[MOAB-dev] commit/MOAB: tautges: Add real option processing and timing data collection/reporting.
commits-noreply at bitbucket.org
Fri Sep 6 15:01:35 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/da61d2e82880/
Changeset: da61d2e82880
Branch: master
User: tautges
Date: 2013-09-06 22:01:22
Summary: Add real option processing and timing data collection/reporting.
Affected #: 1 file
diff --git a/test/parallel/structured3.cpp b/test/parallel/structured3.cpp
index f06b382..17ad177 100644
--- a/test/parallel/structured3.cpp
+++ b/test/parallel/structured3.cpp
@@ -2,6 +2,8 @@
#include "moab/ParallelComm.hpp"
#include "moab/ScdInterface.hpp"
#include "moab/HomXform.hpp"
+#include "moab/ProgOptions.hpp"
+#include "MBTagConventions.hpp"
#include "TestUtil.hpp"
#include <string>
#include <iomanip>
@@ -11,7 +13,7 @@
using namespace moab;
// Number of cells in each direction:
-int NC = 4;
+int NC;
const int ITERS = 50;
void create_parallel_mesh();
@@ -20,7 +22,10 @@ int main(int argc, char *argv[])
MPI_Init(&argc, &argv);
- if (argc > 1) NC = atoi(argv[1]);
+ ProgOptions po;
+ po.addOpt<int>( "int,i", "Number of intervals on a side" );
+ po.parseCommandLine( argc, argv );
+ if(!po.getOpt( "int", &NC )) NC = 4;
int err = RUN_TEST(create_parallel_mesh);
@@ -49,13 +54,28 @@ void create_parallel_mesh()
par_data.partMethod = ScdParData::SQIJK;
+ // timing data
+ double times[5]; // tstart, tvert, tnonvert, tghost, titer;
+ times[0] = MPI_Wtime();
rval = scdi->construct_box(HomCoord(), HomCoord(), NULL, 0, // no vertex positions
new_box, NULL, // not locally periodic
- &par_data, true, true); // assign global ids & resolve shared verts
+ &par_data, true, false); // assign global ids & resolve shared verts
CHECK_ERR(rval);
+ // get global id tag
+ Tag tag;
+ rval = mbint.tag_get_handle(GLOBAL_ID_TAG_NAME, tag);
+ CHECK_ERR(rval);
+ // resolve shared verts
+ rval = pc.resolve_shared_ents(new_box->box_set(), -1, 0, &tag);
+ CHECK_ERR(rval);
+ times[1] = MPI_Wtime();
rval = pc.exchange_ghost_cells(-1, -1, 0, 0, true, true);
CHECK_ERR(rval);
+ times[2] = MPI_Wtime();
// pc.list_entities(0,-1);
@@ -66,11 +86,11 @@ void create_parallel_mesh()
std::cerr << "Error: proc " << pc.rank() << ": " << err << std::endl;
CHECK_ERR(rval);
+ times[3] = MPI_Wtime();
// Create a tag, used in exchange_tags
- Tag tag;
int def_val = 1.0;
rval = mbint.tag_get_handle("test_tag", 1, MB_TYPE_DOUBLE, tag, MB_TAG_DENSE|MB_TAG_EXCL, &def_val);
CHECK_ERR(rval);
@@ -83,4 +103,17 @@ void create_parallel_mesh()
CHECK_ERR(rval);
if (!pc.rank()) std::cout << std::endl;
+ times[4] = MPI_Wtime();
+ for (int i = 4; i >= 1; i--) times[i] -= times[i-1];
+ double tottimes[5];
+ MPI_Reduce(times+1, tottimes+1, 4, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD);
+ if (!pc.rank())
+ std::cout << "Times: " << std::endl
+ << "Create: " << times[1] << std::endl
+ << "Resolve verts: " << times[2] << std::endl
+ << "Resolve non-verts: " << times[3] << std::endl
+ << "Exchange ghosts: " << times[4] << std::endl;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
