[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Thu Sep 12 16:29:11 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/68361b9d366f/
Changeset:   68361b9d366f
Branch:      None
User:        tautges
Date:        2013-09-12 23:27:47
Summary:     Adding a bounding box and associated class.  This was part of my coupler upgrade stuff,
but I need it now.
Affected #:  3 files
diff --git a/src/Makefile.am b/src/Makefile.am
index 28ef5c2..ab5077a 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -41,6 +41,7 @@ libMOAB_la_SOURCES = \
   BitPage.hpp \
   BitTag.cpp \
   BitTag.hpp \
+  BoundBox.cpp \
   BSPTree.cpp \
   BSPTreePoly.cpp \
   CN.cpp \
@@ -139,6 +140,7 @@ libMOAB_la_SOURCES = \
 # The list of header files which are to be installed
 nobase_libMOAB_la_include_HEADERS = \
   moab/AdaptiveKDTree.hpp \
+  moab/BoundBox.hpp \
   moab/BSPTree.hpp \
   moab/BSPTreePoly.hpp \
   moab/CN.hpp \
diff --git a/test/Makefile.am b/test/Makefile.am
index 5b63e9e..9566338 100644
--- a/test/Makefile.am
+++ b/test/Makefile.am
@@ -44,7 +44,8 @@ TESTS = range_test \
         bsp_tree_poly_test \
 	reorder_test \
 	test_prog_opt \
-	coords_connect_iterate
+	coords_connect_iterate \
+        test_boundbox
 if HDF5_FILE
   TESTS += mbfacet_test \
@@ -137,6 +138,8 @@ kd_tree_test_CPPFLAGS = $(AM_CPPFLAGS) $(CPPFLAGS)
 coords_connect_iterate_SOURCES = coords_connect_iterate.cpp
 coords_connect_iterate_CPPFLAGS = $(AM_CPPFLAGS) $(CPPFLAGS)
+test_boundbox_SOURCES = test_boundbox.cpp
 if PARALLEL
 moab_test_CPPFLAGS += -I$(top_srcdir)/src/parallel
 kd_tree_test_CPPFLAGS += -I$(top_srcdir)/src/parallel
diff --git a/test/test_boundbox.cpp b/test/test_boundbox.cpp
new file mode 100644
index 0000000..d3c8c3d
--- /dev/null
+++ b/test/test_boundbox.cpp
@@ -0,0 +1,154 @@
+#include "TestUtil.hpp"
+#include "moab/Core.hpp"
+#include "moab/BoundBox.hpp"
+#include "moab/ScdInterface.hpp"
+using namespace moab;
+#include <iostream>
+//! test add_entities, get_entities, num_entities
+void test_bound_box();
+int main()
+  int err = 0;
+  err += RUN_TEST(test_bound_box);
+  if (!err)
+    printf("ALL TESTS PASSED\n");
+  else
+    printf("%d TESTS FAILED\n",err);
+  return err;
+  BoundBox box;
+  CartVect vec(0.0);
+  double tol = 0.0;
+  std::vector<double> vals(6, 0.0);
+  BoundBox other_box(&vals[0]);
+    // test for contains point failure
+  bool result = box.contains_point(vec.array(), tol);
+  CHECK(!result);
+  result = box.contains_box(other_box, tol);
+  CHECK(!result);
+  box = other_box;
+  tol = 1.0e-10;
+    // test for success
+  result = box.contains_point(&vals[0], tol);
+  CHECK(result);
+  CHECK(result);
+    // check update functions
+  CartVect three(3.0);
+  box.update_max(three.array());
+  result = box.contains_point(three.array(), tol);
+  CHECK(result);
+  result = box.contains_point((three*1.1).array(), tol);
+  CHECK(!result);
+  result = box.contains_box(BoundBox(three, three), tol);
+  CHECK(result);
+  result = box.contains_box(BoundBox(three, 1.1*three), tol);
+  CHECK(!result);
+  CartVect negthree(-3.0);
+  box.update_min(negthree.array());
+  result = box.contains_point(negthree.array(), tol);
+  CHECK(result);
+  result = box.contains_point((negthree*1.1).array(), tol);
+  CHECK(!result);
+  result = box.contains_box(BoundBox(negthree, negthree), tol);
+  CHECK(result);
+  result = box.contains_box(BoundBox(1.1*negthree, negthree), tol);
+  CHECK(!result);
+  for (int i = 0; i < 3; i++) {
+    vals[i] = -4.0; vals[3+i] = 4.0;
+  box.update(&vals[0]);
+  CHECK(result);
+  result = box.contains_point((CartVect(&vals[0])*1.1).array(), tol);
+  CHECK(!result);
+  result = box.contains_box(BoundBox(&vals[0]), tol);
+  CHECK(result);
+  result = box.contains_box(BoundBox(1.1*CartVect(&vals[0]), CartVect(&vals[3])), tol);
+  CHECK(!result);
+    // check length functions
+  tol = 1.0e-6;
+    // box should be 8 on a side, or 3*(2^3)^2 or 192 for diag length squared
+  double diagsq = box.diagonal_squared();
+  CHECK_REAL_EQUAL(diagsq, 192.0, tol);
+  double diag = box.diagonal_length();
+  CHECK_REAL_EQUAL(diag, sqrt(3)*8.0, tol);
+    // check distance function
+    // face-centered
+  vals[0] = vals[1] = 0.0;
+  vals[2] = 6.0;
+  double dist = box.distance_squared(CartVect(&vals[0]).array());
+  CHECK_REAL_EQUAL(dist, 4.0, tol);
+  dist = box.distance(CartVect(&vals[0]).array());
+  CHECK_REAL_EQUAL(dist, 2.0, tol);
+    // edge-centered
+  vals[0] = 0.0;
+  vals[1] = vals[2] = 6.0;
+  dist = box.distance_squared(CartVect(&vals[0]).array());
+  CHECK_REAL_EQUAL(dist, 8.0, tol);
+  CHECK_REAL_EQUAL(dist, sqrt(8.0), tol);
+    // vertex-centered
+  vals[0] = vals[1] = vals[2] = 6.0;
+  CHECK_REAL_EQUAL(dist, 12.0, tol);
+  CHECK_REAL_EQUAL(dist, sqrt(12.0), tol);
+    // check entity-based functions
+  Core mb;
+  ScdInterface *scdi;
+  ErrorCode rval = mb.query_interface(scdi);
+  CHECK_ERR(rval);
+  ScdBox *scd_box;
+    // create a 10x10x10 box
+  rval = scdi->construct_box(HomCoord(0, 0, 0), HomCoord(10, 10, 10), NULL, 0, scd_box);
+  CHECK_ERR(rval);
+  EntityHandle vert = scd_box->start_vertex(), elem = scd_box->start_element();
+  rval = box.update(mb, vert);
+  CHECK_ERR(rval);
+  rval = mb.get_coords(&vert, 1, &vals[0]);
+  CHECK_ERR(rval);
+  tol = 1.0e-10;
+  CHECK(result);
+  rval = box.update(mb, elem);
+  CHECK_ERR(rval);
+  rval = mb.get_coords(&elem, 1, &vals[0]);
+  CHECK_ERR(rval);
+  CHECK(result);
+  Range all_elems(elem, elem + scd_box->num_elements() - 1);
+  rval = box.update(mb, all_elems);
+  CHECK_ERR(rval);
+  CartVect center;
+  box.compute_center(center);
+  tol = 1.0e-6;
+  CHECK_REAL_EQUAL((center - CartVect(5.0, 5.0, 5.0)).length(), 0.0, tol);
https://bitbucket.org/fathomteam/moab/commits/c0a8ccff7e86/
Changeset:   c0a8ccff7e86
Branch:      master
User:        tautges
Date:        2013-09-12 23:28:16
Summary:     Merge branch 'master' of bitbucket.org:fathomteam/moab
Affected #:  1 file
diff --git a/tools/dagmc/cub2h5m.cc b/tools/dagmc/cub2h5m.cc
index 535a689..f9ec41b 100644
--- a/tools/dagmc/cub2h5m.cc
+++ b/tools/dagmc/cub2h5m.cc
@@ -4,7 +4,7 @@
 #include "moab/CN.hpp"
 #include "moab/CartVect.hpp"
-#include "FileOptions.hpp"
+#include "moab/FileOptions.hpp"
 #include "moab/Skinner.hpp"
 #include "quads_to_tris.hpp"
 #include "DagMC.hpp"
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
