Create a quad mesh, as depicted above
- *    -#  Set up map from starting quad handle for a chunk to struct of (tag1_ptr, tag2_ptr, tag3_ptr), pointers to
- *        the dense tag storage for those tags for the chunk
- *    make DirectAccessWithHoles MOAB_DIR=<installdir>  \n
- * <b>To run</b>: ./DirectAccess [-nquads <# quads>] [-holes <# holes>]\n
+ *    make DirectAccessNoHoles MOAB_DIR=<installdir>  \n
+ * <b>To run</b>: ./DirectAccessNoHoles [-nquads <# quads>]\n
@@ -131,12 +130,16 @@ int main(int argc, char **argv)
+  int n_dis = 0;
-    if (tag1_ptr[3*i] != tag2_ptr[3*i] || tag1_ptr[3*i+1] != tag2_ptr[3*i+1] || tag1_ptr[3*i+2] != tag2_ptr[3*i+2])
+    if (tag1_ptr[3*i] != tag2_ptr[3*i] || tag1_ptr[3*i+1] != tag2_ptr[3*i+1] || tag1_ptr[3*i+2] != tag2_ptr[3*i+2]) {
+      n_dis++;
+  if (!n_dis) std::cout << "All tags agree, success!" << std::endl;
   delete mbImpl;
@@ -151,7 +154,7 @@ ErrorCode create_mesh_no_holes(Interface *mbImpl, int nquads)
-    // create verts, num is 4(nquads+1) because they're in a 1d row; will initialize coords in loop over quads later
+    // create verts, num is 2(nquads+1) because they're in a 1d row; will initialize coords in loop over quads later
     // create quads
@@ -160,8 +163,12 @@ ErrorCode create_mesh_no_holes(Interface *mbImpl, int nquads)
-    for (int j = 0; j < 4; j++) connect[4*i+j] = quad_v+j; // connectivity of each quad is a sequence starting from quad_v
+    connect[4*i+0] = quad_v;
+    connect[4*i+1] = quad_v+2;
+    connect[4*i+2] = quad_v+3;
+    connect[4*i+3] = quad_v+1;
diff --git a/examples/DirectAccessNoHolesF90.F90 b/examples/DirectAccessNoHolesF90.F90
index 0000000..3cf5fa7
--- /dev/null
+++ b/examples/DirectAccessNoHolesF90.F90
@@ -0,0 +1,231 @@
+! @example DirectAccessNoHolesF90.F90 \n
+! \brief Use direct access to MOAB data to avoid calling through API, in Fortran90 \n
+! This example creates a 1d row of quad elements, such that all quad and vertex handles
+! are contiguous in the handle space and in the database.  Then it shows how to get access
+! to pointers to MOAB-native data for vertex coordinates, quad connectivity, and tag storage
+! (vertex to quad adjacency lists aren't accessible from Fortran because they are std::vector's).
+! This allows applications to access this data directly
+! without going through MOAB's API.  In cases where the mesh is not changing (or only mesh
+! vertices are moving), this can save significant execution time in applications.
+! Using direct access (or MOAB in general) from Fortran is complicated in two specific ways:
+! 1) There is no way to use arrays with specified dimension starting/ending values with ISO_C_BINDING;
+!    therefore, all arrays passed back from MOAB/iMesh must use 1-based indices; this makes it a bit
+!    more difficult to traverse the direct arrays.  In this example, I explicitly use indices that
+!    look like my_array(1+v_ind...) to remind users of this.
+! 2) Arithmetic on handles is complicated by the fact that Fortran has no unsigned integer type.  I get
+!    around this by assigning to a C-typed variable first, before the handle arithmetic.  This seems to
+!    work fine.  C-typed variables are part of the Fortran95 standard.
+!    -#  Initialize MOAB \n
+!    -#  Create a quad mesh, as depicted above
+!    -#  Create 2 dense tags (tag1, tag2) for avg position to assign to quads, and # verts per quad (tag3)
+!    -#  Get connectivity, coordinate, tag1 iterators
+!    -#  Iterate through quads, computing midpoint based on vertex positions, set on quad-based tag1
+!    -#  Iterate through vertices, summing positions into tag2 on connected quads and incrementing vertex count
+!    -#  Iterate through quads, normalizing tag2 by vertex count and comparing values of tag1 and tag2
+! <b>To compile</b>: \n
+!    make DirectAccessNoHolesF90 MOAB_DIR=<installdir>  \n
+! <b>To run</b>: ./DirectAccessNoHolesF90 [-nquads <# quads>]\n
+#define CHECK(a) \
+  if (a .ne. iBase_SUCCESS) call exit(a)
+module freem
+  interface
+     subroutine c_free(ptr) bind(C, name='free')
+       use ISO_C_BINDING
+       type(C_ptr), value, intent(in) :: ptr
+     end subroutine c_free
+  end interface
+end module freem
+program DirectAccessNoHolesF90
+  use ISO_C_BINDING
+  use freem
+  implicit none
+#include "iMesh_f.h"
+  ! declarations
+  iMesh_Instance imesh
+  iBase_EntitySetHandle root_set
+  integer ierr, nquads, nquads_tmp, nverts
+  iBase_TagHandle tag1h, tag2h, tag3h
+  TYPE(C_PTR) verts_ptr, quads_ptr, conn_ptr, x_ptr, y_ptr, z_ptr, tag1_ptr, tag2_ptr, tag3_ptr, &
+       tmp_quads_ptr, offsets_ptr  ! pointers that are equivalence'd to arrays using c_f_pointer
+  real(C_DOUBLE), pointer :: x(:), y(:), z(:), tag1(:), tag2(:) ! arrays equivalence'd to pointers
+  integer, pointer :: tag3(:), offsets(:)                       ! arrays equivalence'd to pointers
+  iBase_EntityHandle, pointer :: quads(:), verts(:), conn(:), tmp_quads(:)  ! arrays equivalence'd to pointers
+  iBase_EntityArrIterator viter, qiter
+  integer(C_SIZE_T) :: startv, startq, v_ind, e_ind  ! needed to do handle arithmetic
+  integer count, vpere, e, i, j, v, offsets_size, tmp_quads_size, n_dis
+  character*120 opt
+  ! initialize interface and get root set
+  call iMesh_newMesh("", imesh, ierr); CHECK(ierr)
+  call iMesh_getRootSet(%VAL(imesh), root_set, ierr); CHECK(ierr)
+  ! create mesh
+  nquads_tmp = 1000
+  call create_mesh_no_holes(imesh, nquads_tmp, ierr); CHECK(ierr)
+  ! get all vertices and quads as arrays
+  nverts = 0
+  call iMesh_getEntities(%VAL(imesh), %VAL(root_set), %VAL(0), %VAL(iBase_VERTEX), &
+       verts_ptr, nverts, nverts, ierr); CHECK(ierr)
+  call c_f_pointer(verts_ptr, verts, [nverts])
+  nquads = 0
+  call iMesh_getEntities(%VAL(imesh), %VAL(root_set), %VAL(2), %VAL(iMesh_QUADRILATERAL), &
+       quads_ptr, nquads, nquads, ierr); CHECK(ierr)
+  call c_f_pointer(quads_ptr, quads, [nquads])
+  ! First vertex/quad is at start of vertex/quad list, and is offset for vertex/quad index calculation
+  startv = verts(1); startq = quads(1)
+  call c_free(quads_ptr)  ! free memory we allocated in MOAB
+  ! create tag1 (element-based avg), tag2 (vertex-based avg)
+  opt = 'moab:TAG_STORAGE_TYPE=DENSE moab:TAG_DEFAULT_VALUE=0'
+  call iMesh_createTagWithOptions(%VAL(imesh), 'tag1', opt, %VAL(3), %VAL(iBase_DOUBLE), &
+       tag1h, ierr, %VAL(4), %VAL(56)); CHECK(ierr)
+  call iMesh_createTagWithOptions(%VAL(imesh), 'tag2', opt, %VAL(3), %VAL(iBase_DOUBLE), &
+       tag2h, ierr, %VAL(4), %VAL(56)); CHECK(ierr)
+  ! Get iterator to verts, then pointer to coordinates
+  call iMesh_initEntArrIter(%VAL(imesh), %VAL(root_set), %VAL(iBase_VERTEX), %VAL(iMesh_ALL_TOPOLOGIES), &
+       %VAL(nverts), %VAL(0), viter, ierr); CHECK(ierr)
+  call iMesh_coordsIterate(%VAL(imesh), %VAL(viter), x_ptr, y_ptr, z_ptr, count, ierr); CHECK(ierr)
+  CHECK(count-nverts) ! check that all verts are in one contiguous chunk
+  call c_f_pointer(x_ptr, x, [nverts]); call c_f_pointer(y_ptr, y, [nverts]); call c_f_pointer(z_ptr, z, [nverts])
+  ! Get iterator to quads, then pointers to connectivity and tags
+  call iMesh_initEntArrIter(%VAL(imesh), %VAL(root_set), %VAL(iBase_FACE), %VAL(iMesh_ALL_TOPOLOGIES), &
+       %VAL(nquads), %VAL(0), qiter, ierr); CHECK(ierr)
+  call iMesh_connectIterate(%VAL(imesh), %VAL(qiter), conn_ptr, vpere, count, ierr); CHECK(ierr)
+  call c_f_pointer(conn_ptr, conn, [vpere*nquads])
+  call iMesh_tagIterate(%VAL(imesh), %VAL(tag1h), %VAL(qiter), tag1_ptr, count, ierr); CHECK(ierr)
+  call c_f_pointer(tag1_ptr, tag1, [3*nquads])
+  call iMesh_tagIterate(%VAL(imesh), %VAL(tag2h), %VAL(qiter), tag2_ptr, count, ierr); CHECK(ierr)
+  call c_f_pointer(tag2_ptr, tag2, [3*nquads])
+  ! iterate over elements, computing tag1 from coords positions; use (1+... in array indices for 1-based indexing
+  do i = 0, nquads-1
+     tag1(1+3*i+0) = 0.0; tag1(1+3*i+1) = 0.0; tag1(1+3*i+2) = 0.0 ! initialize position for this element
+     do j = 0, vpere-1 ! loop over vertices in this quad
+        v_ind = conn(1+vpere*i+j) ! assign to v_ind to allow handle arithmetic
+        v_ind = v_ind - startv ! vert index is just the offset from start vertex
+        tag1(1+3*i+0) = tag1(1+3*i+0) + x(1+v_ind)
+        tag1(1+3*i+1) = tag1(1+3*i+1) + y(1+v_ind) ! sum vertex positions into tag1...
+        tag1(1+3*i+2) = tag1(1+3*i+2) + z(1+v_ind)
+     end do
+     tag1(1+3*i+0) = tag1(1+3*i+0) / vpere;
+     tag1(1+3*i+1) = tag1(1+3*i+1) / vpere; ! then normalize
+     tag1(1+3*i+2) = tag1(1+3*i+2) / vpere;
+  end do ! loop over elements in chunk
+  ! Iterate through vertices, summing positions into tag2 on connected elements; get adjacencies all at once,
+  ! could also get them per vertex (time/memory tradeoff)
+  tmp_quads_size = 0
+  offsets_size = 0
+  call iMesh_getEntArrAdj(%VAL(imesh), verts, %VAL(nverts), %VAL(iMesh_QUADRILATERAL), &
+       tmp_quads_ptr, tmp_quads_size, tmp_quads_size, &
+       offsets_ptr, offsets_size, offsets_size, ierr); CHECK(ierr)
+  call c_f_pointer(tmp_quads_ptr, tmp_quads, [tmp_quads_size])
+  call c_f_pointer(offsets_ptr, offsets, [offsets_size])
+  call c_free(verts_ptr)  ! free memory we allocated in MOAB
+  do v = 0, nverts-1
+     do e = 1+offsets(1+v), 1+offsets(1+v+1)-1  ! 1+ because offsets are in terms of 0-based arrays
+        e_ind = tmp_quads(e) ! assign to e_ind to allow handle arithmetic
+        e_ind = e_ind - startq ! e_ind is the quad handle minus the starting quad handle
+        tag2(1+3*e_ind+0) = tag2(1+3*e_ind+0) + x(1+v)
+        tag2(1+3*e_ind+1) = tag2(1+3*e_ind+1) + y(1+v)   ! tag on each element is 3 doubles, x/y/z
+        tag2(1+3*e_ind+2) = tag2(1+3*e_ind+2) + z(1+v)
+     end do
+  end do
+  call c_free(tmp_quads_ptr)  ! free memory we allocated in MOAB
+  call c_free(offsets_ptr)    ! free memory we allocated in MOAB
+  ! Normalize tag2 by vertex count (vpere); loop over elements using same approach as before
+  ! At the same time, compare values of tag1 and tag2
+  n_dis = 0
+  do e = 0, nquads-1
+     do j = 0, 2
+        tag2(1+3*e+j) = tag2(1+3*e+j) / vpere;  ! normalize by # verts
+     end do
+     if (tag1(1+3*e) .ne. tag2(1+3*e) .or. tag1(1+3*e+1) .ne. tag2(1+3*e+1) .or. tag1(1+3*e+2) .ne. tag2(1+3*i+2)) then
+        print *, "Tag1, tag2 disagree for element ", e
+        print *, "tag1: ", tag1(1+3*e), tag1(1+3*e+1), tag1(1+3*e+2)
+        print *, "tag2: ", tag2(1+3*e), tag2(1+3*e+1), tag2(1+3*e+2)
+        n_dis = n_dis + 1
+     end if
+  end do
+  if (n_dis .eq. 0) print *, 'All tags agree, success!'
+    ! Ok, we are done, shut down MOAB
+  call iMesh_dtor(%VAL(imesh), ierr)
+  return
+end program DirectAccessNoHolesF90
+subroutine create_mesh_no_holes(imesh, nquads, ierr)
+  use ISO_C_BINDING
+  use freem
+  implicit none
+  integer nquads, ierr
+  real(C_DOUBLE), pointer :: coords(:,:)
+  TYPE(C_PTR) connect_ptr, tmp_ents_ptr, stat_ptr
+  iBase_EntityHandle, pointer :: connect(:), tmp_ents(:)
+  integer, pointer :: stat(:)
+  integer nverts, tmp_size, stat_size, i
+  ! first make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are numbered in layers
+  ! create verts, num is 2(nquads+1) because they're in a 1d row
+  nverts = 2*(nquads+1)
+  allocate(coords(0:2, 0:nverts-1))
+     coords(0,2*i) = i; coords(0,2*i+1) = i ! x values are all i
+     coords(1,2*i) = 0.0; coords(1,2*i+1) = 1.0 ! y coords
+     coords(2,2*i) = 0.0; coords(2,2*i+1) = 0.0 ! z values, all zero (2d mesh)
+  end do
+  ! last two vertices
+  coords(0, nverts-2) = nquads; coords(0, nverts-1) = nquads
+  coords(1, nverts-2) = 0.0; coords(1, nverts-1) = 1.0 ! y coords
+  coords(2, nverts-2) = 0.0; coords(2, nverts-1) = 0.0 ! z values, all zero (2d mesh)
+  tmp_size = 0
+  call iMesh_createVtxArr(%VAL(imesh), %VAL(nverts), %VAL(iBase_INTERLEAVED), &
+       coords, %VAL(3*nverts), tmp_ents_ptr, tmp_size, tmp_size, ierr); CHECK(ierr)
+  call c_f_pointer(tmp_ents_ptr, tmp_ents, [nverts])
+  deallocate(coords)
+  allocate(connect(0:4*nquads-1))
+     connect(4*i+0) = tmp_ents(1+2*i)
+     connect(4*i+1) = tmp_ents(1+2*i+2)
+     connect(4*i+2) = tmp_ents(1+2*i+3)
+     connect(4*i+3) = tmp_ents(1+2*i+1)
+  end do
+  stat_size = 0
+  stat_ptr = C_NULL_PTR
+  ! re-use tmp_ents here; we know it'll always be larger than nquads so it's ok
+  call iMesh_createEntArr(%VAL(imesh), %VAL(iMesh_QUADRILATERAL), connect, %VAL(4*nquads), &
+       tmp_ents_ptr, tmp_size, tmp_size, stat_ptr, stat_size, stat_size, ierr); CHECK(ierr)
+  ierr = iBase_SUCCESS
+  call c_free(tmp_ents_ptr)
+  call c_free(stat_ptr)
+  deallocate(connect)
+  return
+end subroutine create_mesh_no_holes
index fd6585e..3402f96 100644
@@ -1,7 +1,8 @@
 # MOAB_DIR points to top-level install dir, below which MOAB's lib/ and include/ are located
 include ${MOAB_DIR}/lib/moab.make
+include ${MOAB_DIR}/lib/iMesh-Defs.inc
-.SUFFIXES: .o .cpp
+.SUFFIXES: .o .cpp .F90
 # MESH_DIR is the top-level MOAB source directory, used to locate mesh files that come with MOAB source
 MESH_DIR="../MeshFiles/unittest"
@@ -27,6 +28,12 @@ DirectAccessWithHoles: DirectAccessWithHoles.o
+DirectAccessNoHolesF90: DirectAccessNoHolesF90.o
+	${MOAB_CXX} -o $@ $< ${IMESH_LIBS}
 .cpp.o :
+.F90.o :
+	${IMESH_FC} ${IMESH_FCFLAGS} ${IMESH_INCLUDES} ${IMESH_FCDEFS} -DMESH_DIR=\"${MESH_DIR}\" -c $<
diff --git a/itaps/iBase_f.h.in b/itaps/iBase_f.h.in
index 4a70fd3..90fde77 100644
--- a/itaps/iBase_f.h.in
+++ b/itaps/iBase_f.h.in
@@ -50,7 +50,27 @@
       parameter (iBase_REGION = 3)
       parameter (iBase_ALL_TYPES = 4)
+      integer iBase_AdjacencyCost_MIN
+      integer iBase_UNAVAILABLE
+      integer iBase_ALL_ORDER_1
+      integer iBase_ALL_ORDER_LOGN
+      integer iBase_ALL_ORDER_N
+      integer iBase_SOME_ORDER_1
+      integer iBase_SOME_ORDER_LOGN
+      integer iBase_SOME_ORDER_N
+      integer iBase_AVAILABLE
+      integer iBase_AdjacencyCost_MAX
+      parameter (iBase_AdjacencyCost_MIN = 0)
+      parameter (iBase_UNAVAILABLE = 0)
+      parameter (iBase_ALL_ORDER_1 = 1)
+      parameter (iBase_ALL_ORDER_LOGN = 2)
+      parameter (iBase_ALL_ORDER_N = 3)
+      parameter (iBase_SOME_ORDER_1 = 4)
+      parameter (iBase_SOME_ORDER_LOGN = 5)
+      parameter (iBase_SOME_ORDER_N = 6)
+      parameter (iBase_AVAILABLE = 7)
+      parameter (iBase_AdjacencyCost_MAX = 7)
       integer iBase_NEW
       integer iBase_ALREADY_EXISTED
diff --git a/itaps/imesh/Makefile.am b/itaps/imesh/Makefile.am
index 647b8c1..97c76bb 100644
--- a/itaps/imesh/Makefile.am
+++ b/itaps/imesh/Makefile.am
@@ -45,6 +45,9 @@ if PARALLEL
 #  ftest_DEPENDENCIES = libiMesh.la $(top_builddir)/libMOAB.la
 endif
+FCLINK = $(CXXLINK)
+F77LINK = $(CXXLINK)
 TESTS = $(check_PROGRAMS)
 LDADD = libiMesh.la $(top_builddir)/src/libMOAB.la ${MOAB_CXX_LINKFLAGS} ${MOAB_CXX_LIBS}
 TESTDEPS = libiMesh.la $(top_builddir)/src/libMOAB.la
diff --git a/moab.make.in b/moab.make.in
index 1e294b3..e6dc42d 100644
--- a/moab.make.in
+++ b/moab.make.in
@@ -10,12 +10,16 @@ MOAB_INCLUDES = -I at abs_srcdir@/src \
 MOAB_CXXFLAGS = @CXXFLAGS@ @AM_CXXFLAGS@
 MOAB_CFLAGS = @CFLAGS@ @AM_CFLAGS@
+MOAB_FFLAGS = @FFLAGS@
+MOAB_FCFLAGS = @FCFLAGS@
 MOAB_LDFLAGS = @EXPORT_LDFLAGS@
 MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB @LIBS@ @PNETCDF_LIBS@ @NETCDF_LIBS@ @HDF5_LIBS@ @CCMIO_LIBS@ @CGM_LIBS@
 MOAB_CXX = @CXX@
 MOAB_CC  = @CC@
+MOAB_FC  = @FC@
+MOAB_F77  = @F77@
 # Override MOAB_LIBDIR and MOAB_INCLUDES from above with the correct
 # values for the installed MOAB.
diff --git a/src/parallel/WriteHDF5Parallel.cpp b/src/parallel/WriteHDF5Parallel.cpp
index da16c7b..e96d933 100644
--- a/src/parallel/WriteHDF5Parallel.cpp
+++ b/src/parallel/WriteHDF5Parallel.cpp
@@ -1680,23 +1680,17 @@ static void convert_to_ranged_ids( const TYPE* buffer,
   result.resize( len*2 );
-  std::copy( buffer, buffer+len, result.begin()+len );
-  std::sort( result.begin()+len, result.end() );
-  std::vector<WriteHDF5::id_t>::iterator w = result.begin();
-  std::vector<WriteHDF5::id_t>::const_iterator r = result.begin()+len;
-  *w = *r; ++w;
-  *w = *r; ++r;
-  for (; r != result.end(); ++r) {
-    if (*r == *w + 1) {
-      ++*w;
-    else {
-      ++w; *w = *r;
-      ++w; *w = *r;
+  Range tmp;
+  for (size_t i=0; i<len; i++)
+    tmp.insert( (EntityHandle)buffer[i]);
+  result.resize(tmp.psize()*2);
+  int j=0;
+  for (Range::const_pair_iterator pit=tmp.const_pair_begin();
+      pit!=tmp.const_pair_end(); pit++, j++)
+    result[2*j]=pit->first;
+    result[2*j+1]=pit->second-pit->first+1;
-  ++w;
-  result.erase( w, result.end() );
 static void merge_ranged_ids( const unsigned long* range_list,
@@ -1710,22 +1704,21 @@ static void merge_ranged_ids( const unsigned long* range_list,
   result.insert( result.end(), range_list, range_list+len );
   size_t plen = result.size()/2;
-  if (plen > 1) {
-    std::pair<id_t,id_t> *plist = reinterpret_cast<std::pair<id_t,id_t>*>(&result[0]);
-    std::sort( plist, plist+plen );
-    std::pair<id_t,id_t> *wr = plist, *pend = plist+plen;
-    std::sort( plist, pend );
-    for (std::pair<id_t,id_t> *iter = plist+1; iter != pend; ++iter) {
-      if (wr->second+1 < iter->first) {
-        ++wr;
-        *wr = *iter;
-      else {
-        wr->second = std::max( wr->second, iter->second );
-    ++wr;
-    result.resize( 2*(wr - plist) );
+  Range tmp;
+  for (size_t i=0; i<plen; i++)
+    EntityHandle starth=(EntityHandle)result[2*i];
+    EntityHandle endh=(EntityHandle)result[2*i]+(id_t)result[2*i+1]-1; // id+count-1
+    tmp.insert( starth, endh);
+  // now convert back to std::vector<WriteHDF5::id_t>, compressed range format
+  int j=0;
@@ -1767,7 +1760,7 @@ ErrorCode WriteHDF5Parallel::unpack_set( EntityHandle set,
     if (flags & mhdf_SET_RANGE_BIT) {
       tmp = data->contentIds;
       convert_to_ranged_ids( &tmp[0], tmp.size(), data->contentIds );
-      data->setFlags &= mhdf_SET_RANGE_BIT;
+      data->setFlags |= mhdf_SET_RANGE_BIT;
     else {
       tmp.clear();
https://bitbucket.org/fathomteam/moab/commits/a486afb25464/
Changeset:   a486afb25464
Branch:      None
User:        iulian07
Date:        2013-05-07 17:54:42
Summary:     move the cslam_par_test driver to cslam tools folder
Affected #:  2 files
Diff not available.
https://bitbucket.org/fathomteam/moab/commits/c90ca7aadbc5/
Changeset:   c90ca7aadbc5
Branch:      master
User:        iulian07
Date:        2013-05-07 18:00:11
Summary:     complete the move correctly, for cslam_par_test
Affected #:  2 files
Diff not available.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
