[MOAB-dev] commit/MOAB: iulian07: remove point search tool
commits-noreply at bitbucket.org
Tue Sep 17 09:37:20 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b4610cfb16c0/
Changeset: b4610cfb16c0
Branch: master
User: iulian07
Date: 2013-09-17 16:35:20
Summary: remove point search tool
Affected #: 4 files
diff --git a/configure.ac b/configure.ac
index fd4062a..cc1d3e0 100644
--- a/configure.ac
+++ b/configure.ac
@@ -623,7 +623,6 @@ AC_HELP_STRING([--disable-tools],[Disable all tools by default])],
[ENABLE_TOOLS=$enableval],[ENABLE_TOOLS=] )
# Individual tools
MB_OPTIONAL_TOOL([mbconvert], [yes])
-MB_OPTIONAL_TOOL([pointsearch], [no])
MB_OPTIONAL_TOOL([hexmodops], [yes])
MB_OPTIONAL_TOOL([qvdual], [no] )
MB_OPTIONAL_TOOL([vtkMOABReader],[${VTKMOAB_DEFAULT}] )
diff --git a/test/Makefile.am b/test/Makefile.am
index e4b7909..e4d591f 100644
--- a/test/Makefile.am
+++ b/test/Makefile.am
@@ -123,7 +123,6 @@ var_len_test_no_template_CPPFLAGS = -UTEMPLATE_SPECIALIZATION $(AM_CPPFLAGS) $(C
tag_test_SOURCES = TestUtil.hpp TagTest.cpp
spatial_locator_test_SOURCES = TestUtil.hpp spatial_locator_test.cpp
-test_boundbox_SOURCES = TestUtil.hpp test_boundbox.cpp
mbcn_test_SOURCES = $(top_srcdir)/src/moab/CN.hpp \
$(top_srcdir)/src/CN.cpp \
diff --git a/tools/Makefile.am b/tools/Makefile.am
index 0789a83..e8ad0db 100644
--- a/tools/Makefile.am
+++ b/tools/Makefile.am
@@ -31,10 +31,6 @@ EXTRA_DIST = README.hexmodops \
README.spheredecomp \
mbzoltan/README
-if ENABLE_pointsearch
- bin_PROGRAMS += pointsearch
-endif
if ENABLE_mbconvert
bin_PROGRAMS += mbconvert
@@ -145,7 +141,6 @@ SUBDIRS = . \
$(dagmc_DIR)
mbconvert_SOURCES = convert.cpp
-pointsearch_SOURCES = point_search.cpp
mbgsets_SOURCES = gsets.cc
hexmodops_SOURCES = makeops.cpp
mbsize_SOURCES = measure.cpp measure.hpp size.cpp
diff --git a/tools/point_search.cpp b/tools/point_search.cpp
deleted file mode 100644
index 97cfdf2..0000000
--- a/tools/point_search.cpp
+++ /dev/null
@@ -1,208 +0,0 @@
- * MOAB, a Mesh-Oriented datABase, is a software component for creating,
- * storing and accessing finite element mesh data.
- * Copyright 2004 Sandia Corporation. Under the terms of Contract
- * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
- * retains certain rights in this software.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
-//Point Locater
-extern "C"
-#include "moab/FindPtFuncs.h"
-#include "moab/point_locater/point_locater.hpp"
-#include "moab/point_locater/io.hpp"
-#include "moab/point_locater/tree/element_tree.hpp"
-#include "moab/point_locater/tree/bvh_tree.hpp"
-#include "moab/point_locater/parametrizer.hpp"
-//iMesh
-#include "imesh/iMesh_extensions.h"
-#include "imesh/MBiMesh.hpp"
-//MOAB
-#include "moab/Core.hpp"
-#include "moab/ParallelComm.hpp"
-#include "MBTagConventions.hpp"
-//STL
-#include <string>
-#include <vector>
-#include <sstream>
-#include <iostream>
-#include <algorithm>
-namespace io = moab::point_locator::io;
-void print_usage() {
- std::cerr << "Usage: point_search" ;
- std::cerr << "-meshes <source_mesh><target_mesh> ";
- std::cerr << " -itag <interp_tag> [-gnorm <gnorm_tag>] " ;
- std::cerr << " [-ssnorm <ssnorm_tag><ssnorm_selection>] [-ropts <roptions>]";
- std::cerr << " [-outfile <out_file> [-wopts <woptions>]]";
- std::cerr << " [-dbgout [<dbg_file>]]" << std::endl;
- std::cerr << " -meshes" << std::endl;
- std::cerr << " Read in mesh files <source_mesh> and <target_mesh>."
- << std::endl;
- std::cerr << " -itag" << std::endl;
- std::cerr << " Interpolate tag <interp_tag> from source mesh to target"
- << " mesh." << std::endl;
- std::cerr << " -gnorm" << std::endl;
- std::cerr << " Normalize the value of tag <gnorm_tag> over then entire"
- << "mesh and save to" << std::endl;
- std::cerr << " tag \"<gnorm_tag>_normf\" on the mesh set. Do this for"
- << " all meshes." << std::endl;
- std::cerr << " -ssnorm" << std::endl;
- std::cerr << " Normalize the value of tag <ssnorm_tag> over "
- << "subsets of a mesh and save to" << std::endl;
- std::cerr << " tag \"<ssnorm_tag>_normf\" on the Entity Set for each subset. Subsets are selected" << std::endl;
- std::cerr << " using criteria in <ssnorm_selection>. Do this for all meshes." << std::endl;
- std::cerr << " -ropts" << std::endl;
- std::cerr << " Read in the mesh files using options in <roptions>." << std::endl;
- std::cerr << " -outfile" << std::endl;
- std::cerr << " Write out target mesh to <out_file>." << std::endl;
- std::cerr << " -wopts" << std::endl;
- std::cerr << " Write out mesh files using options in <woptions>." << std::endl;
- std::cerr << " -dbgout" << std::endl;
- std::cerr << " Write stdout and stderr streams to the file \'<dbg_file>.txt\'." << std::endl;
-template< typename Pair>
-struct Count_predicate: std::unary_function< Pair, bool>{
- bool operator()(const Pair & pair){ return pair.first != 0; }
-// default types.. whatevs.
-typedef moab::common_tree::Box< double> Bounding_box;
-typedef std::vector< Bounding_box> Boxes;
-typedef moab::EntityHandle Element;
-typedef moab::element_utility::Parametrizer Parametrizer;
-typedef Range Elements;
-typedef moab::Element_tree< Elements, Bounding_box, moab::Core, Parametrizer>
- Element_tree_;
-typedef moab::Bvh_tree< Elements, Bounding_box, moab::Core, Parametrizer>
- Bvh_tree_;
-typedef moab::ParallelComm Communicator;
-typedef moab::Point_search< Element_tree_, std::vector< Bounding_box> >
- Element_locater;
-typedef moab::Point_search< Bvh_tree_, std::vector< Bounding_box> >
- Bvh_locater;
-template< typename Communicator, typename Moab,
- typename Root, typename String, typename String_>
-void read_mesh( Communicator & comm,
- Moab & moab, Root root,
- String filename, String_ & options){
- moab::ErrorCode result = moab::MB_SUCCESS;
- std::stringstream ss;
- ss << options << ";PARALLEL_COMM=" << comm.get_id();
- std::string read_options( ss.str());
- std::cout << read_options << std::endl;
- result = moab.load_file( filename,
- root,
- read_options.c_str() );
- if(result != moab::MB_SUCCESS){
- std::string error;
- moab.get_last_error( error);
- std::cerr << error << std::endl;
- MPI_Abort(MPI_COMM_WORLD, result);
- std::exit( -1);
-int main(int argc, char* argv[]){
- MPI_Init(&argc, &argv);
- io::File_options<> options;
- bool help = false;
- result = io::get_file_options(argc, argv, options);
- if (result != moab::MB_SUCCESS || help) {
- print_usage();
- MPI_Finalize();
- return 1;
- int nprocs, rank;
- MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
- MPI_Comm_rank(MPI_COMM_WORLD, &rank);
- moab::Core moab;
- Communicator source_comm( &moab, MPI_COMM_WORLD);
- Communicator target_comm( &moab, MPI_COMM_WORLD);
- std::vector< moab::EntityHandle > roots( options.meshFiles.size());
- moab.create_meshset( moab::MESHSET_SET, roots[ 0]);
- moab.create_meshset( moab::MESHSET_SET, roots[ 1]);
- read_mesh( source_comm, moab, &roots[ 0],
- options.meshFiles[ 0].c_str(), options.readOpts);
- read_mesh( target_comm, moab, &roots[ 1],
- options.meshFiles[ 1].c_str(), options.readOpts);
- Range source_element_range, target_element_range;
- Range target_vertex_handles, non_owned_vertices;
- source_comm.get_part_entities( source_element_range, 3);
- target_comm.get_part_entities( target_element_range, 3);
- moab.get_adjacencies( target_element_range, 0, false,
- target_vertex_handles,
- moab::Interface::UNION);
- target_comm.get_pstatus_entities( 0, PSTATUS_NOT_OWNED,
- non_owned_vertices);
- moab::subtract( target_vertex_handles, non_owned_vertices);
- moab::common_tree::Box< double> bounding_box;
- Parametrizer p;
- //double construction_start = MPI_Wtime();
- //Element_tree_ tree_1(source_element_range, moab, bounding_box, p);
- //double construction = MPI_Wtime() - construction_start;
- //std::cout << "element construction time: "
- //<< construction << std::endl;
- double construction_start = MPI_Wtime();
- Bvh_tree_ tree_2(source_element_range, moab, bounding_box, p);
- double construction = MPI_Wtime() - construction_start;
- std::cout << "bvh construction time: " << construction << std::endl;
- Boxes boxes;
- Bvh_locater locator( tree_2, boxes);
- typedef std::vector< double> Point;
- typedef std::pair< moab::EntityHandle, Point > Result;
- typedef Count_predicate< Result> Predicate;
- std::vector< Result > located_elements;
- std::vector< Point > target_vertices;
- target_vertices.reserve( target_vertex_handles.size());
- std::size_t index = 0;
- for( Range::iterator i = target_vertex_handles.begin();
- i != target_vertex_handles.end();
- ++i, ++index){
- std::vector< double> coordinate( 3, 0);
- moab.get_coords( &*i, 3, &coordinate[ 0]);
- target_vertices.push_back( coordinate);
- const double tol=1e-6;
- std::cout << "point location beginning" << std::endl;
- double locate_start = MPI_Wtime();
- locator.locate_points( target_vertices, located_elements, tol);
- double locate_points = MPI_Wtime() - locate_start;
- std::cout << "point_location: " << locate_points << std::endl;
- std::size_t unfound_points = std::count_if( located_elements.begin(),
- located_elements.end(),
- Predicate());
- typedef ct::_Element_data< const Bounding_box, double > Element_data;
- typedef std::tr1::unordered_map< Element,
- Element_data> Entity_map;
- if( unfound_points > 0){
- std::cout << "unlocated points: " << unfound_points
- << "/" << located_elements.size() << std::endl;
- locator.bruteforce_locate_points( target_vertices,
- located_elements, tol);
- }else{
- std::cout << "all points located!" << std::endl;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
