[MOAB-dev] commit/MOAB: iulian07: fix the mergemesh test
commits-noreply at bitbucket.org
Fri Sep 20 14:00:59 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/ee0504329853/
Changeset: ee0504329853
Branch: master
User: iulian07
Date: 2013-09-20 20:56:15
Summary: fix the mergemesh test
MergeMesh, by default, it will not create new skin entities
add a new parameter to one of the find_skin methods, which will
be by default true (create skin entities)
from inside MergeMesh, call the version of find_skin with "false" for this new
flag, so no new entities should be created.
note:
merging higher dimensional entities needs more work;
Affected #: 5 files
diff --git a/src/MergeMesh.cpp b/src/MergeMesh.cpp
index 4cc8158..7293e17 100644
--- a/src/MergeMesh.cpp
+++ b/src/MergeMesh.cpp
@@ -61,7 +61,7 @@ moab::ErrorCode MergeMesh::merge_entities(moab::Range &elems,
// get the skin of the entities
moab::Skinner skinner(mbImpl);
moab::Range skin_range;
- moab::ErrorCode result = skinner.find_skin(0, elems, 0, skin_range);
+ moab::ErrorCode result = skinner.find_skin(0, elems, 0, skin_range, false, false);
if (moab::MB_SUCCESS != result) return result;
// create a tag to mark merged-to entity; reuse tree_root
@@ -232,16 +232,16 @@ moab::ErrorCode MergeMesh::merge_higher_dimensions(moab::Range &elems)
for(int dim = 1; dim <3; dim++){
skinEnts.clear();
moreDeadEnts.clear();
- result = skinner.find_skin(0, elems, dim, skinEnts);
+ result = skinner.find_skin(0, elems, dim, skinEnts, false, false);
//Go through each skin entity and see if it shares adjacancies with another entity
for(moab::Range::iterator skinIt = skinEnts.begin(); skinIt != skinEnts.end(); skinIt++){
adj.clear();
//Get the adjacencies 1 dimension lower
- result = mbImpl->get_adjacencies(&(*skinIt), 1, dim-1, true, adj);
+ result = mbImpl->get_adjacencies(&(*skinIt), 1, dim-1, false, adj);
if(result != moab::MB_SUCCESS) return result;
//See what other entities share these adjacencies
matches.clear();
- result = mbImpl->get_adjacencies(adj, dim, true, matches, moab::Interface::INTERSECT);
+ result = mbImpl->get_adjacencies(adj, dim, false, matches, moab::Interface::INTERSECT);
//If there is more than one entity, then we have some to merge and erase
if(matches.size() > 1){
diff --git a/src/Skinner.cpp b/src/Skinner.cpp
index b5fd24e..c3c6b1b 100644
--- a/src/Skinner.cpp
+++ b/src/Skinner.cpp
@@ -1015,11 +1015,12 @@ ErrorCode Skinner::find_skin(const EntityHandle this_set,
const Range &entities,
int dim,
Range &skin_entities,
- bool create_vert_elem_adjs)
+ bool create_vert_elem_adjs,
+ bool create_skin_elements)
Range tmp_skin;
ErrorCode result = find_skin(this_set, entities, (dim==0), tmp_skin, 0,
- create_vert_elem_adjs, true);
+ create_vert_elem_adjs, create_skin_elements);
if (MB_SUCCESS != result || tmp_skin.empty()) return result;
if (tmp_skin.all_of_dimension(dim)) {
@@ -1029,7 +1030,7 @@ ErrorCode Skinner::find_skin(const EntityHandle this_set,
skin_entities.merge(tmp_skin);
else {
- result = thisMB->get_adjacencies( tmp_skin, dim, true, skin_entities,
+ result = thisMB->get_adjacencies( tmp_skin, dim, create_skin_elements, skin_entities,
Interface::UNION );
diff --git a/src/moab/Skinner.hpp b/src/moab/Skinner.hpp
index 7ec5450..4eb2f51 100644
--- a/src/moab/Skinner.hpp
+++ b/src/moab/Skinner.hpp
@@ -119,7 +119,8 @@ public:
int dim,
- bool create_vert_elem_adjs = false);
+ bool create_vert_elem_adjs = false,
+ bool create_skin_elements = true);
ErrorCode classify_2d_boundary( const Range &boundary,
const Range &bar_elements,
diff --git a/test/Makefile.am b/test/Makefile.am
index 100285b..99c5211 100644
--- a/test/Makefile.am
+++ b/test/Makefile.am
@@ -76,6 +76,7 @@ MOSTLYCLEANFILES = mb_write.g \
tri_mid_edge_face_nodes.g \
mb_stress_out.g \
merge_test.g \
+ mm_out.h5m \
tree.h5m
# Tests and such
diff --git a/test/mergemesh_test.cpp b/test/mergemesh_test.cpp
index 0b382e6..fca5304 100644
--- a/test/mergemesh_test.cpp
+++ b/test/mergemesh_test.cpp
@@ -38,11 +38,11 @@ int main( int argc, char* argv[] )
// Fixed for now
-// const char *outfile = "mm_out.h5m";
-// rval = iface->write_mesh( outfile);
-// if (MB_SUCCESS != rval) {
-// std::cerr << "Error saving file: " << outfile << std::endl;
-// exit(2);
+ const char *outfile = "mm_out.h5m";
+ rval = iface->write_mesh( outfile);
+ if (MB_SUCCESS != rval) {
+ std::cerr << "Error saving file: " << outfile << std::endl;
+ exit(2);
return 0;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
