[MOAB-dev] commit/MOAB: 2 new changesets
    commits-noreply at bitbucket.org
    Tue Sep  3 16:48:07 CDT 2013
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/ef97993ceca7/
Changeset:   ef97993ceca7
Branch:      None
User:        danwu
Date:        2013-09-03 23:44:28
Summary:     Create file id tag (duplicate global id data) for Euler and FV meshes, which will be used in the resolve_shared stuff.
Affected #:  1 file
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index c3b6b8b..f4fd618 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -812,6 +812,7 @@ ErrorCode ScdNCHelper::create_mesh(Range& faces)
   Interface*& mbImpl = _readNC->mbImpl;
   Tag& mGlobalIdTag = _readNC->mGlobalIdTag;
+  const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
   DebugOutput& dbgOut = _readNC->dbgOut;
   ScdInterface* scdi = _readNC->scdi;
   ScdParData& parData = _readNC->parData;
@@ -842,12 +843,21 @@ ErrorCode ScdNCHelper::create_mesh(Range& faces)
   assert(count == scd_box->num_vertices());
   int* gid_data = (int*) data;
+  // Duplicate global id data, which will be used to resolve sharing
+  int* fid_data;
+  if (mpFileIdTag) {
+    rval = mbImpl->tag_iterate(*mpFileIdTag, tmp_range.begin(), topv, count, data);
+    ERRORR(rval, "Failed to get tag iterator on file id tag.");
+    assert(count == scd_box->num_vertices());
+    fid_data = (int*) data;
   // Set the vertex coordinates
   double *xc, *yc, *zc;
   rval = scd_box->get_coordinate_arrays(xc, yc, zc);
   ERRORR(rval, "Couldn't get vertex coordinate arrays.");
-  int i, j, k, il, jl, kl, itmp;
+  int i, j, k, il, jl, kl, itmp, id;
   int dil = lDims[3] - lDims[0] + 1;
   int djl = lDims[4] - lDims[1] + 1;
   int di = gDims[3] - gDims[0] + 1;
@@ -866,8 +876,13 @@ ErrorCode ScdNCHelper::create_mesh(Range& faces)
         yc[pos] = jlVals[j];
         zc[pos] = (-1 == lDims[2] ? 0.0 : levVals[k]);
         itmp = (!locallyPeriodic[0] && globallyPeriodic[0] && il == gDims[3] ? gDims[0] : il);
-        *gid_data = (-1 != kl ? kl * di * dj : 0) + jl * di + itmp + 1;
+        id = (-1 != kl ? kl * di * dj : 0) + jl * di + itmp + 1;
+        *gid_data = id;
         gid_data++;
+          *fid_data = id;
+          fid_data++;
https://bitbucket.org/fathomteam/moab/commits/b1fdd22d8ba9/
Changeset:   b1fdd22d8ba9
Branch:      master
User:        danwu
Date:        2013-09-03 23:46:25
Summary:     Merge branch 'master' of https://bitbucket.org/fathomteam/moab
Affected #:  9 files
diff --git a/.gitignore b/.gitignore
index 6d29b5e..967aaa7 100644
--- a/.gitignore
+++ b/.gitignore
@@ -131,10 +131,12 @@ test/obb/obb_time
 test/obb/obb_tree_tool
 test/obb_test
 test/oldinc/test_oldinc
+test/read_mpas_nc
 test/parallel/*.h5m
 test/parallel/*.vtk
 test/parallel/mbparallelcomm_test
 test/parallel/mhdf_parallel
+test/parallel/mpastrvpart
 test/parallel/par_coupler_test
 test/parallel/par_intx_sph
 test/parallel/parallel_hdf5_test
@@ -158,6 +160,7 @@ test/perf/tstt_perf_binding
 test/range_test
 test/reorder_test
 test/scdseq_test
+test/scd_test_partn
 test/seq_man_test
 test/tag_test
 test/test_adj
diff --git a/itaps/imesh/iMesh_MOAB.cpp b/itaps/imesh/iMesh_MOAB.cpp
index 6d55492..d09fec1 100644
--- a/itaps/imesh/iMesh_MOAB.cpp
+++ b/itaps/imesh/iMesh_MOAB.cpp
@@ -3424,7 +3424,7 @@ void iMesh_createStructuredMesh(iMesh_Instance instance,
 void iMesh_freeMemory(
-        iMesh_Instance instance,
+    iMesh_Instance /*instance*/,
           /**< [in] iMesh instance handle */
          void ** ptrToMem)
diff --git a/src/ScdInterface.cpp b/src/ScdInterface.cpp
index 054b8dd..5413e3e 100644
--- a/src/ScdInterface.cpp
+++ b/src/ScdInterface.cpp
@@ -659,9 +659,12 @@ ErrorCode ScdInterface::tag_shared_vertices(ParallelComm *pcomm, EntityHandle se
   if (MB_SUCCESS != rval) return rval;
     // create interface sets
-  rval = pcomm->create_interface_sets(proc_nvecs, -1, -1);
+  rval = pcomm->create_interface_sets(proc_nvecs);
+    // add the box to the PComm's partitionSets
+  pcomm->partition_sets().insert(box->box_set());
     // make sure buffers are allocated for communicating procs
   for (std::vector<int>::iterator pit = procs.begin(); pit != procs.end(); pit++)
     pcomm->get_buffers(*pit);
diff --git a/src/Skinner.cpp b/src/Skinner.cpp
index 57b3d51..b5fd24e 100644
--- a/src/Skinner.cpp
+++ b/src/Skinner.cpp
@@ -264,66 +264,13 @@ ErrorCode Skinner::find_skin( const EntityHandle meshset,
       !this_core->a_entity_factory()->vert_elem_adjacencies())
     this_core->a_entity_factory()->create_vert_elem_adjacencies();
-  if (this_core && this_core->a_entity_factory()->vert_elem_adjacencies())
-    return find_skin_vertices( meshset,
-                               source_entities,
-                               get_vertices ? &output_handles : 0,
-                               get_vertices ? 0 : &output_handles,
-                               output_reverse_handles,
-                               create_skin_elements );
+  return find_skin_vertices( meshset,
+                             source_entities,
+                             get_vertices ? &output_handles : 0,
+                             get_vertices ? 0 : &output_handles,
+                             output_reverse_handles,
+                             create_skin_elements );
-  Range forward, reverse;
-  Range prev;
-  const int d = CN::Dimension(TYPE_FROM_HANDLE(source_entities.front()));
-  if (!source_entities.all_of_dimension(d))
-    return MB_TYPE_OUT_OF_RANGE;
-  rval = thisMB->get_entities_by_dimension( meshset, d-1, prev );
-  if (MB_SUCCESS != rval)
-    return rval;
-  rval = find_skin_noadj( source_entities, forward, reverse );
-    return rval;
-  if (get_vertices && !output_reverse_handles) {
-    forward.merge( reverse );
-    reverse.clear();
-  if (get_vertices) {
-    rval = thisMB->get_connectivity( forward, output_handles );
-      return rval;
-  if (!create_skin_elements) {
-    Range new_skin;
-    rval = thisMB->get_entities_by_dimension( meshset, d-1, new_skin);
-      return rval;
-    new_skin = subtract( new_skin, prev );
-    forward = subtract( forward, new_skin );
-    reverse = subtract( reverse, new_skin );
-    rval = thisMB->delete_entities( new_skin );
-      return rval;
-  if (!get_vertices) {
-    if (output_handles.empty())
-      output_handles.swap( forward );
-    else
-      output_handles.merge( forward );
-    if (!output_reverse_handles)
-      output_handles.merge( reverse );
-    else if (output_reverse_handles->empty())
-      output_reverse_handles->swap( reverse );
-    else
-      output_reverse_handles->merge( reverse );
-  return MB_SUCCESS;
 ErrorCode Skinner::find_skin_scd(const Range& source_entities,
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index 4977f91..20fc5da 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -250,7 +250,7 @@ namespace moab {
       if (tag < MB_MESG_REMOTEH_ACK) myDebug->print(3, ", recv_ent_reqs=");
       else if (tag < MB_MESG_TAGS_ACK) myDebug->print(3, ", recv_remoteh_reqs=");
       else myDebug->print(3, ", recv_tag_reqs=");
-      for (unsigned int i = 0; i < reqs.size(); i++) myDebug->printf(3, " %x", reqs[i]);
+      for (unsigned int i = 0; i < reqs.size(); i++) myDebug->printf(3, " %p", (void*)reqs[i]);
       myDebug->print(3, "\n");
@@ -409,7 +409,6 @@ namespace moab {
                                              const bool owned_only)
     Range entities[4];
-    int local_num_elements[4];
     ErrorCode result;
     std::vector<unsigned char> pstatus;
     for (int dim = 0; dim <= dimension; dim++) {
@@ -430,7 +429,23 @@ namespace moab {
         if (pstatus[i] & PSTATUS_NOT_OWNED)
           dum_range.insert(*rit);
       entities[dim] = subtract( entities[dim], dum_range);
+    return assign_global_ids(entities, dimension, start_id, parallel, owned_only);
+  //! assign a global id space, for largest-dimension or all entities (and
+  //! in either case for vertices too)
+  ErrorCode ParallelComm::assign_global_ids( Range entities[],
+                                             const int dimension,
+                                             const int start_id,
+                                             const bool parallel,
+                                             const bool owned_only)
+    int local_num_elements[4];
+    ErrorCode result;
+    std::vector<unsigned char> pstatus;
+    for (int dim = 0; dim <= dimension; dim++) {
       local_num_elements[dim] = entities[dim].size();
@@ -3527,9 +3542,9 @@ ErrorCode ParallelComm::reduce_void(int tag_data_type, const MPI_Op mpi_op, int
 ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
-                                              int resolve_dim,
-                                              int shared_dim,
-                                              const Tag* id_tag)
+                                            int resolve_dim,
+                                            int shared_dim,
+                                            const Tag* id_tag)
     ErrorCode result;
     Range proc_ents;
@@ -3541,7 +3556,7 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
       result = scdi->tag_shared_vertices(this, this_set);
       if (MB_SUCCESS == result) {
         myDebug->tprintf(1, "Total number of shared entities = %lu.\n", (unsigned long)sharedEnts.size());
-        return result;
+        if (shared_dim == 0) return result;
@@ -3572,13 +3587,14 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
     // must call even if we don't have any entities, to make sure
     // collective comm'n works
-    return resolve_shared_ents(this_set, proc_ents, resolve_dim, shared_dim, id_tag);
+    return resolve_shared_ents(this_set, proc_ents, resolve_dim, shared_dim, NULL, id_tag);
                                               Range &proc_ents,
                                               int resolve_dim,
                                               int shared_dim,
+                                              Range *skin_ents,
                                               const Tag* id_tag)
 #ifdef USE_MPE
@@ -3591,12 +3607,13 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
     ErrorCode result;
     myDebug->tprintf(1, "Resolving shared entities.\n");
+    if (resolve_dim < shared_dim) {
+      result = MB_FAILURE;
+      RRA("MOAB does not support vertex-based partitions, only element-based ones.");
     if (-1 == shared_dim) {
-      if (0 == resolve_dim) {
-        result = mbImpl->get_dimension(shared_dim);
-        RRA("Couldn't get dimension.");
-      else if (!proc_ents.empty())
+      if (!proc_ents.empty())
         shared_dim = mbImpl->dimension_from_handle(*proc_ents.begin())-1;
       else if (resolve_dim == 3)
         shared_dim = 2;
@@ -3605,60 +3622,37 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
         return MB_FAILURE;
-    assert(shared_dim >= 0 && resolve_dim >= 0);
+    assert(shared_dim >= 0 && resolve_dim >= shared_dim);
     // get the skin entities by dimension
-    Range skin_ents[4];
-    std::vector<int> gid_data;
+    Range tmp_skin_ents[4];
     std::vector<EntityHandle> handle_vec;
     int skin_dim;
-    // get the entities to be skinned
-    if (resolve_dim < shared_dim) {
-      // for vertex-based partition, it's the elements adj to the vertices
-      result = mbImpl->get_adjacencies(proc_ents, shared_dim,
-                                       false, skin_ents[resolve_dim],
-                                       Interface::UNION);
-      RRA("Failed getting skinned entities.");
-      skin_dim = shared_dim-1;
-    else {
-      // for element-based partition, it's just the elements
+    if (!skin_ents) {
+        // need to compute the skin here
+      skin_ents = tmp_skin_ents;
+        // get the entities to be skinned
       skin_ents[resolve_dim] = proc_ents;
       skin_dim = resolve_dim-1;
-    // find the skin
-    Skinner skinner(mbImpl);
-    result = skinner.find_skin(this_set, skin_ents[skin_dim+1], false, skin_ents[skin_dim],
-                               NULL, true, true, true);
-    RRA("Failed to find skin.");
-    myDebug->tprintf(1, "Found skin, now resolving.\n");
-    // get entities adjacent to skin ents from shared_dim down to zero
-    for (int this_dim = skin_dim-1; this_dim >= 0; this_dim--) {
-      result = mbImpl->get_adjacencies(skin_ents[skin_dim], this_dim,
-                                       true, skin_ents[this_dim],
-      RRA("Failed getting skin adjacencies.");
+        // find the skin
+      Skinner skinner(mbImpl);
+      result = skinner.find_skin(this_set, skin_ents[resolve_dim], false, skin_ents[skin_dim],
+                                 NULL, true, true, true);
+      RRA("Failed to find skin.");
+      myDebug->tprintf(1, "Found skin, now resolving.\n");
+        // get entities adjacent to skin ents from shared_dim down to zero
+      for (int this_dim = skin_dim-1; this_dim >= 0; this_dim--) {
+        result = mbImpl->get_adjacencies(skin_ents[skin_dim], this_dim,
+                                         true, skin_ents[this_dim],
+                                         Interface::UNION);
+        RRA("Failed getting skin adjacencies.");
-    return resolve_shared_ents(this_set, proc_ents, skin_ents,
-                               resolve_dim, shared_dim, id_tag);
-  ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
-                                              Range &proc_ents,
-                                              Range skin_ents[],
-                                              int resolve_dim,
-                                              int shared_dim,
-  { // resolve shared vertices first
-    ErrorCode result;
-    std::vector<EntityHandle> handle_vec;
-    int skin_dim = resolve_dim-1;
     // global id tag
     Tag gid_tag; int def_val = -1;
     if (id_tag)
@@ -3672,25 +3666,17 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
       else if (tag_created) {
         // just created it, so we need global ids
-        result = assign_global_ids(this_set, skin_dim+1,true,true,true);
+        Range tmp_ents[4];
+        tmp_ents[resolve_dim] = proc_ents.subset_by_dimension(resolve_dim);
+        result = mbImpl->get_adjacencies(tmp_ents[resolve_dim], 0, false, tmp_ents[0]);
+        RRA("Failed to get adjacent vertices.");
+        result = assign_global_ids(tmp_ents, resolve_dim, 1, true, true);
         RRA("Failed assigning global ids.");
-    // store index in temp tag; reuse gid_data
-    gid_data.resize(2*skin_ents[0].size());
-    int idx = 0;
-    for (Range::iterator rit = skin_ents[0].begin();
-         rit != skin_ents[0].end(); rit++)
-      gid_data[idx] = idx, idx++;
-    Tag idx_tag;
-    result = mbImpl->tag_get_handle("__idx_tag", 1, MB_TYPE_INTEGER,
-                                    idx_tag, MB_TAG_DENSE|MB_TAG_CREAT, &def_val );
-    if (MB_SUCCESS != result) return result;
-    result = mbImpl->tag_set_data(idx_tag, skin_ents[0], &gid_data[0]);
-    RRA("Couldn't assign index tag.");
     // get gids for skin ents in a vector, to pass to gs
+    std::vector<int> gid_data(skin_ents[0].size());
     result = mbImpl->tag_get_data(gid_tag, skin_ents[0], &gid_data[0]);
     RRA("Couldn't get gid tag for skin vertices.");
@@ -3707,7 +3693,6 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
     // get a crystal router
     gs_data::crystal_data *cd = procConfig.crystal_router();
     // get total number of entities; will overshoot highest global id, but
     // that's ok
@@ -3779,8 +3764,7 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
                                      Interface::UNION);
     RRA("Couldn't get proc_verts.");
-    result = tag_shared_verts(shared_verts, skin_ents,
-                              proc_nvecs, proc_verts);
+    result = tag_shared_verts(shared_verts, skin_ents, proc_nvecs, proc_verts);
     RRA("Trouble tagging shared verts.");
 #ifdef USE_MPE
@@ -3790,8 +3774,7 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
 #endif
     // get entities shared by 1 or n procs
-    result = tag_shared_ents(resolve_dim, shared_dim, skin_ents,
-                             proc_nvecs);
+    result = get_proc_nvecs(resolve_dim, shared_dim, skin_ents, proc_nvecs);
     RRA("Trouble tagging shared entities.");
     shared_verts.reset();
@@ -3809,7 +3792,7 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
     // create the sets for each interface; store them as tags on
     // the interface instance
     Range iface_sets;
-    result = create_interface_sets(proc_nvecs, resolve_dim, shared_dim);
+    result = create_interface_sets(proc_nvecs);
     RRA("Trouble creating iface sets.");
     // establish comm procs and buffers for them
@@ -3822,7 +3805,7 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
     RRA("Shared handle check failed after iface vertex exchange.");
 #endif
-    // resolve shared entity remote handles; implemented in ghost cell exchange
+    // resolve shared non-vertex remote handles; implemented in ghost cell exchange
     // code because it's so similar
     result = exchange_ghost_cells(-1, -1, 0, 0, true, true);
     RRA("Trouble resolving shared entity remote handles.");
@@ -4368,15 +4351,12 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
       RRA("");
-                             proc_nvecs);
-    return create_interface_sets(proc_nvecs, resolve_dim, shared_dim);
+    return create_interface_sets(proc_nvecs);
-  ErrorCode ParallelComm::create_interface_sets(std::map<std::vector<int>, std::vector<EntityHandle> > &proc_nvecs,
-                                                int /*resolve_dim*/,
-                                                int /*shared_dim*/)
+  ErrorCode ParallelComm::create_interface_sets(std::map<std::vector<int>, std::vector<EntityHandle> > &proc_nvecs)
     if (proc_nvecs.empty()) return MB_SUCCESS;
@@ -4530,10 +4510,10 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
     return MB_SUCCESS;
-  ErrorCode ParallelComm::tag_shared_ents(int resolve_dim,
-                                          int shared_dim,
-                                          Range *skin_ents,
-                                          std::map<std::vector<int>, std::vector<EntityHandle> > &proc_nvecs)
+  ErrorCode ParallelComm::get_proc_nvecs(int resolve_dim,
+                                         int shared_dim,
+                                         Range *skin_ents,
+                                         std::map<std::vector<int>, std::vector<EntityHandle> > &proc_nvecs)
     // set sharing procs tags on other skin ents
     ErrorCode result;
@@ -6247,7 +6227,7 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
     // create interface sets from shared entities
-    result = create_interface_sets(proc_nvecs, 3, 2);
     return MB_SUCCESS;
diff --git a/src/parallel/ParallelMergeMesh.cpp b/src/parallel/ParallelMergeMesh.cpp
index f0b99c6..138e32c 100644
--- a/src/parallel/ParallelMergeMesh.cpp
+++ b/src/parallel/ParallelMergeMesh.cpp
@@ -559,7 +559,7 @@ namespace moab{
-    rval = myPcomm->tag_shared_ents(dim,dim-1, &mySkinEnts[0],proc_nranges);
+    rval = myPcomm->get_proc_nvecs(dim,dim-1, &mySkinEnts[0],proc_nranges);
     if(rval != MB_SUCCESS){
       return rval;
@@ -567,7 +567,7 @@ namespace moab{
     Range iface_sets;
-    rval = myPcomm->create_interface_sets(proc_nranges, dim, dim-1);
+    rval = myPcomm->create_interface_sets(proc_nranges);
       return rval;
diff --git a/src/parallel/moab/ParallelComm.hpp b/src/parallel/moab/ParallelComm.hpp
index 90cbad6..5468de1 100644
--- a/src/parallel/moab/ParallelComm.hpp
+++ b/src/parallel/moab/ParallelComm.hpp
@@ -96,17 +96,47 @@ namespace moab {
     // \section GLOBAL IDS
-    //! assign a global id space, for largest-dimension or all entities (and
-    //! in either case for vertices too)
-    //!\param owned_only If true, do not get global IDs for non-owned entities
-    //!                  from remote processors.
+    /* \brief Assign a global id space for entities
+     * Spaces are separate (and overlapping) for each dimension (i.e. global id space
+     * is not unique over all dimension entities)
+     * \param this_set Assign ids for entities in this set
+     * \param max_dim Assign for entities up to max_dim
+     * \param start_id Starting id for entities, defaults to 1
+     * \param largest_dim_only Assign only for max_dim and vertices, otherwise for edges/faces too
+     * \param parallel If true, use MPI_Scan-like function to properly assign over all processors,
+     *        otherwise gids are assigned locally only
+     * \param owned_only If false, exchanged gids with sharing processors so gids are valid for
+     *        non-owned entities too
     ErrorCode assign_global_ids(EntityHandle this_set,
-                                const int dimension,
+                                const int max_dim,
                                 const int start_id = 1,
                                 const bool largest_dim_only = true,
                                 const bool parallel = true,
                                 const bool owned_only = false);
+     * Same as set-based variant of this function, except entity Range vectors are input directly
+     * (by dimension, so entities[0] contains vertices, etc.)
+     * \param entities Assign ids for entities in the vector by dimension
+  ErrorCode assign_global_ids( Range entities[],
+                               const bool parallel = true,
+                               const bool owned_only = true);
     //! check for global ids; based only on tag handle being there or not;
     //! if it's not there, create them for the specified dimensions
@@ -396,54 +426,51 @@ namespace moab {
      * Resolve shared entities between processors for entities in proc_ents,
      * by comparing global id tag values on vertices on skin of elements in
-     * proc_ents.  Shared entities are assigned a tag that's either
-     * PARALLEL_SHARED_PROC_TAG_NAME, which is 1 integer in length, or
-     * PARALLEL_SHARED_PROCS_TAG_NAME, whose length depends on the maximum
-     * number of sharing processors.  Values in these tags denote the ranks
-     * of sharing processors, and the list ends with the value -1.
-     * If shared_dim is input as -1 or not input, a value one less than the
-     * maximum dimension of entities in proc_ents is used.
+     * proc_ents.
+     * \param this_set Set from which entities for proc_ents are taken
      * \param proc_ents Entities for which to resolve shared entities
-     * \param shared_dim Maximum dimension of shared entities to look for
+     * \param resolve_dim Dimension of entities in part/partition
+     * \param shared_dim Maximum dimension of shared entities to look for; if -1,
+     *        resolve_dim-1 is used
+     * \param id_tag If non-NULL, use this tag to get global id on which vertex resolution
+     *        is based
     ErrorCode resolve_shared_ents(EntityHandle this_set,
-                                  Range &proc_ents,
-                                  int resolve_dim = -1,
+                                  int resolve_dim = 3,
                                   int shared_dim = -1,
                                   const Tag* id_tag = 0);
     /** \brief Resolve shared entities between processors
-     * Same as resolve_shared_ents(Range&), except works for
-     * all entities in instance of dimension dim.
+     * Same as resolve_shared_ents with entity set as first argument, except instead
+     * a range is input containing entities in the part/partition.
-     * maximum dimension of entities is used.
-     * \param dim Dimension of entities in the partition
+     * \param this_set In this function variant, set is used to speed up skinning
+     * \param proc_ents Entities for which to resolve shared entities
+     *        is based
-                                  int resolve_dim = 3,
+                                  Range &proc_ents,
+                                  int resolve_dim = -1,
+                                  Range *skin_ents = NULL,
-     * Entity skin array is offered by user not by skinner
-     * It is used by other resolve_shared_ents functions above
-     * \param skin_ents[] entity skin array by user
+     * This version can be used statically, with messages exchanged via direct calls to buffer
+     * pack/unpack functions instead of MPI
+     * \param pc Array of ParallelComm instances
+     * \param np Number of ParallelComm objects in previous argument
+     * \param this_set Set of entities in parts/partition
+     * \param to_dim Maximum dimension of shared entities to look for
-    ErrorCode resolve_shared_ents(EntityHandle this_set,
-                                  Range &proc_ents,
-				  int shared_dim = -1,
-				  const Tag* id_tag = 0);
     static ErrorCode resolve_shared_ents(ParallelComm **pc,
                                          const unsigned int np,
@@ -863,8 +890,7 @@ namespace moab {
     // and tags the set with the procs sharing it; interface sets are optionally
     // returned; NOTE: a subsequent step is used to verify entities on the interface
     // and remove them if they're not shared
-    ErrorCode create_interface_sets(std::map<std::vector<int>, std::vector<EntityHandle> > &proc_nvecs,
-                                    int resolve_dim, int shared_dim);
+    ErrorCode create_interface_sets(std::map<std::vector<int>, std::vector<EntityHandle> > &proc_nvecs);
     // do the same but working straight from sharedEnts
     ErrorCode create_interface_sets(EntityHandle this_set, int resolve_dim, int shared_dim);
@@ -1230,10 +1256,10 @@ namespace moab {
                                Range &proc_verts);
-    ErrorCode tag_shared_ents(int resolve_dim,
-                              int shared_dim,
-                              Range *skin_ents,
-                              std::map<std::vector<int>, std::vector<EntityHandle> > &proc_nvecs);
+    ErrorCode get_proc_nvecs(int resolve_dim,
+                             int shared_dim,
+                             Range *skin_ents,
+                             std::map<std::vector<int>, std::vector<EntityHandle> > &proc_nvecs);
     // after verifying shared entities, now parent/child links between sets can be established
     ErrorCode create_iface_pc_links();
diff --git a/test/parallel/parallel_hdf5_test.cc b/test/parallel/parallel_hdf5_test.cc
index 2b2a1c8..355e99e 100644
--- a/test/parallel/parallel_hdf5_test.cc
+++ b/test/parallel/parallel_hdf5_test.cc
@@ -1491,7 +1491,7 @@ void test_write_unbalanced()
   ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
   if (0 == pcomm)
     pcomm = new ParallelComm( &mb, MPI_COMM_WORLD );
-  rval = pcomm->resolve_shared_ents( 0, entities, 2, 0, &idtag );
+  rval = pcomm->resolve_shared_ents( 0, entities, 2, 0, NULL, &idtag );
   CHECK_ERR(rval);
   rval = pcomm->resolve_shared_sets( sets, idtag );
   CHECK_ERR(rval);
diff --git a/test/scdseq_test.cpp b/test/scdseq_test.cpp
index b241bb1..6393ddc 100644
--- a/test/scdseq_test.cpp
+++ b/test/scdseq_test.cpp
@@ -584,7 +584,7 @@ ErrorCode eseq_test2d(ScdInterface *scdi)
     // tri-valent shared edge between the three blocks
     // interval settings: only 3 of them
-  int int1 = 100, int2 = 100, int3 = 100, int4 = 100;
+  int int1 = 10, int2 = 10, int3 = 10, int4 = 10;
   ScdBox *ebox[3], *vbox[3];
   ErrorCode result = create_3dtri_3_sequences(scdi, int1, int2, int3, int4, vbox, ebox);
   CHECK_ERR(result);
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
