[MOAB-dev] commit/MOAB: danwu: 1) Renamed dimVals to dimLens in ReadNC. Suppose a netCDF dimension has a length N, using dimVals could be confusing with the N values stored for that dimension. Similarly, renamed __DIM_VALUES tag to __DIM_LENS.
commits-noreply at bitbucket.org
Fri Aug 30 16:03:19 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/a1e8fba86da1/
Changeset: a1e8fba86da1
Branch: master
User: danwu
Date: 2013-08-30 22:53:12
Summary: 1) Renamed dimVals to dimLens in ReadNC. Suppose a netCDF dimension has a length N, using dimVals could be confusing with the N values stored for that dimension. Similarly, renamed __DIM_VALUES tag to __DIM_LENS.
2) In init_mesh_vals() of NCHelperEuler and NCHelperFV, created __<dim_name>_LOC_VALS tags for spatial dimensions like lon or lat, as specified in Table 5 of metadata_info document.
Affected #: 7 files
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index b013472..c3b6b8b 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -57,7 +57,7 @@ NCHelper* NCHelper::get_nc_helper(ReadNC* readNC, int fileId, const FileOptions&
ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums) {
Interface*& mbImpl = _readNC->mbImpl;
std::vector<std::string>& dimNames = _readNC->dimNames;
- std::vector<int>& dimVals = _readNC->dimVals;
+ std::vector<int>& dimLens = _readNC->dimLens;
std::map<std::string, ReadNC::AttData>& globalAtts = _readNC->globalAtts;
std::map<std::string, ReadNC::VarData>& varInfo = _readNC->varInfo;
DebugOutput& dbgOut = _readNC->dbgOut;
@@ -94,7 +94,7 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
tag_name = "__DIM_NAMES";
std::string dimnames;
unsigned int dimNamesSz = dimNames.size();
- for (unsigned int i = 0; i != dimNamesSz; ++i) {
+ for (unsigned int i = 0; i != dimNamesSz; i++) {
dimnames.append(dimNames[i]);
dimnames.push_back('\0');
@@ -107,16 +107,15 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
if (MB_SUCCESS == rval)
dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
- // <__DIM_VALUES>
- Tag dimValsTag = 0;
- tag_name = "__DIM_VALUES";
- int dimValsSz = (int)dimVals.size();
- rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_INTEGER, dimValsTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
- ERRORR(rval, "Trouble creating __DIM_VALUES tag.");
- ptr = &(dimVals[0]);
- rval = mbImpl->tag_set_by_ptr(dimValsTag, &_fileSet, 1, &ptr, &dimValsSz);
- ERRORR(rval, "Trouble setting data for __DIM_VALUES tag.");
+ // <__DIM_LENS>
+ Tag dimLensTag = 0;
+ tag_name = "__DIM_LENS";
+ int dimLensSz = dimLens.size();
+ rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_INTEGER, dimLensTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
+ ERRORR(rval, "Trouble creating __DIM_LENS tag.");
+ ptr = &(dimLens[0]);
+ rval = mbImpl->tag_set_by_ptr(dimLensTag, &_fileSet, 1, &ptr, &dimLensSz);
+ ERRORR(rval, "Trouble setting data for __DIM_LENS tag.");
@@ -138,8 +137,8 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
- // __<dim_name>_LOC_MINMAX
+ // __<dim_name>_LOC_MINMAX (for time)
if (dimNames[i] == "time") {
std::stringstream ss_tag_name;
ss_tag_name << "__" << dimNames[i] << "_LOC_MINMAX";
@@ -157,28 +156,28 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
- // __<dim_name>_LOC_VALS
- if (dimNames[i] != "time")
- continue;
- std::vector<int> val;
- if (!tstep_nums.empty())
- val = tstep_nums;
- else {
- val.resize(tVals.size());
- for (unsigned int j = 0; j != tVals.size(); ++j)
- val[j] = j;
+ // __<dim_name>_LOC_VALS (for time)
+ if (dimNames[i] == "time") {
+ std::vector<int> val;
+ if (!tstep_nums.empty())
+ val = tstep_nums;
+ else {
+ val.resize(tVals.size());
+ for (unsigned int j = 0; j != tVals.size(); j++)
+ val[j] = j;
+ Tag tagh = 0;
+ std::stringstream ss_tag_name;
+ ss_tag_name << "__" << dimNames[i] << "_LOC_VALS";
+ tag_name = ss_tag_name.str();
+ rval = mbImpl->tag_get_handle(tag_name.c_str(), val.size(), MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT);
+ ERRORR(rval, "Trouble creating __<dim_name>_LOC_VALS tag.");
+ rval = mbImpl->tag_set_data(tagh, &_fileSet, 1, &val[0]);
+ ERRORR(rval, "Trouble setting data for __<dim_name>_LOC_VALS tag.");
+ if (MB_SUCCESS == rval)
+ dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
- Tag tagh = 0;
- std::stringstream ss_tag_name;
- ss_tag_name << "__" << dimNames[i] << "_LOC_VALS";
- tag_name = ss_tag_name.str();
- rval = mbImpl->tag_get_handle(tag_name.c_str(), val.size(), MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT);
- ERRORR(rval, "Trouble creating __<dim_name>_LOC_VALS tag.");
- rval = mbImpl->tag_set_data(tagh, &_fileSet, 1, &val[0]);
- ERRORR(rval, "Trouble setting data for __<dim_name>_LOC_VALS tag.");
- if (MB_SUCCESS == rval)
- dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
// __<var_name>_DIMS
@@ -191,7 +190,7 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
if (varDimSz == 0)
continue;
varInfo[mapIter->first].varTags.resize(varDimSz, 0);
- for (unsigned int i = 0; i != varDimSz; ++i) {
+ for (unsigned int i = 0; i != varDimSz; i++) {
Tag tmptag = 0;
std::string tmptagname = dimNames[varInfo[mapIter->first].varDims[i]];
mbImpl->tag_get_handle(tmptagname.c_str(), 0, MB_TYPE_OPAQUE, tmptag, MB_TAG_ANY);
@@ -687,7 +686,7 @@ void NCHelper::init_dims_with_no_cvars_info()
ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
ErrorCode rval = MB_SUCCESS;
@@ -706,7 +705,7 @@ ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>&
// Assume point-based values for now?
- if (-1 == tDim || dimVals[tDim] <= (int) t)
+ if (-1 == tDim || dimLens[tDim] <= (int) t)
ERRORR(MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number.");
// Set up the dimensions and counts
@@ -736,7 +735,7 @@ ErrorCode NCHelper::read_variable_to_set_allocate(std::vector<ReadNC::VarData>&
if (tDim != vdatas[i].varDims[idx]){
// Push other variable dimensions, except time, which was already pushed
vdatas[i].readStarts[t].push_back(0);
- vdatas[i].readCounts[t].push_back(dimVals[vdatas[i].varDims[idx]]);
+ vdatas[i].readCounts[t].push_back(dimLens[vdatas[i].varDims[idx]]);
@@ -1011,7 +1010,7 @@ ErrorCode ScdNCHelper::read_scd_variable_setup(std::vector<std::string>& var_nam
ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -1061,7 +1060,7 @@ ErrorCode ScdNCHelper::read_scd_variable_to_nonset_allocate(std::vector<ReadNC::
- if (-1 == tDim || dimVals[tDim] <= (int) t) {
+ if (-1 == tDim || dimLens[tDim] <= (int) t) {
else if (vdatas[i].varDims[0] != tDim) {
diff --git a/src/io/NCHelperEuler.cpp b/src/io/NCHelperEuler.cpp
index 7c80dc7..e5b3f08 100644
--- a/src/io/NCHelperEuler.cpp
+++ b/src/io/NCHelperEuler.cpp
@@ -53,7 +53,7 @@ ErrorCode NCHelperEuler::init_mesh_vals()
bool& isParallel = _readNC->isParallel;
@@ -71,7 +71,7 @@ ErrorCode NCHelperEuler::init_mesh_vals()
iCDim = idx;
gCDims[0] = 0;
- gCDims[3] = dimVals[idx] - 1;
+ gCDims[3] = dimLens[idx] - 1;
// Check i periodicity and set globallyPeriodic[0]
std::vector<double> til_vals(2);
@@ -92,7 +92,7 @@ ErrorCode NCHelperEuler::init_mesh_vals()
jCDim = idx;
gCDims[1] = 0;
- gCDims[4] = dimVals[idx] - 1;
+ gCDims[4] = dimLens[idx] - 1;
// For Eul models, will always be non-periodic in j
gDims[1] = 0;
@@ -111,7 +111,7 @@ ErrorCode NCHelperEuler::init_mesh_vals()
ERRORR(MB_FAILURE, "Couldn't find 'time' or 't' dimension.");
tDim = idx;
- nTimeSteps = dimVals[idx];
+ nTimeSteps = dimLens[idx];
// Look for level dimension
if ((vit = std::find(dimNames.begin(), dimNames.end(), "lev")) != dimNames.end())
@@ -122,7 +122,7 @@ ErrorCode NCHelperEuler::init_mesh_vals()
ERRORR(MB_FAILURE, "Couldn't find 'lev' or 'ilev' dimension.");
levDim = idx;
- nLevels = dimVals[idx];
+ nLevels = dimLens[idx];
// Parse options to get subset
int rank = 0, procs = 1;
@@ -328,35 +328,49 @@ ErrorCode NCHelperEuler::init_mesh_vals()
vd.entLoc = ReadNC::ENTLOCFACE;
- // <coordinate_dim_name>
- std::vector<std::string> ijdimNames(4);
- ijdimNames[0] = "__slon";
- ijdimNames[1] = "__slat";
- ijdimNames[2] = "__lon";
- ijdimNames[3] = "__lat";
+ std::vector<std::string> ijdimNames(2);
+ ijdimNames[0] = "__lon";
+ ijdimNames[1] = "__lat";
std::string tag_name;
- int val_len = 0;
+ Tag tagh;
+ // __<dim_name>_LOC_MINMAX (for lon and lat)
for (unsigned int i = 0; i != ijdimNames.size(); i++) {
- tag_name = ijdimNames[i];
- void* val = NULL;
- if (tag_name == "__slon") {
- val = &ilVals[0];
- val_len = ilVals.size();
+ std::vector<int> val(2, 0);
+ if (ijdimNames[i] == "__lon") {
+ val[0] = lCDims[0];
+ val[1] = lCDims[3];
- else if (tag_name == "__slat") {
- val = &jlVals[0];
- val_len = jlVals.size();
+ else if (ijdimNames[i] == "__lat") {
+ val[0] = lCDims[1];
+ val[1] = lCDims[4];
- else if (tag_name == "__lon") {
+ ss_tag_name.clear();
+ ss_tag_name << ijdimNames[i] << "_LOC_MINMAX";
+ rval = mbImpl->tag_get_handle(tag_name.c_str(), 2, MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT);
+ ERRORR(rval, "Trouble creating __<dim_name>_LOC_MINMAX tag.");
+ ERRORR(rval, "Trouble setting data for __<dim_name>_LOC_MINMAX tag.");
+ // __<dim_name>_LOC_VALS (for lon and lat)
+ for (unsigned int i = 0; i != ijdimNames.size(); i++) {
+ void* val = NULL;
+ int val_len = 0;
val = &ilCVals[0];
val_len = ilCVals.size();
- else if (tag_name == "__lat") {
val = &jlCVals[0];
val_len = jlCVals.size();
- Tag tagh = 0;
DataType data_type;
// Assume all has same data type as lon
@@ -378,61 +392,21 @@ ErrorCode NCHelperEuler::init_mesh_vals()
ERRORR(MB_FAILURE, "Unrecognized data type");
break;
+ ss_tag_name << ijdimNames[i] << "_LOC_VALS";
rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, data_type, tagh, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
- ERRORR(rval, "Trouble creating <coordinate_dim_name> tag.");
rval = mbImpl->tag_set_by_ptr(tagh, &_fileSet, 1, &val, &val_len);
- ERRORR(rval, "Trouble setting data for <coordinate_dim_name> tag.");
- // __<coordinate_dim_name>_LOC_MINMAX
- for (unsigned int i = 0; i != ijdimNames.size(); i++) {
- ss_tag_name << ijdimNames[i] << "_LOC_MINMAX";
- Tag tagh = 0;
- std::vector<int> val(2, 0);
- if (ijdimNames[i] == "__slon") {
- val[0] = lDims[0];
- val[1] = lDims[3];
- else if (ijdimNames[i] == "__slat") {
- val[0] = lDims[1];
- val[1] = lDims[4];
- else if (ijdimNames[i] == "__lon") {
- val[0] = lCDims[0];
- val[1] = lCDims[3];
- else if (ijdimNames[i] == "__lat") {
- val[0] = lCDims[1];
- val[1] = lCDims[4];
- rval = mbImpl->tag_get_handle(tag_name.c_str(), 2, MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT);
- ERRORR(rval, "Trouble creating __<coordinate_dim_name>_LOC_MINMAX tag.");
- ERRORR(rval, "Trouble setting data for __<coordinate_dim_name>_LOC_MINMAX tag.");
- // __<coordinate_dim_name>_GLOBAL_MINMAX
+ // __<dim_name>_GLOBAL_MINMAX (for lon and lat)
- ss_tag_name << ijdimNames[i] << "_GLOBAL_MINMAX";
- Tag tagh = 0;
- val[0] = gDims[0];
- val[1] = gDims[3];
- val[0] = gDims[1];
- val[1] = gDims[4];
val[0] = gCDims[0];
val[1] = gCDims[3];
@@ -440,10 +414,13 @@ ErrorCode NCHelperEuler::init_mesh_vals()
val[0] = gCDims[1];
val[1] = gCDims[4];
+ ss_tag_name << ijdimNames[i] << "_GLOBAL_MINMAX";
- ERRORR(rval, "Trouble creating __<coordinate_dim_name>_GLOBAL_MINMAX tag.");
+ ERRORR(rval, "Trouble creating __<dim_name>_GLOBAL_MINMAX tag.");
- ERRORR(rval, "Trouble setting data for __<coordinate_dim_name>_GLOBAL_MINMAX tag.");
+ ERRORR(rval, "Trouble setting data for __<dim_name>_GLOBAL_MINMAX tag.");
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index 8b21e36..dd555ff 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -46,7 +46,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
@@ -64,7 +64,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
iDim = idx;
gDims[0] = 0;
- gDims[3] = dimVals[idx] - 1;
+ gDims[3] = dimLens[idx] - 1;
// Then j
if ((vit = std::find(dimNames.begin(), dimNames.end(), "slat")) != dimNames.end())
@@ -74,7 +74,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
jDim = idx;
gDims[1] = 0;
- gDims[4] = dimVals[idx] - 1 + 2; // Add 2 for the pole points
+ gDims[4] = dimLens[idx] - 1 + 2; // Add 2 for the pole points
// Look for names of center i/j dimensions
// First i
@@ -85,7 +85,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
iCDim = idx;
gCDims[0] = 0;
@@ -106,7 +106,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
jCDim = idx;
gCDims[1] = 0;
// For FV models, will always be non-periodic in j
assert(gDims[4] == gCDims[4] + 1);
@@ -124,7 +124,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
tDim = idx;
// Get number of levels
@@ -135,7 +135,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
levDim = idx;
@@ -330,35 +330,67 @@ ErrorCode NCHelperFV::init_mesh_vals()
vd.entLoc = ReadNC::ENTLOCEWEDGE;
- int val_len = 0;
+ Tag tagh;
+ // __<dim_name>_LOC_MINMAX (for slon, slat, lon and lat)
+ if (ijdimNames[i] == "__slon") {
+ val[0] = lDims[0];
+ val[1] = lDims[3];
+ else if (ijdimNames[i] == "__slat") {
+ val[0] = lDims[1];
+ val[1] = lDims[4];
+ else if (ijdimNames[i] == "__lon") {
+ // __<dim_name>_LOC_VALS (for slon, slat, lon and lat)
void* val = NULL;
+ int val_len = 0;
val = &ilVals[0];
val = &jlVals[0];
val = &ilCVals[0];
val = &jlCVals[0];
- Tag tagh = 0;
DataType data_type;
@@ -380,51 +412,19 @@ ErrorCode NCHelperFV::init_mesh_vals()
break;
+ // __<dim_name>_GLOBAL_MINMAX (for slon, slat, lon and lat)
- Tag tagh = 0;
- Tag tagh = 0;
val[0] = gDims[0];
@@ -442,10 +442,13 @@ ErrorCode NCHelperFV::init_mesh_vals()
val[0] = gCDims[1];
val[1] = gCDims[4];
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index 98aa9c6..f883bd7 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -59,7 +59,7 @@ bool NCHelperHOMME::can_read_file(ReadNC* readNC, int fileId)
ErrorCode NCHelperHOMME::init_mesh_vals()
ErrorCode rval;
@@ -75,7 +75,7 @@ ErrorCode NCHelperHOMME::init_mesh_vals()
tDim = idx;
// Get number of vertices (labeled as number of columns)
if ((vit = std::find(dimNames.begin(), dimNames.end(), "ncol")) != dimNames.end())
@@ -84,7 +84,7 @@ ErrorCode NCHelperHOMME::init_mesh_vals()
ERRORR(MB_FAILURE, "Couldn't find 'ncol' dimension.");
vDim = idx;
- nVertices = dimVals[idx];
+ nVertices = dimLens[idx];
// Set number of cells
nCells = nVertices - 2;
@@ -98,7 +98,7 @@ ErrorCode NCHelperHOMME::init_mesh_vals()
levDim = idx;
// Store lon values in xVertVals
std::map<std::string, ReadNC::VarData>::iterator vmit;
@@ -569,7 +569,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_setup(std::vector<std::string>& var_n
ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -595,7 +595,7 @@ ErrorCode NCHelperHOMME::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index c78956c..45d1b00 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -37,7 +37,7 @@ bool NCHelperMPAS::can_read_file(ReadNC* readNC)
ErrorCode NCHelperMPAS::init_mesh_vals()
ErrorCode rval;
@@ -47,7 +47,7 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
// Get max edges per cell
if ((vit = std::find(dimNames.begin(), dimNames.end(), "maxEdges")) != dimNames.end()) {
idx = vit - dimNames.begin();
- maxCellEdges = dimVals[idx];
+ maxCellEdges = dimLens[idx];
if (maxCellEdges > MAX_EDGES_PER_CELL) {
ERRORR(MB_FAILURE, "maxEdges read from MPAS file has exceeded the limit");
@@ -62,7 +62,7 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
ERRORR(MB_FAILURE, "Couldn't find 'Time' or 'time' dimension.");
tDim = idx;
// Get number of cells
if ((vit = std::find(dimNames.begin(), dimNames.end(), "nCells")) != dimNames.end())
@@ -71,7 +71,7 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
ERRORR(MB_FAILURE, "Couldn't find 'nCells' dimension.");
cDim = idx;
- nCells = dimVals[idx];
+ nCells = dimLens[idx];
// Get number of edges
if ((vit = std::find(dimNames.begin(), dimNames.end(), "nEdges")) != dimNames.end())
@@ -80,7 +80,7 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
ERRORR(MB_FAILURE, "Couldn't find 'nEdges' dimension.");
eDim = idx;
- nEdges = dimVals[idx];
+ nEdges = dimLens[idx];
vDim = -1;
@@ -90,7 +90,7 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
ERRORR(MB_FAILURE, "Couldn't find 'nVertices' dimension.");
vDim = idx;
if ((vit = std::find(dimNames.begin(), dimNames.end(), "nVertLevels")) != dimNames.end())
@@ -99,7 +99,7 @@ ErrorCode NCHelperMPAS::init_mesh_vals()
ERRORR(MB_FAILURE, "Couldn't find 'nVertLevels' dimension.");
levDim = idx;
// Store xVertex values in xVertVals
@@ -697,7 +697,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_setup(std::vector<std::string>& var_na
ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -747,7 +747,7 @@ ErrorCode NCHelperMPAS::read_ucd_variable_to_nonset_allocate(std::vector<ReadNC:
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index eee8a9e..50225df 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -294,9 +294,9 @@ ErrorCode ReadNC::read_header()
dbgOut.tprintf(1, "Read %u attributes\n", (unsigned int) globalAtts.size());
// Read in dimensions into dimVals
- result = get_dimensions(fileId, dimNames, dimVals);
+ result = get_dimensions(fileId, dimNames, dimLens);
ERRORR(result, "Getting dimensions.");
- dbgOut.tprintf(1, "Read %u dimensions\n", (unsigned int) dimVals.size());
+ dbgOut.tprintf(1, "Read %u dimensions\n", (unsigned int) dimNames.size());
// Read in variables into varInfo
result = get_variables();
@@ -328,7 +328,7 @@ ErrorCode ReadNC::get_attributes(int var_id, int num_atts, std::map<std::string,
return MB_SUCCESS;
-ErrorCode ReadNC::get_dimensions(int file_id, std::vector<std::string>& dim_names, std::vector<int>& dim_vals)
+ErrorCode ReadNC::get_dimensions(int file_id, std::vector<std::string>& dim_names, std::vector<int>& dim_lens)
// Get the number of dimensions
int num_dims;
@@ -341,18 +341,18 @@ ErrorCode ReadNC::get_dimensions(int file_id, std::vector<std::string>& dim_name
char dim_name[NC_MAX_NAME + 1];
- NCDF_SIZE dum_len;
+ NCDF_SIZE dim_len;
dim_names.resize(num_dims);
- dim_vals.resize(num_dims);
+ dim_lens.resize(num_dims);
for (int i = 0; i < num_dims; i++) {
- success = NCFUNC(inq_dim)(file_id, i, dim_name, &dum_len);
+ success = NCFUNC(inq_dim)(file_id, i, dim_name, &dim_len);
ERRORS(success, "Trouble getting dimension info.");
- dim_vals[i] = dum_len;
dim_names[i] = std::string(dim_name);
+ dim_lens[i] = dim_len;
- dbgOut.tprintf(2, "Dimension %s, length=%u\n", dim_name, (unsigned int) dum_len);
+ dbgOut.tprintf(2, "Dimension %s, length=%u\n", dim_name, (unsigned int) dim_len);
return MB_SUCCESS;
@@ -367,7 +367,7 @@ ErrorCode ReadNC::get_variables()
int ntimes = 0;
if (vit != dimNames.end())
- ntimes = dimVals[vit - dimNames.begin()];
+ ntimes = dimLens[vit - dimNames.begin()];
if (!ntimes)
ntimes = 1;
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index 41c866a..e8b1845 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -138,7 +138,7 @@ private:
const char *prefix = "");
//! Get all dimensions in the file
- ErrorCode get_dimensions(int file_id, std::vector<std::string>& dim_names, std::vector<int>& dim_vals);
+ ErrorCode get_dimensions(int file_id, std::vector<std::string>& dim_names, std::vector<int>& dim_lens);
//! Get the variable names and other info defined for this file
ErrorCode get_variables();
@@ -159,15 +159,15 @@ private:
//! File numbers assigned by netcdf
int fileId;
- //! Dimensions
+ //! Dimension names
std::vector<std::string> dimNames;
+ //! Dimension lengths
+ std::vector<int> dimLens;
//! These should be taken out when we fix the dummy var info things
std::set<std::string> dummyVarNames;
- //! Dimension values
- std::vector<int> dimVals;
//! Global attribs
std::map<std::string, AttData> globalAtts;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
