[MOAB-dev] some errors I met I build moab
Jiangtao Hu jiangtao_ma at yahoo.com
Tue Sep 17 12:23:23 CDT 2013
And mbsize with -l option did give out counts for meshes:
Constructed 1 Volume: 1
   type   count    total    minimum    average        rms    maximum   std.dev.
   Edge  720001  2.3e+03  0.0017362  0.0031342     1.1785       1000     1.1785
    Tri     140  6.9e+05     26.381     4928.8     6392.6     8715.6     4070.9
1D Side     420  1.6e+05     17.431     373.66      588.2     1000.2     454.26
 Vertex  720142
So cgm reader should work with above build.
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called according to his purpose, all things are working together for good." (Romans 8:28)
To: Tim Tautges <tautges at mcs.anl.gov>; "moab-dev at mcs.anl.gov" <moab-dev at mcs.anl.gov>
Sent: Tuesday, September 17, 2013 12:12 PM
Subject: Re: [MOAB-dev] some errors I met I build moab
Instead of using--enable-tools option, I changed in configure for following:
-enable-mbcoupler --enable-mbcslam --enable-dagmc --with-mpi=/usr/bin CC=/usr/bin/mpicc CXX=/usr/bin/mpic++ F77=/usr/bin/mpif77 FC=/usr/bin/mpif90 F90=/usr/bin/mpif90 --with-cgm=/home/jhu/cgm/parellel
And build is successful.
"Make check" can work for following directory, just some of the testcases failed. I believe I didn't include all the libraries, which causes the failure.
> tools/mbcoupler
> tools/mbcslam
> tools/dagmc
> test/perf
Can you double check with your configure options, and see if it works that way. I'll continue to double check if cgm reader works.
Jane
Asst. Researcher
UW @ Madison
To: moab-dev at mcs.anl.gov
Sent: Tuesday, September 17, 2013 10:57 AM
Thanks for the note, comments below...
On 09/16/2013 10:36 PM, 魏华祎 wrote:
> Hi there,
>      I checked out  moab from https://bitbucket.org/fathomteam/moab. When I build, I meet some error, I think maybe they
> are bugs.
> First ,  when I run the following command and meet an error like:
> $  autoreconf -fi
> test/parallel/Makefile.am:30: `:='-style assignments are not portable
> After I change ":=" to "=",
 it work well.
As Vijay said, this isn't the right way to fix this, it's better to tolerate the warning.  (I may have found a way to
fix this, so stay tuned...)
> Then I configure it by:
> ./configure --prefix=/home/why/software/moab/20130914 --enable-static --enable-igeom --enable-debug --enable-tools
> --enable-docs  --disable-mbzoltan --disable-qvdual \
> --with-netcdf \
> --with-mpi \
> --with-hdf5 \
> --with-zoltan=/usr/local \
> --with-parmetis=/usr \
> --with-cgm=/home/why/software/cgma/6070 \
> --with-vtk=/home/why/software/vtk
> and when I make it,  I find I can't compile three tools and a test:
> tools/mbcoupler
> tools/mbcslam
> tools/dagmc
> test/perf
> The problem is that they can't link with cgm. I find that the problem come from the Makefile in these directories. So I
 just change the line
> "LIBS = -lm"  to  "LIBS =  -lm ${CGM_LIBS}", then make can pass, and make check also work well.
Ok, we're checking on this.
> I still can't compile the tools/mbzoltan and tools/qvdual, and I havn't figure out the reason why.
As Vijay said, you're disabling them with configure options.  And, qvdual is deprecated, I'll go ahead and remove it.
- tim
> Hope these informatin can improve the build process of  Moad.
> Best
> Huayi
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National
 Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130917/7476baaa/attachment-0001.html>
