[MOAB-dev] commit/MOAB: danwu: Some updates for Table 5 in metadata.h.
commits-noreply at bitbucket.org
Tue Sep 3 09:56:38 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/33724d0a6f27/
Changeset: 33724d0a6f27
Branch: master
User: danwu
Date: 2013-09-03 16:53:16
Summary: Some updates for Table 5 in metadata.h.
1) For duplicated tag names __DIM_NAMES, the second one should be __VAR_NAMES
2) Added a new row for __DIM_LENS
3) Added a new row for __<dim_name>_GLOBAL_MIN_MAX
4) Modified data type field of <dim_name>, should be *var instead of *va
5) Modified the purpose field of __<var_name>_DIMS
Affected #: 1 file
diff --git a/doc/MetaData/metadata.h b/doc/MetaData/metadata.h
index 6d03665..d67ca27 100644
--- a/doc/MetaData/metadata.h
+++ b/doc/MetaData/metadata.h
@@ -649,27 +649,33 @@ centered variables correctly.
</tr><tr><td>__DIM_NAMES </td>
-<td>C*var </td>
-<td>S </td>
+<td>C*var</td>
+<td>S</td><td>The dimension names, concatenated into a
character string, with '\0' terminating each name.
- </td>
+</td>
+</tr>
+<tr>
+<td>__DIM_LENS </td>
+<td>I*var</td>
+<td>S</td>
+<td>A vector of integers, storing the length of
+each dimension.
+</td></tr><tr>
-<td>__DIM_NAMES
+<td>__VAR_NAMES
</td><td>C*var</td><td>S</td>
-<td>The variable names, concatenated into a character
-string, with '\0' terminating each name.
+<td>The variable names, concatenated into a
+character string, with '\0' terminating each name.
</td></tr><tr><td><dim_name></td>
-<td>(I or
-D)*va
-</td>
+<td>(I or D)*var</td><td>S</td><td>For each dimension, the values for the dimension.
The data type for this tag corresponds to that in the
@@ -678,7 +684,7 @@ values stored for the dimension in the netcdf file.</td></tr><tr><td>__<dim_name>_LOC_MIN_MAX</td>
-<td>2*(I or D)</td>
+<td>(I or D)*2</td><td>S</td><td>The indices (0-based) of the local min and max
values of dimension stored locally. For spatial
@@ -692,8 +698,8 @@ __<dim_name>_LOC_MIN_MAX can be used for a given
dimension.</td></tr><tr>
-<td >__<dim_name>_LOC_VAL </td>
-<td>(I or D)*var </td>
+<td>__<dim_name>_LOC_VAL </td>
+<td>(I or D)*var</td><td>S</td><td>The indices (0-based) of the dimension stored
locally. This tag only makes sense for dimensions
@@ -703,16 +709,22 @@ __<dim_name>_LOC_MIN_MAX can be used for a given
+<td>__<dim_name>_GLOBAL_MIN_MAX</td>
+<td>S</td>
+<td>The indices (0-based) of the global min and max
+values of dimension.</td>
+</tr>
+<tr><td>__<var_name>_DIMS
</td><td>H*n
</td><td>S</td>
-<td>For each variable, the tag handles for the
-dimensions defining this variable, in netcdf
-ordering (last dimension varying fastest). The
-length of this tag, n, is # dimensions for the
-variable * sizeof(TagHandle).
+<td>For each variable, this tag stores the tag
+handles for the n dimensions defining this variable,
+in netcdf ordering (last dimension varying fastest).
+The size of this tag is n * sizeof(TagHandle).
</td></tr><tr>
@@ -729,7 +741,7 @@ Timestep index is 0-based.
<tr><td>__GLOBAL_ATTRIBS
</td>
-<td>C*Var
+<td>C*var
</td><td>S</td><td>The global attributes, concatenated into a character
@@ -741,7 +753,7 @@ string, with ‘\0’ terminating each attribute name, ‘;’
<tr><td>__GLOBAL_ATTRIBS_LEN
</td>
-<td>I*Var
+<td>I*var
</td><td>S</td><td>A vector of integers, marking the end position of
@@ -751,7 +763,7 @@ each attribute (name/data type/value) in __GLOBAL_ATTRIBS tag.
<tr><td>__<var_name>_ATTRIBS
</td>
-<td>C*Var
+<td>C*var
</td><td>S</td><td>The variable attributes, concatenated into a
@@ -763,7 +775,7 @@ character string, with ‘\0’ terminating each attribute
<tr><td>__<var_name>_ATTRIBS_LEN
</td>
-<td>I*Var
+<td>I*var
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
