[MOAB-dev] commit/MOAB: danwu: Use a better way to fix [-Wunused-parameter] warnings.
commits-noreply at bitbucket.org
Fri Sep 6 16:11:27 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/d243673a70ba/
Changeset: d243673a70ba
Branch: master
User: danwu
Date: 2013-09-06 23:11:15
Summary: Use a better way to fix [-Wunused-parameter] warnings.
Affected #: 4 files
diff --git a/src/moab/point_locater/element_maps/linear_hex_map.hpp b/src/moab/point_locater/element_maps/linear_hex_map.hpp
index 829addb..4b9cb77 100644
--- a/src/moab/point_locater/element_maps/linear_hex_map.hpp
+++ b/src/moab/point_locater/element_maps/linear_hex_map.hpp
@@ -36,24 +36,17 @@ class Linear_hex_map {
//Constructor
Linear_hex_map() {}
//Copy constructor
- Linear_hex_map( const Self & f ) {
- // Remove the warning about unused parameter
- if (NULL != &f) {}
+ Linear_hex_map( const Self & /* f */ ) {}
public:
//Natural coordinates
template< typename Moab, typename Entity_handle,
typename Points, typename Point>
- std::pair< bool, Point> operator()( const Moab & moab,
- const Entity_handle & h,
+ std::pair< bool, Point> operator()( const Moab & /* moab */,
+ const Entity_handle & /* h */,
const Points & v,
const Point & p,
const double tol = 1.e-6) const {
- // Remove the warnings about unused parameters
- if (NULL != &moab) {}
- if (NULL != &h) {}
Point result(3, 0.0);
solve_inverse( p, result, v);
bool point_found = solve_inverse( p, result, v, tol) &&
diff --git a/src/moab/point_locater/element_maps/quadratic_hex_map.hpp b/src/moab/point_locater/element_maps/quadratic_hex_map.hpp
index 92ea3ed..905b65c 100644
--- a/src/moab/point_locater/element_maps/quadratic_hex_map.hpp
+++ b/src/moab/point_locater/element_maps/quadratic_hex_map.hpp
@@ -53,15 +53,11 @@ class Quadratic_hex_map {
const Points & v,
const Point & p,
is_contained( result, tol);
@@ -200,10 +196,7 @@ class Quadratic_hex_map {
template< typename Point, typename Points>
- Matrix& jacobian( const Point & p, const Points & points, Matrix & J) const {
- if (NULL != &points) {}
+ Matrix& jacobian( const Point & p, const Points & /* points */, Matrix & J) const {
J = Matrix(0.0);
for (int i = 0; i < 27; i++) {
const double sh[3] = { SH(reference_points(i,0), p[0]),
diff --git a/src/moab/point_locater/element_maps/spectral_hex_map.hpp b/src/moab/point_locater/element_maps/spectral_hex_map.hpp
index c255545..11bd573 100644
--- a/src/moab/point_locater/element_maps/spectral_hex_map.hpp
+++ b/src/moab/point_locater/element_maps/spectral_hex_map.hpp
@@ -61,15 +61,11 @@ class Spectral_hex_map {
const Points & v,
const Point & p,
- const double tol=1.e-6) {
+ const double tol = 1.e-6) {
moab.tag_get_by_ptr(_xm1Tag, &eh, 1,(const void **) &_xyz[ 0] );
@@ -146,10 +142,7 @@ class Spectral_hex_map {
- Point& evaluate( const Point & p, const Points & points, Point & f) {
+ Point& evaluate( const Point & p, const Points & /* points */, Point & f) {
for (int d = 0; d < 3; ++d) { lagrange_0(&_ld[ d], p[ 0]); }
f[ d] = tensor_i3( _ld[ 0].J, _ld[ 0].n,
@@ -210,11 +203,7 @@ class Spectral_hex_map {
- Matrix& jacobian( const Point & p, const Points & points, Matrix & J) {
- if (NULL != &p) {}
+ Matrix& jacobian( const Point & /* p */, const Points & /* points */, Matrix & J) {
real x[ 3];
for (int i = 0; i < 3; ++i) { _data.elx[ i] = _xyz[ i]; }
opt_vol_set_intp_3(& _data, x);
diff --git a/tools/mbzoltan/MBZoltan.cpp b/tools/mbzoltan/MBZoltan.cpp
index 299e3c4..f1b712c 100644
--- a/tools/mbzoltan/MBZoltan.cpp
+++ b/tools/mbzoltan/MBZoltan.cpp
@@ -621,8 +621,8 @@ ErrorCode MBZoltan::assemble_graph(const int dimension,
#ifdef CGM
-ErrorCode MBZoltan::assemble_graph(const int dimension,
- std::vector<double> &coords,
+ErrorCode MBZoltan::assemble_graph(const int /* dimension */,
+ std::vector<double> & /* coords */,
std::vector<int> &moab_ids,
std::vector<int> &adjacencies,
std::vector<int> &length,
@@ -633,10 +633,6 @@ ErrorCode MBZoltan::assemble_graph(const int dimension,
const double part_geom_mesh_size,
const int n_part)
- // To remove the warnings about unused variables
- if (dimension > 0) {}
- if (coords.size() > 0) {}
// get body vertex weights
DLIList<RefEntity*> body_list;
gti->ref_entity_list("body", body_list, CUBIT_FALSE);
@@ -1696,26 +1692,16 @@ void MBZoltan::mbShowError(int val, const char *s)
** call backs
-int mbGetNumberOfAssignedObjects(void *userDefinedData, int *err)
+int mbGetNumberOfAssignedObjects(void * /* userDefinedData */, int *err)
- if (userDefinedData) {}
*err = 0;
return NumPoints;
-void mbGetObjectList(void *userDefinedData, int numGlobalIds, int numLids,
+void mbGetObjectList(void * /* userDefinedData */, int /* numGlobalIds */, int /* numLids */,
ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int wgt_dim, float *obj_wgts,
int *err)
- if (numGlobalIds > 0){}
- if (numLids > 0) {}
- if (gids) {}
- if (lids) {}
for (int i = 0; i < NumPoints; i++) {
gids[i] = GlobalIds[i];
lids[i] = i;
@@ -1726,25 +1712,15 @@ void mbGetObjectList(void *userDefinedData, int numGlobalIds, int numLids,
*err = 0;
-int mbGetObjectSize(void *userDefinedData, int *err)
+int mbGetObjectSize(void * /* userDefinedData */, int *err)
*err = 0;
return 3;
-void mbGetObject(void *userDefinedData, int numGlobalIds, int numLids, int numObjs,
- ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int numDim, double *pts, int *err)
+void mbGetObject(void * /* userDefinedData */, int /* numGlobalIds */, int /* numLids */, int numObjs,
+ ZOLTAN_ID_PTR /* gids */, ZOLTAN_ID_PTR lids, int numDim, double *pts, int *err)
- if (numGlobalIds > 0) {}
- if (gids) {}
- if (lids) {}
int i, id, id3;
int next = 0;
@@ -1769,18 +1745,11 @@ void mbGetObject(void *userDefinedData, int numGlobalIds, int numLids, int numOb
-void mbGetNumberOfEdges(void *userDefinedData, int numGlobalIds, int numLids,
+void mbGetNumberOfEdges(void * /* userDefinedData */, int /* numGlobalIds */, int /* numLids */,
int numObjs,
- ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int *numEdges,
+ ZOLTAN_ID_PTR /* gids */, ZOLTAN_ID_PTR lids, int *numEdges,
int *err)
- if (gids) {}
- if (lids) {}
int i, id;
int next = 0;
@@ -1796,20 +1765,12 @@ void mbGetNumberOfEdges(void *userDefinedData, int numGlobalIds, int numLids,
-void mbGetEdgeList(void *userDefinedData, int numGlobalIds, int numLids,
+void mbGetEdgeList(void * /* userDefinedData */, int /* numGlobalIds */, int /* numLids */,
int numObjs,
+ ZOLTAN_ID_PTR /* gids */, ZOLTAN_ID_PTR lids, int * /* numEdges */,
ZOLTAN_ID_PTR nborGlobalIds, int *nborProcs, int wgt_dim,
float *edge_wgts, int *err)
- if (gids) {}
- if (lids) {}
- if (numEdges) {}
int i, id, idSum, j;
int next = 0;
@@ -1836,17 +1797,10 @@ void mbGetEdgeList(void *userDefinedData, int numGlobalIds, int numLids,
-void mbGetPart(void *userDefinedData, int numGlobalIds, int numLids,
- int numObjs, ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids,
+void mbGetPart(void * /* userDefinedData */, int /* numGlobalIds */, int /* numLids */,
+ int numObjs, ZOLTAN_ID_PTR /* gids */, ZOLTAN_ID_PTR lids,
int *part, int *err)
- if (gids) {}
- if (lids) {}
int i, id;
int next = 0;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
