[MOAB-dev] commit/MOAB: iulian07: do not include Error.hpp in Coupler.hpp
commits-noreply at bitbucket.org
Fri Sep 20 11:56:59 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b4a866dde5ef/
Changeset: b4a866dde5ef
Branch: master
User: iulian07
Date: 2013-09-20 18:55:49
Summary: do not include Error.hpp in Coupler.hpp
it will cause compilation errors outside moab
Affected #: 2 files
diff --git a/tools/mbcoupler/Coupler.cpp b/tools/mbcoupler/Coupler.cpp
index 71231b8..f7f74b2 100644
--- a/tools/mbcoupler/Coupler.cpp
+++ b/tools/mbcoupler/Coupler.cpp
@@ -6,6 +6,7 @@
#include "iMesh_extensions.h"
#include "moab/gs.hpp"
#include "moab/TupleList.hpp"
+#include "moab/Error.hpp"
#include "iostream"
#include <stdio.h>
#include <algorithm>
@@ -518,6 +519,27 @@ ErrorCode Coupler::test_local_box(double *xyz,
return MB_SUCCESS;
+ErrorCode Coupler::interpolate(Coupler::Method method,
+ const std::string &interp_tag,
+ double *interp_vals,
+ TupleList *tl,
+ bool normalize)
+ Tag tag;
+ ErrorCode result ;
+ if (_spectralSource)
+ result = mbImpl->tag_get_handle(interp_tag.c_str(), _ntot, MB_TYPE_DOUBLE, tag);
+ else
+ result = mbImpl->tag_get_handle(interp_tag.c_str(), 1, MB_TYPE_DOUBLE, tag);
+ if (MB_SUCCESS != result) {
+ std::ostringstream str;
+ str << "Failed to get handle for interpolation tag \"" << interp_tag << "\"";
+ mError->set_last_error(str.str());
+ return result;
+ return interpolate(method, tag, interp_vals, tl, normalize);
ErrorCode Coupler::interpolate(Coupler::Method *methods,
Tag *tags,
int *points_per_method,
diff --git a/tools/mbcoupler/Coupler.hpp b/tools/mbcoupler/Coupler.hpp
index 74170d5..705e2dc 100644
--- a/tools/mbcoupler/Coupler.hpp
+++ b/tools/mbcoupler/Coupler.hpp
@@ -29,7 +29,6 @@
#include "moab/Interface.hpp"
#include "moab/CartVect.hpp"
-#include "moab/Error.hpp"
#include <sstream>
@@ -41,6 +40,8 @@ class AdaptiveKDTree;
class TupleList;
+class Error;
class Coupler
public:
@@ -530,27 +531,6 @@ private:
// error object used to set last error on interface
Error *mError;
-inline ErrorCode Coupler::interpolate(Coupler::Method method,
- const std::string &interp_tag,
- double *interp_vals,
- TupleList *tl,
- bool normalize)
- Tag tag;
- ErrorCode result ;
- if (_spectralSource)
- result = mbImpl->tag_get_handle(interp_tag.c_str(), _ntot, MB_TYPE_DOUBLE, tag);
- else
- result = mbImpl->tag_get_handle(interp_tag.c_str(), 1, MB_TYPE_DOUBLE, tag);
- if (MB_SUCCESS != result) {
- std::ostringstream str;
- str << "Failed to get handle for interpolation tag \"" << interp_tag << "\"";
- mError->set_last_error(str.str());
- return result;
- return interpolate(method, tag, interp_vals, tl, normalize);
Tag tag,
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
